Instead of requiring the map to unregister, simply unregister all map entries
associated with the given iio device. This simplifies map removal and also works
for maps generated through devicetree.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Pass device pointer instead of device name as parameter to iio_channel_get_all
and iio_channel_get_all_cb. This will enable us to use OF information to
retrieve consumer channel information.
For chips with more than 8 bit ADC resolution, received data was always
masked against 0xfff, ie with a 12 bit mask. This can result in bad data
for chips with 10 bit resolution if those chips have higher bits set
(seen with MAX1139).
The receive buffer was defined as char array. This could result in
unintentional sign extensions if the upper bit in a received byte
was set. Since the chip is configured for unipolar mode, we never
have to handle negative values, and sign extensions are never needed.
Add 'iio-hwmon' OF compatibility table entry to enable OF matches.
The 'name' attribute is mandatory for hwmon devices.
This patch remove st_sensors_get_sampling_frequency_avl and
st_sensors_get_scale_avl functions used only in
st_sensors_sysfs_sampling_frequency_avail and st_sensors_sysfs_scale_avail
sysfs functions.
Signed-off-by: Denis Ciocca <denis.ciocca@st.com>
This patch adds support for the InvenSense itg3200.
The itg3200 is a three-axis gyro with 16-bit ADC and
I2C interface.
Signed-off-by: Manuel Stahl <manuel.stahl@iis.fraunhofer.de>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
The adxrs450 is in a reasonable shape now. It follows the IIO ABI and non of the
standard code checker tools report any issue, so move it out of staging.
The contents of the adxrs450 header file is not used outside the main drivers
file, so just move the contents from the header file into the drivers main file.
Also rename the adxrs450 driver file from adxrs450_core.c to adxrs450.c.
Fix the name of the iio_device parameter for a few functions and add
documentation for one missing function parameter.
The adxrs450 requires a delay of at least 0.1 ms between register writes. Using
msleep() for such small delays is not recommended. So use usleep_range instead.
Fixes the following checkpatch warning:
WARNING: msleep < 20ms can sleep for up to 20ms; see Documentation/timers/timers-howto.txt
+ msleep(1);
This is one of the exceptions to the 80 chars per line rule since breaking the
string in half it badly affects the grep-ability.
WARNING: quoted string split across lines
#203: FILE: staging/iio/gyro/adxrs450_core.c:203:
+ dev_warn(&st->us->dev, "The initial power on response "
+ "is not correct! Restart without reset?\n");
Reflow two lines to meet the 80 characters per line limit.
Fixes the following checkpatch warnings:
WARNING: line over 80 characters
#29: FILE: staging/iio/gyro/adxrs450_core.c:29:
+ * @reg_address: the address of the lower of the two registers,which should be an even address,
#81: FILE: staging/iio/gyro/adxrs450_core.c:81:
Don't spam the bootlog with the devices part id and serial number.
Instead of silently discarding the upper bits reject out of range values for the
calibscale property.
The calibbias (DNC) register contains a 10-bit twos complement value. Perform a
proper sign extension when reading the register, otherwise negative will
incorrectly be displayed as large positive values.
Fixes the following sparse warnings:
drivers/staging/iio/gyro/adxrs450_core.c:46:15: warning: cast to restricted __be32
drivers/staging/iio/gyro/adxrs450_core.c:62:17: warning: cast to restricted __be32
drivers/staging/iio/gyro/adxrs450_core.c:89:15: warning: cast to restricted __be32
drivers/staging/iio/gyro/adxrs450_core.c:129:17: warning: cast to restricted __be32
drivers/staging/iio/gyro/adxrs450_core.c:168:16: warning: cast to restricted __be32
spi_write."
This partially reverts commit cb4496876f03631eff913b3c608c964d48d61eb9. There is
no apparent reason why we should split a transaction which consists out of
multiple transfers into multiple transactions each having one transfer. While
this works it introduces a bunch of unnecessary context switch and additional
setup costs.
__iio_update_buffer updates the buffer's bytes_per_datum and length fields.
But the only user of this function just passes in these exact fields, so the
call basically looks like this:
buffer->bytes_per_datum = buffer->bytes_per_datum;
buffer->length = buffer->length;
Which means it is a noop and can be removed. Also remove the function itself,
since it is now unused.
