We dont support the following machines any more:
colibri-t20/colibri-t30/apalis-t30/apalis-tk1/colibri-vf, let's drop
their references.
The recipe spidev-test is only used by colibri-vf, also drop it.
Related-to: ELB-4471
Signed-off-by: Ming Liu <ming.liu@toradex.com>
With use-mainline-bsp the SoC overrides mx6/mx6q/mx6ull... are filtered out of
the overrides. Replace them with the specific machine name.
Related-to: ELB-2805
(cherry picked from commit 0cc6da1e699eddf065cdc6594f153f4a9c0495b6)
The gpio-tool recipe declares all binaries as stripped. The packages qa check
fails now if the binaries are not stripped as follows:
| ERROR: gpio-tool-1.0-r3 do_package: QA Issue: gpio-tool: Files/directories were installed but not shipped in any package:
| /usr/bin/.debug
| /usr/bin/.debug/gpio-tool
| Please set FILES such that these items are packaged. Alternatively if they are unneeded, avoid installing them or delete them within do_install.
| gpio-tool: 2 installed and not shipped files. [installed-vs-shipped]
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
Colibri iMX6ULL: The alternate function of the pins in the IOMUXC SNVS is
wrongly displayed. These pins are always GPIO. (TAMPER[0-9], BOOT_MODE[0-1].
Colibri iMX7: SODIMM-55/63, The alternate function 2 (CAN), text corrected.
Inital version for colibri-imx6ull.
Follow Pinmuxing for Apalis TK1 V1.2 Hardware.
For i.MX6 the pin NANDF_D4 was wrongly muxed.
For TK1 the number of pins was wrong which prevented access to some pins.
Follow the name change in the WinCE team.
