This the basic functional Invensense MPU6050 Device driver.
Signed-off-by: Ge Gao <ggao@invensense.com>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
This patch implements support for sampling of a touchscreen into
the MXS LRADC driver. The LRADC block allows configuring some of
it's channels into special mode where they either output the drive
voltage or sample it, allowing it to operate a 4-wire or 5-wire
resistive touchscreen.
In case the touchscreen mode is enabled, the LRADC slot #7 is
reserved for touchscreen only, therefore it is not possible to
sample 8 LRADC channels at time, but only 7 channels.
The touchscreen controller is configured such that the PENDOWN event
disables touchscreen interrupts and triggers execution of worker
thread, which then polls the touchscreen controller for X, Y and
Pressure values. This reduces the overhead of interrupt-driven
operation. Upon the PENUP event, the worker thread re-enables the
PENDOWN detection interrupt and exits.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Pull ARM SoC fixes from Olof Johansson:
"Here's a long-pending fixes pull request for arm-soc (I didn't send
one in the -rc4 cycle).
The larger deltas are from:
- A fixup of error paths in the mvsdio driver
- Header file move for a driver that hadn't been properly converted
to multiplatform on i.MX, which was causing build failures when
included
- Device tree updates for at91 dealing mostly with their new pinctrl
setup merged in 3.8 and mistakes in those initial configs
The rest are the normal mix of small fixes all over the place; sunxi,
omap, imx, mvebu, etc, etc."
* tag 'fixes-for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
mfd: vexpress-sysreg: Don't skip initialization on probe
ARM: vexpress: Enable A7 cores in V2P-CA15_A7's Device Tree
ARM: vexpress: extend the MPIDR range used for pen release check
ARM: at91/dts: correct comment in at91sam9x5.dtsi for mii
ARM: at91/at91_dt_defconfig: add at91sam9n12 SoC to DT defconfig
ARM: at91/at91_dt_defconfig: remove memory specification to cmdline
ARM: at91/dts: add macb mii pinctrl config for kizbox
ARM: at91: rm9200: remake the BGA as default version
ARM: at91: fix gpios on i2c-gpio for RM9200 DT
ARM: at91/at91sam9x5 DTS: add SCK USART pins
ARM: at91/at91sam9x5 DTS: correct wrong PIO BANK values on u(s)arts
ARM: at91/at91-pinctrl documentation: fix typo and add some details
ARM: kirkwood: fix missing #interrupt-cells property
mmc: mvsdio: use devm_ API to simplify/correct error paths.
clk: mvebu/clk-cpu.c: fix memory leakage
ARM: OMAP2+: omap4-panda: add UART2 muxing for WiLink shared transport
ARM: OMAP2+: DT node Timer iteration fix
ARM: OMAP2+: Fix section warning for omap_init_ocp2scp()
ARM: OMAP2+: fix build break for omapdrm
ARM: OMAP2: Fix missing omap2xxx_clkt_vps_late_init function calls
The relation between PIN_BANK numbers and pio letters wasn't made very
clear.
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs fixes from Jaegeuk Kim:
o Support swap file and link generic_file_remap_pages
o Enhance the bio streaming flow and free section control
o Major bug fix on recovery routine
o Minor bug/warning fixes and code cleanups
* tag 'f2fs-for-3.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (22 commits)
f2fs: use _safe() version of list_for_each
f2fs: add comments of start_bidx_of_node
f2fs: avoid issuing small bios due to several dirty node pages
f2fs: support swapfile
f2fs: add remap_pages as generic_file_remap_pages
f2fs: add __init to functions in init_f2fs_fs
f2fs: fix the debugfs entry creation path
f2fs: add global mutex_lock to protect f2fs_stat_list
f2fs: remove the blk_plug usage in f2fs_write_data_pages
f2fs: avoid redundant time update for parent directory in f2fs_delete_entry
f2fs: remove redundant call to set_blocksize in f2fs_fill_super
f2fs: move f2fs_balance_fs to punch_hole
f2fs: add f2fs_balance_fs in several interfaces
f2fs: revisit the f2fs_gc flow
f2fs: check return value during recovery
f2fs: avoid null dereference in f2fs_acl_from_disk
f2fs: initialize newly allocated dnode structure
f2fs: update f2fs partition info about SIT/NAT layout
f2fs: update f2fs document to reflect SIT/NAT layout correctly
f2fs: remove unneeded INIT_LIST_HEAD at few places
"People are back from the holiday breaks, and it shows. Here are a
bunch of fixes for a number of platforms:
- A couple of small fixes for Nomadik
- A larger set of changes for kirkwood/mvebu
- uart driver selection, dt clocks, gpio-poweroff fixups, a few
__init annotation fixes and some error handling improvement in
their xor dma driver.
- i.MX had a couple of minor fixes (and a critical one for flexcan2
clock setup)
- MXS has a small board fix and a framebuffer bugfix
- A set of fixes for Samsung Exynos, fixing default bootargs and some
Exynos5440 clock issues
- A set of OMAP changes including PM fixes and a few sparse warning
fixups
All in all a bit more positive code delta than we'd ideally want to
see here, mostly from the OMAP PM changes, but nothing overly crazy."
* tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (44 commits)
ARM: clps711x: Fix bad merge of clockevents setup
ARM: highbank: save and restore L2 cache and GIC on suspend
ARM: highbank: add a power request clear
ARM: highbank: fix secondary boot and hotplug
ARM: highbank: fix typos with hignbank in power request functions
ARM: dts: fix highbank cpu mpidr values
ARM: dts: add device_type prop to cpu nodes on Calxeda platforms
ARM: mx5: Fix MX53 flexcan2 clock
ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array
pinctrl: mvebu: make pdma clock on dove mandatory
ARM: Dove: Add pinctrl clock to DT
dma: mv_xor: fix error handling for clocks
dma: mv_xor: fix error handling of mv_xor_channel_add()
arm: mvebu: Add missing ; for cpu node.
arm: mvebu: Armada XP MV78230 has only three Ethernet interfaces
arm: mvebu: Armada XP MV78230 has two cores, not one
clk: mvebu: Remove inappropriate __init tagging
ARM: Kirkwood: Use fixed-regulator instead of board gpio call
ARM: Kirkwood: Fix missing sdio clock
ARM: Kirkwood: Switch TWSI1 of 88f6282 to DT clock providers
into fixes
From Shawn Guo:
It includes one critical fix - wrong flexcan2 clock will hang system
when the port gets brought up. The other two are non-critical fixes,
which are sent together here, since it's still early -rc stage.