This patch adds a generic magnetometer driver for STMicroelectronics
magnetometers, currently it supports:
LSM303DLHC, LSM303DLM, LIS3MDL.
This patch adds a generic gyroscope driver for STMicroelectronics
gyroscopes, currently it supports:
L3G4200D, LSM330DL, L3GD20, L3GD20H, LSM330DLC, L3G4IS, LSM330.
This patch adds a generic accelerometer driver for STMicroelectronics
accelerometers, currently it supports:
LSM303DLH, LSM303DLHC, LIS3DH, LSM330D, LSM330DL, LSM330DLC,
LIS331DLH, LSM303DL, LSM303DLM, LSM330.
This patch add a generic library for STMicroelectronics 3-axis sensors.
These functions are only used by the comedi core. Move the
prototypes to comedi_internal.h so they are not exposed to
the comedi drivers.
Cc: Ian Abbott <abbotti@mev.co.uk>
the comedi drivers.
Tidy up comedi_internal.h a bit so that all the internal stuff
in drivers.c is grouped.
Group all the general comedi driver register/config/attach
prototypes into one place in comedidev.h.
Reorder the functions in drivers.c a bit so they are in a more
logical usage order (bottom to top).
Convert this pcmcia driver to the comedi auto attach mechanism.
This allows getting rid of the "hack" needed to pass the pcmcia_device
pointer from the pcmcia_driver to the comedi_driver.
We can also get rid of the boardinfo since it was only used to
provide the "name" that was used with the manual attach.
We still need the boardinfo because the das08 driver uses it. But we
can get rid of the duplicate that allowed attaching with the driver
name.
Introduce some helper functions to allow converting the comedi
pcmcia drivers to the comedi auto_attach mechanism.
Separate the comedi_pcmcia_* functions out of drivers.c into a new
source file, comedi_pcmcia.c. This allows conditionally building
support for comedi pcmcia drivers into the comedi core without the
need for the #if'defery. Fix the Kconfig and Makefile appropriately.
Group all the comedi_pcmcia_* prototypes into one place in comedidev.h.
Protect these prototypes with an #ifdef so that building a comedi
pcmcia driver without PCMCIA support will cause a build error. This
will normally not happen as long as the comedi pcmcia driver is placed
in the proper group in the Kconfig.
Remove the #include <pcmcia/*.h> from drivers.c. These includes are only
needed by the comedi pcmcia driver support code and the pcmcia drivers.
The include should occur in those files.
Separate the comedi_pci_* functions out of drivers.c into a new
source file, comedi_pci.c. This allows conditionally building
support for comedi PCI drivers into the comedi core. Fix the
Group all the comedi_pci_* prototypes and related defines into one
place in comedidev.h. Protect these prototypes with an #ifdef and
provide some dummy functions so that the mixed ISA/PCI comedi
drivers will still build correctly.
Remove the #include <linux/pci.h> from comedidev.h and drivers.c. This
include is only needed by the comedi PCI driver support code and the
PCI drivers. The include should occur in those files.
Also, remove the #include <linux/pci.h> from a couple non-PCI drivers
since it's not needed.
Separate the comedi_usb_* functions out of drivers.c into a new
source file, comedi_usb.c. This allows conditionally building
support for comedi USB drivers into the comedi core without the
For aesthetic reasons, add some whitespace to the Makefile to keep
everything lined up.
Group all the comedi_usb_* prototypes into one place in comedidev.h.
usb driver without USB support will cause a build error. This will
normally not happen as long as the comedi USB driver is placed in
Remove the #include<linux/usb.h> from comedidev.h and drivers.c. This
include is only needed by the comedi USB driver support code and the
USB drivers. The include should occur in those files.
Removing the include of usb.h exposed a couple drivers that need
<linux/interrupt.h> and <linux/sched.h>. Add the missing includes.
This error happens because PIPEnsControlOut and PIPEnsControlIn unlock the
spin lock for delay, letting in another thread.
The patch moves the current MP_SET_FLAG to before filling
of sUsbCtlRequest for pControlURB and clears it in event of failing.
