path: root/tools
2018-03-21tools/env: allow equal sign as key value separationStefan Agner
Treat the first equal sign as a key/value separation too. This makes the script files compatible with mkenvimage input file format. It won't support variables with equal signs anymore, but this seems not really like a loss. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-11-22tools: env: allow to print U-Boot versionStefan Agner
The fw_env utility family has a default environment compiled in which ties it quite strongly to the U-Boot source/config it has been built with. Allow to display the U-Boot version it has been built with using the -v/--version argument. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> (cherry picked from commit 84d46e7e8948780d7ca20c24dfc7b653b900f728)
2017-01-18imx: move imximage header to common locationStefan Agner
Move the imximage.h header file to a common location so we can make use of it from U-Boot too. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11tools/env: fix environment alignment tests for block devicesMax Krummenacher
commit 183923d3e412500bdc597d1745e2fb6f7f679ec7 enforces that the environment must start at an erase block boundary. For block devices the sample fw_env.config does not mandate a erase block size for block devices. A missing setting defaults to the full env size. Depending on the environment location the alignment check now errors out for perfectly legal settings. Fix this by defaulting to the standard blocksize of 0x200 for environments stored in a block device. That keeps the fw_env.config files for block devices working even with that new check. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-11-13tools: fix mksunxiboot build for tools-all targetAndre Przywara
Commit fed329aebe3a ("tools: add mksunxiboot to tools-all target") added mksunxiboot to the tools-all target, but used the CONFIG_SUNXI symbol to enable its build. Now commit aec9a0f19f64 ("sunxi: Rename CONFIG_SUNXI to CONFIG_ARCH_SUNXI"), merged before that, renamed that symbol, so that the first patch basically gets ineffective. Adjust the symbol name in tools/Makefile to make it build again. Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2016-11-06mkimage: Allow including a ramdisk in FIT auto modeTomeu Vizoso
Adds -i option that allows specifying a ramdisk file to be added to the FIT image when we are using the automatic FIT mode (no ITS file). This makes adding Depthcharge support to LAVA much more convenient, as no additional configuration files need to be kept around in the machine that dispatches jobs to the boards. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Cc: Simon Glass <sjg@chromium.org> Cc: Matt Hart <matthew.hart@linaro.org> Cc: Neil Williams <codehelp@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-06buildman: Fix building based on 'options' fieldTom Rini
The README for buildman says that we can use any field in boards.cfg to decide what to build. However, we were not saving the options field correctly. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-11-05tools: imximage: check return value when open the plugin filePeng Fan
Check return value when open the plugin file. Coverity report: ** CID 153926: Error handling issues (NEGATIVE_RETURNS) /tools/imximage.c: 542 in copy_plugin_code() ifd = open(plugin_file, O_RDONLY|O_BINARY); >>> CID 153926: Error handling issues (NEGATIVE_RETURNS) >>> "ifd" is passed to a parameter that cannot be negative. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@konsulko.com> Reported-by: Coverity (CID: 153926) Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-31mkimage: Fix missing free() in show_valid_options()Simon Glass
The allocated memory should be freed. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Coverity (CID: 150963) Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-31Fix spelling of "occur".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Angelo Dureghello <angelo@sysam.it> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-30tools: add mksunxiboot to tools-all targetStefan Brüns
mksunxiboot is useful outside of u-boot, it is e.g. used by sunxi-tools. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-30sunxi: Rename CONFIG_SUNXI to CONFIG_ARCH_SUNXIJagan Teki
CONFIG_SUNXI -> CONFIG_ARCH_SUNXI and removed CONFIG_SUNIX from config_whitelist.txt Cc: Simon Glass <sjg@chromium.org> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: common/Kconfig configs/dms-ba16_defconfig
2016-10-24tools: moveconfig: support wildcards in --defconfigs fileMasahiro Yamada
Supporting shell-style wildcards for the --defconfigs option will be useful to run the moveconfig tool against a specific platform. For example, "uniphier*" in the file passed by --defconfigs option will be expanded to defconfig files that start with "uniphier". This is easier than listing out all defconfig files you are interested in. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2016-10-24tools: imximage: add plugin supportPeng Fan
Add plugin support for imximage. Define CONFIG_USE_IMXIMG_PLUGIN in defconfig to enable using plugin. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Eric Nelson <eric@nelint.com> Cc: Ye Li <ye.li@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-14pbl: use "wait" command instead of "flush" commandZhao Qiang
PBL flush command is restricted to CCSR memory space. So use WAIT PBI command to provide enough time for data to get flush in target memory. Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> [York Sun: rewrap commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-09tools: buildman: Add compiler wrapperYork Sun
Now we can use compiler wrapper such as ccache or distcc for buildman. Signed-off-by: York Sun <york.sun@nxp.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09tools: buildman: Remove duplicated codeYork Sun
Signed-off-by: York Sun <york.sun@nxp.com> CC: Simon Glass <sjg@chromium.org> Fixed commit subject: Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Make integer division python 3.x safePaul Burton
If we use the '/' operator then python 3.x will produce a float, and refuse to multiply the string sequence in Conv_name_to_c by it with: TypeError: can't multiply sequence by non-int of type 'float' Use the '//' operator instead to enforce that we want integer rather than floating point division. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Decode strings for struct.unpack on python 3.xPaul Burton
On python 3.x struct.unpack will complain if we provide it with a string since it expects to operate on a bytes object. In order to satisfy this requirement, encode the string to a bytes object when running on python 3.x. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Use items() to iterate over dictionaries in python 3.xPaul Burton
In python 3.x the iteritems() method has been removed from dictionaries, and the items() method does effectively the same thing. On python 2.x using items() is a little less efficient since it involves copying data, but as speed isn't a concern in the affected code switch to using items() anyway for simplicity. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Fix doctest StringIO import for python 3.xPaul Burton
In python 3.x StringIO is no longer a module, and the class can instead be found in the io module. Adjust the code in the doctest input to account for both. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Use items() to iterate over dictionariesPaul Burton
