path: root/tools
2006-10-11Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-10-09Define IH_CPU_AVR32Stefan Roese
Make it possible to generate AVR32 uImage files with mkimage and make cmd_bootm recognize them. Patch by Haavard Skinnemoen, 22 Sep 2006
2006-10-09Coding style cleanupWolfgang Denk
2006-09-06Fix mkimage -l bug with multifile images on 64bit platformsWolfgang Denk
Patch by David Updegraff, 06 Sep 2006
2006-09-01Fix tools/updater build error.Marian Balakowicz
2006-09-01tools/easylogo/easylogo.cMarian Balakowicz
2006-08-16* Support for FDT in uImage format, error when using FDT from flashMatthew McClintock
Signed-off-by: Matthew McClintock <msm@freescale.com>
2006-04-28Fixed handling of bad checksums with "mkimage -l"Wolfgang Denk
2006-03-12Fix array overflow with fw_setenv on uninitialised environmentWolfgang Denk
Patch by Murray Jensen, 15 Jul 2005
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2006-02-21Add GIT version information (commid ID) to untagged U-Boot versionsWolfgang Denk
As done in the linux kernel, the U-Boot version (U_BOOT_VERSION) of all unreleased (untagged) U-Boot images will be automatically extended upon compiletime with a part of the GIT commit ID and possibly with "dirty" if uncommited changes are detected. Here an example for the resulting version: "U-Boot 1.1.4-g3457ac18-dirty" The version is now maintained in the toplevel Makefile and the version headers are autogenerated. Patch by Stefan Roese, 9 Feb 2006
2006-01-11Fix mkimage bug with multifile images created on 64 bit systems.Wolfgang Denk
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-09-25Fix tools/bmp_logo.c using incorrect offset to pixel dataWolfgang Denk
Patch by Andrew Dyer, 31 Jan 2005
2005-09-25Fix error handling in tools/env/fw_env.cWolfgang Denk
Patch by Ara Avanesyan, 01 Feb 2005
2005-08-12Update Hymod Board Database PHP code in "tools" directoryWolfgang Denk
Patch by Murray Jensen, 01 Jul 2005
2005-08-12Fix Murray Jensen's mail address.Wolfgang Denk
Patch by Murray Jensen, 30 Jun 2005
2005-08-03Cleanup build problems (on Fedora Core x86_64 build host)Wolfgang Denk
2005-07-21Fix file permissionsWolfgang Denk
2005-04-03* Patch by Scott McNutt, 01 Nov 2004:wdenk
Add missing NIOS/NIOS2 support for "iminfo" command * Patch by Detlev Zundel, 29 Oct 2004: Add missing NIOS/NIOS2 support for "mkimage" tool.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-11-21* Update for AT91RM9200DK and CMC_PU2 boards:wdenk
- Enable booting directly from flash - fix CMC_PU2 flash driver * Fix mkimage usage message
2004-10-10* Configure SX1 board to use drivers/cfi_flash.cwdenk
* Patches by Michael Bendzick, 30 Aug 2004: - Configure omap1510inn board to use drivers/cfi_flash.c - Make drivers/cfi_flash.c protect environment and redundant environment. * Patch by Steven Scholz, 23 Jun 2004: - Add script (tools/img2brec.sh) to programm U-Boot into (Synch)Flash using the Bootstrap Mode of the MC9328MX1/L
2004-10-09* Clean up tools/bmp_logo.c to not add trailing white spacewdenk
* Patch by Hinko Kocevar, 21 Aug 2004: - Group common framebuffer functions in common/lcd.c - Group common framebuffer macros and #defines in include/lcd.h - Provide calc_fbsize() for video ATAG
2004-09-28* Patch by Yuli Barcohen, 19 Jul 2004:wdenk
- Fix host tools building in Cygwin environment - Fix header files search order for host tools * Patch by Tom Armistead, 19 Jul 2004: Fix kgdb.S support for 74xx_75x cpu
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
2004-02-26* Patch by Rahul Shanbhag, 19 Feb 2004:wdenk
Fixes for for OMAP1610 board: - shift some IRQ specific code to platform.S file - remove duplicatewatchdog reset code from start.S * Make Auto-MDIX Support configurable on INCA-IP board * Fix license for mkimage tool
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-10-30* Fix parameter passing to standalone images with bootm commandU-Boot-1_0_0wdenk
* Patch by Kyle Harris, 30 Oct 2003: Fix build errors for ixdp425 board * Patch by David M. Horn, 29 Oct 2003: Fixes to build under CYGWIN * Get IceCube MGT5100 working (again)
2003-10-08* Patch by Anders Larsen, 18 Sep 2003:wdenk
allow mkimage to build and run on Cygwin-hosted systems * Patch by Frank Müller, 18 Sep 2003: use bi_intfreq instead of bi_busfreq to compute fec_mii_speed in cpu/mpc8xx/fec.c * Patch by Pantelis Antoniou, 16 Sep 2003: add tool to compute fileds in the PLPRCR register for MPC86x
2003-10-07Fix build problems under FreeBSDwdenk
2003-10-06Add generic filesystem image typewdenk
2003-09-16Make IPB clock on MGT5100/MPC5200 configurable in board config file;wdenk
go back to 66 MHz for stability
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-08-07Removed the file tools/gdb/astest.cdzu
2003-08-07Removed tools/gdb from "make all" target. Added make target "gdbtools"dzu
in toplevel directory instead. Removed astest.c from tools/gdb because it is no longer relevant.
2003-08-05* Map ISP1362 USB OTG controller for NSCU boardwdenk
* Patch by Brad Parker, 02 Aug 2003: fix sc520_cdp problems * Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements) * Allow erase command to cross flash bank boundaries
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-06-21Patch by Murray Jensen, 20 Jun 2003:wdenk
- hymod update - cleanup (especially for gcc-3.x compilers)
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2003-05-03Fix problem with usage of "true" (undefined in current versions of bfd.h)wdenk
2003-04-20* Make sure Block Lock Bits get cleared in R360MPI flash driverwdenk
* MPC823 LCD driver: Fill color map backwards, to allow for steady display when Linux takes over * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS (this time for real). * Add support for "bmp info" and "bmp display" commands to load bitmap images; this can be used (for example in a "preboot" command) to display a splash screen very quickly after poweron. * Add support for 133 MHz clock on INCA-IP board
2003-04-12* Patch by Lutz Dennig, 10 Apr 2003:LABEL_2003_04_15_1900wdenk
Update for R360MPI board * Add new meaning to "autostart" environment variable: If set to "no", a standalone image passed to the "bootm" command will be copied to the load address (and eventually uncompressed), but NOT be started. This can be used to load and uncompress arbitrary data. * Set max brightness for MN11236 displays on TRAB board
