path: root/tools
2013-09-12Merge and reformat boards.cfg and MAINTAINERSAlbert ARIBAUD
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-09-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
2013-09-06Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-06fw_env: fix writing environment for mtd devicesOliver Metz
Signed-off-by: Oliver Metz <oliver@freetz.org> Tested-by: Luka Perkov <luka@openwrt.org>
2013-09-06fw_env: add redundant env support for MTD_ABSENTOliver Metz
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-09-04Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-08-31tools: mxsboot: Staticize functionsMarek Vasut
Make remaining non-static functions static and the same for vars. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-08-31tools: Sort lists of files in MakefileMarek Vasut
Fix the lists of files so they are in order again. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Stefano Babic <sbabic@denx.de>
2013-08-31ARM: mxs: tools: Add mkimage support for MXS bootstreamMarek Vasut
Add mkimage support for generating and verifying MXS bootstream. The implementation here is mostly a glue code between MXSSB v0.4 and mkimage, but the long-term goal is to rectify this and merge MXSSB with mkimage more tightly. Once this code is properly in U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage support. Note that the mxsimage generator needs libcrypto from OpenSSL, I therefore enabled the libcrypto/libssl unconditionally. MXSSB: http://git.denx.de/?p=mxssb.git;a=summary The code is based on research presented at: http://www.rockbox.org/wiki/SbFileFormat Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
2013-08-31tools: add support for setting the CSF into imximageStefano Babic
Add support for setting the CSF (Command Sequence File) pointer which is used for HAB (High Assurance Boot) in the imximage by adding e.g. CSF 0x2000 in the imximage.cfg file. This will set the CSF pointer accordingly just after the padded data image area. The boot_data.length is adjusted with the value from the imximage.cfg config file. The resulting u-boot.imx can be signed with the FSL HAB tooling. The generated CSF block needs to be appended to the u-boot.imx. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-31tools: add padding of data image file for imximageStefano Babic
Implement function vrec_header to be able to pad the final data image file according the what has been calculated for boot_data.length. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-31tools: add variable padding of data image in mkimageStefano Babic
Use previously unused return value of function vrec_header to return a padding size to generic mkimage. This padding size is used in copy_files to pad with zeros after copying the data image. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-31tools: dynamically allocate imx_header in imximageStefano Babic
Change to dynamically allocate the imx_header to correctly allocate the IVT, Boot Data and DCD at correct locations depending on the boot media. Also check that the Image Vector Table Offset + IVT + Boot Data + DCD <= Initial Load Region Size. Previously struct imx_header was always 4096 bytes and was not dealing correctly with the Image Vector Table Offset. Now, the memory allocation looks for e.g. SD boot like this Storage u-boot.imx RAM Device 00000000 177ff000 <-------------- | 00000400 00000000 d1 00 20 40 IVT.header 177ff400 <------- | 00000404 00000004 00 00 80 17 IVT.entry 177ff404 ----------- | 00000408 00000008 00 00 00 00 IVT.reserved1 177ff408 | | | 0000040C 0000000C 2c f4 7f 17 IVT.dcd 177ff40C ------ | | | 00000410 00000010 20 f4 7f 17 IVT.boot 177ff410 ---- | | | | 00000414 00000014 00 f4 7f 17 IVT.self 177ff414 -------- | | 00000418 00000018 00 00 00 00 IVT.csf 177ff418 | | | | 0000041C 0000001C 00 00 00 00 IVT.reserved2 177ff41C | | | | 00000420 00000020 00 f0 7f 17 BootData.start 177ff420 <--- | | --- 00000424 00000024 00 60 03 00 BootData.length 177ff424 | | 00000428 00000028 00 00 00 00 BootData.plugin 177ff428 | | 0000042C 0000002C d2 03 30 40 DCD.header 177ff42C <----- | ... | 00001000 00000c00 13 00 00 ea U-Boot Start 17800000 <---------- While at it also remove the unused #define HEADER_OFFSET. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-31tools: rename mximage_flash_offset to imximage_ivt_offsetStefano Babic
This better reflects the naming from the Reference Manual as well as fits better since "flash" is not really applicabe for SATA. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-31tools: imx_header should not include flash_offsetStefano Babic
Doing a make distclean; make mx6qsabresd_config; make and hexdump -C u-boot.imx | less ... 00000360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 000003f0 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 |................| ^^^^^^^^^^^ 00000400 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 00001000 13 00 00 ea 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 |...ê.ð.å.ð.å.ð.å| ... shows the flash_offset value being written into the final generated image, wich is not correct. Instead create flash_offset as static variable such that the generated image is "clean". 00000360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 00001000 13 00 00 ea 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 |...ê.ð.å.ð.å.ð.å| Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-28arm, am335x: add support for 3 siemens boardsHeiko Schocher
