This patch adds an entry in ABI documentation for in_voltage-voltage_scale.
It has at least one user driver, adis16220, in accel driver.
Signed-off-by: Darshana Padmadas <darshanapadmadas@gmail.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
The ADC on exynos7 is quite similar to ADCv2. The differences are as
follows:
- exynos7-adc has 8 input channels (as against 10 in ADCv2).
- exynos7 does not include an ADC PHY control register.
- Some ADC_CON2 register bits being used in ADCv2 are listed as
reserved in exynos7-adc. This results in a different init_hw
function for exynos7.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
This patch updates the DT bindings for ADC in exynos-adc.txt with the
syscon phandle to the ADC nodes.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
To: devicetree@vger.kernel.org
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
The current ADC is peripheral of Qualcomm SPMI PMIC chips. It has
16 bits resolution and register space inside PMIC accessible across
SPMI bus.
The driver registers itself through IIO interface.
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
This patch adds documentation for RGBC in_intensity_*_hardwaregain.
There is at least one user for these, ADJD-S311-CR999 digital color sensor
driver.
Signed-off-by: Roberta Dobrescu <roberta.dobrescu@gmail.com>
This patch adds ABI documentation entries for in_humidityrelative_offset
and in_humidityrelative_scale, since there is at least one user for these,
Si7005 humidity and temperature sensor driver.
Reviewed-by: Daniel Baluta <daniel.baluta@intel.com>
Signed-off-by: Vlad Dogaru <vlad.dogaru@intel.com>
Add documentation for input current raw sysfs attribute.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Older Rockchip SoCs, at least the rk3066, used a slightly modified saradc
for temperature measurements. This so called tsadc does not contain any
active parts like temperature interrupts and only supports polling the
current temperature. The returned voltage can then be converted by a
suitable thermal driver to and actual temperature and used for thermal
handling.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Hartmut Knaack <knaack.h@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
Second round of new IIO drivers, features and cleanups for the 3.18 cycle.
New drivers and part support
* Bosch bmg160 Gyroscope driver
* Dyna-Image al3320a ambient light sensor driver
* Bosh bmi055 gyroscope part driver (accelerometer part supported by bmc150)
* isl29018 - add support for isl29023 and isl29035
* kxcjk-1013 - add support for kxcj9-1008 and kxtj2-1009
* bmc150 - additional part support (BMI055 accelerometer part, BMA255,
BMA222E, BMA250E and BMA280). Different resolutions but otherwise similar
parts.
* bma180 - add BMA250 (note different from the BMA250E support above despite
the naming). A lot of driver reworking lead up to this - described below.
New features
* kxcjk1013 - add threshold event support.
* rockchip - document DT bindings.
* isl29018 - ACPI support
* bma180 - enable use without IRQ
Cleanups
* Tree wide - drop owner field assignment if using the module_platform_driver
helper as that assigns it anyway.
* kxcjk1013 - drop a redundant assignment of the current range and fix a
a defined but not used warning.
* inv_mpu6050 - Remove an unnecessary cast form a void pointer.
* rockchip - drop and unused variable.
* at91_adc - make a local function static.
* st-sensors-core - correctly handle an error in setting in
st_sensors_set_drdy_int_pin
* isl29018 - typo fix
* bmc150 - fix incorrect scale value for 16G range (Driver new this cycle)
* bmc150 - fix issues when CONFIG_PM_RUNTIME not set (Driver new this cycle)
* ad7606 - line length tidy up.
* bmg160 - set power state only if PM_RUNTIME is defined.
* ak8975 - fix some unnecessary casting between char * and const char *
* bma180 - prefix remaining bits and bobs with bma180_ and ensure consistent.
- use a bool instead of an int for state (as its either on or off).
- expose the temperature channel
- statically allocate buffers to avoid need for update_scan_mode
callback.
- refactor to allow futher chip variants including support for part
specific config and disable code + different resolutions.
This fixes a merge conflict in lustre, and we want the other fixes that
went into 3.17-rc5 as well.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some USB and PHY fixes for 3.17-rc5.
