Copy operating points from imx7d.dtsi removing unsupported 1.2 ghz one.
This fixes the following run time error:
[ 2.002793] DCDC2: unsupportable voltage range: 1225000-1100000uV
[ 2.010618] DCDC2: unsupportable voltage range: 1225000-1100000uV
[ 2.018391] cpu cpu0: failed to scale vddarm up: -22
[ 2.025083] cpufreq: __target_index: Failed to change cpu frequency: -22
Add mandatory 800 MHz operating point without which the system will
freeze upon entering user space during boot.
Add support for Aster Carrier Board with Colibri iMX6.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Add a new pin group just for GPIO5_IO04 pin at the module level.
Add this new group to pinctrl-0 in iomuxc by default at module level
and overwrite it at Aster carrier board level without new pingroup.
This is required so this pin is muxed as GPIO at module level but
can be used by SPI driver as chip select for Aster carrier board on
RPi header X20.
Prepare for snapd integration.
toradex_4.1-2.0.x-imx-next
arch/arm/boot/dts/imx7d.dtsi
arch/arm/mach-imx/busfreq-imx.c
arch/arm/mach-imx/imx_rpmsg.c
drivers/mmc/host/sdhci-esdhc-imx.c
Parts moved to:
arch/arm/boot/dts/imx7s.dtsi
Note: This also includes NXP's latest rel_imx_4.1.15_2.1.0_ga.
The USDHC instance 1 is powered with a separate rail. This
allows to switch voltage of the SD card signals for higher
speed modes such as UHS-I. The reset state of that rail is
enabled and 3.3V.
Revision before Colibri iMX7S V1.1C and iMX7D V1.1D had
that rail connected to +3.3V rail switchable with a PMIC
GPIO which turned out to be not controllable in regular
run mode and to LDO2.
Colibri iMX7S V1.1C and iMX7D V1.1D and later connect it
to the PMIC LDO2 only, which allows to control the voltage
directly.
This change explicitly assigning the PMIC regulator which
allows the SDHC driver code to control the SD card voltage
and hence negotiate higher speeds for SD cards capable of
UHS-I or later. Note that the carrier board device tree
needs to be adjusted too (see comments at the usdhc1 node)
and the carrier board should have no pull-ups populated.
Add support for Aster Carrier Board with Colibri iMX7.
Add a new hoggrp just for GPIO4_IO23 pin at the module level.
level and overwrite it at Aster carrier board level without the
new hoggrp-6. This is required so this pin is muxed as GPIO at
module level but can be used by SPI driver as chip select for
Aster carrier board on RPi header X20.
Linux 4.1.41
* tag 'v4.1.41': (473 commits)
Linux 4.1.41
mm/huge_memory.c: respect FOLL_FORCE/FOLL_COW for thp
xc2028: Fix use-after-free bug properly
iio: proximity: as3935: fix as3935_write
ipx: call ipxitf_put() in ioctl error path
sched/fair: Initialize throttle_count for new task-groups lazily
sched/fair: Do not announce throttled next buddy in dequeue_task_fair()
iio: dac: ad7303: fix channel description
mwifiex: pcie: fix cmd_buf use-after-free in remove/reset
rtlwifi: rtl8821ae: setup 8812ae RFE according to device type
ARM: tegra: paz00: Mark panel regulator as enabled on boot
fs/xattr.c: zero out memory copied to userspace in getxattr
vfio/type1: Remove locked page accounting workqueue
crypto: algif_aead - Require setkey before accept(2)
staging: gdm724x: gdm_mux: fix use-after-free on module unload
drm/ttm: fix use-after-free races in vm fault handling
f2fs: sanity check segment count
ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf
ipv6: initialize route null entry in addrconf_init()
rtnetlink: NUL-terminate IFLA_PHYS_PORT_NAME string
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
* imx/imx_4.1.15_2.0.0_ga: (157 commits)
MLK-14762 ARM: dts: imx6sll-evk: correct gpio pin for lcd power control
MLK-14285-3 usb: phy: mxs: optimize disconnect line condition
MLK-14285-2 usb: chipidea: set mode for usb phy driver
MLK-14285-1 usb: phy: add usb mode for usb_phy
MLK-14747 driver: cpufreq: Correct dc regulator voltage on imx6ull
MLK-14720 epdc: correct WFE setting when bypass legacy process
MLK-13801-02 ARM: dts: Correct the gpt timer clock source on imx6ul/ull/sll
MLK-13801-01 ARM: imx: add gpt_3m clock on imx6sll
MLK-14680 pxp/epdc: add LUT cancellation feature
MLK-14518-2 pxp: set data path for pxp after reset
MLK-14518-1 pxp: initialize pxp according to recommended flow
MLK-14516 epdc: bypass pxp legacy process when there's no transformation
MLK-14369 epdc: sync LUT status to PXP before enable collision detection
MLK-13198 pxp: imx7d: fix error histogram status report issue
MLK-13917 pxp: fix build error for pxp library in user space
MLK-13862-2 epdc/pxp: imx6ull/imx6sll: enhance the LUT cleanup flow to avoid stalling display
MLK-13862-1 epdc/pxp: imx7d: enhance the LUT cleanup flow to avoid stalling display
MLK-14697 ARM: dts: imx: update the setpoint data of imx6sll
MXSCM-266 arm: dts: increase lpddr2 voltage to 1.25V
MXSCM-265: dts: place imx6sxscm dtb files under CONFIG_SOC_IMX6SX
[ Upstream commit 0c18927f51f4d390abdcf385bff5f995407ee732 ]
Current U-Boot enables the display already. Marking the regulator as
enabled on boot fixes sporadic panel initialization failures.