Any thread calling either function while fMP_CONTROL_READS or fMP_CONTROL_WRITES
flags set will return STATUS_FAILURE.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
Cc: stable@vger.kernel.org # 3.8
Fix:
drivers/staging/fwserial/fwserial.c:581:3: warning: format '%ld' expects argument of type 'long int', but argument 4 has type 'size_t'
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Fixes these sparse warnings:
drivers/staging/fwserial/fwserial.c:430:16: sparse: incompatible types in comparison expression (different address spaces)
drivers/staging/fwserial/fwserial.c:699:30: sparse: incompatible types in comparison expression (different address spaces)
drivers/staging/fwserial/fwserial.c:802:16: sparse: incompatible types in comparison expression (different address spaces)
drivers/staging/fwserial/fwserial.c:898:16: sparse: incompatible types in comparison expression (different address spaces)
drivers/staging/fwserial/fwserial.c:1842:14: sparse: incompatible types in comparison expression (different address spaces)
zs_create_pool() currently takes a name argument which is
never used in any useful way.
This patch removes it.
Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com>
Acked-by: Nitin Gupta <ngupta@vflare.org>
m68k allmodconfig:
CC [M] drivers/staging/comedi/drivers/pcl812.o
drivers/staging/comedi/drivers/pcl812.c: In function ‘pcl812_ai_cmd’:
drivers/staging/comedi/drivers/pcl812.c:736: error: implicit declaration of function ‘set_dma_mode’
drivers/staging/comedi/drivers/pcl812.c:736: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/pcl812.c:736: error: (Each undeclared identifier is reported only once
drivers/staging/comedi/drivers/pcl812.c:736: error: for each function it appears in.)
drivers/staging/comedi/drivers/pcl812.c:737: error: implicit declaration of function ‘claim_dma_lock’
drivers/staging/comedi/drivers/pcl812.c:738: error: implicit declaration of function ‘clear_dma_ff’
drivers/staging/comedi/drivers/pcl812.c:739: error: implicit declaration of function ‘set_dma_addr’
drivers/staging/comedi/drivers/pcl812.c:740: error: implicit declaration of function ‘set_dma_count’
drivers/staging/comedi/drivers/pcl812.c:741: error: implicit declaration of function ‘release_dma_lock’
drivers/staging/comedi/drivers/pcl812.c:742: error: implicit declaration of function ‘enable_dma’
drivers/staging/comedi/drivers/pcl812.c: In function ‘interrupt_pcl812_ai_dma’:
drivers/staging/comedi/drivers/pcl812.c:883: error: implicit declaration of function ‘disable_dma’
drivers/staging/comedi/drivers/pcl812.c:884: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/pcl812.c: In function ‘pcl812_ai_poll’:
drivers/staging/comedi/drivers/pcl812.c:947: error: implicit declaration of function ‘get_dma_residue’
make[2]: *** [drivers/staging/comedi/drivers/pcl812.o] Error 1
CC [M] drivers/staging/comedi/drivers/pcl816.o
drivers/staging/comedi/drivers/pcl816.c: In function ‘interrupt_pcl816_ai_mode13_dma’:
drivers/staging/comedi/drivers/pcl816.c:359: error: implicit declaration of function ‘disable_dma’
drivers/staging/comedi/drivers/pcl816.c:366: error: implicit declaration of function ‘set_dma_mode’
drivers/staging/comedi/drivers/pcl816.c:366: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/pcl816.c:366: error: (Each undeclared identifier is reported only once
drivers/staging/comedi/drivers/pcl816.c:366: error: for each function it appears in.)