* tag 'imx-fixes-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6:
ARM: dts: imx31-bug: Fix manufacturer compatible string
clk: imx: Remove 'clock-output-names' from the examples
Pull networking fixes from David Miller:
1) New sysctl ndisc_notify needs some documentation, from Hanns
Frederic Sowa.
2) Netfilter REJECT target doesn't set transport header of SKB
correctly, from Mukund Jampala.
3) Forcedeth driver needs to check for DMA mapping failures, from Larry
Finger.
4) brcmsmac driver can't use usleep_range while holding locks, use
udelay instead. From Niels Ole Salscheider.
5) Fix unregister of netlink bridge multicast database handlers, from
Vlad Yasevich and Rami Rosen.
6) Fix checksum calculations in netfilter's ipv6 network prefix
translation module.
7) Fix high order page allocation failures in netfilter xt_recent, from
Eric Dumazet.
8) mac802154 needs to use netif_rx_ni() instead of netif_rx() because
mac802154_process_data() can execute in process rather than
interrupt context. From Alexander Aring.
9) Fix splice handling of MSG_SENDPAGE_NOTLAST, otherwise we elide one
tcp_push() too many. From Eric Dumazet and Willy Tarreau.
10) Fix skb->truesize tracking in XEN netfront driver, from Ian
Campbell.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (46 commits)
xen/netfront: improve truesize tracking
ipv4: fix NULL checking in devinet_ioctl()
tcp: fix MSG_SENDPAGE_NOTLAST logic
net/ipv4/ipconfig: really display the BOOTP/DHCP server's address.
ip-sysctl: fix spelling errors
mac802154: fix NOHZ local_softirq_pending 08 warning
ipv6: document ndisc_notify in networking/ip-sysctl.txt
ath9k: Fix Kconfig for ATH9K_HTC
netfilter: xt_recent: avoid high order page allocations
netfilter: fix missing dependencies for the NOTRACK target
netfilter: ip6t_NPT: fix IPv6 NTP checksum calculation
bridge: add empty br_mdb_init() and br_mdb_uninit() definitions.
vxlan: allow live mac address change
bridge: Correctly unregister MDB rtnetlink handlers
brcmfmac: fix parsing rsn ie for ap mode.
brcmsmac: add copyright information for Canonical
rtlwifi: rtl8723ae: Fix warning for unchecked pci_map_single() call
rtlwifi: rtl8192se: Fix warning for unchecked pci_map_single() call
rtlwifi: rtl8192de: Fix warning for unchecked pci_map_single() call
rtlwifi: rtl8192ce: Fix warning for unchecked pci_map_single() call
Pull ACPI and power management fixes from Rafael Wysocki:
- Removal of some ACPICA code that the kernel will never use from Lv
Zheng.
- APEI fix from Adrian Huang.
- Removal of unnecessary ACPI memory hotplug driver code from Liu
Jinsong.
- Minor ACPI power management fixes.
- ACPI debug code fix from Joe Perches.
- ACPI fix to make system bus device nodes get the right names.
- PNP resources handling fixes from Witold Szczeponik.
- cpuidle fix for a recent regression stalling boot on systems with
great numbers of CPUs from Daniel Lezcano.
- cpuidle fixes from Sivaram Nair.
- intel_idle debug message fix from Youquan Song.
- cpufreq build regression fix from Larry Finger.
- cpufreq fix for an obscure initialization race related to statistics
from Konstantin Khlebnikov.
- cpufreq change disabling the Longhaul driver by default from Rafał
Bilski.
- PM core fix preventing device suspend errors from happening during
system suspend due to obscure race conditions.
- PM QoS local variable name cleanup.
* tag 'pm+acpi-for-3.8-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM: Move disabling/enabling runtime PM to late suspend/early resume
PM / QoS: Rename local variable in dev_pm_qos_add_ancestor_request()
ACPI / scan: Do not use dummy HID for system bus ACPI nodes
cpufreq / governor: Fix problem with cpufreq_ondemand or cpufreq_conservative
cpufreq / Longhaul: Disable driver by default
cpufreq / stats: fix race between stats allocation and first usage
cpuidle: fix lock contention in the idle path
intel_idle: pr_debug information need separated
cpuidle / coupled: fix ready counter decrement
cpuidle: Fix finding state with min power_usage
PNP: Handle IORESOURCE_BITS in resource allocation
PNP: Simplify setting of resources
ACPI / power: Remove useless message from device registering routine
ACPI / glue: Update DBG macro to include KERN_DEBUG
ACPI / PM: Do not apply ACPI_SUCCESS() to acpi_bus_get_device() result
ACPI / memhotplug: remove redundant logic of acpi memory hotadd
ACPI / APEI: Fix the returned value in erst_dbg_read
ACPICA: Remove useless mini-C library.
Improve the documentation to clarify level vs edge triggered power off.
Improve the comments for level vs edge triggered power off.
Make use of gpio_is_valid().
Reported-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Currently, the PM core disables runtime PM for all devices right
after executing subsystem/driver .suspend() callbacks for them
and re-enables it right before executing subsystem/driver .resume()
callbacks for them. This may lead to problems when there are
two devices such that the .suspend() callback executed for one of
them depends on runtime PM working for the other. In that case,
if runtime PM has already been disabled for the second device,
the first one's .suspend() won't work correctly (and analogously
for resume).