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Tested-by: Misha Komarovskiy <zombah@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit d65e5677ad5b3a49c43f60ec07644dc1f87bbd2e ]
MIPS instructions MULTU, MADDU and MSUBU emulation requires registers HI/LO
to be converted to signed 32bits before 64bit sign extension on MIPS64.
Bug was found on running MIPS32 R2 test application on MIPS64 R6 kernel.
Fixes: b0a668fb2038 ("MIPS: kernel: mips-r2-to-r6-emul: Add R2 emulator for MIPS R6")
Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Reported-by: Nikola.Veljkovic@imgtec.com
Cc: paul.burton@imgtec.com
Cc: yamada.masahiro@socionext.com
Cc: akpm@linux-foundation.org
Cc: andrea.gelmini@gelma.net
Cc: macro@imgtec.com
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/14043/
[ Upstream commit 1fb883bb827ee8efc1cc9ea0154f953f8a219d38 ]
L2 was running with uninitialized PML fields which led to incomplete
dirty bitmap logging. This manifested as all kinds of subtle erratic
behavior of the nested guest.
Fixes: 843e4330573c ("KVM: VMX: Add PML support in VMX")
Signed-off-by: Ladi Prosek <lprosek@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit 0b4c208d443ba2af82b4c70f99ca8df31e9a0020 ]
This reverts commit bc6134942dbbf31c25e9bd7c876be5da81c9e1ce.
A CPUID instruction executed in VMX non-root mode always causes a
VM-exit, regardless of the leaf being queried.
Fixes: bc6134942dbb ("KVM: nested VMX: disable perf cpuid reporting")
Signed-off-by: Jim Mattson <jmattson@google.com>
[The issue solved by bc6134942dbb has been resolved with ff651cb613b4
("KVM: nVMX: Add nested msr load/restore algorithm").]
[ Upstream commit 80354c29025833acd72ddac1ffa21c6cb50128cd ]
The interrupt line used for the watchdog is 12, according to the official
Intel Edison BSP code.
And indeed after fixing it we start getting an interrupt and thus the
watchdog starts working again:
[ 191.699951] Kernel panic - not syncing: Kernel Watchdog
Cc: David Cohen <david.a.cohen@linux.intel.com>
Fixes: 78a3bb9e408b ("x86: intel-mid: add watchdog platform code for Merrifield")
Link: http://lkml.kernel.org/r/20170312150744.45493-1-andriy.shevchenko@linux.intel.com
probed
[ Upstream commit 75013fb16f8484898eaa8d0b08fed942d790f029 ]
Fix to the exception table entry check by using probed address
instead of the address of copied instruction.
This bug may cause unexpected kernel panic if user probe an address
where an exception can happen which should be fixup by __ex_table
(e.g. copy_from_user.)
Unless user puts a kprobe on such address, this doesn't
cause any problem.
This bug has been introduced years ago, by commit:
464846888d9a ("x86/kprobes: Fix a bug which can modify kernel code permanently").