Nothing major here, just a number of tiny fixes for reported issues,
and some new device ids as well.
All have been tested in linux-next"
* tag 'usb-3.17-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (46 commits)
xhci: fix oops when xhci resumes from hibernate with hw lpm capable devices
usb: xhci: Fix OOPS in xhci error handling code
xhci: Fix null pointer dereference if xhci initialization fails
storage: Add single-LUN quirk for Jaz USB Adapter
uas: Add missing le16_to_cpu calls to asm1051 / asm1053 usb-id check
usb: chipidea: msm: Initialize PHY on reset event
usb: chipidea: msm: Use USB PHY API to control PHY state
usb: hub: take hub->hdev reference when processing from eventlist
uas: Disable uas on ASM1051 devices
usb: dwc2/gadget: avoid disabling ep0
usb: dwc2/gadget: delay enabling irq once hardware is configured properly
usb: dwc2/gadget: do not call disconnect method in pullup
usb: dwc2/gadget: break infinite loop in endpoint disable code
usb: dwc2/gadget: fix phy initialization sequence
usb: dwc2/gadget: fix phy disable sequence
uwb: init beacon cache entry before registering uwb device
USB: ftdi_sio: Add support for GE Healthcare Nemo Tracker device
USB: document the 'u' flag for usb-storage quirks parameter
usb: host: xhci: fix compliance mode workaround
usb: dwc3: fix TRB completion when multiple TRBs are started
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev fixes from Tomi Valkeinen:
"Minor fixes for amba-clcd and video DT bindings"
* tag 'fbdev-fixes-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux:
video: ARM CLCD: Fix color model capabilities for DT platforms
video: fix composite video connector compatible string
Pull dmaengine fixes from Vinod Koul:
"Two minor fixes.
First one from Kuninori clarifying dmas bindings and second from Lars
for fixing dma descriptor completion in non cyclic case"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: jz4740: Fix non-cyclic descriptor completion
dt/bindings: rcar-audmapp: tidyup dmas explanation
Commit d24d481b7d36 (usb-storage: Modify and export adjust_quirks so
that it can be used by uas) added the 'u' flag to the quirks module
parameter for usb-storage, but neglected to update the
documentation. This patch adds the documentation.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Cc: stable <stable@vger.kernel.org> # 3.15+
Pull networking fixes from David Miller:
1) Fix skb leak in mac802154, from Martin Townsend
2) Use select not depends on NF_NAT for NFT_NAT, from Pablo Neira
Ayuso
3) Fix union initializer bogosity in vxlan, from Gerhard Stenzel
4) Fix RX checksum configuration in stmmac driver, from Giuseppe
CAVALLARO
5) Fix TSO with non-accelerated VLANs in e1000, e1000e, bna, ehea,
i40e, i40evf, mvneta, and qlge, from Vlad Yasevich
6) Fix capability checks in phy_init_eee(), from Giuseppe CAVALLARO
7) Try high order allocations more sanely for SKBs, specifically if a
high order allocation fails, fall back directly to zero order pages
rather than iterating down one order at a time. From Eric Dumazet
8) Fix a memory leak in openvswitch, from Li RongQing
9) amd-xgbe initializes wrong spinlock, from Thomas Lendacky
10) RTNL locking was busted in setsockopt for anycast and multicast, fix
from Sabrina Dubroca
11) Fix peer address refcount leak in ipv6, from Nicolas Dichtel
12) DocBook typo fixes, from Masanari Iida
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (101 commits)
ipv6: restore the behavior of ipv6_sock_ac_drop()
amd-xgbe: Enable interrupts for all management counters
amd-xgbe: Treat certain counter registers as 64 bit
greth: moved TX ring cleaning to NAPI rx poll func
cnic : Cleanup CONFIG_IPV6 & VLAN check
net: treewide: Fix typo found in DocBook/networking.xml
bnx2x: Fix link problems for 1G SFP RJ45 module
3c59x: avoid panic in boomerang_start_xmit when finding page address:
netfilter: add explicit Kconfig for NETFILTER_XT_NAT
ipv6: use addrconf_get_prefix_route() to remove peer addr
ipv6: fix a refcnt leak with peer addr
net-timestamp: only report sw timestamp if reporting bit is set
drivers/net/fddi/skfp/h/skfbi.h: Remove useless PCI_BASE_2ND macros
l2tp: fix race while getting PMTU on PPP pseudo-wire
ipv6: fix rtnl locking in setsockopt for anycast and multicast
VMXNET3: Check for map error in vmxnet3_set_mc
openvswitch: distinguish between the dropped and consumed skb
amd-xgbe: Fix initialization of the wrong spin lock
openvswitch: fix a memory leak
netfilter: fix missing dependencies in NETFILTER_XT_TARGET_LOG
new link for - How to piss off a Linux kernel subsystem maintainer
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
The NFS/RDMA Kconfig symbol was split into separate options for client
and server in commit 2e8c12e1b765 ("xprtrdma: add separate Kconfig
options for NFSoRDMA client and server support").