To make those issues go away, make the PM core disable runtime PM
for devices right before executing subsystem/driver .suspend_late()
callbacks for them and enable runtime PM for them right after
executing subsystem/driver .resume_early() callbacks for them. This
way the potential conflitcs between .suspend_late()/.resume_early()
and their runtime PM counterparts are still prevented from happening,
but the subtle ordering issues related to disabling/enabling runtime
PM for devices during system suspend/resume are much easier to avoid.
Reported-and-tested-by: Jan-Matthias Braun <jan_braun@gmx.net>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Cc: 3.4+ <stable@vger.kernel.org>
Signed-off-by: Carlos Alberto Lopez Perez <clopez@igalia.com>
Cc: Rob Landley <rob@landley.net>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Tejun Heo <tj@kernel.org>
Add 3 new variables and sysctls to tune them (by one "next_id" variable
for messages, semaphores and shared memory respectively). This variable
can be used to set desired id for next allocated IPC object. By default
it's equal to -1 and old behaviour is preserved. If this variable is
non-negative, then desired idr will be extracted from it and used as a
start value to search for free IDR slot.
Notes:
1) this patch doesn't guarantee that the new object will have desired
id. So it's up to user space how to handle new object with wrong id.
2) After a sucessful id allocation attempt, "next_id" will be set back
to -1 (if it was non-negative).
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
I slipped in a new sysctl without proper documentation. I would like to
make up for this now.
'clock-output-names' is not used in any of the dts/dtsi files for i.mx.
Remove it from the examples, so that the example and the real usage in the
dtsi files can match.
Acked-by: Rob Herring <rob.herring@calxeda.com>
document to reflect the layout generated by mkfs.f2fs .
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core __dev* removal patches - take 3 - from Greg Kroah-Hartman:
"Here are the remaining __dev* removal patches against the 3.8-rc2
tree. All of these patches were previously sent to the subsystem
maintainers, most of them were picked up and pushed to you, but there
were a number that fell through the cracks, and new drivers were added
during the merge window, so this series cleans up the rest of the
instances of these markings.
Third time's the charm...
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up trivial conflict with the pinctrl pull in pinctrl-sirf.c.
* tag 'driver-core-3.8-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (54 commits)
misc: remove __dev* attributes.
include: remove __dev* attributes.
Documentation: remove __dev* attributes.
Drivers: misc: remove __dev* attributes.
Drivers: block: remove __dev* attributes.
Drivers: bcma: remove __dev* attributes.
Drivers: char: remove __dev* attributes.
Drivers: clocksource: remove __dev* attributes.
Drivers: ssb: remove __dev* attributes.
Drivers: dma: remove __dev* attributes.
Drivers: gpu: remove __dev* attributes.
Drivers: infinband: remove __dev* attributes.
Drivers: memory: remove __dev* attributes.
Drivers: mmc: remove __dev* attributes.
Drivers: iommu: remove __dev* attributes.
Drivers: power: remove __dev* attributes.
Drivers: message: remove __dev* attributes.
Drivers: macintosh: remove __dev* attributes.
Drivers: mfd: remove __dev* attributes.
pstore: remove __dev* attributes.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from the kernel documentation.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pinctrl fixes from Linus Walleij:
"A first round of pinctrl fixes for v3.8:
- i.MX5 register configuration
- Swap a kfree to devm_kfree() to avoid memory corruption in the at91
driver
- Add the missing device tree binding doc for the SIRF pin controller
- Enable the SIRF GPIO pull up/down configuration from the device
tree, it was previously retired from the hard-coded approach.
- NULL check for the prcm_base in the Nomadik pin controller.
- Provide the prcm_base from the device tree in the DT boot path for
the Nomadik pin controller."
* tag 'pinctrl-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
ARM: ux500: add pinctrl address resources
pinctrl: nomadik: return if prcm_base is NULL
pinctrl: sirf: enable GPIO pullup/down configuration from dts
pinctrl: sirf: add missing DT-binding document
pinctrl: fix comment mistake
drivers/pinctrl/pinctrl-at91.c: convert kfree to devm_kfree
pinctrl: imx5: fix GPIO_8 pad CAN1_RXCAN configuration
Add DT support for twl4030_wdt. This is needed to get twl4030_wdt to
probe when booting with DT.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
commit 7bec207427c2efb794 remove sirfsoc_gpio_set_pull function,
this patches takes the feature back by adding sirf,pullups and
sirf,pulldowns prop in dts, and the driver will set the GPIO
pull according to the dts.
Signed-off-by: Barry Song <Baohua.Song@csr.com>
While sending email to Linus for reviewing:
"pinctrl: sirf: add DT-binding pinmux mapping support"
https://patchwork.kernel.org/patch/1364361/
i have included the devicetree/bindings/pinctrl/pinctrl-sirf.txt
But while sending pull request with commit 056876f6c73406c,
i missed the document.
this patch takes the document back.
Pull watchdog updates from Wim Van Sebroeck:
"This includes some fixes and code improvements (like
clk_prepare_enable and clk_disable_unprepare), conversion from the
omap_wdt and twl4030_wdt drivers to the watchdog framework, addition
of the SB8x0 chipset support and the DA9055 Watchdog driver and some
OF support for the davinci_wdt driver."