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Fixes: 464846888d9a ("x86/kprobes: Fix a bug which can modify kernel code permanently")
Link: http://lkml.kernel.org/r/148829899399.28855.12581062400757221722.stgit@devbox
[ Upstream commit 68dee8e2f2cacc54d038394e70d22411dee89da2 ]
commit 8fd524b355da ("x86: Kill bad_dma_address variable") has killed
bad_dma_address variable and used instead of macro DMA_ERROR_CODE
which is always zero. Since dma_addr is unsigned, the statement
dma_addr >= DMA_ERROR_CODE
is always true, and not needed.
arch/x86/kernel/pci-calgary_64.c: In function ‘iommu_free’:
arch/x86/kernel/pci-calgary_64.c:299:2: warning: comparison of unsigned expression >= 0 is always true [-Wtype-limits]
if (unlikely((dma_addr >= DMA_ERROR_CODE) && (dma_addr < badend))) {
Fixes: 8fd524b355da ("x86: Kill bad_dma_address variable")
Signed-off-by: Nikola Pajkovsky <npajkovsky@suse.cz>
Cc: iommu@lists.linux-foundation.org
Cc: Jon Mason <jdmason@kudzu.us>
Cc: Muli Ben-Yehuda <mulix@mulix.org>
Link: http://lkml.kernel.org/r/7612c0f9dd7c1290407dbf8e809def922006920b.1479161177.git.npajkovsky@suse.cz
[ Upstream commit a7e0fb6c2029a780444d09560f739e020d54fe4d ]
Currently the opal_exit tracepoint usually shows the opcode as 0:
<idle>-0 [047] d.h. 635.654292: opal_entry: opcode=63
<idle>-0 [047] d.h. 635.654296: opal_exit: opcode=0 retval=0
kopald-1209 [019] d... 636.420943: opal_entry: opcode=10
kopald-1209 [019] d... 636.420959: opal_exit: opcode=0 retval=0
This is because we incorrectly load the opcode into r0 before calling
__trace_opal_exit(), whereas it expects the opcode in r3 (first function
parameter). In fact we are leaving the retval in r3, so opcode and
retval will always show the same value.
Instead load the opcode into r3, resulting in:
<idle>-0 [040] d.h. 636.618625: opal_entry: opcode=63
<idle>-0 [040] d.h. 636.618627: opal_exit: opcode=63 retval=0
Fixes: c49f63530bb6 ("powernv: Add OPAL tracepoints")
[ Upstream commit 34a477e5297cbaa6ecc6e17c042a866e1cbe80d6 ]
On x86-32, with CONFIG_FIRMWARE and multiple CPUs, if you enable function
graph tracing and then suspend to RAM, it will triple fault and reboot when
it resumes.
The first fault happens when booting a secondary CPU:
startup_32_smp()
load_ucode_ap()
prepare_ftrace_return()
ftrace_graph_is_dead()
(accesses 'kill_ftrace_graph')
The early head_32.S code calls into load_ucode_ap(), which has an an
ftrace hook, so it calls prepare_ftrace_return(), which calls
ftrace_graph_is_dead(), which tries to access the global
'kill_ftrace_graph' variable with a virtual address, causing a fault
because the CPU is still in real mode.
The fix is to add a check in prepare_ftrace_return() to make sure it's
running in protected mode before continuing. The check makes sure the
stack pointer is a virtual kernel address. It's a bit of a hack, but
it's not very intrusive and it works well enough.
For reference, here are a few other (more difficult) ways this could
have potentially been fixed:
- Move startup_32_smp()'s call to load_ucode_ap() down to *after* paging
is enabled. (No idea what that would break.)
- Track down load_ucode_ap()'s entire callee tree and mark all the
functions 'notrace'. (Probably not realistic.)
- Pause graph tracing in ftrace_suspend_notifier_call() or bringup_cpu()
or __cpu_up(), and ensure that the pause facility can be queried from
real mode.
Reported-by: Paul Menzel <pmenzel@molgen.mpg.de>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Tested-by: Paul Menzel <pmenzel@molgen.mpg.de>
Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: "Rafael J . Wysocki" <rjw@rjwysocki.net>
Cc: linux-acpi@vger.kernel.org
Cc: stable@kernel.org
Cc: Len Brown <lenb@kernel.org>
Link: http://lkml.kernel.org/r/5c1272269a580660703ed2eccf44308e790c7a98.1492123841.git.jpoimboe@redhat.com
[ Upstream commit 9ae34dbd8afd790cb5f52467e4f816434379eafa ]
This commit moves sparc64's prototype of pmd_write() outside
of the CONFIG_TRANSPARENT_HUGEPAGE ifdef.