Update the documentation to reflect this split.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Cc: "J. Bruce Fields" <bfields@redhat.com>
hpfall.c was renamed to freefall.c in 3.16, but this file still refer to
hpfall.c instead of freefall.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
The example code provided with the i2c device interface documentation
won't compile since it uses the reserved word "register" to name a
variable.
The compiler fails with this error message:
error: expected identifier or '(' before '=' token
__u8 register = 0x20; /* Device register to access */
Rename the variable "register" to simply "reg" in the example code.
Another couple of typos has been fixed as well.
[Change "! =" to "!=".]
Signed-off-by: Jose Alarcon Roldan <jose.alarcon.roldan@gmail.com>
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Despite the fact that these functions have been around for years, they
are little used (only 15 uses in 13 files at the preseht time) even
though many other files use work-arounds to achieve the same result.
By documenting them, hopefully they will become more widely used.
Signed-off-by: Rob Jones <rob.jones@codethink.co.uk>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator documentation fixes from Mark Brown:
"All the fixes people have found for the regulator API have been
documentation fixes, avoiding warnings while building the kerneldoc,
fixing some errors in one of the DT bindings documents and fixing some
typos in the header"
* tag 'regulator-v3.17-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: fix kernel-doc warnings in header files
regulator: Proofread documentation
regulator: tps65090: Fix tps65090 typos in example
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
- some documentation sync
- resource leak in the bt8xx driver
- again fix the way varargs are used to handle the optional flags on
the gpiod_* accessors. Now hopefully nailed the entire problem.
* tag 'gpio-v3.17-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: move varargs hack outside #ifdef GPIOLIB
gpio: bt8xx: fix release of managed resources
Documentation: gpio: documentation for optional getters functions
'regulator/fix/tps65090' into regulator-linus
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"This time it contains a bunch of small ASoC fixes that slipped from in
previous updates, in addition to the usual HD-audio fixes and the
regression fixes for FireWire updates in 3.17.
All commits are reasonably small fixes"
* tag 'sound-3.17-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Fix COEF setups for ALC1150 codec
ASoC: simple-card: Fix bug of wrong decrement DT node's refcount
ALSA: hda - Fix digital mic on Acer Aspire 3830TG
ASoC: omap-twl4030: Fix typo in 2nd dai link's platform_name
ALSA: firewire-lib/dice: add arrangements of PCM pointer and interrupts for Dice quirk
ALSA: dice: fix wrong channel mappping at higher sampling rate
ASoC: cs4265: Fix setting of functional mode and clock divider
ASoC: cs4265: Fix clock rates in clock map table
ASoC: rt5677: correct mismatch widget name
ASoC: rt5640: Do not allow regmap to use bulk read-write operations
ASoC: tegra: Fix typo in include guard
ASoC: da732x: Fix typo in include guard
ASoC: core: fix .info for SND_SOC_BYTES_TLV
ASoC: rcar: Use && instead of & for boolean expressions
ASoC: Use dev_set_name() instead of init_name
ASoC: axi: Fix ADI AXI SPDIF specification
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"A fix for MT breakage, enhancement to Elantech PS/2 driver and a
couple of assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: elantech - add support for trackpoint found on some v3 models
Input: elantech - reset the device when elantech probe fails
Input: ALPS - suppress message about 'Unknown touchpad'
Input: fix used slots detection breakage
Input: sparc - i8042-sparcio.h: fix unused kbd_res warning
Input: atmel_mxt_ts - improve description of gpio-keymap property
Add compatible string for imx6sx-usbphy.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
The quite-recently-added analog-tv-connector bindings say that the
compatible string for composite video connector is
"composite-connector". That string is also used in the omap3-n900.dts
file. However, the connector driver uses "composite-video-connector", so
this has never worked.
