path: root/tools
2015-06-04tools: ifdtool: Do not write region while its size is negativeBin Meng
We should ignore those regions whose size is negative. These are typically optional and unused regions (like GbE and platform data). Change-Id: I65ad01746144604a1dc0588b617af21f2722ebbf Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-29sunxi/nand: change BLOCK_SIZE in mksunxiboot to match NAND block sizeDaniel Kochmański
This change is necessary to calculate correct checksum for NAND boot. Works both for MMC and NAND. Without it BROM rejects boot image as invalid (bad checksum). (Changes block size from 0x200 to 0x2000). Signed-off-by: Daniel Kochmański <dkochmanski@turtle-solutions.eu> Signed-off-by: Roy Spliet <r.spliet@ultimaker.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-28tools: use pkg-config when available to get SSL flagsThomas Petazzoni
Instead of hardcoding -lssl -lcrypto as the flags needed to build mkimage with FIT signature enabled, use pkg-config when available. This allows to properly support cases where static linking is used, which requires linking with -lz, since OpenSSL uses zlib internally. We gracefully fallback on the previous behavior of hardcoding -lssl -lcrypto if pkg-config is not available or fails with an error. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2015-05-27moveconfig: Print status about the processed defconfigsJoe Hershberger
This gives a basic idea about progress. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-27moveconfig: Add a switch to enable printing errorsJoe Hershberger
In some cases the build for the autoconf breaks. This outputs the errors following the status so that action can be taken without building again manually. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-27moveconfig: Print a message for missing compilerJoe Hershberger
A common case for failed builds is a missing compiler. Print a message for that case to tell the user concisely which compiler was expected that was not found. This patch also has the effect of not printing build errors any longer. The next patch will add a switch to optionally bring that back. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-27moveconfig: Output a list of failed boardsJoe Hershberger
If boards fail, output that list to a file so that it can easily be passed back into moveconfig.py using the -d option. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-27moveconfig: Cleanup headers in arch and boardJoe Hershberger
Some config.h files live in arch and board directories. They will need to be cleaned up as well, so run the same filters there. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-27moveconfig: Add a switch to only cleanup headersJoe Hershberger
In some case you may want to only cleanup the headers. Make it possible without waiting for all boards to compile. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-27moveconfig: Add a parameter to accept a list to buildJoe Hershberger
This is helpful to re-attempt to move failed boards from a previous run without starting over. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-27moveconfig: Ignore duplicate configs when movingJoe Hershberger
When moving configs, it is important to know what was defined in the config header even if it duplicates the configs coming from Kconfig. This is specifically needed for the case where a config is set to default 'y' in the Kconfig. This would previously cause the actual value from the include config to be filtered out, and moveconfig.py would think that it was 'n'... This means that the value that should be 'y' is now (in every defconfig) set to 'not set'. tools/moveconfig.py now defines KCONFIG_IGNORE_DUPLICATES to prevent the filtering from happening and selecting wrong values for the defconfig. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-27moveconfig: Always run savedefconfig on the moved configJoe Hershberger
This will ensure that the order of the defconfig entries will always match that of the Kconfig files. After one slightly painful (but still early in the process) pass over all boards, this should keep the defconfigs clean from here on. Users must edit the Kconfig first to add the menu entries and then run moveconfig.py to update the defconfig files and the include configs. As such, moveconfig.py cannot compare against the '.config' contents. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-27tools: moveconfig: a tool to move CONFIGs from headers to defconfigsMasahiro Yamada
This tool was originally written for my local use to ease the task of tons of CONFIG moves, but there have been some requests for mainlining it. So, I have tidied up the code with nicer comments, and here it is. See the comment block of the script for usage. The first draft was http://patchwork.ozlabs.org/patch/430422/ Main updates are: - Adapted to the single .config configuration - Support colored log - Support moving multiple options at once (and take configs via input file only) - Continue even if some boards fail (Idea provided by Joe Hershberger) - Add more options - More comments and code cleanups Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-24tools: mxsboot: Calculate ECC strength dynamicallyJörg Krause
Calculating the ECC strength dynamically to be aligned with the mxs NAND driver and the Linux Kernel. Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks> Reviewed-by: Marek Vasut <marex@denx.de>
2015-05-24mtd: nand: mxs: Replace magic number for bits per ECC level with macroJörg Krause
2015-05-15logos: Add Solidrun's logoFabio Estevam
Let Solidrun's logo appear on Cuboxi and Hummingboard by default. Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-05-08Fix musl buildJörg Krause
This patch fixes cross-compiling U-Boot tools with the musl C library: * including <sys/types.h> is needed for ulong * defining _GNU_SOURCE is needed for loff_t Tested for target at91sam9261ek_dataflash_cs3. Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks> Cc: Tom Rini <trini@konsulko.com>
