Use the standard sys_soc interface to expose the SoC UID information.
e.g.
~# cat /sys/bus/soc/devices/soc0/machine
NVIDIA Tegra
~# cat /sys/bus/soc/devices/soc0/family
NVIDIA Tegra30
~# cat /sys/bus/soc/devices/soc0/revision
A03
~# cat /sys/bus/soc/devices/soc0/soc_id
98317451306464792
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Parse and handle fbmem2 cmdline parameter.
bug 1175957
Change-Id: I0933825371bf13782e9f4364a4dba078929ae836
Signed-off-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/170662
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Add tegra_clear_framebuffer function.
bug 1175957
Change-Id: I12c249e011ecd839bbe9c5371b8be6e8a4b27bba
Reviewed-on: http://git-master/r/170661
arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
Clean-up some of the early clock initialisation hacks.
Merge with latest NVIDIA L4T R16.
Only real conflict concerning inverted VBUS gpio support.
This is an alternate way to have the L2 disabled available with
later TL secureos versions.
In this version, the sleep CPU SMC which is the last one issued
before entering LP2 on CPU0, will also disable the L2 without a
flush of the secureos workspace.
Change-Id: I61c3caade6cb6f922b9d9f9ca0739bc6ae4e78cd
Signed-off-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Reviewed-on: http://git-master/r/128951
Reviewed-by: James Zhao <jamesz@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
In Tegra kernel L2 is disabled only upon CPU cluster power down,
e.g. LP2 entry. Flushing L2 upon every LP2 entry is costly.
Since we are always in single core mode upon cluster power down
we can safely omit L2 flush upon L2 disable.
Change-Id: I27542b11e6133f3192a02440e5b14ea408b860fd
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-on: http://git-master/r/105625
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
For the CONFIG_TRUSTED_FOUNDATION code paths, differentiate L2
enable vs. reenable, which are different SMCs (won't trigger an
invalidate in the case of a reenable).
On an L2 disable SMC, optionally pass a 0 for the L2 ways arg,
which skips the full clean/invalidate (and simply just disabled
the L2).
In order to safely skip flushing the L2 on the disable, we have
to be careful what we dirty from the type we flush the L1 and
disable the L2.
Bug 939415
Signed-off-by: Chris Johnson<cwj@nvidia.com>
Change-Id: I756d2ceda83d5d8d6bc5670218e9d874d5e5f62a
Reviewed-on: http://git-master/r/119786
Reviewed-by: Simone Willett <swillett@nvidia.com>
Read board_info data from device tree instead of ATAGs,
if we're booting with device tree.
Bug 1001225
Change-Id: I2d659252a6a91f723bf4bb6c74918774650b87e2
Original-Author: Dan Willemsen <dwillemsen@nvidia.com>
Signed-off-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-on: http://git-master/r/116604
Set SCLK floor to 80MHz for Tegra3 CPU mode switch.
Bug 933984
Change-Id: Ibbb0a24cd763c11b3cead60efe26096bae3e6ddd
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/106035
Reviewed-by: Prajakta Gudadhe <pgudadhe@nvidia.com>
Tested-by: Jay Cheng <jacheng@nvidia.com>
(cherry picked from commit 842f7ddb7a188e36a2ff153dc0d8ed38b5e28319)
Reviewed-on: http://git-master/r/113981
Support fbmem in addition to tegra_fbmem kernel argument for backwards compatibility reason.
Support nvmem kernel argument for carveout definition to be backward compatible.
Add special handling in case of already reserved fbmem/nvmem.
It fixes the issue where cpu governor change
was inconsistent across platforms.
In T2x, AUTO HOTPLUG is disabled therefore we need
to store/restore gov for all online cpus across
LP0 cycle.
In T3x, AUTO HOTPLUG is enabled therefore storing/restoring
gov for Cpu0 across LP0 cycle. Cpu0 remains online in suspend
and resume.
bug 991081
Change-Id: I167654aa21e4832b3fdc40e3d388a4d3f984632b
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: http://git-master/r/105404
Warnings removed are related to unused variables/labels,
structure/argument type mismatch, copyright update, function return
type mismatch and wrong C coding style.
Bug 949219
Change-Id: Ib748d12d5ab3cfc35118be28c29983081cca6cbb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/103770
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Older code sets "conservative" governor in early-suspend
using sysfs entries.This implementation changes governor
in early-suspend using cpufreq interfaces.
bug 871958
Change-Id: I721afb6184982a063dc5f330da31f8fb88481cfd
Reviewed-on: http://git-master/r/100849
Bug 947861
Change-Id: Ib4ce7bfa3624562a766678a2ef20ebdcd3055d89
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/100462
Reviewed-by: Bo Yan <byan@nvidia.com>
If bootloader specify that marvell wifi chip is
present on the board, then create marvell wifi device,
else create broadcom wifi device.
Bug 954218
Change-Id: Ia0515e70b6d4b239a165b8d8629e3b90c19666b6
Signed-off-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-on: http://git-master/r/98490
Moved SCLK shared users initialization from silicon only section
of init table to common silicon/emulation section - there is no
reason to limit this settings to silicon only.
