The last user of this were the Tegras using the downstream kernel which
were dropped. Drop the recipe.
Related-to: ELB-2733
(cherry picked from commit 800e3beb2415365098581f8dcd2d473f7098d35b)
- Drop FILES_${PN}, it's redundant.
- Drop deprecated NATIVE_SYSTEMD_SUPPORT.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 091ab721540ab40742d9ef1c0d4c48b74d14b96d)
These machines use an old Nvidia provided downstream kernel 3.1.10. They no
longer much the way more recent sysroot components, e.g. libc, xserver et. al.
The maintance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
Use '${COMMON_LICENSE_DIR} for license files
fix the warning:
| WARNING: packagegroup-xfce-base-1.0-r5 do_populate_lic:
| ${COREBASE}/LICENSE is not a valid license file, please use
|'${COMMON_LICENSE_DIR}/MIT' for a MIT License file in LIC_FILES_CHKSUM.
|This will become an error in the future
We noticed that our latest move to using systemd/networkd leaves the
rndis0 interface down. Manually bringing the link up solved the issue.
As a workaround add upping the link to our start-rndis.sh script.
Since we use networkd now for RNDIS network interface setup now,
we can remove the custom part which starts up the RNDIS device and
sets up a DHCP server.
- Make sure leases file is not persistent (in /var/run now)
This allows to serve the same IP to the generated (and hence
different IP addresses)
- Start RNDIS service after the network.target
- Tegra: Add extra service for udhcpd. When running dhcpd directly
from udev, the daemon will be killed after a while
Disable USB RNDIS systemd service for now due to possible race upon
first boot:
[ OK ] Started Load/Configure the kernel driver providing the RNDIS
gadget.
=> system hang
ifconfig does no longer understand 192.168.11.2/24 and its
use is deprecated, so instead of changing to another way of
stating the subnetmask use /sbin/ip.
i.MX6 and Vybrid modules use the g_ether driver for RNDIS functionality.
This commit uses a systemd service to load the kernel module, configures the new
usb0 NIC and starts a dhcp server to serve an IP address to a USB host.
The Tegras use the android gadget driver. The configuration remains unchanged.
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- add recipe which configures RNDIS and dhcp on the new NIC
requires kernel commit b7e977a36ee2b1ab1a55238761fe8d63df9bc638
see also http://permalink.gmane.org/gmane.linux.usb.general/56244