* git://www.linux-watchdog.org/linux-watchdog: (22 commits)
watchdog: mei: avoid oops in watchdog unregister code path
watchdog: Orion: Fix possible null-deference in orion_wdt_probe
watchdog: sp5100_tco: Add SB8x0 chipset support
watchdog: davinci_wdt: add OF support
watchdog: da9052: Fix invalid free of devm_ allocated data
watchdog: twl4030_wdt: Change TWL4030_MODULE_PM_RECEIVER to TWL_MODULE_PM_RECEIVER
watchdog: remove depends on CONFIG_EXPERIMENTAL
watchdog: Convert dev_printk(KERN_<LEVEL> to dev_<level>(
watchdog: DA9055 Watchdog driver
watchdog: omap_wdt: eliminate goto
watchdog: omap_wdt: delete redundant platform_set_drvdata() calls
watchdog: omap_wdt: convert to devm_ functions
watchdog: omap_wdt: convert to new watchdog core
watchdog: WatchDog Timer Driver Core: fix comment
watchdog: s3c2410_wdt: use clk_prepare_enable and clk_disable_unprepare
watchdog: imx2_wdt: Select the driver via ARCH_MXC
watchdog: cpu5wdt.c: add missing del_timer call
watchdog: hpwdt.c: Increase version string
watchdog: Convert twl4030_wdt to watchdog core
davinci_wdt: preparation for switch to common clock framework
Merge the rest of Andrew's patches for -rc1:
"A bunch of fixes and misc missed-out-on things.
That'll do for -rc1. I still have a batch of IPC patches which still
have a possible bug report which I'm chasing down."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (25 commits)
keys: use keyring_alloc() to create module signing keyring
keys: fix unreachable code
sendfile: allows bypassing of notifier events
SGI-XP: handle non-fatal traps
fat: fix incorrect function comment
Documentation: ABI: remove testing/sysfs-devices-node
proc: fix inconsistent lock state
linux/kernel.h: fix DIV_ROUND_CLOSEST with unsigned divisors
memcg: don't register hotcpu notifier from ->css_alloc()
checkpatch: warn on uapi #includes that #include <uapi/...
revert "rtc: recycle id when unloading a rtc driver"
mm: clean up transparent hugepage sysfs error messages
hfsplus: add error message for the case of failure of sync fs in delayed_sync_fs() method
hfsplus: rework processing of hfs_btree_write() returned error
hfsplus: rework processing errors in hfsplus_free_extents()
hfsplus: avoid crash on failed block map free
kcmp: include linux/ptrace.h
drivers/rtc/rtc-imxdi.c: must include <linux/spinlock.h>
mm: cma: WARN if freed memory is still in use
exec: do not leave bprm->interp on stack
Pull VFS update from Al Viro:
"fscache fixes, ESTALE patchset, vmtruncate removal series, assorted
misc stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (79 commits)
vfs: make lremovexattr retry once on ESTALE error
vfs: make removexattr retry once on ESTALE
vfs: make llistxattr retry once on ESTALE error
vfs: make listxattr retry once on ESTALE error
vfs: make lgetxattr retry once on ESTALE
vfs: make getxattr retry once on an ESTALE error
vfs: allow lsetxattr() to retry once on ESTALE errors
vfs: allow setxattr to retry once on ESTALE errors
vfs: allow utimensat() calls to retry once on an ESTALE error
vfs: fix user_statfs to retry once on ESTALE errors
vfs: make fchownat retry once on ESTALE errors
vfs: make fchmodat retry once on ESTALE errors
vfs: have chroot retry once on ESTALE error
vfs: have chdir retry lookup and call once on ESTALE error
vfs: have faccessat retry once on an ESTALE error
vfs: have do_sys_truncate retry once on an ESTALE error
vfs: fix renameat to retry on ESTALE errors
vfs: make do_unlinkat retry once on ESTALE errors
vfs: make do_rmdir retry once on ESTALE errors
vfs: add a flags argument to user_path_parent
This file is already documented in the stable ABI (see commit
5bbe1ec11fcf).
Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com>
Cc: Greg KH <greg@kroah.com>
Remove the documentation for capability.disable. The code supporting
this parameter was removed with commit 5915eb53861c ("security: remove
dummy module")
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Miklos Szeredi <mszeredi@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into for-linus
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Pull nfsd update from Bruce Fields:
"Included this time:
- more nfsd containerization work from Stanislav Kinsbursky: we're
not quite there yet, but should be by 3.9.
- NFSv4.1 progress: implementation of basic backchannel security
negotiation and the mandatory BACKCHANNEL_CTL operation. See
http://wiki.linux-nfs.org/wiki/index.php/Server_4.0_and_4.1_issues
for remaining TODO's
- Fixes for some bugs that could be triggered by unusual compounds.
Our xdr code wasn't designed with v4 compounds in mind, and it
shows. A more thorough rewrite is still a todo.
- If you've ever seen "RPC: multiple fragments per record not
supported" logged while using some sort of odd userland NFS client,
that should now be fixed.
- Further work from Jeff Layton on our mechanism for storing
information about NFSv4 clients across reboots.
- Further work from Bryan Schumaker on his fault-injection mechanism
(which allows us to discard selective NFSv4 state, to excercise
rarely-taken recovery code paths in the client.)
- The usual mix of miscellaneous bugs and cleanup.
Thanks to everyone who tested or contributed this cycle."
* 'for-3.8' of git://linux-nfs.org/~bfields/linux: (111 commits)
nfsd4: don't leave freed stateid hashed
nfsd4: free_stateid can use the current stateid
nfsd4: cleanup: replace rq_resused count by rq_next_page pointer
nfsd: warn on odd reply state in nfsd_vfs_read
nfsd4: fix oops on unusual readlike compound
nfsd4: disable zero-copy on non-final read ops
svcrpc: fix some printks
NFSD: Correct the size calculation in fault_inject_write
NFSD: Pass correct buffer size to rpc_ntop
nfsd: pass proper net to nfsd_destroy() from NFSd kthreads
nfsd: simplify service shutdown
nfsd: replace boolean nfsd_up flag by users counter
nfsd: simplify NFSv4 state init and shutdown
nfsd: introduce helpers for generic resources init and shutdown
nfsd: make NFSd service structure allocated per net
nfsd: make NFSd service boot time per-net
nfsd: per-net NFSd up flag introduced
nfsd: move per-net startup code to separated function
nfsd: pass net to __write_ports() and down
nfsd: pass net to nfsd_set_nrthreads()
Provide a proper invalidation method rather than relying on the netfs retiring
the cookie it has and getting a new one. The problem with this is that isn't
easy for the netfs to make sure that it has completed/cancelled all its
outstanding storage and retrieval operations on the cookie it is retiring.