While changing the driver's compatible string to "composite-connector"
would be safer, as published DT bindings should not be changed, I'd
rather fix the bindings in this case for two reasons:
* composite-connector is a bit too generic name, as it doesn't even hint
at video.
* it's clear that this has never worked, which means no one has used
those bindings, which should make it safe to change this.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
'asoc/fix/da732x', 'asoc/fix/omap', 'asoc/fix/rsnd', 'asoc/fix/rt5640', 'asoc/fix/rt5677', 'asoc/fix/simple' and 'asoc/fix/tegra' into asoc-linus
We want the staging bugfixes in this branch as well.
Pull ARM SoC fixes from Olof Johansson:
"Here's the weekly batch of fixes from arm-soc.
The delta is a largeish negative delta, due to revert of SMP support
for Broadcom's STB SoC -- it was accidentally merged before some
issues had been addressed, so they will make a new attempt for 3.18.
I didn't see a need for a full revert of the whole platform due to
this, we're keeping the rest enabled.
The rest is mostly:
- a handful of DT fixes for i.MX (Hummingboard/Cubox-i in particular)
- some MTD/NAND fixes for OMAP
- minor DT fixes for shmobile
- warning fix for UP builds on vexpress/spc
There's also a couple of patches that wires up hwmod on TI's DRA7 SoC
so it can boot. Drivers and the rest had landed for 3.17, and it's
small and isolated so it made sense to pick up now even if it's not a
bugfix"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
vexpress/spc: fix a build warning on array bounds
ARM: DRA7: hwmod: Add dra74x and dra72x specific ocp interface lists
ARM: DRA7: Add support for soc_is_dra74x() and soc_is_dra72x() variants
MAINTAINERS: catch special Rockchip code locations
ARM: dts: microsom-ar8035: MDIO pad must be set open drain
ARM: dts: omap54xx-clocks: Fix the l3 and l4 clock rates
ARM: brcmstb: revert SMP support
ARM: OMAP2+: hwmod: Rearm wake-up interrupts for DT when MUSB is idled
ARM: dts: Enable UART wake-up events for beagleboard
ARM: dts: Remove twl6030 clk32g "regulator"
ARM: OMAP2+: omap_device: remove warning that clk alias already exists
ARM: OMAP: fix %d confusingly prefixed with 0x in format string
ARM: dts: DRA7: fix interrupt-cells for GPIO
mtd: nand: omap: Fix 1-bit Hamming code scheme, omap_calculate_ecc()
ARM: dts: omap3430-sdp: Revert to using software ECC for NAND
ARM: OMAP2+: GPMC: Support Software ECC scheme via DT
mtd: nand: omap: Revert to using software ECC by default
ARM: dts: hummingboard/cubox-i: change SPDIF output to be more descriptive
ARM: dts: hummingboard/cubox-i: add USB OC pinctrl configuration
ARM: shmobile: r8a7791: add missing 0x0100 for SDCKCR
This add the necessary binding documentation for the saradc found in all recent
processors from Rockchip.
The PTP reference clock, used for setting the addend in the Timestamp Addend
Register, was erroneously hard-coded (as reported in the databook just as
example).