In 2013, commit a7b9403f0e6d ("sparc64: Encode huge PMDs using PTE
encoding.") exposed a path where pmd_write() could be called without
CONFIG_TRANSPARENT_HUGEPAGE defined. This can result in the panic below.
The diff is awkward to read, but the changes are straightforward.
pmd_write() was moved outside of #ifdef CONFIG_TRANSPARENT_HUGEPAGE.
Also, __HAVE_ARCH_PMD_WRITE was defined.
kernel BUG at include/asm-generic/pgtable.h:576!
\|/ ____ \|/
/_| \__/ |_\
\__U_/
oracle_8114_cdb(8114): Kernel bad sw trap 5 [#1]
CPU: 120 PID: 8114 Comm: oracle_8114_cdb Not tainted
4.1.12-61.7.1.el6uek.rc1.sparc64 #1
task: fff8400700a24d60 ti: fff8400700bc4000 task.ti: fff8400700bc4000
TSTATE: 0000004411e01607 TPC: 00000000004609f8 TNPC: 00000000004609fc Y:
00000005 Not tainted
TPC: <gup_huge_pmd+0x198/0x1e0>
g0: 000000000001c000 g1: 0000000000ef3954 g2: 0000000000000000 g3: 0000000000000001
g4: fff8400700a24d60 g5: fff8001fa5c10000 g6: fff8400700bc4000 g7: 0000000000000720
o0: 0000000000bc5058 o1: 0000000000000240 o2: 0000000000006000 o3: 0000000000001c00
o4: 0000000000000000 o5: 0000048000080000 sp: fff8400700bc6ab1 ret_pc: 00000000004609f0
RPC: <gup_huge_pmd+0x190/0x1e0>
l0: fff8400700bc74fc l1: 0000000000020000 l2: 0000000000002000 l3: 0000000000000000
l4: fff8001f93250950 l5: 000000000113f800 l6: 0000000000000004 l7: 0000000000000000
i0: fff8400700ca46a0 i1: bd0000085e800453 i2: 000000026a0c4000 i3: 000000026a0c6000
i4: 0000000000000001 i5: fff800070c958de8 i6: fff8400700bc6b61 i7: 0000000000460dd0
I7: <gup_pud_range+0x170/0x1a0>
Call Trace:
[0000000000460dd0] gup_pud_range+0x170/0x1a0
[0000000000460e84] get_user_pages_fast+0x84/0x120
[00000000006f5a18] iov_iter_get_pages+0x98/0x240
[00000000005fa744] do_direct_IO+0xf64/0x1e00
[00000000005fbbc0] __blockdev_direct_IO+0x360/0x15a0
[00000000101f74fc] ext4_ind_direct_IO+0xdc/0x400 [ext4]
[00000000101af690] ext4_ext_direct_IO+0x1d0/0x2c0 [ext4]
[00000000101af86c] ext4_direct_IO+0xec/0x220 [ext4]
[0000000000553bd4] generic_file_read_iter+0x114/0x140
[00000000005bdc2c] __vfs_read+0xac/0x100
[00000000005bf254] vfs_read+0x54/0x100
[00000000005bf368] SyS_pread64+0x68/0x80
Signed-off-by: Tom Hromatka <tom.hromatka@oracle.com>
[ Upstream commit adfae8a5d833fa2b46577a8081f350e408851f5b ]
I encountered this bug when using /proc/kcore to examine the kernel. Plus a
coworker inquired about debugging tools. We computed pa but did
not use it during the maximum physical address bits test. Instead we used
the identity mapped virtual address which will always fail this test.
I believe the defect came in here:
[bpicco@zareason linus.git]$ git describe --contains bb4e6e85daa52
v3.18-rc1~87^2~4
Signed-off-by: Bob Picco <bob.picco@oracle.com>
[ Upstream commit c06b6d70feb32d28f04ba37aa3df17973fd37b6b ]
On slow platforms with unreliable TSC, such as QEMU emulated machines,
it is possible for the kernel to request the next event in the past. In
that case, in the current implementation of xen_vcpuop_clockevent, we
simply return -ETIME. To be precise the Xen returns -ETIME and we pass
it on. However the result of this is a missed event, which simply causes
the kernel to hang.
Instead it is better to always ask the hypervisor for a timer event,
even if the timeout is in the past. That way there are no lost
interrupts and the kernel survives. To do that, remove the
VCPU_SSHOTTMR_future flag.