Instead, have the cache provide an invalidation method that will cancel or wait
for all currently outstanding operations before invalidating the cache, and
will cause new operations to queue up behind that. Whilst invalidation is in
progress, some requests will be rejected until the cache can stack a barrier on
the operation queue to cause new operations to be deferred behind it.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph update from Sage Weil:
"There are a few different groups of commits here. The largest is
Alex's ongoing work to enable the coming RBD features (cloning,
striping). There is some cleanup in libceph that goes along with it.
Cyril and David have fixed some problems with NFS reexport (leaking
dentries and page locks), and there is a batch of patches from Yan
fixing problems with the fs client when running against a clustered
MDS. There are a few bug fixes mixed in for good measure, many of
which will be going to the stable trees once they're upstream.
My apologies for the late pull. There is still a gremlin in the rbd
map/unmap code and I was hoping to include the fix for that as well,
but we haven't been able to confirm the fix is correct yet; I'll send
that in a separate pull once it's nailed down."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (68 commits)
rbd: get rid of rbd_{get,put}_dev()
libceph: register request before unregister linger
libceph: don't use rb_init_node() in ceph_osdc_alloc_request()
libceph: init event->node in ceph_osdc_create_event()
libceph: init osd->o_node in create_osd()
libceph: report connection fault with warning
libceph: socket can close in any connection state
rbd: don't use ENOTSUPP
rbd: remove linger unconditionally
rbd: get rid of RBD_MAX_SEG_NAME_LEN
libceph: avoid using freed osd in __kick_osd_requests()
ceph: don't reference req after put
rbd: do not allow remove of mounted-on image
libceph: Unlock unprocessed pages in start_read() error path
ceph: call handle_cap_grant() for cap import message
ceph: Fix __ceph_do_pending_vmtruncate
ceph: Don't add dirty inode to dirty list if caps is in migration
ceph: Fix infinite loop in __wake_requests
ceph: Don't update i_max_size when handling non-auth cap
bdi_register: add __printf verification, fix arg mismatch
Fix the state management of internal fscache operations and the accounting of
what operations are in what states.
This is done by:
(1) Give struct fscache_operation a enum variable that directly represents the
state it's currently in, rather than spreading this knowledge over a bunch
of flags, who's processing the operation at the moment and whether it is
queued or not.
This makes it easier to write assertions to check the state at various
points and to prevent invalid state transitions.
(2) Add an 'operation complete' state and supply a function to indicate the
completion of an operation (fscache_op_complete()) and make things call
it. The final call to fscache_put_operation() can then check that an op
in the appropriate state (complete or cancelled).
(3) Adjust the use of object->n_ops, ->n_in_progress, ->n_exclusive to better
govern the state of an object:
(a) The ->n_ops is now the number of extant operations on the object
and is now decremented by fscache_put_operation() only.
(b) The ->n_in_progress is simply the number of objects that have been
taken off of the object's pending queue for the purposes of being
run. This is decremented by fscache_op_complete() only.
(c) The ->n_exclusive is the number of exclusive ops that have been
submitted and queued or are in progress. It is decremented by
fscache_op_complete() and by fscache_cancel_op().
fscache_put_operation() and fscache_operation_gc() now no longer try to
clean up ->n_exclusive and ->n_in_progress. That was leading to double
decrements against fscache_cancel_op().
fscache_cancel_op() now no longer decrements ->n_ops. That was leading to
double decrements against fscache_put_operation().
fscache_submit_exclusive_op() now decides whether it has to queue an op
based on ->n_in_progress being > 0 rather than ->n_ops > 0 as the latter
will persist in being true even after all preceding operations have been
cancelled or completed. Furthermore, if an object is active and there are
runnable ops against it, there must be at least one op running.
(4) Add a remaining-pages counter (n_pages) to struct fscache_retrieval and
provide a function to record completion of the pages as they complete.
When n_pages reaches 0, the operation is deemed to be complete and
fscache_op_complete() is called.
Add calls to fscache_retrieval_complete() anywhere we've finished with a
page we've been given to read or allocate for. This includes places where
we just return pages to the netfs for reading from the server and where
accessing the cache fails and we discard the proposed netfs page.
The bugs in the unfixed state management manifest themselves as oopses like the
following where the operation completion gets out of sync with return of the
cookie by the netfs. This is possible because the cache unlocks and returns
all the netfs pages before recording its completion - which means that there's
nothing to stop the netfs discarding them and returning the cookie.
FS-Cache: Cookie 'NFS.fh' still has outstanding reads
kernel BUG at fs/fscache/cookie.c:519!
