[ Upstream commit 6035cbcceb069f87296b3cd0bc4736ad5618bf47 ]
DWC2 hardware module integrated in Samsung SoCs requires some quirks to
operate properly, so use Samsung SoC specific compatible to notify driver
to apply respective fixes.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit a66352e005488ecb4b534ba1af58a9f671eba9b8 upstream.
Add minimal parameters needed by the Exynos CLKOUT driver to Exynos3250
PMU node. This fixes the following warning on boot:
exynos_clkout_init: failed to register clkout clock
Fixes: d19bb397e19e ("ARM: dts: exynos: Update PMU node with CLKOUT related data")
Cc: <stable@vger.kernel.org>
There are some differences of mobile storage host between exynos3250
and exnos5250. For example, exynos3250 supports the HS400 mode, but
exynos5250 doesn't support it.
Since exynos3250 can perform the similar function with exynos5420
compatible, this patch changes the compatible from exynos5250 to
exynos5420 for mshc.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
This patch add the cooling device to control the overheating issue on
Exynos3250-based Rinato/Monk board.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by Krzysztof Kozlowski <k.kozlowski@samsung.com>
This patch add CPU operating points which include CPU frequency and
regulator voltage to use generic cpufreq drivers.
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
As a follow-up to recent changes to Exynos mipi video phy driver,
introducing support for PMU regmap in commit e4b3d38088df ("phy:
exynos-video-mipi: Fix regression by adding support for PMU regmap")
add a syscon phandle to video-phy node to bring back to life both
MIPI DSI display and MIPI CSIS-2 camera sensor on Exynos3250.
Signed-off-by: Beata Michalska <b.michalska@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
This patch adds System MMU nodes to the devices that are specific to
Exynos3250 series.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Mark "samsung,exynos3250-rtc" compatible as deprecated because it
duplicates the "samsung,s3c6410-rtc". Use "samsung,s3c6410-rtc" on
Exynos3250 and Exynos4415 boards.
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
Tested-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
git://git.infradead.org/users/jcooper/linux into irq/core
irqchip core change for v4.1 (round 3) from Jason Cooper
Purge the gic_arch_extn hacks and abuse by using the new stacked domains
NOTE: Due to the nature of these changes, patches crossing subsystems have
been kept together in their own branches.
- tegra
- Handle the LIC properly
- omap
- Convert crossbar to stacked domains
- kill arm,routable-irqs in GIC binding
- exynos
- Convert PMU wakeup to stacked domains
- shmobile, ux500, zynq (irq_set_wake branch)
- Switch from abusing gic_arch_extn to using gic_set_irqchip_flags
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt
Merge "Samsung DT updates for v4.1" from Kukjin Kim:
- for exynos3250
: add assigned clock parents for CMU nodes
- for exynos4412-odroid
: add eMMC reset line
- for exynos5250
: fixed typo for interrupt-cells
- for exynos5250-snow
: define stdout-path property
: represent bridge and panel connection
: enable wifi power-on and add cap-sdio-irq to wifi mmc node
- for exynos5250-spring
- for exynos5420
: add async-bridge clocks for gsc and disp1 PDs
- for exynos5420 boards
: Mux XMMCnDATA[0] pad correctly
- for exynos5420-odroidxu3
- for Peach boards
: add HS400 support and define stdout-path property
: add mclk entry and add WiFi module support
* tag 'samsung-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: dts: Fixed typo interrupt-cells for exynos5420 and exynos5250
ARM: dts: Add HS400 support for exynos5420 and exynos5800
ARM: dts: add async-bridge clocks to gsc power domain for exynos5420
ARM: dts: add async-bridge clocks to disp1 power domain for exynos5420
dt-bindings: add asynchronous bridge clock for exynos
ARM: dts: Define stdout-path property for exynos5250-spring
ARM: dts: Define stdout-path property for exynos5250-snow
ARM: dts: Define stdout-path property for Peach boards
ARM: dts: Add assigned clock parents to CMU node for exynos3250
ARM: dts: Add mclk entry for Peach boards
ARM: dts: Add WiFi module support for Peach boards
ARM: dts: Mux XMMCnDATA[0] pad correctly for Exynos5420 boards
ARM: dts: add eMMC reset line for exynos5422-odroidxu3
ARM: dts: add eMMC reset line for exynos4412-odroid-common
ARM: dts: represent bridge and panel connection for exynos5420-peach-pit
ARM: dts: represent bridge and panel connection for exynos5250-snow
ARM: dts: Add cap-sdio-irq to wifi mmc node for exynos5250-snow
ARM: dts: Enable wifi power-on for exynos5250-snow
Exynos has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the fact that the PMU block is actually the first
interrupt controller in the chain for RTC, kernels with this patch
applied wont have any suspend-resume facility when booted
with old DTs, and old kernels with updated DTs may not even boot.