In python 3.x the iteritems() method has been removed from dictionaries, and the items() method does effectively the same thing. On python 2.x using items() is a little less efficient since it involves copying data, but as speed isn't a concern in this code switch to using items() anyway for simplicity. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Import 'configparser' lower case to be python 3.x safePaul Burton
In python 3.x module names used in import statements are case sensitive, and the configparser module is named in all lower-case. Import it as such in order to avoid errors when running with python 3.x. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Make exception handling python 3.x safePaul Burton
Syntax for exception handling is a little more strict in python 3.x. Convert all uses to a form accepted by both python 2.x & python 3.x. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Make print statements python 3.x safePaul Burton
In python 3.x, print must be used as a function call. Convert all print statements to the function call style, importing from __future__ where we print with no trailing newline or print to a file object. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Replace tabs with spacesPaul Burton
In preparation for running on python 3.x, which will refuse to run scripts which mix tabs & spaces for indentation, replace 2 tab characters present in series.py with spaces. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Add a way for tests to request the fallback librarySimon Glass
We need to test both the normal (Python libfdt module) and fallback (fdtget) implementations of the Fdt class. Add a way to select which implementation to use. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Adjust GetProps() in fdt_normal to use the node pathSimon Glass
There is no need to pass a node path separately. Instead we should use the path for the node provided. Correct this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09dtoc: Fix bug in GetProp()Simon Glass
This does not actually call fdtget correctly when requesting a particular type. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Drop the 'alive' flag in BuilderThreadSimon Glass
This is not used, so drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Don't show a stacktrace on Ctrl-CSimon Glass
When Ctrl-C is pressed, just exited quietly. There is no sense in displaying a stack trace since buildman will always be in the same place: waiting for threads to complete building all the jobs on the queue. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Drop the 'active' flag in the builderSimon Glass
This serves no real purpose, since when we are not active, we exit. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Allow builds to terminate cleanlySimon Glass
It is annoying that buildman does not respond cleanly to Ctrl-C or SIGINT, particularly on machines with lots of CPUS. Unfortunately queue.join() blocks the main thread and does not allow it to see the signal. Use a separate thread instead, Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Put our local libraries first in the pathSimon Glass
If patman is installed on the machine (e.g. in the standard dist-packages directory), it will find libraries from there in preference to our local libraries. Adjust the order of the path to ensure that local libraries are found first. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Print a message indicating the build is startingSimon Glass
Make it clear when buildman actually starts building. This happens when it has prepared the threads, working directory and output directories. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Print a message when removing old directoriesSimon Glass
When buildman starts, it prepares its output directory by removing any old build directories which will not be used this time. This can happen if a previous build left directories around for commit hashes which are no-longer part of the branch. This can take quite a while, so print a message to indicate what is going on. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09buildman: Tidy up the 'cloning' messageSimon Glass
On a machine with a lot of CPUs this prints a lot of useless lines of the form: Cloning repo for thread <n> Adjust the output so that these all appear on one line, and disappear when the cloning is complete. Note: This cloning is actually unnecessary and very wasteful on disk space (about 3.5GB each time). It would be better to create symlinks. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Flush output when there is no newlineSimon Glass
Output which does not include a newline will not be displayed unless flushed. Add a flush to ensure that it becomes visible. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-10-08env: tool: add command line option to input lockfile pathB, Ravi
The default lockname is set to /var/lock. This limits the usage of this application where OS uses different lockfile location parameter. For example, In case of android, the default lock path location is /data. Hence by providing the command line option to input lockfile path will be useful to reuse the tool across multiple operating system. usage: ./fw_printenv -l <lockfile path> Signed-off-by: Ravi Babu <ravibabu@ti.com>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-10-06Suspected Spam: Do not open attachements![PATCH 4/6] tools/env: ↵Andreas Fenkart
flash_write_buf: enforce offset to be start of environment This allows to take advantage of the environment being block aligned. This is not a new constraint. Writes always start at the begin of the environment, since the header with CRC/length as there. Every environment modification requires updating the header Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools/env: lookup dev_type directly from flash_read_buf/flash_write_bufAndreas Fenkart
flash_write_buf already looks up size/offset/#sector from struct envdev_s. It can look up mtd_type as well. Same applies to flash_read_buf. Makes the interface simpler Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools/env: pass bad block offset by valueAndreas Fenkart
the offset is not modified by linux ioctl call see mtd_ioctl{drivers/mtd/mtdchar.c} Makes the interface less ambiguous, since the caller can now exclude a modification of blockstart Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools/env: factor out environment_end functionAndreas Fenkart
instead of adhoc computation of the environment end, use a function with a proper name Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools: mkimage: add support for Vybrid image formatAlbert ARIBAUD \(3ADEV\)
This format can be flashed directly at address 0 of the NAND FLASH, as it contains all necessary headers. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2016-09-18dtoc: Add methods for reading data from propertiesSimon Glass
Provide easy helpers for reading integer, string and boolean values from device-tree properties. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Correct quotes in fdt_utilSimon Glass
The style is to use single quotes for strings where possible. Adjust this function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Support finding the offset of a propertySimon Glass
Add a way to find the byte offset of a property within the device tree. This is only supported with the normal libfdt implementation since fdtget does not provide this information. Signed-off-by: Simon Glass <sjg@chromium.org>