Change-Id: Ib1aa1bd3f98008b6584222e6c49f0825d635b8bd
Reviewed-on: http://git-master/r/98104
Bug 949219
Change-Id: I875f8688a272c415ebf345b8f30e4afdf7551b29
Reviewed-on: http://git-master/r/91523
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Remove CONFIG_TEGRA_SMMU_BASE_AT_E0000000 workaround as T30 A01 is no
longer supported.
Change-Id: I0ba6c838984e3c3ec401057925727c9596a8075f
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/95644
- Moved table entries for always running core clocks on the top of
the table (this way we guarantee that changing parent of such clock
down the road would automatically enable new parent).
- Removed unnecessary pll_a and pll_a_out0 entries (effectively they
are "NOP") - actual audio configuration is done in per-board tables.
- Removed unnecessary pll_c and pll_c_out1 entries for emulation
platforms
Change-Id: I8327d6313804419405dd93af08f369db02fcbf25
Reviewed-on: http://git-master/r/95465
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-by: Wen Yi <wyi@nvidia.com>
Change the minimal rate of sclk to 12 MHz and set the lowest
frequency of sbus to be 40 MHz when display is on.
bug 939415
Original change http://git-master/r/#change,76959
Change-Id: I81cda6a95494764721c1be5b4001c476f3aed6ab
Signed-off-by: Amit Kamath <akamath@nvidia.com>
Reviewed-on: http://git-master/r/93850
Configure PLLC on emulation platforms after SCLK is switched to PLLP.
This would avoid failure in case when emulation initialization script
set PLLC as SCLK source.
Change-Id: Ie0f48c066f6df7f6f3c67858de7e9d7608dcb7ff
Reviewed-on: http://git-master/r/93730
Reviewed-by: Hoang Pham <hopham@nvidia.com>
Based on command line parameter, override the sku
Bug 925878
Signed-off-by: Ray Poudrier <rapoudrier@nvidia.com>
Reviewed-on: http://git-master/r/83241
(cherry picked from commit 24df2878418fc0c5f2b2dd20130df91a23dd042e)
Change-Id: Ic8d2408c6e408fcf28f9b64f12866971b753b41e
Reviewed-on: http://git-master/r/88864
With this change, we can identify if system
enters RCK mode in kernel.
Bug 948270
Change-Id: I4240fd4171b6b71fbc5f1271f21a588d62db88b1
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/90914
Setting pll_p init state to false may cause lp0 resume issue when
cpu_restore_complex tries to restore pll_p state on CPU cluster
switching.
Bug 932820
Signed-off-by: Peter Zu <pzu@nvidia.com>
Reviewed-on: http://git-master/r/86904
(cherry picked from commit 939e6c177927a4731b043ac77543f075ac17fca2)
Change-Id: I4513470515a20edcf54a9aa11a54e65838012fe5
Reviewed-on: http://git-master/r/90568
Tested-by: Gerrit_Virtual_Submit
Setting sclk frequency for spi to 40MHz.
bug 949393
Reviewed-on: http://git-master/r/89525
cherry-picked from
171f5693e4137e9fe5a8b4e496c0c5db3b7838f1
Change-Id: I34808a64b834111dfff1592dd9244a45e9d3312c
Reviewed-on: http://git-master/r/90295
Bug 952455
Change-Id: I5272bdf2fc726994f3a22fd42671bb807bc30a21
Signed-off-by: Tom Cherry <tcherry@nvidia.com>
Reviewed-on: http://git-master/r/89875
Set SCRATCH0 bit 1 when forced-recovery is set.
Bootrom will check this and put device into nvflash mode.
Bug 948326
Signed-off-by: Gaurav Sarode <gsarode@nvidia.com>
Change-Id: I78108021dffda681d63ddc6760e07cb563ba2eac
Reviewed-on: http://git-master/r/87238
Reviewed-by: Vivek Kumar <vivekk@nvidia.com>
Reviewed-by: Hon Fei Chong <hchong@nvidia.com>
PMC SCRATCH register 0 holds value across warmboot.
Storing values in bit31:30 for recovery and fastboot.
This requires change in bootloader as well to parse these arguments.
Bug 863014
Change-Id: I1d4b752dbc6dd7b065e9d0cc87df189e7caeb201
Reviewed-on: http://git-master/r/86140
Moving clock source rate initialisation of debug ports in
common place from board files.
In this way, it does not need to call the same function from
all board files and so avoid duplicating.
Change-Id: I4e0292c7760488125c0dd8ee5fa23f50faca3436
Reviewed-on: http://git-master/r/85174
This reverts commit a61ef84d7746134aae316fa76867d69fc0753880.
Bug 939415
Change-Id: I7d7c2a69ac7261a221cf69b8f8981d42f575f789
Signed-off-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Reviewed-on: http://git-master/r/84025
Change-Id: I9862e73f264c757f97aaad03f3373fb1d3e95462
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/79138
Source coresite clock from clk_m and reduce its frequency
to 1Mhz to reduce the power consumption on csite module.