Also, I strongly suspect that there is more than two wake-up
interrupts on these platforms, but I leave it to the maintainers
to fix their mess.
Link: https://lkml.kernel.org/r/1426088693-15724-2-git-send-email-marc.zyngier@arm.com
[ jac: squash in maz's fixup from
https://lkml.kernel.org/r/5506989D.9050703@arm.com ]
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Use assigned-clocks/assigned-clock-parents properties for
CMU clock controller DT node to secure proper clock setup:
switching the two muxes to root oscillator clock is not only
required for proper powering down the ISP power domain,
but it also reduces the risk of accessing the ISP CMU
registers while the ISP power domain remains turned off
(i.e. through the common clock framework by clk_summary)
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Presented device tree bindings provide data already hardcoded in the
exynos_tmu_data.c file.
After this commit, it should be possible to reuse common thermal core
framework in Exynos SoCs.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
This patch adds PPMU (Platform Performance Monitoring Unit) dt node
to estimate the utilization of each IP in Exynos SoC through DEVFREQ
Event subsystem.
This patch adds following PPMU dt nodes:
- PPMU_DMC0 0x106a0000
- PPMU_DMC1 0x106b0000
- PPMU_RIGHTBUS 0x112A0000
- PPMU_LEFTBUS 0x116A0000
- PPMU_CAMIF 0x11AC0000
- PPMU_LCD0 0x11E40000
- PPMU_FSYS 0x12630000
- PPMU_3D 0x13220000
- PPMU_MFC 0x13660000
- PPMU_CPU 0x106c0000
Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com>
This patch replaces all custom samsung,power-domain dt
properties with generic power domain bindings and updates
documentation Samsung's devices referring to old binding.
Suggested-by: Kevin Hilman <khilman@kernel.org>
[javier.martinez@collabora.co.uk: tested on the Exynos5800 Peach Pi Chromebook]
Tested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
This patch adds device tree node for hsotg to control USB 2.0 Device.
Signed-off-by: Jaewon Kim <jaewon02.kim@samsung.com>
This patch adds device tree node for exynos_usbphy to use USB 2.0 Device.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big staging tree pull request for 3.19-rc1.
We continued to delete more lines than were added, always a good
thing, but not at a huge rate this release, only about 70k lines
removed overall mostly from removing the horrid bcm driver.
Lots of normal staging driver cleanups and fixes all over the place,
well over a thousand of them, the shortlog shows all the horrid
details.
The "contentious" thing here is the movement of the Android binder
code out of staging into the "real" part of the kernel. This is code
that has been stable for a few years now and is working as-is in the
tens of millions of devices with no issues. Yes, the code is horrid,
and the userspace api leaves a lot to be desired, but it's not going
to change due to legacy issues that we have no control over. Because
so many devices and companies rely on this, and the code is stable,
might as well promote it out of staging.
This was all discussed at the Linux Plumbers conference, and everyone
participating agreed that this was the best way forward.
There is work happening to replace the binder code with something new
that is happening right now, but I don't expect to see the results of
that work for another year at the earliest. If that ever happens, and
Android switches over to it, I'll gladly remove this version.