The patch removes the macro named: STMMAC_SYSCLOCK and allows to use a
reference clock (clk_ptp_ref_i) that can be passed from the platform.
If not passed, the main driver clock will be used as default; note that
this can be fine on some platforms.
Note that, prior this patch, using the old STMMAC_SYSCLOCK on some platforms,
as side effect, the ptp clock can move faster/slower than the system clock.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Add arm specific parts to kdump kernel documentation.
Signed-off-by: Hu Keping <hukeping@huawei.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Haren Myneni <hbabu@us.ibm.com>
Cc: Rob Landley <rob@landley.net>
Add a mention about the _optional variants of (devm_)gpiod_get*().
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull mfd fixes from Lee Jones:
"Couple of simple fixes due for the 3.17 rcs
(and a sneaky document addition that slipped from the previous
pull-request)"
* tag 'mfd-fixes-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd:
mfd: twl4030-power: Fix PM idle pin configuration to not conflict with regulators
mfd: tc3589x: Add device tree bindings
mfd: ab8500-core: Use 'ifdef' for config options
mfd: htc-i2cpld: Fix %d confusingly prefixed with 0x in format string
mfd: omap-usb-host: Fix %d confusingly prefixed with 0x in format string
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin-control fixes from Linus Walleij:
"My first (a bit delayed) pack of pin control fixes for the v3.17
series, only driver fixes:
- SH-PFC (Renesas) r8a7791 CAN bus pin group problem
- Rockchip (GPIO0 configuration)
- Tegra-xusb (interrupt handling)
- Exynos (GPIO interrupt locking)
- Qualcomm (fix misleading example interrupts)
- minor non-critical fixes for abx500 and AT91 also sneaked in,
because I initially intended this pull for post RC-1, hope it's
still OK"
* tag 'pinctrl-v3.17-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
pinctrl: qcom: apq8064: Correct interrupts in example
pinctrl: exynos: Lock GPIOs as interrupts when used as EINTs
pinctrl: pinctrl-at91.c: fix decimal printf format specifiers prefixed with 0x
pinctrl: abx500: remove useless check
pinctrl: tegra-xusb: testing wrong variable in probe()
pinctrl: tegra-xusb: fix an off by one test
pinctrl: rockchip: fix rk3288 gpio0 configuration
sh-pfc: r8a7791: fix CAN pin groups
This defines the device tree bindings for the Toshiba TC3589x
series of multi-purpose expanders. Only the stuff I can test
is defined: GPIO and keypad. Others may implement more
subdevices further down the road.
This is to complement
commit a435ae1d51e2f18414f2a87219fdbe068231e692
"mfd: Enable the tc3589x for Device Tree" which left off
the definition of the device tree bindings.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Update some descriptions for API arguments and descriptions.
Signed-off-by: Gioh Kim <gioh.kim@lge.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Mark Brown <broonie@linaro.org>
Update the description for per cpu operations to clarify use cases of
this_cpu operations and add considerations for remote access.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
Added any-motion trigger documentation.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
For v3.14 and prior, 1-bit Hamming code ECC via software was the
default choice for some boards e.g. 3430sdp.
Commit ac65caf514ec in v3.15 changed the behaviour
to use 1-bit Hamming code via Hardware using a different ECC layout
i.e. (ROM code layout) than what is used by software ECC.
This ECC layout change causes NAND filesystems created in v3.14
and prior to be unusable in v3.15 and later. So don't mark "sw" scheme
as deperecated and support it.
Signed-off-by: Roger Quadros <rogerq@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into work-next
Jonathan writes:
1st round of new IIO drivers, functionality and cleanups for the 3.18 cycle.
Maintainer Updates
* Add 3 designated reviewers for IIO. Lars, Peter and Hartmut have been
actively reviewing a lot of patches for a while now so this reflects
the status quo. These three are probably the only reason I keep
my head above the water!
New drivers and device support
* max5821 DAC
* Rockchip SARADC
* TI ADC128S052 ADC
* BMC150 Accelerometer
* exynos ADC driver gains support for s3c24xx and s3c64xx parts.