BUG 922351
Signed-off-by: ScottPeterson <speterson@nvidia.com>
Reviewed-on: http://git-master/r/76287
(cherry picked from commit 80c11f4c789efea49b30b8731711aa4c20d7630c)
Change-Id: If8a75924229c8d6aae4fd449eff6ae2e194a6e45
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/79995
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Bug 922351
Reviewed-on: http://git-master/r/78310
Change-Id: I4d1a341386b10c584715d2bbb76ac69877b47fb7
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-on: http://git-master/r/78904
Bug 841336
Reviewed-on: http://git-master/r/76912
Change-Id: I2806c8e4f08af49edf57f00a43438b1503d6aedb
Reviewed-on: http://git-master/r/78706
BUG 922351
Reviewed-on: http://git-master/r/76959
Change-Id: I6a2871d1cc02a19829cf397e9583122e02255f81
Signed-off-by: Wen Yi <wyi@nvidia.com>
Reviewed-on: http://git-master/r/78010
Added clock for memory path selection module (MSelect) to Tegra3
peripheral clocks. Initialized MSelect clock rate to 102MHz.
Reviewed-on: http://git-master/r/76484
Change-Id: I73676882d8e6805445985b23257bcf6410e8c3e0
Reviewed-on: http://git-master/r/77766
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Clock audio from clkm as
a pre-condition of disabling pllp_out1 and plla
when I2S is in slave mode.
Change-Id: I1706c2989cf7ad9045526ceba3326777b702868a
Reviewed-on: http://git-master/r/76391
Change-Id: I243508cc553ebf22bb5594a9461019abfec24b65
Reviewed-on: http://git-master/r/77753
Use the parameter name and value to set to the conservative
governor.
Also defined the value of freq_step to be 3 and set it during
early suspension.
Bug 922351
Reviewed-on: http://git-master/r/73841
Change-Id: Ieefa487f8b255d4bf242a7d98b07dc3758a70e86
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/77743
Disable unused pll_p_out clocks until they are
needed to reduce power.
Reviewed-on: http://git-master/r/76778
Change-Id: I16dba325fff48cc895ec115f3a4124a1d7228cee
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/77736
Tegra3 platform may boot with one of the predefined fixed PLLP
(peripheral PLL) output rates: 216MHz, 408MHz, or 204MHz. This
commit implements auto-detection of PLLP rate, as well as CPU,
and system bus PLLP dependencies configuration during clock tree
initialization.
Bug 928260
Change-Id: I65ea4db2e5cfe96f13566c93e882a3be9deaa129
Reviewed-on: http://git-master/r/75850
Reviewed-on: http://git-master/r/77295
cleanup ram console related source codes and move most of the
implementation in board files to common.c since ram console is a common
debug mechanism.
bug 873307
Signed-off-by: Haley Teng <hteng@nvidia.com>
Reviewed-on: http://git-master/r/54598
Reviewed-on: http://git-master/r/66588
(cherry picked from commit 119ce36b7bed370a528dfebc80bd79698118248d)
Change-Id: I8b769b422305101a97f1fbc99db4af48dc7d4f25
Reviewed-on: http://git-master/r/71961
Reviewed-on: http://git-master/r/74552
This is the preparation the following patches so that this header can
be referred from another directly than "arch/arm/mach-tegra".
Change-Id: I846970f306ff3daa8229e10e6f33b8e9fcf57cf9
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/73947
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Change-Id: I60c2a7ca50a957f23ca20ec559dbbb1aa26ca797
Reviewed-on: http://git-master/r/72464
HOTPLUG_CPU option is enabled for both Tegra20 and Tegra30.
For Tegra20, need to switch governor for both CPUs.
Use TERA_AUTO_HOTPLUG config which is enabled only for Tegra30.
Bug 909096
Change-Id: I683079d834f137bb84ff2d3bdb853dac826038d6
Reviewed-on: http://git-master/r/72127
The cpufreq sysfs entry for cpus other than cpu0 in T30 is
populated when the cpu becomes online and removed when the cpu
becomes offline. This caused race condition between setting cpu
governor and bringing cpu offline. The solution is to change
the governor for cpu0 only.
BUG 914009
Signed-Off by: Karthik Ramakrishnan <karthikr@nvidia.com>
Cherry-picked from: http://git-master/r/#change,50155
Change-Id: Ia604169f2a211083803f161d1e28bc0e3ca80ab2
Reviewed-on: http://git-master/r/70213
Tested-by: Sang-Hun Lee <sanlee@nvidia.com>
1. Tell the kernel the pointers from within the kernel address
space are safe before accessing the file. Save/restore current
process address before/after the file accessing.
2. Use macro IS_ERR to check file opening is successful or not
because filp_open() returns negtive value once error happens.
bug 865113
bug 917684
Reviewed-on: http://git-master/r/48788
(cherry picked from commit 76d0a832b0fb8c5c6446f9c86ccc743701ff704e)
Change-Id: Ie96152396f93a49babe848041feca354c6dfce50
Signed-off-by: Roger Hsieh <rhsieh@nvidia.com>
Reviewed-on: http://git-master/r/71152