As for maintainers, I'll be glad to maintain this code, I've been
doing it for the past few years with no problems. I'll send a
MAINTAINERS entry for it before 3.19-final is out, still need to talk
to the Google developers about if they are willing to help with it or
not, last I checked they were, which was good.
All of these patches have been in linux-next for a while with no
reported issues"
* tag 'staging-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1382 commits)
Staging: slicoss: Fix long line issues in slicoss.c
staging: rtl8712: remove unnecessary else after return
staging: comedi: change some printk calls to pr_err
staging: rtl8723au: hal: Removed the extra semicolon
lustre: Deletion of unnecessary checks before three function calls
staging: lustre: fix sparse warnings: static function declaration
staging: lustre: fixed sparse warnings related to static declarations
staging: unisys: remove duplicate header
staging: unisys: remove unneeded structure
staging: ft1000 : replace __attribute ((__packed__) with __packed
drivers: staging: rtl8192e: Include "asm/unaligned.h" instead of "access_ok.h" in "rtl819x_BAProc.c"
Drivers:staging:rtl8192e: Fixed checkpatch warning
Drivers:staging:clocking-wizard: Added a newline
staging: clocking-wizard: check for a valid clk_name pointer
staging: rtl8723au: Hal_InitPGData() avoid unnecessary typecasts
staging: rtl8723au: _DisableAnalog(): Avoid zero-init variables unnecessarily
staging: rtl8723au: Remove unnecessary wrapper _ResetDigitalProcedure1()
staging: rtl8723au: _ResetDigitalProcedure1_92C() reduce code obfuscation
staging: rtl8723au: Remove unnecessary wrapper _DisableRFAFEAndResetBB()
staging: rtl8723au: _DisableRFAFEAndResetBB8192C(): Reduce code obfuscation
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
First round of new drivers, features and cleanups for IIO in the 3.19 cycle.
New drivers / supported parts
* rockchip - rk3066-tsadc variant
* si7020 humidity and temperature sensor
* mcp320x - add mcp3001, mcp3002, mcp3004, mcp3008, mcp3201, mcp3202
* bmp280 pressure and temperature sensor
* Qualcomm SPMI PMIC current ADC driver
* Exynos_adc - support exynos7
New features
* vf610-adc - add temperature sensor support
* Documentation of current attributes, scaled pressure, offset and
scaled humidity, RGBC intensity gain factor and scale applied to
differential voltage channels.
* Bring iio_event_monitor up to date with newer modifiers.
* Add of_xlate function to allow for complex channel mappings from the
device tree.
* Add -g parameter to generic_buffer example to allow for devices with
directly fed (no trigger) buffers.
* Move exynos driver over to syscon for PMU register access.
Cleanups, fixes for new drivers
* lis3l02dq drop an unneeded else.
* st sensors - renam st_sensors to st_sensor_settings (for clarity)
* st sensors - drop an unused parameter from all the probe utility
functions.
* vf610 better error handling and tidy up.
* si7020 - cleanups following merge
* as3935 - drop some unnecessary semicolons.
* bmp280 - fix the pressure calculation.
Instead of using the ADC_PHY register base address, use sysreg phandle
in ADC node to control ADC_PHY configuration register.
This patch adds syscon node for Exynos3250, Exynos4x12, Exynos5250,
and Exynos5420, Exynos5800.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
To: linux-samsung-soc@vger.kernel.org
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
git://git.linaro.org/people/mike.turquette/linux
Pull clock tree updates from Mike Turquette:
"The clk tree changes for 3.18 are dominated by clock drivers. Mostly
fixes and enhancements to existing drivers as well as new drivers.
This tag contains a bit more arch code than I usually take due to some
OMAP2+ changes. Additionally it contains the restart notifier
handlers which are merged as a dependency into several trees.
The PXA changes are the only messy part. Due to having a stable tree
I had to revert one patch and follow up with one more fix near the tip
of this tag. Some dead code is introduced but it will soon become
live code after 3.18-rc1 is released as the rest of the PXA family is
converted over to the common clock framework.
Another trend in this tag is that multiple vendors have started to
push the complexity of changing their CPU frequency into the clock
driver, whereas this used to be done in CPUfreq drivers.