2015-05-05fw_env.h: include autoconf.hMax Krummenacher
Without this, when CONFIG_ENV_VARS_UBOOT_CONFIG is active we get a compile time error when doing 'make env'. In file included from tools/env/fw_env.c:117:0: include/env_default.h:110:11: error: expected ‘}’ before ‘CONFIG_SYS_ARCH’ When building U-Boot this is included indirectly by the compiler switch -include /home/trdx/git.toradex.com/u-boot-2014.10-toradex/include/linux/kconfig.h Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-04-23patman: check git format.subjectprefix setting when generate patches prefixWu, Josh
For the local project, we may specified format.subjectprefix setting. Then the patch will be formated as [Project_prefix][PATCH]. But patman will not check this setting. It will remove the format.subjectprefix. So This patch will let patman check this setting and add it as a project prefix. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-04-23buildman: Add gcc 4.9.0 with Microblaze toolchainMichal Simek
Also read gcc 4.9.0 at kernel.org which also have Microblaze toolchain. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Fixed unit test failure by updating the test: Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18patman: cover letter shows like 00/xx if more than 10 patchesWu, Josh
Make cover letter shows like 0/x, 00/xx and 000/xxx etc. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Make -V (verbose_build) really be verboseTom Rini
The help text for -V says we will pass V=1 but all it really did was not pass in -s. Change the logic to pass make V=1 with given to buildman -V or -s to make otherwise. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Keep more outputs with the --keep-outputs flagTom Rini
When told to keep outputs, be much more liberal in what files we keep. In addition to adding 'MLO', keep anything that matches u-boot-spl.* (so that we keep the map file as well) and anything we generate about 'u-boot itself. A large number of bootable formats now match this and thus it's easier to build many targets and then boot them afterwards using buildman. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Allow comparison of build configurationSimon Glass
It is useful to be able to see CONFIG changes made by commits. Add this feature to buildman using the -K flag so that all CONFIG changes are reported. The CONFIG options exist in a number of files. Each is reported individually as well as a summary that covers all files. The output shows three parts: green for additions, red for removals and yellow for changes. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Store build config filesSimon Glass
Store all config file output so that we can compare changes if requested. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Adjust the 'aborted' heuristic for writing outputSimon Glass
At present buildman tries to detect an aborted build and doesn't record a result in that case. This is to make sure that an abort (e.g. with Ctrl-C) does not mark the build as done. Without this option, buildman would never retry the build unless -f/-F are provided. The effect is that aborting the build creates 'fake errors' on whatever builds buildman happens to be working on at the time. Unfortunately the current test is not reliable and this detection can trigger if a required toolchain tool is missing. In this case the toolchain problem is never reported. Adjust the logic to continue processing the build result, mark the build as done (and failed), but with a return code which indicates that it should be retried. The correct fix is to fully and correctly detect an aborted build, quit buildman immediately and not write any partial build results in this case. Unfortunately this is currently beyond my powers and is left as an exercise for the reader (and patches are welcome). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Show 'make' command line when -V is usedSimon Glass
When a verbose build it selected, show the make command before the output of that command. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-10lpc32xx: add lpc32xx-spl.bin boot image targetAlbert ARIBAUD \(3ADEV\)
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-03Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: board/armltd/vexpress64/vexpress64.c Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-30ARM: tegra: rename colibri_t20 board/configuration/device-treeMarcel Ziswiler
In accordance with our other modules supported by U-Boot and as agreed upon for Apalis/Colibri T30 get rid of the carrier board in the board/ configuration/device-tree naming. While at it also bring the prompt more in line with our other products. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-28Patch to mkenvimage to handle text files with length that exceed env sizeBrian McFarland
The current head revision of mkenvimage (e72be8947e129f5ab274c0a9f235d2cc0014b2ea) will prevent you from creating an env image from a text file that is larger than the env length specified by the '-s' option. That doesn't make sense given that the tool now allows comments and blank lines. This patch removes that limitation and allows longer text files to be used. I don't have time / desire at the moment to figure out "patman" and could really care less if this is adopted up stream. Just figured I would share in case anybody else finds it useful enough to take time to do a proper patch. >From 39ff30190c2bf687861f4b4b33230f1944fb64f9 Mon Sep 17 00:00:00 2001 From: Brian McFarland <bmcfarland@rldrake.com> Date: Thu, 12 Mar 2015 11:37:19 -0400 Subject: [PATCH] In mkenvimage, removed the check that prevented using a source text file larger than the output environment image. Instead, the main parsing loop checks to see if the environment buffer is full, and quits if it is. After the main parse loop, a second loop swallows comments and whitespace until either the EOF is reached or more env vars are found, in which case an error will be thrown.
