path: root/devel
2017-02-07backports-update-manager: add new kernelsJohannes Berg
2017-02-07backports-update-manager: remove rebuild stepJohannes Berg
This really breaks more than it fixes, afterwards it's no longer possible to compile against those headers (modpost doesn't exist due to the PIC issue.) Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-07backports-update-manager: install kernels one by oneJohannes Berg
That way, the user at least has some feedback that something is happening. Also add the missing try/finally so that the temporary directory is cleaned up. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2017-02-07backports-update-manager: remove dead codeJohannes Berg
2017-02-07backports-update-manager: remove a stray space from a messageJohannes Berg
2017-02-06git-tracker: add an option to add a Change-Id to commitsJohannes Berg
When the resulting output trees are used with gerrit, it can be useful for patches to have a Change-Id. Add an option to let the script generate them. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2016-11-15backports: rename .local-symbols to local-symbolsJohannes Berg
Remove the leading . in the file, which has tripped up people a few times already because it's hidden, and not always copied. Change-Id: I48729af712f01b56cf43c4982321b989e33259f3 Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2016-07-13devel: update test kernel versionsHauke Mehrtens
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2016-04-30devel: update test kernel versionsHauke Mehrtens
2016-02-12devel: update test kernel versionsbackports-20160104Hauke Mehrtens
2015-12-06devel: update test kernel versionsHauke Mehrtens
2015-11-02devel: update the test kernel versionsbackports-20150923Hauke Mehrtens
2015-09-14devel: update test kernel versionsHauke Mehrtens
2015-09-13git-tracker: read INPUT_HTTP[S]_PROXY environment variableJohannes Berg
This allows using a different HTTP[S] proxy for input and output trees, if necessary. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-07-23devel: update the test kernel versionsbackports-20150710Hauke Mehrtens
2015-07-23devel: convert backports-update-manager to python3Hauke Mehrtens
This converts the backports-update-manager to use python3 instead of python2. python3 is needed because new Debian packages are compressed with the xz algorithm and only the tar module of python3 supports this algorithm. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-07-20ckmake: address directory max depthLuis R. Rodriguez
It seems new versions of python make the os walk recurse more than we used to before, our ckmake implementation was picking up more kernels targets than obviously we want to build then. Fix this by replacing the os.walk() with a simple os.listdir() which just keeps us at the top level directory of lib/modules. While at it, this adds the --develdebug option which lets you debug the the directory naming it will use for display and what directories it will traverse without actually compiling anything and without using ncurses. For instance to debug or ckmake without compilation you can use: $ ckmake --allyesconfig --develdebug Paths for kernels: 3.4.103-0304103-generic 3.9.11-030911-generic 3.2.62-030262-generic 3.16.2-031602-generic 3.11.10-031110-generic 3.8.13-030813-generic 3.5.7-03050712-generic 3.0.101-0300101-generic 3.15.10-031510-generic 3.6.11-030611-generic 3.13.11-031311-generic 3.1.10-030110-generic 3.10.54-031054-generic 3.3.8-030308-generic 3.7.10-030710-generic 3.14.18-031418-generic 3.17.0-031700rc3-generic 3.12.27-031227-generic IDX VERSION DIRECTORY 1 3.0.101 /home/mcgrof/ksrc-backports/lib/modules/3.0.101-0300101-generic 2 3.1.10 /home/mcgrof/ksrc-backports/lib/modules/3.1.10-030110-generic 3 3.2.62 /home/mcgrof/ksrc-backports/lib/modules/3.2.62-030262-generic 4 3.3.8 /home/mcgrof/ksrc-backports/lib/modules/3.3.8-030308-generic 5 3.4.103 /home/mcgrof/ksrc-backports/lib/modules/3.4.103-0304103-generic 6 3.5.7 /home/mcgrof/ksrc-backports/lib/modules/3.5.7-03050712-generic 7 3.6.11 /home/mcgrof/ksrc-backports/lib/modules/3.6.11-030611-generic 8 3.7.10 /home/mcgrof/ksrc-backports/lib/modules/3.7.10-030710-generic 9 3.8.13 /home/mcgrof/ksrc-backports/lib/modules/3.8.13-030813-generic 10 3.9.11 /home/mcgrof/ksrc-backports/lib/modules/3.9.11-030911-generic 11 3.10.54 /home/mcgrof/ksrc-backports/lib/modules/3.10.54-031054-generic 12 3.11.10 /home/mcgrof/ksrc-backports/lib/modules/3.11.10-031110-generic 13 3.12.27 /home/mcgrof/ksrc-backports/lib/modules/3.12.27-031227-generic 14 3.13.11 /home/mcgrof/ksrc-backports/lib/modules/3.13.11-031311-generic 15 3.14.18 /home/mcgrof/ksrc-backports/lib/modules/3.14.18-031418-generic 16 3.15.10 /home/mcgrof/ksrc-backports/lib/modules/3.15.10-031510-generic 17 3.16.2 /home/mcgrof/ksrc-backports/lib/modules/3.16.2-031602-generic 18 3.17-rc3 /home/mcgrof/ksrc-backports/lib/modules/3.17.0-031700rc3-generic Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-06-25backports-update-manager: bump 4.1-rc1 to 4.1-rc8Luis R. Rodriguez
2015-06-09pycocci: sync pycocci with Coccinelle upstreamLuis R. Rodriguez
pycocci is now part of Coccinelle upstream. Coccinelle has a plan to actually extend multithreaded support to enable us to not have to script this out. Until then pyccoci is used and I'll sync both solutions up as there is a bit of latency between a coccinelle release and what we may need from pycocci. Please send patches or report issues about pycocci to the coccinelle mailing list. This commit syncs pycocci with the upstream pycocci with just one minor change introduced: commit cf8ef1aee7d40cddfee0f8707b2f481eb8258b4d Author: Luis R. Rodriguez <mcgrof@suse.com> Date: Fri May 29 15:15:57 2015 -0700 pycocci: update Python script to print errors clearly When you run into errors with the pycocci script errors seem cryptic, fix this. While at it also spit out what the script will run, as typically when debugging you just want to runt he same commands on your own. For instance, when run on a 32 core machine you'll now see: mcgrof@drvbp1 ~/linux-next (git::master)$ time pycocci rename-dma.cocci ./ spatch --sp-file rename-dma.cocci --in-place --recursive-includes --relax-include-path --use-coccigrep --timeout 120 --dir ./ -max 32 -index 0 ... spatch --sp-file rename-dma.cocci --in-place --recursive-includes --relax-include-path --use-coccigrep --timeout 120 --dir ./ -max 32 -index 27 real 0m50.074s user 14m50.168s sys 2m8.260s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2015-04-28devel: update the test kernelsHauke Mehrtens