invalid opcode: 0000 [#1] SMP
CPU 1
Modules linked in: cachefiles nfs fscache auth_rpcgss nfs_acl lockd sunrpc
Pid: 400, comm: kswapd0 Not tainted 3.1.0-rc7-fsdevel+ #1090 /DG965RY
RIP: 0010:[<ffffffffa007050a>] [<ffffffffa007050a>] __fscache_relinquish_cookie+0x170/0x343 [fscache]
RSP: 0018:ffff8800368cfb00 EFLAGS: 00010282
RAX: 000000000000003c RBX: ffff880023cc8790 RCX: 0000000000000000
RDX: 0000000000002f2e RSI: 0000000000000001 RDI: ffffffff813ab86c
RBP: ffff8800368cfb50 R08: 0000000000000002 R09: 0000000000000000
R10: ffff88003a1b7890 R11: ffff88001df6e488 R12: ffff880023d8ed98
R13: ffff880023cc8798 R14: 0000000000000004 R15: ffff88003b8bf370
FS: 0000000000000000(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000008ba008 CR3: 0000000023d93000 CR4: 00000000000006e0
Process kswapd0 (pid: 400, threadinfo ffff8800368ce000, task ffff88003b8bf040)
Stack:
ffff88003b8bf040 ffff88001df6e528 ffff88001df6e528 ffffffffa00b46b0
ffff88003b8bf040 ffff88001df6e488 ffff88001df6e620 ffffffffa00b46b0
ffff88001ebd04c8 0000000000000004 ffff8800368cfb70 ffffffffa00b2c91
Call Trace:
[<ffffffffa00b2c91>] nfs_fscache_release_inode_cookie+0x3b/0x47 [nfs]
[<ffffffffa008f25f>] nfs_clear_inode+0x3c/0x41 [nfs]
[<ffffffffa0090df1>] nfs4_evict_inode+0x2f/0x33 [nfs]
[<ffffffff810d8d47>] evict+0xa1/0x15c
[<ffffffff810d8e2e>] dispose_list+0x2c/0x38
[<ffffffff810d9ebd>] prune_icache_sb+0x28c/0x29b
[<ffffffff810c56b7>] prune_super+0xd5/0x140
[<ffffffff8109b615>] shrink_slab+0x102/0x1ab
[<ffffffff8109d690>] balance_pgdat+0x2f2/0x595
[<ffffffff8103e009>] ? process_timeout+0xb/0xb
[<ffffffff8109dba3>] kswapd+0x270/0x289
[<ffffffff8104c5ea>] ? __init_waitqueue_head+0x46/0x46
[<ffffffff8109d933>] ? balance_pgdat+0x595/0x595
[<ffffffff8104bf7a>] kthread+0x7f/0x87
[<ffffffff813ad6b4>] kernel_thread_helper+0x4/0x10
[<ffffffff81026b98>] ? finish_task_switch+0x45/0xc0
[<ffffffff813abcdd>] ? retint_restore_args+0xe/0xe
[<ffffffff8104befb>] ? __init_kthread_worker+0x53/0x53
[<ffffffff813ad6b0>] ? gs_change+0xb/0xb
Pull new F2FS filesystem from Jaegeuk Kim:
"Introduce a new file system, Flash-Friendly File System (F2FS), to
Linux 3.8.
Highlights:
- Add initial f2fs source codes
- Fix an endian conversion bug
- Fix build failures on random configs
- Fix the power-off-recovery routine
- Minor cleanup, coding style, and typos patches"
From the Kconfig help text:
F2FS is based on Log-structured File System (LFS), which supports
versatile "flash-friendly" features. The design has been focused on
addressing the fundamental issues in LFS, which are snowball effect
of wandering tree and high cleaning overhead.
Since flash-based storages show different characteristics according to
the internal geometry or flash memory management schemes aka FTL, F2FS
and tools support various parameters not only for configuring on-disk
layout, but also for selecting allocation and cleaning algorithms.
and there's an article by Neil Brown about it on lwn.net:
http://lwn.net/Articles/518988/
* tag 'for-3.8-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (36 commits)
f2fs: fix tracking parent inode number
f2fs: cleanup the f2fs_bio_alloc routine
f2fs: introduce accessor to retrieve number of dentry slots
f2fs: remove redundant call to f2fs_put_page in delete entry
f2fs: make use of GFP_F2FS_ZERO for setting gfp_mask
f2fs: rewrite f2fs_bio_alloc to make it simpler
f2fs: fix a typo in f2fs documentation
f2fs: remove unused variable
f2fs: move error condition for mkdir at proper place
f2fs: remove unneeded initialization
f2fs: check read only condition before beginning write out
f2fs: remove unneeded memset from init_once
f2fs: show error in case of invalid mount arguments
f2fs: fix the compiler warning for uninitialized use of variable
f2fs: resolve build failures
f2fs: adjust kernel coding style
f2fs: fix endian conversion bugs reported by sparse
f2fs: remove unneeded version.h header file from f2fs.h
f2fs: update the f2fs document
f2fs: update Kconfig and Makefile
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"A few new features this merge-window. The most important one is
probably, that dma-debug now warns if a dma-handle is not checked with
dma_mapping_error by the device driver. This requires minor changes
to some architectures which make use of dma-debug. Most of these
changes have the respective Acks by the Arch-Maintainers.
Besides that there are updates to the AMD IOMMU driver for refactor
the IOMMU-Groups support and to make sure it does not trigger a
hardware erratum.
The OMAP changes (for which I pulled in a branch from Tony Lindgren's
tree) have a conflict in linux-next with the arm-soc tree. The
conflict is in the file arch/arm/mach-omap2/clock44xx_data.c which is
deleted in the arm-soc tree. It is safe to delete the file too so
solve the conflict. Similar changes are done in the arm-soc tree in
the common clock framework migration. A missing hunk from the patch
in the IOMMU tree will be submitted as a seperate patch when the
merge-window is closed."
* tag 'iommu-updates-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (29 commits)
ARM: dma-mapping: support debug_dma_mapping_error
ARM: OMAP4: hwmod data: ipu and dsp to use parent clocks instead of leaf clocks
iommu/omap: Adapt to runtime pm
iommu/omap: Migrate to hwmod framework
iommu/omap: Keep mmu enabled when requested
iommu/omap: Remove redundant clock handling on ISR
iommu/amd: Remove obsolete comment
iommu/amd: Don't use 512GB pages
iommu/tegra: smmu: Move bus_set_iommu after probe for multi arch
iommu/tegra: gart: Move bus_set_iommu after probe for multi arch
iommu/tegra: smmu: Remove unnecessary PTC/TLB flush all
tile: dma_debug: add debug_dma_mapping_error support
sh: dma_debug: add debug_dma_mapping_error support
powerpc: dma_debug: add debug_dma_mapping_error support
mips: dma_debug: add debug_dma_mapping_error support
microblaze: dma-mapping: support debug_dma_mapping_error
ia64: dma_debug: add debug_dma_mapping_error support
c6x: dma_debug: add debug_dma_mapping_error support
ARM64: dma_debug: add debug_dma_mapping_error support
intel-iommu: Prevent devices with RMRRs from being placed into SI Domain
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull hwmon subsystem update from Jean Delvare:
"There are many improvements to the it87 driver, as well as suspend
support for the Winbond Super-I/O chips, and a few other fixes."