drivers/staging/comedi/drivers/pcl816.c:367: error: implicit declaration of function ‘claim_dma_lock’
drivers/staging/comedi/drivers/pcl816.c:369: error: implicit declaration of function ‘set_dma_addr’
drivers/staging/comedi/drivers/pcl816.c:372: error: implicit declaration of function ‘set_dma_count’
drivers/staging/comedi/drivers/pcl816.c:378: error: implicit declaration of function ‘release_dma_lock’
drivers/staging/comedi/drivers/pcl816.c:379: error: implicit declaration of function ‘enable_dma’
drivers/staging/comedi/drivers/pcl816.c: In function ‘pcl816_ai_cmd’:
drivers/staging/comedi/drivers/pcl816.c:629: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/pcl816.c:631: error: implicit declaration of function ‘clear_dma_ff’
drivers/staging/comedi/drivers/pcl816.c: In function ‘pcl816_ai_poll’:
drivers/staging/comedi/drivers/pcl816.c:679: error: implicit declaration of function ‘get_dma_residue’
make[2]: *** [drivers/staging/comedi/drivers/pcl816.o] Error 1
CC [M] drivers/staging/comedi/drivers/pcl818.o
drivers/staging/comedi/drivers/pcl818.c: In function ‘interrupt_pcl818_ai_mode13_dma’:
drivers/staging/comedi/drivers/pcl818.c:547: error: implicit declaration of function ‘disable_dma’
drivers/staging/comedi/drivers/pcl818.c:550: error: implicit declaration of function ‘set_dma_mode’
drivers/staging/comedi/drivers/pcl818.c:550: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/pcl818.c:550: error: (Each undeclared identifier is reported only once
drivers/staging/comedi/drivers/pcl818.c:550: error: for each function it appears in.)
drivers/staging/comedi/drivers/pcl818.c:551: error: implicit declaration of function ‘claim_dma_lock’
drivers/staging/comedi/drivers/pcl818.c:552: error: implicit declaration of function ‘set_dma_addr’
drivers/staging/comedi/drivers/pcl818.c:555: error: implicit declaration of function ‘set_dma_count’
drivers/staging/comedi/drivers/pcl818.c:561: error: implicit declaration of function ‘release_dma_lock’
drivers/staging/comedi/drivers/pcl818.c:562: error: implicit declaration of function ‘enable_dma’
drivers/staging/comedi/drivers/pcl818.c: In function ‘pcl818_ai_mode13dma_int’:
drivers/staging/comedi/drivers/pcl818.c:886: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/pcl818.c:888: error: implicit declaration of function ‘clear_dma_ff’
make[2]: *** [drivers/staging/comedi/drivers/pcl818.o] Error 1
CC [M] drivers/staging/comedi/drivers/das16.o
drivers/staging/comedi/drivers/das16.c: In function ‘das16_cmd_exec’:
drivers/staging/comedi/drivers/das16.c:644: error: implicit declaration of function ‘claim_dma_lock’
drivers/staging/comedi/drivers/das16.c:645: error: implicit declaration of function ‘disable_dma’
drivers/staging/comedi/drivers/das16.c:648: error: implicit declaration of function ‘clear_dma_ff’
drivers/staging/comedi/drivers/das16.c:650: error: implicit declaration of function ‘set_dma_addr’
drivers/staging/comedi/drivers/das16.c:654: error: implicit declaration of function ‘set_dma_count’
drivers/staging/comedi/drivers/das16.c:655: error: implicit declaration of function ‘enable_dma’
drivers/staging/comedi/drivers/das16.c:656: error: implicit declaration of function ‘release_dma_lock’
drivers/staging/comedi/drivers/das16.c: In function ‘disable_dma_on_even’:
drivers/staging/comedi/drivers/das16.c:845: error: implicit declaration of function ‘get_dma_residue’
drivers/staging/comedi/drivers/das16.c: In function ‘das16_attach’:
drivers/staging/comedi/drivers/das16.c:1197: error: implicit declaration of function ‘set_dma_mode’
drivers/staging/comedi/drivers/das16.c:1197: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/das16.c:1197: error: (Each undeclared identifier is reported only once
drivers/staging/comedi/drivers/das16.c:1197: error: for each function it appears in.)
