This fixes link errors with gcc 10.
| ...ld: lxtask-callbacks.o:.../lxtask-0.1.9/src/interface.h:64: multiple definition of `column';
| lxtask-main.o:.../lxtask-0.1.9/src/interface.h:64: first defined here
Remove the only place where gdk-x11 is needed and thus make it
work under gtk under wayland.
(cherry picked from commit c8d84165284d95c0775584537ab2a2e9490723ea)
The desktop file has key 'MimeType' which mandates 'inhert mime-xdg'.
This dropes the no longer available dependency on libglade and moves to gtk3+
The openbox recipe now also provides x-session-manager. Adapt recipe,
so that when lxde-common is installed the lxde session takes precedence.
Using the following pattern is very inefficent, stop using it.
SRC_URI = "src1"
SRC_URI += "src2"
Updates to version 0.3.2.
Uses the code from git rather than from a (changing) source tarball.
Move back to use the versioned tar ball, as that is now supporting
gtk3.
The gtk3 patch is upstreamed now, but new code does not comply with
gtk3.
Fixes run.do_configure: line 169: glib-gettextize: command not found.
Fixes run.do_configure: line 172: glib-gettextize: command not found.
Fixes do_compile:/bin/sh: valac: command not found.
Otherwise you get build errors like this:
| error: Package `glib-2.0' not found in specified Vala API directories
| or GObject-Introspection GIR directories
configure checks for XML catalogs from the host installation. If missing
the resulting man/Makefile will fail in do_compile.
Workaround this by ignoring that the man page can not be built.
On Ubuntu were this was observed the following installs the required
dependencies:
sudo apt-get install docbook-xsl
Better still one would fix lxterminal's configure to pick up OE's catalogs.
While libxslt-native is needed there are still docbook stylesheets and
xmlto-native missing.
xmlot-native pulls in all needed components so replacing libxslt-native
with xmlto-native fixes the build.
| make[2]: Entering directory '/build/krm/oe-core_V2.6.2/build_test/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/lxterminal/git-r0/build/man'
| /build/krm/oe-core_V2.6.2/build_test/tmp-glibc/sysroots/x86_64-linux/usr/bin/xsltproc -nonet http://docbook.sourceforge.net/release/xsl/current/manpages/docbook.xsl ../../git/man/lxterminal.xml
| I/O error : Attempt to load network entity http://docbook.sourceforge.net/release/xsl/current/manpages/docbook.xsl
| warning: failed to load external entity "http://docbook.sourceforge.net/release/xsl/current/manpages/docbook.xsl"
| cannot parse http://docbook.sourceforge.net/release/xsl/current/manpages/docbook.xsl
| Makefile:532: recipe for target 'lxterminal.1' failed
Without this many of the buttons are shown with an ugly place holder
image.
root@apalis-t30:~# gpicview
(gpicview:657): Gtk-WARNING **: Error loading theme icon 'media-playback-start' for stock:
(gpicview:657): Gtk-WARNING **: Error loading theme icon 'zoom-out' for stock: Icon 'zoom-out' not present in theme nuoveXT2
(gpicview:657): Gtk-WARNING **: Error loading theme icon 'zoom-in' for stock: Icon 'zoom-in' not present in theme nuoveXT2
(gpicview:657): Gtk-WARNING **: Error loading theme icon 'zoom-fit-best' for stock: Icon 'zoom-fit-best' not present in theme nuoveXT2
(gpicview:657): Gtk-WARNING **: Error loading theme icon 'zoom-original' for stock: Icon 'zoom-original' not present in theme nuoveXT2
Building from git requires regenerating the man pages with
xsltproc. Thus the recipe must depend on libxslt-native.
When the wnck pager is displayed the panel's width was set to the sum of
all widgets, not the screen width.
The with of a single task in the task bar was not reduced when all task's
did no longer fit in the allocated taskbar width resulting in a panel which
extended past the right side of the screen.