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon-vid: Add support for AMD family 11h to 15h processors
hwmon: (it87) Support PECI for additional chips
hwmon: (it87) Report thermal sensor type as Intel PECI if appropriate
hwmon: (it87) Manage device specific features with table
hwmon: (it87) Replace pwm group macro with direct attribute definitions
hwmon: (it87) Avoid quoted string splits across lines
hwmon: (it87) Save fan registers in 2-dimensional array
hwmon: (it87) Introduce support for tempX_offset sysfs attribute
hwmon: (it87) Replace macro defining tempX_type sensors with direct definitions
hwmon: (it87) Save voltage register values in 2-dimensional array
hwmon: (it87) Save temperature registers in 2-dimensional array
hwmon: (w83627ehf) Get rid of smatch warnings
hwmon: (w83627hf) Don't touch nonexistent I2C address registers
hwmon: (w83627ehf) Add support for suspend
hwmon: (w83627hf) Add support for suspend
hwmon: Fix PCI device reference leak in quirk
git://git.secretlab.ca/git/linux-2.6
Pull devicetree, gpio and spi bugfixes from Grant Likely:
"Device tree v3.8 bug fix:
- Fixes an undefined struct device build error and a missing symbol
export.
GPIO device driver bug fixes:
- gpio/mvebu-gpio: Make mvebu-gpio depend on OF_CONFIG
- gpio/ich: Add missing spinlock init
SPI device driver bug fixes:
- Most of this is bug fixes to the core code and the sh-hspi and
s3c64xx device drivers.
- There is also a patch here to add DT support to the Atmel driver.
This one should have been in the first round, but I missed it.
It's a low risk change contained within a single driver and the
Atmel maintainer has requested it."
* tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6:
of: define struct device in of_platform.h if !OF_DEVICE and !OF_ADDRESS
of: Fix export of of_find_matching_node_and_match()
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6:
* tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6:
spi/sh-hspi: fix return value check in hspi_probe().
spi: fix tegra SPI binding examples
spi/atmel: add DT support
of/spi: Fix SPI module loading by using proper "spi:" modalias prefixes.
spi: Change FIFO flush operation and spi channel off
spi: Keep chipselect assertion during one message
This adds OF support for davinci_wdt driver.
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
IT8721 and IT8728 support Intel PECI temperature reporting. Each sensor
can be programmed to display the temperature reported on the PECI interface.
If configured for Intel PECI, the driver reported the wrong sensor type for
the respective thermal sensor. Fix the code to correctly report it as
"Intel PECI (6)".
Pull Xtensa patchset from Chris Zankel:
"This contains support of device trees, many fixes, and code clean-ups"
* tag 'xtensa-20121218' of git://github.com/czankel/xtensa-linux: (33 commits)
xtensa: don't try to build DTB when OF is disabled
xtensa: set the correct ethernet address for xtfpga
xtensa: clean up files to make them code-style compliant
xtensa: provide endianness macro for sparse
xtensa: fix RASID SR initialization
xtensa: initialize CPENABLE SR when core has one
xtensa: reset all timers on initialization
Use for_each_compatible_node() macro.
xtensa: add XTFPGA DTS
xtensa: add support for the XTFPGA boards
xtensa: add device trees support
xtensa: add IRQ domains support
xtensa: add U-Boot image support (uImage).
xtensa: clean up boot make rules
xtensa: fix mb and wmb definitions
xtensa: add s32c1i-based spinlock implementations
xtensa: add s32c1i-based bitops implementations
xtensa: add s32c1i-based atomic ops implementations
xtensa: add s32c1i sanity check
xtensa: add trap_set_handler function
Pull small x86 fixes from Peter Anvin:
"A collection of very small fixes, mostly pure documentation."
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, doc: Document that bootloader ID 4 is used also by iPXE
x86, doc: Add a formal bootloader ID for kexec-tools
x86, 8042: Enable A20 using KBC to fix S3 resume on some MSI laptops
Pull MTD updates from David Woodhouse:
- Various cleanups especially in NAND tests
- Add support for NAND flash on BCMA bus
- DT support for sh_flctl and denali NAND drivers
- Kill obsolete/superceded drivers (fortunet, nomadik_nand)
- Fix JFFS2 locking bug in ENOMEM failure path
- New SPI flash chips, as usual
- Support writing in 'reliable mode' for DiskOnChip G4
- Debugfs support in nandsim
* tag 'for-linus-20121219' of git://git.infradead.org/linux-mtd: (96 commits)
mtd: nand: typo in nand_id_has_period() comments
mtd: nand/gpio: use io{read,write}*_rep accessors
mtd: block2mtd: throttle writes by calling balance_dirty_pages_ratelimited.
mtd: nand: gpmi: reset BCH earlier, too, to avoid NAND startup problems
mtd: nand/docg4: fix and improve read of factory bbt
mtd: nand/docg4: reserve bb marker area in ecclayout
mtd: nand/docg4: add support for writing in reliable mode
mtd: mxc_nand: reorder part_probes to let cmdline override other sources
mtd: mxc_nand: fix unbalanced clk_disable() in error path
mtd: nandsim: Introduce debugfs infrastructure
mtd: physmap_of: error checking to prevent a NULL pointer dereference
mtg: docg3: potential divide by zero in doc_write_oob()
mtd: bcm47xxnflash: writing support
mtd: tests/read: initialize buffer for whole next page
mtd: at91: atmel_nand: return bit flips for the PMECC read_page()
mtd: fix recovery after failed write-buffer operation in cfi_cmdset_0002.c
mtd: nand: onfi need to be probed in 8 bits mode
mtd: nand: add NAND_BUSWIDTH_AUTO to autodetect bus width
mtd: nand: print flash size during detection
mted: nand_wait_ready timeout fix
Pull pwm changes from Thierry Reding:
"A new driver has been added for the SPEAr platform and the
TWL4030/6030 driver has been replaced by two drivers that control the
regular PWMs and the PWM driven LEDs provided by the chips.