2015-04-03devel: update the test kernelsbackports-20150222Hauke Mehrtens
2015-04-03git-tracker: ask for verbose messages from per-commit processingJohannes Berg
The messages are only printed if something fails anyway, so better ask for verbose messages to be able to better identify what failed. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22devel: update the test kernelsHauke Mehrtens
2014-12-21devel: update the test kernelsbackports-20141201Hauke Mehrtens
2014-11-18backports: fix breakage from integration patchsetJohannes Berg
Various small things broken in the integration patchset, fix them to actually make backports useful again. For example, a driver using devcoredump wouldn't have worked without these changes as it would depend on devcoredump, and that wasn't backported due to the bugs, despite being in the backport Kconfig file. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-11-14backports: add full kernel integration supportLuis R. Rodriguez
This enables support for using the backports project to integrate device drivers from a future version of Linux into an older version of Linux. What you end up seeing is a backports submenu when configuring your kernel and the ability to select specific device drivers from subsystems supported through the Linux backports project. At this time enabling one device driver from a future version of Linux will require using only the latest version of the subsystem modules and other subsystem drivers. For example enabling cfg80211 and mac80211 from a future version of Linux will require you to only use future version of the respective device drivers. In order to enable the backported version of 802.11 drivers for example, you will have to enable first: Networking support --> Wireless --> But under that menu disable all options, then jump to the backports submenu to now enable: Backports --> cfg80211 mac80211 Wireless LAN ---> etc You build these device drivers modular or built-in to the kernel. Integration support requires only slight modifications to the original kernel sources, one to the top level Kconfig to add our entry, and also the top level Makefile to enable backports code to be part of the built-in vmlinux. Support for integration takes advantage over the existing infrastructure added by Johannes to keep track of each indvidual change done by the backports infrastructure if --gitdebug is used. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean \ /home/mcgrof/linux-next /home/mcgrof/build/backports-20141023 Copy original source files ... Applying patches from patches to /home/mcgrof/build/backports-20141023 ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m27.942s user 13m23.752s sys 0m47.608s 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 42m44.838s user 1190m5.092s sys 140m37.208s Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: remove extra BACKPORT_ prefix from kernel versioningLuis R. Rodriguez
The CPTCFG_ prefix already implies backport, when integration is used we'd end up with a double BACKPORT_ prefix, so just remove the existing one as its not needed. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-14backports: allow for different backport prefix and simple integration supportLuis R. Rodriguez
The way we backport when packaging is to minimize the amount of changes required by taking advantage of the fact that Kconfig can treat CONFIG_ as an environment variable with getenv() when parsing menu entries. When doing integration we don't want to do this so instead we'll rely on the CONFIG_BACKPORT prefix. This requires a bit of work on our current parsers, so to do that identify the backport and provide that to helpers. This also provides initial basic support for integration where no additional code was required other than prefixes or ensuring certain things are not done for integration. Before we expose integration support we'll need to add quite a bit more things so this just assumes integration is never desired. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-10-25devel: update the test kernelsHauke Mehrtens
2014-09-06backports: update test kernel versionsHauke Mehrtens
2014-08-09backports: update test kernel versionsbackports-20140808Hauke Mehrtens
This updates the kernel versions to test against to the most recent versions. Do not use 3.15.9, but 3.15.7 because there are some problems with the define UTS_UBUNTU_RELEASE_ABI in the more recent kernel version, see: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1347879 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-17backports: update test kernel versionsv3.16-rc1-1backports-20140616Hauke Mehrtens
This adds kernel 3.16 and updates some other kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: update test kernel versionsHauke Mehrtens
This updates the kernel versions to test against to the most recent versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02git-tracker: remove shortlog for empty changesJohannes Berg
When the input tree had changes but the output doesn't get any changes at all, then the shortlog was being generated over all commits since no files were specified. Catch this special case and instead of generating a shortlog just add a note that no commits changed generated code. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-05-01backports: lib: remove raising ExecutionError exceptionArend van Spriel