make[2]: *** [drivers/staging/comedi/drivers/das16.o] Error 1
CC [M] drivers/staging/comedi/drivers/das1800.o
drivers/staging/comedi/drivers/das1800.c: In function ‘das1800_flush_dma_channel’:
drivers/staging/comedi/drivers/das1800.c:555: error: implicit declaration of function ‘disable_dma’
drivers/staging/comedi/drivers/das1800.c:559: error: implicit declaration of function ‘clear_dma_ff’
drivers/staging/comedi/drivers/das1800.c:562: error: implicit declaration of function ‘get_dma_residue’
drivers/staging/comedi/drivers/das1800.c: In function ‘das1800_flush_dma’:
drivers/staging/comedi/drivers/das1800.c:586: error: implicit declaration of function ‘claim_dma_lock’
drivers/staging/comedi/drivers/das1800.c:603: error: implicit declaration of function ‘release_dma_lock’
drivers/staging/comedi/drivers/das1800.c: In function ‘das1800_handle_dma’:
drivers/staging/comedi/drivers/das1800.c:622: error: implicit declaration of function ‘set_dma_addr’
drivers/staging/comedi/drivers/das1800.c:624: error: implicit declaration of function ‘set_dma_count’
drivers/staging/comedi/drivers/das1800.c:625: error: implicit declaration of function ‘enable_dma’
drivers/staging/comedi/drivers/das1800.c: In function ‘das1800_init_dma’:
drivers/staging/comedi/drivers/das1800.c:1424: error: implicit declaration of function ‘set_dma_mode’
drivers/staging/comedi/drivers/das1800.c:1424: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/das1800.c:1424: error: (Each undeclared identifier is reported only once
drivers/staging/comedi/drivers/das1800.c:1424: error: for each function it appears in.)
make[2]: *** [drivers/staging/comedi/drivers/das1800.o] Error 1
CC [M] drivers/staging/comedi/drivers/dt282x.o
drivers/staging/comedi/drivers/dt282x.c: In function ‘dt282x_ao_dma_interrupt’:
drivers/staging/comedi/drivers/dt282x.c:328: error: implicit declaration of function ‘disable_dma’
drivers/staging/comedi/drivers/dt282x.c: In function ‘prep_ai_dma’:
drivers/staging/comedi/drivers/dt282x.c:416: error: implicit declaration of function ‘set_dma_mode’
drivers/staging/comedi/drivers/dt282x.c:416: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/dt282x.c:416: error: (Each undeclared identifier is reported only once
drivers/staging/comedi/drivers/dt282x.c:416: error: for each function it appears in.)
drivers/staging/comedi/drivers/dt282x.c:417: error: implicit declaration of function ‘claim_dma_lock’
drivers/staging/comedi/drivers/dt282x.c:418: error: implicit declaration of function ‘clear_dma_ff’
drivers/staging/comedi/drivers/dt282x.c:419: error: implicit declaration of function ‘set_dma_addr’
drivers/staging/comedi/drivers/dt282x.c:420: error: implicit declaration of function ‘set_dma_count’
drivers/staging/comedi/drivers/dt282x.c:421: error: implicit declaration of function ‘release_dma_lock’
drivers/staging/comedi/drivers/dt282x.c:423: error: implicit declaration of function ‘enable_dma’
drivers/staging/comedi/drivers/dt282x.c: In function ‘prep_ao_dma’:
drivers/staging/comedi/drivers/dt282x.c:439: error: ‘DMA_MODE_WRITE’ undeclared (first use in this function)
drivers/staging/comedi/drivers/dt282x.c: In function ‘dt282x_interrupt’:
drivers/staging/comedi/drivers/dt282x.c:471: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/dt282x.c: In function ‘dt282x_ai_cmd’:
drivers/staging/comedi/drivers/dt282x.c:690: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/dt282x.c: In function ‘dt282x_ao_cmd’:
drivers/staging/comedi/drivers/dt282x.c:938: error: ‘DMA_MODE_WRITE’ undeclared (first use in this function)
make[2]: *** [drivers/staging/comedi/drivers/dt282x.o] Error 1
CC [M] drivers/staging/comedi/drivers/ni_at_a2150.o
drivers/staging/comedi/drivers/ni_at_a2150.c: In function ‘a2150_interrupt’:
drivers/staging/comedi/drivers/ni_at_a2150.c:237: error: implicit declaration of function ‘claim_dma_lock’
drivers/staging/comedi/drivers/ni_at_a2150.c:238: error: implicit declaration of function ‘disable_dma’
drivers/staging/comedi/drivers/ni_at_a2150.c:241: error: implicit declaration of function ‘clear_dma_ff’
drivers/staging/comedi/drivers/ni_at_a2150.c:249: error: implicit declaration of function ‘get_dma_residue’
drivers/staging/comedi/drivers/ni_at_a2150.c:286: error: implicit declaration of function ‘set_dma_addr’
drivers/staging/comedi/drivers/ni_at_a2150.c:287: error: implicit declaration of function ‘set_dma_count’
drivers/staging/comedi/drivers/ni_at_a2150.c:288: error: implicit declaration of function ‘enable_dma’
drivers/staging/comedi/drivers/ni_at_a2150.c:290: error: implicit declaration of function ‘release_dma_lock’
drivers/staging/comedi/drivers/ni_at_a2150.c: In function ‘a2150_attach’:
drivers/staging/comedi/drivers/ni_at_a2150.c:794: error: implicit declaration of function ‘set_dma_mode’
drivers/staging/comedi/drivers/ni_at_a2150.c:794: error: ‘DMA_MODE_READ’ undeclared (first use in this function)
drivers/staging/comedi/drivers/ni_at_a2150.c:794: error: (Each undeclared identifier is reported only once
drivers/staging/comedi/drivers/ni_at_a2150.c:794: error: for each function it appears in.)