Changes to the clk core include a generic gpio-clock type and a
clk_set_phase() function added to the top-level clk.h api. Due to
some confusion on the fbdev mailing list the kernel boot parameters
documentation was updated to further explain the clk_ignore_unused
parameter, which is often required by users of the simplefb driver.
Finally some fixes to the locking around the clock debugfs stuff was
done to prevent deadlocks when interacting with other subsystems."
* tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits)
clk: pxa clocks build system fix
Revert "arm: pxa: Transition pxa27x to clk framework"
clk: samsung: register restart handlers for s3c2412 and s3c2443
clk: rockchip: add restart handler
clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate
doc/kernel-parameters.txt: clarify clk_ignore_unused
dts: add devicetree bindings for pxa27x clocks
clk: add pxa27x clock drivers
arm: pxa: add clock pll selection bits
clk: dts: document pxa clock binding
clk: add pxa clocks infrastructure
clk: gpio-gate: Ensure gpiod_ APIs are prototyped
clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe
clk: ti: LLVMLinux: Move __init outside of type definition
clk: ti: consider the fact that of_clk_get() might return an error
clk: ti: dra7-atl-clock: fix a memory leak
clk: ti: change clock init to use generic of_clk_init
clk: hix5hd2: add I2C clocks
clk: hix5hd2: add watchdog0 clocks
Pull drm updates from Dave Airlie:
"This is the main git pull for the drm,
I pretty much froze major pulls at -rc5/6 time, and haven't had much
fallout, so will probably continue doing that.
Lots of changes all over, big internal header cleanup to make it clear
drm features are legacy things and what are things that modern KMS
drivers should be using. Also big move to use the new generic fences
in all the TTM drivers.
core:
atomic prep work,
vblank rework changes, allows immediate vblank disables
major header reworking and cleanups to better delinate legacy
interfaces from what KMS drivers should be using.
cursor planes locking fixes
ttm:
move to generic fences (affects all TTM drivers)
ppc64 caching fixes
radeon:
userptr support,
uvd for old asics,
reset rework for fence changes
better buffer placement changes,
dpm feature enablement
hdmi audio support fixes
intel:
Cherryview work,
180 degree rotation,
skylake prep work,
execlist command submission
full ppgtt prep work
cursor improvements
edid caching,
vdd handling improvements
nouveau:
fence reworking
kepler memory clock work
gt21x clock work
fan control improvements
hdmi infoframe fixes
DP audio
ast:
ppc64 fixes
caching fix
rcar:
rcar-du DT support
ipuv3:
prep work for capture support
msm:
LVDS support for mdp4, new panel, gpu refactoring
exynos:
exynos3250 SoC support, drop bad mmap interface,
mipi dsi changes, and component match support"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (640 commits)
drm/mst: rework payload table allocation to conform better.
drm/ast: Fix HW cursor image
drm/radeon/kv: add uvd/vce info to dpm debugfs output
drm/radeon/ci: add uvd/vce info to dpm debugfs output
drm/radeon: export reservation_object from dmabuf to ttm
drm/radeon: cope with foreign fences inside the reservation object
drm/radeon: cope with foreign fences inside display
drm/core: use helper to check driver features
drm/radeon/cik: write gfx ucode version to ucode addr reg
drm/radeon/si: print full CS when we hit a packet 0
drm/radeon: remove unecessary includes
drm/radeon/combios: declare legacy_connector_convert as static
drm/radeon/atombios: declare connector convert tables as static
drm/radeon: drop btc_get_max_clock_from_voltage_dependency_table
drm/radeon/dpm: drop clk/voltage dependency filters for BTC
drm/radeon/dpm: drop clk/voltage dependency filters for CI
drm/radeon/dpm: drop clk/voltage dependency filters for SI
drm/radeon/dpm: drop clk/voltage dependency filters for NI
drm/radeon: disable audio when we disable hdmi (v2)
drm/radeon: split audio enable between eg and r600 (v2)
Fix wrong compatible string of Exynos3250 RTC (Real-Time Clock) dt node.