add support for the am335x based boards from siemens: dxr2: - DDR3 128MiB - NAND 256MiB - Ethernet with external Switch SMSC LAN9303 - no PMIC - internal Watchdog - DFU support pxm2: - DDR2 512 MiB - NAND 1024 MiB - PMIC - PHY atheros ar803x - USB Host - internal Watchdog - DFU support rut: - DDR3 256 MiB - NAND 256 MiB - PMIC - PHY natsemi dp83630 - external Watchdog - DFU support Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Tom Rini <trini@ti.com>
2013-08-27CONFIG: EXYNOS5: Replace misnomer SMDK5250 with EXYNOS5250 and update MakefilesChander Kashyap
Update the Makefiles so that all boards can use the same spl generation tool Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-16tools/Makefile: Move _GNU_SOURCE to MakefileYork Sun
Commit 669dfc2e adds libfdt_env.h to HOSTCPPFLAGS. It causes stdio.h to be included before _GNU_SOURCE is defined in C files. On some old hosts some prototypes are protected by #ifdef __USE_GNU, which is set when _GNU_SOURCE is defined. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-08-10tools, bmp_logo: fix index from uint16_t to int to allow bigger logosHeiko Schocher
when generating the bmp_logo_bitmap, the index is casted as an uint16_t. So bigger logos as 65535 bytes are converted wrong Fix this. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
2013-08-02Validate dtc is new enoughStephen Warren
Subsequent patches assume that dtc supports various recent features. These are available in dtc 1.4.0. Validate that dtc is at least that version. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-07-24Add LGPL-2.0+ SPDX-License-Identifier to source filesWolfgang Denk
2013-07-15patman: README documentation nits (unit test)Gerhard Sittig
adjust instructions for the invocation of Patman's self test: the -t flag appears to have a different meaning now, refer to the --test option for the builtin unit test; adjust a directory location and make sure to run the file which resides in the source directory Signed-off-by: Gerhard Sittig <gsi@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-03tools/proftool: remove REG_NOERRORAndreas Bießmann
Remove non portable usage of REG_NOERROR. BSD (like OS X) variants of regex.h do not declare REG_NOERROR, even GNU regex(3) does not mention REG_NOERROR, just remove it. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-06-28mkimage: Build signing only if board has CONFIG_FIT_SIGNATURESimon Glass
At present mkimage is set up to always build with image signing support. This means that the SSL libraries (e.g. libssl-dev) are always required. Adjust things so that mkimage can be built with and without image signing, controlled by the presence of CONFIG_FIT_SIGNATURE in the board config file. If CONFIG_FIT_SIGNATURE is not enabled, then mkimage will report a warning that signing is not supported. If the option is enabled, but libraries are not available, then a build error similar to this will be shown: lib/rsa/rsa-sign.c:26:25: fatal error: openssl/rsa.h: No such file or directory Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add support for signing of FIT configurationsSimon Glass
While signing images is useful, it does not provide complete protection against several types of attack. For example, it it possible to create a FIT with the same signed images, but with the configuration changed such that a different one is selected (mix and match attack). It is also possible to substitute a signed image from an older FIT version into a newer FIT (roll-back attack). Add support for signing of FIT configurations using the libfdt's region support. Please see doc/uImage.FIT/signature.txt for more information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26mkimage: Add -r option to specify keys that must be verifiedSimon Glass
Normally, multiple public keys can be provided and U-Boot is not required to use all of them for verification. This is because some images may not be signed, or may be optionally signed. But we still need a mechanism to determine when a key must be used. This feature cannot be implemented in the FIT itself, since anyone could change it to mark a key as optional. The requirement for key verification must go in with the public keys, in a place that is protected from modification. Add a -r option which tells mkimage to mark all keys that it uses for signing as 'required'. If some keys are optional and some are required, run mkimage several times (perhaps with different key directories if some keys are very secret) using the -F flag to update an existing FIT. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -c option to specify a comment for key signingSimon Glass
When signing an image, it is useful to add some details about which tool or person is authorising the signing. Add a comment field which can take care of miscellaneous requirements. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -F option to modify an existing .fit fileSimon Glass
When signing images it is sometimes necessary to sign with different keys at different times, or make the signer entirely separate from the FIT creation to avoid needing the private keys to be publicly available in the system. Add a -F option so that key signing can be a separate step, and possibly done multiple times as different keys are avaiable. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -K to write public keys to an FDT blobSimon Glass