In spatch a ExecutionError was raised, but that causes the thread to finish without closing the outfile and more importantly without putting (ret, fn) tuple on the return queue. This results in the threaded_spatch routine to get stuck on the ret_q.get() call. This patch removes raising the ExecutionError and just return the tuple. The non-zero return code will result in ExecutionErrorThread exception anyway. Signed-off-by: Arend van Spriel <arend@broadcom.com> [mcgrof]: rebased to fit into pycocci Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-05-01backports: devel/backports-update-manager: fix for older shutil.moveLuis R. Rodriguez
Older shutil.move does not seem to like it when there are symlinks on a target, to account for this and to make things clearer just split up the work on the lib/modules and usr/src directory. This fixes running devel/backports-update-manager on OpenSUSE 13.1 base install. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-05-01backports: add ckmake binary requirementsLuis R. Rodriguez
2014-05-01backports: run autopep8 on ckmakeLuis R. Rodriguez
This converts rel-html.py to conform to the PEP 8 style guide using autopep8. If using vi, consider adding this to your .vimrc: filetype indent plugin on au FileType python setlocal tabstop=8 expandtab shiftwidth=4 softtabstop=4 Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-05-01backports: add backports-update-manager binary requirementsLuis R. Rodriguez
2014-05-01git-tracker: restrict shortlog to existing filesJohannes Berg
When the git-tracker updates through a merge commit or otherwise multiple kernel commits, it appends a shortlog of all the changes. That's fine, but is often unhelpful since it's so large - restrict it to the files that are actually backported to make it more readable. While at it, rewrite the bpgit.status() helper function to actually do something useful. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: pycocci - make the Coccinelle wrapper a standalone toolLuis R. Rodriguez
This lets us share it for general use as a generic tool, we'll upkeep it here for now and if Coccinelle picks it up we can drop it and just require folks to install it. This lets us use the same solution for standard testing / regular development and also for backports without any discrepencies. Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: nuke support for kernels < 3.0Luis R. Rodriguez
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-02-08backports: update test kernel versionsHauke Mehrtens
2014-01-18backports: update kernel versionsHauke Mehrtens
Update to current versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-12-08backports: add Python based backports-update-managerLuis R. Rodriguez
This replaces the old shell scripts: * get-compat-kernels * get-compat-trees with a shiny central Python based backpor update manager: * backports-update-manager The new version provides a few features which were simply a difficult to implement and quite frankly pointless to try to implement in shell. Things worth mentioning: * This will now monitor your old directories and packages and remove any stale old directory or packages. You should feel comfortable with now just getting the latest code from the repo and always just running the script, it will do everything you wished it did for you. * This will always check the URLs and ensure your file size matches the target upstream size, we used to only check if you had the file or not * The compat-ksrc directory was renamed to ksrc-backports which goes inline with our rebranding crusade. The tool is smart enough to figure out if you had the old name and rename it for you. Its also smart enough to figure out if you had your old compat-ksrc as a symlink and preserve things just as you intended following the old real path. * The debs/ directory is now moved into ksrc-backports, making it easier to manage and detect what is or not part of backports. * I found no way to deal with objects to extract GNU archive items with Python, so we're stuck with requiring GNU ar, this provides a simple wrapper for our usage. * For the tree updater we instead or relying on Linus' tree to be a remote we leave it separately but always use --reference and allow users to provide their own --reference override for new clones. It should be easy to extend this should others have other custom work spaces through a config file or the like. * To keep backports up to date on a system after an initial run one should only need to run through a cronjob: backports-update-manager --force To only update the git trees: backports-update-manager --force --git-trees-only Relying on an continued update list is dumb though, in the future we should look into putting out new builds through without requiring GNU ar and also updating the list through a json file just as the kernel has its own now: https://www.kernel.org/releases.json Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-12-06ckmake: sort kernel releases properlyJohannes Berg
Ever since 3.10, kernel releases weren't sorted properly. Put them into a parsed list first and then sort them to get the 3.10/11/12 etc. to the bottom of the list. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-11-23backports: update test kernelsHauke Mehrtens
Add kernel 3.13-rc1 and update the other kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-31backports: update test kernel versionsHauke Mehrtens
This brings the kernels test test against to the latest versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: update test kernel versionsbackports-20130822Hauke Mehrtens
2013-08-27remove support for kernel 2.6.24Johannes Berg
By requiring 2.6.25 we can get rid of quite a lot of backport work. 2.6.25 was released more than five years ago (April 2011) and wasn't a long-term kernel either, so there's little point in supporting it now. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