The vt8500, tiecap, tiehrpwm, i.MX, LPC32xx and Samsung drivers have
all been improved and the device tree bindings now support the PWM
signal polarity."
Fix up trivial conflicts due to __devinit/exit removal.
* tag 'for-3.8-rc1' of git://gitorious.org/linux-pwm/linux-pwm: (21 commits)
pwm: samsung: add missing s3c->pwm_id assignment
pwm: lpc32xx: Set the chip base for dynamic allocation
pwm: lpc32xx: Properly disable the clock on device removal
pwm: lpc32xx: Fix the PWM polarity
pwm: i.MX: eliminate build warning
pwm: Export of_pwm_xlate_with_flags()
pwm: Remove pwm-twl6030 driver
pwm: New driver to support PWM driven LEDs on TWL4030/6030 series of PMICs
pwm: New driver to support PWMs on TWL4030/6030 series of PMICs
pwm: pwm-tiehrpwm: pinctrl support
pwm: tiehrpwm: Add device-tree binding
pwm: pwm-tiehrpwm: Adding TBCLK gating support.
pwm: pwm-tiecap: pinctrl support
pwm: tiecap: Add device-tree binding
pwm: Add TI PWM subsystem driver
pwm: Device tree support for PWM polarity
pwm: vt8500: Ensure PWM clock is enabled during pwm_config
pwm: vt8500: Fix build error
pwm: spear: Staticize spear_pwm_config()
pwm: Add SPEAr PWM chip driver support
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"Nothing all that exciting; a new module-from-fd syscall for those who
want to verify the source of the module (ChromeOS) and/or use standard
IMA on it or other security hooks."
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
MODSIGN: Fix kbuild output when using default extra_certificates
MODSIGN: Avoid using .incbin in C source
modules: don't hand 0 to vmalloc.
module: Remove a extra null character at the top of module->strtab.
ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants
ASN.1: Define indefinite length marker constant
moduleparam: use __UNIQUE_ID()
__UNIQUE_ID()
MODSIGN: Add modules_sign make target
powerpc: add finit_module syscall.
ima: support new kernel module syscall
add finit_module syscall to asm-generic
ARM: add finit_module syscall to ARM
security: introduce kernel_module_from_file hook
module: add flags arg to sys_finit_module()
module: add syscall to load module from fd
Fix name of slink binding and address of sflash example to make it
self consistent.
Signed-off-by: Allen Martin <amartin@nvidia.com>
In order to use S32C1I instruction on cores with ATOMCTL SR the register
must be properly initialized.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: Chris Zankel <chris@zankel.net>
Pull i2c-embedded changes from Wolfram Sang:
- CBUS driver (an I2C variant)
- continued rework of the omap driver
- s3c2410 gets lots of fixes and gains pinctrl support
- at91 gains DMA support
- the GPIO muxer gains devicetree probing
- typical fixes and additions all over
* 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (45 commits)
i2c: omap: Remove the OMAP_I2C_FLAG_RESET_REGS_POSTIDLE flag
i2c: at91: add dma support
i2c: at91: change struct members indentation
i2c: at91: fix compilation warning
i2c: mxs: Do not disable the I2C SMBus quick mode
i2c: mxs: Handle i2c DMA failure properly
i2c: s3c2410: Remove recently introduced performance overheads
i2c: ocores: Move grlib set/get functions into #ifdef CONFIG_OF block
i2c: s3c2410: Add fix for i2c suspend/resume
i2c: s3c2410: Fix code to free gpios
i2c: i2c-cbus-gpio: introduce driver
i2c: ocores: Add support for the GRLIB port of the controller and use function pointers for getreg and setreg functions
i2c: ocores: Add irq support for sparc
i2c: omap: Move the remove constraint
ARM: dts: cfa10049: Add the i2c muxer buses to the CFA-10049
i2c: s3c2410: do not special case HDMIPHY stuck bus detection
i2c: s3c2410: use exponential back off while polling for bus idle
i2c: s3c2410: do not generate STOP for QUIRK_HDMIPHY
i2c: s3c2410: grab adapter lock while changing i2c clock
i2c: s3c2410: Add support for pinctrl
Merge patches from Andrew Morton:
"Most of the rest of MM, plus a few dribs and drabs.
I still have quite a few irritating patches left around: ones with
dubious testing results, lack of review, ones which should have gone
via maintainer trees but the maintainers are slack, etc.
I need to be more activist in getting these things wrapped up outside
the merge window, but they're such a PITA."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (48 commits)
mm/vmscan.c: avoid possible deadlock caused by too_many_isolated()
vmscan: comment too_many_isolated()
mm/kmemleak.c: remove obsolete simple_strtoul
mm/memory_hotplug.c: improve comments
mm/hugetlb: create hugetlb cgroup file in hugetlb_init
mm/mprotect.c: coding-style cleanups
Documentation: ABI: /sys/devices/system/node/
slub: drop mutex before deleting sysfs entry
memcg: add comments clarifying aspects of cache attribute propagation
kmem: add slab-specific documentation about the kmem controller
slub: slub-specific propagation changes
slab: propagate tunable values
memcg: aggregate memcg cache values in slabinfo
memcg/sl[au]b: shrink dead caches
memcg/sl[au]b: track all the memcg children of a kmem_cache
memcg: destroy memcg caches
sl[au]b: allocate objects from memcg cache
sl[au]b: always get the cache from its page in kmem_cache_free()
memcg: skip memcg kmem allocations in specified code regions
memcg: infrastructure to match an allocation to the right cache
