1. Add build option to uboot for different media type
2. fix the spi-nor link error
Signed-off-by:Jason Liu <r64343@freescale.com>
The top build system sets up HOSTCFLAGS a bit and exports it, but other
places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the
values stay in sync.
Shove a lot of the HOSTCC and related #ifdef checking crap into the new
compiler.h header so that we can keep all other headers nice and clean.
Also introduce custom uswap functions so we don't have to rely on the non
standard implementations that a host may (or may not in the case of OS X)
provide. This allows mkimage to finally build cleanly on an OS X system.
When the envcrc building was made conditional, it missed a bunch of env
storage types, so add all currently supported types.
This script is similar to the netconsole script, but instead works with
the JTAG console device driver that exists on Blackfin parts.
The --binary option to envcrc can be used to export the embedded env as a
binary blob so that it can be manipulated/examined/whatever externally.
This patch adds, under tools folder, a new command called imls. Its
goal is the same of UBoot's imls but it can be used as Linux shell
command. It reads from raw mtd partition and prints the list of the
stored images.
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Add basic error handling to fread() function calls. This prevents
compililation warnings such as:
bmp_logo.c: In function ‘main’:
bmp_logo.c:71: warning: ignoring return value of ‘fread’, declared with
attribute warn_unused_result
This prevents the compilation warning:
ncb.c: In function 'main':
ncb.c:32: warning: ignoring return value of ‘write’, declared with
__asm__ follows gcc's documented syntax and is generally more common
than __asm. This change is only asthetic and should not affect
functionality.
The PM9263 board is based on the AT91SAM9263-EK board.
Here is the page on Ronetix website:
http://www.ronetix.at/starter_kit_9263.html
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
In addition to the changes for CONFIG_ENV_IS_IN_FLASH as done in
commit afcbce07, we also need to do the same for
CONFIG_ENV_IS_IN_EEPROM and CONFIG_ENV_IS_IN_NVRAM.
Use the new "git <subcmd>" syntax instead of the deprecated
"git-<subcmd>".
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Include <netinet/in.h> instead of <linux/in.h> to get htons()
prototpye.
Since commit a706bfc7 common/env_embedded.o and tools/envcrc were
only built when CONFIG_ENV_IS_EMBEDDED was set, but this breaks
building for many boards.
We always have to build these files when CONFIG_ENV_IS_IN_FLASH is
set.
Add support for compiling the host tools in the tools directory using
the MinGW toolchain. This produces executables which can be used on
standard Windows computers without requiring cygwin.
One must specify the MinGW compiler and strip utilities as if they
were the host toolchain in order to build win32 executables, eg:
make HOSTCC=i586-mingw32msvc-gcc HOSTSTRIP=i586-mingw32msvc-strip tools
Create a few generic build rules to replace the current method which has
1 build target for each file
Files in the SRCS variable have their dependencies automatically
generated so remove duplicate explicit dependencies
Add the libfdt files to the SRCS variable so that they have their
dependencies automatically generated
This change makes the process of symlinking libfdt_internal.h
unnecessary
crc32.c uses the zlib.h header in include/u-boot/zlib.h. The symlink
was previously necessary to give U-Boot's version of zlib.h precedence
over the host computer's version of zlib.h.
This change makes the process of symlinking mkimage.h and fdt_host.h
unnecessary
Also conditionally add ncb.o to OBJ_FILES list
Split variable declarations into multiple lines and use the standard
VAR-y convention. Also move object and binary variable declarations to
after config.mk has been included to allow for these lists to utilize
the CONFIG_XXX variables.
These changes lay the groundwork for conditional compilation of files
in the tools directory.
The values of HOSTARCH and HOSTOS which are exported from the top-level
Makefile should be used
Replace random()/srandom() use with rand()/srand() to support
compilation with the mingw toolchain. The rand()/srand() functions are
generally more common and are functionally equivalent to the original
random()/srandom() calls.
Some images can be quite large, so add an option to compress the
image data with gzip in the U-Boot image. Then at runtime, the
board can decompress it with the normal zlib functions.
The recvfrom() function takes a socklen_t, not an int.
Reported-by: Martin Michlmayr <tbm@cyrius.com>
While the doc/README.NetConsole does have a snippet for people to
create their own netcat script, it's a lot easier to make a simple
dedicated script and tell people to use it.
Also spruce it up a bit to make it user friendly.
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC).
Six eth interface is chosen because the platform I am using combines
UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth.
Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
Add support for environment in NAND with automatic NOR / NAND recognition,
including unaligned environment, bad-block skipping, redundant environment
copy.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