make[2]: *** [drivers/staging/comedi/drivers/ni_at_a2150.o] Error 1
Make PCL816, PCL818, DAS16, DAS1800, DT282X, and NI_AT_A2150 depend on
ISA_DMA_API to fix this.
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
The comedi core module optionally allocates some legacy board minor
devices on module load and cleans these up on module exit. These are
used for manual configuration of comedi boards (for those low-level
comedi drivers that support manual configuration - mainly for ISA
boards). Other board minor devices are created and destroyed
dynamically in response to bus device probe and remove requests. The
ioctl used for manual configuration (attachment) and removal
(detachment) of devices is COMEDI_DEVCONFIG, but that works for any
board minor device, including those that were originally created
dynamically.
If the COMEDI_DEVCONFIG ioctl is used to manually detach an
automatically created and attached device, commit
7d3135af399e92cf4c9bbc5f86b6c140aab3b88c ("staging: comedi: prevent
auto-unconfig of manually configured devices") ensures that the board
minor will no longer be automatically detached and destroyed by a bus
device remove request. From that point on the board minor behaves more
like one of the comedi "legacy" board minors. (There would be some
justification for destroying the board minor instead, but I'd rather
leave that decision until removal of board minors has been
made safer than it currently is.) Although the board minor behaves more
like a legacy board minor, it is not currently cleaned up on module
exit. In fact, the module exit code will bug out because this board
minor has not been cleaned up.
Change comedi_cleanup_legacy_minors() (called from the module exit code,
and from the module init code on error) to clean up all board minors.
Rename the function to comedi_cleanup_board_minors() to reflect the
change in functionality.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Comedi has two sorts of minor devices:
(a) normal board minor devices in the range 0 to
COMEDI_NUM_BOARD_MINORS-1 inclusive; and
(b) special subdevice minor devices in the range COMEDI_NUM_BOARD_MINORS
upwards that are used to open the same underlying comedi device as the
normal board minor devices, but with non-default read and write
subdevices for asynchronous commands.
The special subdevice minor devices get created when a board supporting
asynchronous commands is attached to a normal board minor device, and
destroyed when the board is detached from the normal board minor device.
One way to attach or detach a board is by using the COMEDI_DEVCONFIG
ioctl. This should only be used on normal board minors as the special
subdevice minors are too ephemeral. In particular, the change
introduced in commit 7d3135af399e92cf4c9bbc5f86b6c140aab3b88c ("staging:
comedi: prevent auto-unconfig of manually configured devices") breaks
horribly for special subdevice minor devices.
Since there's no legitimate use for the COMEDI_DEVCONFIG ioctl on a
special subdevice minor device node, disallow it and return -ENOTTY.
Cc: stable <stable@vger.kernel.org>
Reported-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
FWSERIAL_TTY_START_MINOR was removed. The minor_start is allocated
by tty_alloc_driver().
Use tty_alloc_driver() instead.
Add the following file hierarchy to debugfs:
<debugfs>-+
+- firewire_serial -+- <unit> -+- peers
| +- stats
+- <unit> -+- peers
+- stats
The 'peers' file (read-only) contains status and configuration
info for attached peers for the given fwserial unit.
The 'stats' file (read-only) contains statistics and data profiling
information for each tty port for the given fwserial unit.
Factor out extra stats, data profiles, debugging info and peer info
from procfs file in preparation for using debugfs instead.