2015-03-05Merge branch 'buildman' of git://git.denx.de/u-boot-x86Tom Rini
2015-03-05buildman: Add a space before the list of boardsSimon Glass
Tweak the output slightly so we don't get things like: - board1 board2+ board3 board4 There should be a space before the '+'. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-05buildman: Correct toolchain download featureSimon Glass
Commit d908898 updated the ScanPath() function but not its documentation and not all its callers. This breaks the toolchain check after it is downloaded. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-05kwbimage: align v1 binary header to 4BChris Packham
According to the Armada-XP documentation the binary header format requires the header length to be aligned to 4B. Signed-off-by: Chris Packham <judge.packham@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2015-02-17add example for file on VFAT filesystem usageWaldemar Brodkorb
For example on a raspberry pi the u-boot environment can be saved in a file on the first VFAT partition. This example illustrates how to use it with fw_printenv/fw_setenv. Signed-off-by: Waldemar Brodkorb <wbx@openadk.org>
2015-02-17Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-02-16tools: mksunxiboot: Fix problems on big endian systemsSiarhei Siamashka
Now my PS3 can be also used to build u-boot for sunxi devices. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16tools/imagetool: remove linker scriptAndreas Bießmann
Commit a93648d197df48fa46dd55f925ff70468bd81c71 introduced linker generated lists for imagetool which is the base for some host tools (mkimage, dumpimage, et al.). Unfortunately some host tool chains do not support the used type of linker scripts. Therefore this commit broke these host-tools for them, namely FreeBSD and Darwin (OS/X). This commit tries to fix this. In order to have a clean distinction between host and embedded code space we need to introduce our own linker generated list instead of re-using the available linker_lists.h provided functionality. So we copy the implementation used in linux kernel script/mod/file2alias.c which has the very same problem (cause it is a host tool). This code also comes with an abstraction for Mach-O binary format used in Darwin systems. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-02-15buildman: allow multiple toolchains in a single pathAlbert ARIBAUD
When buildman scans a toolchain path, it stops at the first toolchain found. However, a single path can contains several toolchains, each with its own prefix. This patch lets buildman scan all toolchains in the path. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-15patman: Read in the git-mailrc alias fileSimon Glass
We should read this file to obtain a set of aliases. This reduces the need to create them in the ~/.patman file. This feature did exist in some version of patman, and is mentioned in the help but it did not find its way upstream. Reported-by: Graeme Russ <gruss@tss-engineering.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-15buildman: Fix incorrect arguemnt in GetUpstream()Simon Glass
This causes an error when trying to build a local branch which has a local branch as its upstream. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-02-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-02-10imx: imximage: Add QuadSPI boot supportYe.Li
Add QuadSPI boot support to imximage tool. Note: The QuadSPI configuration parameters at offset 0x400 are not included in this patch. Need other tools to generate the parameters part. Signed-off-by: Ye.Li <B37916@freescale.com>
2015-02-07kwbimage: Make the Makefile pass in CONFIG_SYS_SPI_U_BOOT_OFFSTom Rini
We can't use config.h directly as some platforms include headers that aren't safe to use in normal Linux userland. Signed-off-by: Tom Rini <trini@ti.com>
2015-02-06tools: kwbimage: Support u-boot.img padding to CONFIG_SYS_SPI_U_BOOT_OFFSStefan Roese
This is used on the AXP boards, to pad u-boot.img to the desired offset in SPI flash (only this boot target supported right now). This offset is used by the SPL then to load u-boot.img into SDRAM and execute it there. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-02-05x86: Enhance the microcode tool to support header files as inputSimon Glass
Sometimes microcode is delivered as a header file. Allow the tool to support this as well as collecting multiple microcode blocks into a single update. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-31Merge branch 'patman' of git://git.denx.de/u-boot-x86Tom Rini
2015-01-30patman: Explain how to make doc/git-mailrc workSimon Glass
Add an explanation for how to set up git so that patman can find the alias file. Fix up the get_maintainers message too. Reported-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Simon Glass <sjg@chromium.org>