* kxcjk-1013 gainst range control and runtime PM support to drive
down it's power usage.
Driver removals
* Drop ad5930, ad99850, ad9852, ad9910 and ad9951 drivers on the simple
basis that they drivers just provided a register write function with
no compliant user space ABI whatsoever. Much better to drop them and
start again for these in the fullness of time.
Core Enhancements
* Join together neighbouring elements in the demux units that feeds
the binary interfaces. This cuts down on the number of individual
copies needed when splitting out individual channels from the incoming
channel scans.
* Other demux related cleanups such as using roundup instead of a local
implementation.
Cleanups
* Drop an unnecessary double setting of the owner field in xilinx adc.
* Some more patches to use managed (devm) interfaces to cut down on
complexity of removal code.
* adis16060 coding style fixlets.
* Fix some incorrect error returns in the Xilinx ADC driver.
* Coding style fixlets for various accelerometer drivers.
* Some sparse warning fixes to do with endianness and sign of variables.
* Fix an incorrect and entirely pointless use of sizeof on a dynamic pointer
in hid-sensor-magn-3d by dropping the relevant code.
Pull x86 fixes from Ingo Molnar:
"A couple of EFI fixes, plus misc fixes all around the map"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
efi/arm64: Store Runtime Services revision
firmware: Do not use WARN_ON(!spin_is_locked())
x86_32, entry: Clean up sysenter_badsys declaration
x86/doc: Fix the 'tlb_single_page_flush_ceiling' sysconfig path
x86/mm: Fix sparse 'tlb_single_page_flush_ceiling' warning and make the variable read-mostly
x86/mm: Fix RCU splat from new TLB tracepoints
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/urgent
Pull EFI fixes from Matt Fleming:
* WARN_ON(!spin_is_locked()) always triggers on non-SMP machines.
Swap it for the more canonical lockdep_assert_held() which always
does the right thing - Guenter Roeck
* Assign the correct value to efi.runtime_version on arm64 so that all
the runtime services can be invoked - Semen Protsenko
The example in the binding document indicates that interrupt 32 is used
for the TLMM summary IRQ. Correct this to reduce the confusion.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
The below patch improves the documentation for the gpio-property. Stephen
Warren has a good example here:
https://github.com/swarren/linux-tegra/commit/09789801
trackpad@4b {
compatible = "atmel,maxtouch";
reg = <0x4b>;
interrupt-parent = <&gpio>;
interrupts = <TEGRA_GPIO(W, 3) IRQ_TYPE_LEVEL_LOW>;
linux,gpio-keymap = <0 0 0 BTN_LEFT>;
This maps BTN_LEFT to the 4th bit of the T19 message.
Signed-off-by: Nick Dyer <nick.dyer@itdev.co.uk>
Current dmas explanation of SRC/DRS is confusable.
This patch clarifies it.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Marvell MVEBU
- Remove ARCH_KIRKWOOD dependency (Andrew Lunn)
NVIDIA Tegra
- Add debugfs support (Thierry Reding)
Synopsys DesignWare
- Look for configuration space in 'reg', not 'ranges' (Kishon Vijay Abraham I)
- Program ATU with untranslated address (Kishon Vijay Abraham I)
- Add config access-related pcie_host_ops for v3.65 hardware (Murali Karicheri)
- Add MSI-related pcie_host_ops for v3.65 hardware (Murali Karicheri)
TI DRA7xx
- Add TI DR7xx PCIe driver (Kishon Vijay Abraham I)"
* tag 'pci-v3.17-changes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: designware: Add MSI-related pcie_host_ops for v3.65 hardware
PCI: designware: Add config access-related pcie_host_ops for v3.65 hardware
PCI: dra7xx: Add TI DRA7xx PCIe driver
PCI: designware: Program ATU with untranslated address
PCI: designware: Look for configuration space in 'reg', not 'ranges'
PCI: tegra: Add debugfs support
PCI: mvebu: Remove ARCH_KIRKWOOD dependency