Signed-off-by: Stefano Stabellini <sstabellini@kernel.org>
Acked-by: Juergen Gross <jgross@suse.com>
[ Upstream commit c80e1b62ffca52e2d1d865ee58bc79c4c0c55005 ]
As part of handling a crash on an SMP system, an IPI is send to
all other CPUs to save their current registers and stop. It was
using task_pt_regs(current) to get the registers, but that will
only be accurate if the CPU was interrupted running in userland.
Instead allow the architecture to pass in the registers (all
pass NULL now, but allow for the future) and then use get_irq_regs()
which should be accurate as we are in an interrupt. Fall back to
task_pt_regs(current) if nothing else is available.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Cc: David Daney <ddaney@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/13050/
[ Upstream commit 29f72ce3e4d18066ec75c79c857bee0618a3504b ]
MCA bank 3 is reserved on systems pre-Fam17h, so it didn't have a name.
However, MCA bank 3 is defined on Fam17h systems and can be accessed
using legacy MSRs. Without a name we get a stack trace on Fam17h systems
when trying to register sysfs files for bank 3 on kernels that don't
recognize Scalable MCA.
Call MCA bank 3 "decode_unit" since this is what it represents on
Fam17h. This will allow kernels without SMCA support to see this bank on
Fam17h+ and prevent the stack trace. This will not affect older systems
since this bank is reserved on them, i.e. it'll be ignored.
Tested on AMD Fam15h and Fam17h systems.
WARNING: CPU: 26 PID: 1 at lib/kobject.c:210 kobject_add_internal
kobject: (ffff88085bb256c0): attempted to be registered with empty name!
Call Trace:
kobject_add
kobject_create_and_add
threshold_create_device
threshold_init_device
Signed-off-by: Yazen Ghannam <yazen.ghannam@amd.com>
Link: http://lkml.kernel.org/r/1490102285-3659-1-git-send-email-Yazen.Ghannam@amd.com
[ Upstream commit a4866aa812518ed1a37d8ea0c881dc946409de94 ]
Under CONFIG_STRICT_DEVMEM, reading System RAM through /dev/mem is
disallowed. However, on x86, the first 1MB was always allowed for BIOS
and similar things, regardless of it actually being System RAM. It was
possible for heap to end up getting allocated in low 1MB RAM, and then
read by things like x86info or dd, which would trip hardened usercopy:
usercopy: kernel memory exposure attempt detected from ffff880000090000 (dma-kmalloc-256) (4096 bytes)
This changes the x86 exception for the low 1MB by reading back zeros for
System RAM areas instead of blindly allowing them. More work is needed to
extend this to mmap, but currently mmap doesn't go through usercopy, so
hardened usercopy won't Oops the kernel.
Reported-by: Tommi Rantala <tommi.t.rantala@nokia.com>
Tested-by: Tommi Rantala <tommi.t.rantala@nokia.com>
[ Upstream commit 06ce521af9558814b8606c0476c54497cf83a653 ]
handle_vmon gets a reference on VMXON region page,
but does not release it. Release the reference.
Found by syzkaller; based on a patch by Dmitry.
[ Upstream commit 3cc3434fd6307d06b53b98ce83e76bf9807689b9 ]
Since do_IRQ is now invoked on a separate IRQ stack, we select
HAVE_IRQ_EXIT_ON_IRQ_STACK so that softirq's may be invoked directly
from irq_exit(), rather than requiring do_softirq_own_stack.
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Acked-by: Jason A. Donenfeld <jason@zx2c4.com>
Patchwork: https://patchwork.linux-mips.org/patch/14744/
[ Upstream commit 510d86362a27577f5ee23f46cfb354ad49731e61 ]
The SAVE_SOME macro is used to save the execution context on all
exceptions.
If an exception occurs while executing user code, the stack is switched
to the kernel's stack for the current task, and register $28 is switched
to point to the current_thread_info, which is at the bottom of the stack
region.
If the exception occurs while executing kernel code, the stack is left,
and this change ensures that register $28 is not updated. This is the
correct behaviour when the kernel can be executing on the separate irq
stack, because the thread_info will not be at the base of it.
With this change, register $28 is only switched to it's kernel
conventional usage of the currrent thread info pointer at the point at
which execution enters kernel space. Doing it on every exception was
redundant, but OK without an IRQ stack, but will be erroneous once that
is introduced.
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14742/
The i.MX 7Solo SoCs are only rated up to 800MHz. Specify higher
operating points only in the i.MX 7Dual base device tree.