The RTC of Exynos3250 must need additional source clock (XrtcXTI).
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Add CMU (Clock Management Unit) node for DMC (Dynamic Memory Controller)
domain clocks on Exynos3250.
Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Reviewed-by: Andrzej Hajda <a.hajda@samsung.com>
This patch adds mipi_phy device node to reset, disable and enable
DSIM and CSIS PHY.
Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty / serial driver update from Greg KH:
"Here's the big tty / serial driver update for 3.17-rc1.
Nothing major, just a number of fixes and new features for different
serial drivers, and some more tty core fixes and documentation of the
tty locks.
All of these have been in linux-next for a while"
* tag 'tty-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (82 commits)
tty/n_gsm.c: fix a memory leak in gsmld_open
pch_uart: don't hardcode PCI slot to get DMA device
tty: n_gsm, use setup_timer
Revert "ARC: [arcfpga] stdout-path now suffices for earlycon/console"
serial: sc16is7xx: Correct initialization of s->clk
serial: 8250_dw: Add support for deferred probing
serial: 8250_dw: Add optional reset control support
serial: st-asc: Fix overflow in baudrate calculation
serial: st-asc: Don't call BUG in asc_console_setup()
tty: serial: msm: Make of_device_id array const
tty/n_gsm.c: get gsm->num after gsm_activate_mux
serial/core: Fix too big allocation for attribute member
drivers/tty/serial: use correct type for dma_map/unmap
serial: altera_jtaguart: Fix putchar function passed to uart_console_write()
serial/uart/8250: Add tunable RX interrupt trigger I/F of FIFO buffers
Serial: allow port drivers to have a default attribute group
tty: kgdb_nmi: Automatically manage tty enable
serial: altera_jtaguart: Adpot uart_console_write()
serial: samsung: improve code clarity by defining a variable
serial: samsung: correct the case and default order in switch
This patch add missing pinctrl for uart0/1 for Exynos3250. The gpio pin (
uart0_data, uart0_fctl, uart1_data) is only used for UART IP.
This patch removes duplicat 'interrupt-parent' property for Exynos3250
because exynos3250.dtsi already defined 'interrupt-parent' property
as following:
In arch/arm/boot/dts/exynos3250.dtsi:
compatible = "samsung,exynos3250";
interrupt-parent = <&gic>;
This patch add TMU (Thermal Management Unit) dt node to monitor the high
temperature for Exynos3250.
This patchset fix wrong compatible string for Exynos3250 ADC. Exynos3250 SoC
need to control only special clock for ADC. Exynos SoC except for Exynos3250
has not included special clock for ADC. The exynos ADC driver can control
special clock if compatible string is 'exynos3250-adc-v2'.
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
This patch add I2S (Inter-IC Sound) dt node which supports 1-port
stereo (1 channels) IIS-bus for audio interface with DMA-based
operation.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Inha Song <ideal.song@samsung.com>
Tested-by: Inha Song <ideal.song@samsung.com>
This patch adds alias entries for UART nodes of all SoCs using
samsung-uart compatible UART controllers, so that the dependency on
probe order is removed and deterministic device naming is assured.
This patch add pmusysreg node for Exynos3250 to access PMU
(Power Management Unit) register in a centralized way using
syscon driver.
This patch adds new exynos3250.dtsi to support Exynos3250 SoC
based on Cortex-A7 dual core and includes following dt nodes:
- GIC interrupt controller
- Pinctrl to control GPIOs
- Clock controller
- CPU information (Cortex-A7 dual core)
- UART to support serial port
- MCT (Multi Core Timer)
- ADC (Analog Digital Converter)
- I2C/SPI bus
- Power domain
- PMU (Performance Monitoring Unit)
- MSHC (Mobile Storage Host Controller)
- PWM (Pluse Width Modulation)
- AMBA bus
- sysram node for SYSRAM memory mapping
Signed-off-by: Hyunhee Kim <hyunhee.kim@samsung.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: devicetree@vger.kernel.org