FIT image verification requires public keys. Add a convenient option to mkimage to write the public keys to an FDT blob when it uses then for signing an image. This allows us to use: mkimage -f test.its -K dest.dtb -k keys test.fit and have the signatures written to test.fit and the corresponding public keys written to dest.dtb. Then dest.dtb can be used as the control FDT for U-Boot (CONFIG_OF_CONTROL), thus providing U-Boot with access to the public keys it needs. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -k option to specify key directorySimon Glass
Keys required for signing images will be in a specific directory. Add a -k option to specify that directory. Also update the mkimage man page with this information and a clearer list of available commands. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> (v1)
2013-06-26image: Add RSA support for image signingSimon Glass
RSA provides a public key encryption facility which is ideal for image signing and verification. Images are signed using a private key by mkimage. Then at run-time, the images are verified using a private key. This implementation uses openssl for the host part (mkimage). To avoid bringing large libraries into the U-Boot binary, the RSA public key is encoded using a simple numeric representation in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Support signing of imagesSimon Glass
Add support for signing images using a new signature node. The process is handled by fdt_add_verification_data() which now takes parameters to provide the keys and related information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add signing infrastructureSimon Glass
Add a structure to describe an algorithm which can sign and (later) verify images. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Add proftool to decode profile dataSimon Glass
This tool provides the facility to decode U-Boot trace data and write out a text file in Linux ftrace format for use with pytimechart. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-22pxa: palmtreo680 flash programming utilityMike Dunn
This adds a userspace linux utility that writes the u-boot image to an mtd partition on the docg4 nand flash. A special utility is required to do this because u-boot is partially loaded by an initial program loader (IPL) that is permanently programmed to the boot region of the flash. This IPL expects the image to be written in a unique format. The characteristics of this format can be summarized as follows: - Flash blocks to be loaded must have a magic number in the oob bytes of the first page of the block. - Each page must be written redundantly in the subsequent page. - The integrated flash controller's "reliable mode" is used, requiring that alternate 2k regions (4 pages) are skipped when writing. For these reasons, a u-boot image can not be written using nandwrite from mtd-utils. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-06-20powerpc/CoreNet: Allow pbl images to take u-boot images != 512KChris Packham
Instead of assuming that SYS_TEXT_BASE is 0xFFF80000 calculate the initial pbl command offset by subtracting the image size from the top of the 24-bit address range. Also increase the size of the memory buffer to accommodate a larger output image. Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-13Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Small conflict over DRA7XX updates and adding SRAM_SCRATCH_SPACE_ADDR Conflicts: arch/arm/include/asm/arch-omap5/omap.h Signed-off-by: Tom Rini <trini@ti.com>
2013-06-08Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/Makefile
2013-06-06checkpatch.pl: Add 'printf' to logFunctionsTom Rini
2013-06-04mkimage: Add map_sysmem() and IH_ARCH_DEFAULT to simplfy buildingSimon Glass
These are not actually used in mkimage itself, but the image code (which is common with mkimage) does use them. To avoid #ifdefs in the image code just for mkimage, define dummy version of these here. The compiler will eliminate the dead code anyway. A better way to handle this might be to split out more things from common.h so that mkimage can include them. At present any file that mkimage uses has to be very careful what headers it includes. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-03wandboard: Add Boot Splash image with Wandboard logoOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-06-03build: Use generic boot logo matchingOtavio Salvador
The boot logo matching is now done in following way: - use LOGO_BMP if it is set, or - use $(BOARD).bmp if it exists in tools/logos, or - use $(VENDOR).bmp if it exists in tools/logos, or - use denx.bmp otherwise. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Wolfgang Denk <wd@denx.de>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-14buildman: Produce a sensible error message when branch is missingSimon Glass
Rather than a backtrace, produce a nice error message when an invalid branch is provided to buildman. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14mkimage: Put FIT loading in function and tidy error handlingSimon Glass
The fit_handle_file() function is quite long - split out the part that loads and checks a FIT into its own function. We will use this function for storing public keys into a destination FDT file. The error handling is currently a bit repetitive - tidy it. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Rename fit_add_hashes() to fit_add_verification_data()Simon Glass
We intend to add signatures to FITs also, so rename this function so that it is not specific to hashing. Also rename fit_image_set_hashes() and make it static since it is not used outside this file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