[ Upstream commit 061120aed7081b9a4393fbe07b558192f40ad911 ]
An MCE is a rare event. Therefore, there's no need to have
per-CPU instances of both normal and IRQ workqueues. Make them
both global.
Signed-off-by: Chen, Gong <gong.chen@linux.intel.com>
[ Fold in subsequent patch from Rui/Boris/Tony for early boot logging. ]
Signed-off-by: Tony Luck <tony.luck@intel.com>
[ Massage commit message. ]
Link: http://lkml.kernel.org/r/1439396985-12812-4-git-send-email-bp@alien8.de
[ Upstream commit a8c39544a6eb2093c04afd5005b6192bd0e880c6 ]
failing sys_wait4() won't fill struct rusage...
Cc: stable@vger.kernel.org
[ Upstream commit cbfc6c9184ce71b52df4b1d82af5afc81a709178 ]
Huawei folks reported a read out-of-bounds vulnerability in kvm pio emulation.
- "inb" instruction to access PIT Mod/Command register (ioport 0x43, write only,
a read should be ignored) in guest can get a random number.
- "rep insb" instruction to access PIT register port 0x43 can control memcpy()
in emulator_pio_in_emulated() to copy max 0x400 bytes but only read 1 bytes,
which will disclose the unimportant kernel memory in host but no crash.
The similar test program below can reproduce the read out-of-bounds vulnerability:
void hexdump(void *mem, unsigned int len)
unsigned int i, j;
for(i = 0; i < len + ((len % HEXDUMP_COLS) ? (HEXDUMP_COLS - len % HEXDUMP_COLS) : 0); i++)
/* print offset */
if(i % HEXDUMP_COLS == 0)
printf("0x%06x: ", i);
/* print hex data */
if(i < len)
printf("%02x ", 0xFF & ((char*)mem)[i]);
else /* end of block, just aligning for ASCII dump */
printf(" ");
/* print ASCII dump */
if(i % HEXDUMP_COLS == (HEXDUMP_COLS - 1))
for(j = i - (HEXDUMP_COLS - 1); j <= i; j++)
if(j >= len) /* end of block, not really printing */
putchar(' ');
else if(isprint(((char*)mem)[j])) /* printable char */
putchar(0xFF & ((char*)mem)[j]);
else /* other char */
putchar('.');
putchar('\n');
int main(void)
int i;
if (iopl(3))
err(1, "set iopl unsuccessfully\n");
return -1;
static char buf[0x40];
/* test ioport 0x40,0x41,0x42,0x43,0x44,0x45 */
memset(buf, 0xab, sizeof(buf));
asm volatile("push %rdi;");
asm volatile("mov %0, %%rdi;"::"q"(buf));
asm volatile ("mov $0x40, %rdx;");
asm volatile ("in %dx,%al;");
asm volatile ("stosb;");
asm volatile ("mov $0x41, %rdx;");
asm volatile ("mov $0x42, %rdx;");
asm volatile ("mov $0x43, %rdx;");
asm volatile ("mov $0x44, %rdx;");
asm volatile ("mov $0x45, %rdx;");
asm volatile ("pop %rdi;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x40 */
asm volatile ("mov $0x20, %rcx;");
asm volatile ("rep insb;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x43 */
hexdump(buf, 0x40);
printf("\n");
return 0;
The vcpu->arch.pio_data buffer is used by both in/out instrutions emulation
w/o clear after using which results in some random datas are left over in
the buffer. Guest reads port 0x43 will be ignored since it is write only,
however, the function kernel_pio() can't distigush this ignore from successfully
reads data from device's ioport. There is no new data fill the buffer from
port 0x43, however, emulator_pio_in_emulated() will copy the stale data in
the buffer to the guest unconditionally. This patch fixes it by clearing the
buffer before in instruction emulation to avoid to grant guest the stale data
in the buffer.
In addition, string I/O is not supported for in kernel device. So there is no
iteration to read ioport %RCX times for string I/O. The function kernel_pio()
just reads one round, and then copy the io size * %RCX to the guest unconditionally,
actually it copies the one round ioport data w/ other random datas which are left
over in the vcpu->arch.pio_data buffer to the guest. This patch fixes it by
introducing the string I/O support for in kernel device in order to grant the right
ioport datas to the guest.
Before the patch:
0x000000: fe 38 93 93 ff ff ab ab .8......
0x000008: ab ab ab ab ab ab ab ab ........
0x000010: ab ab ab ab ab ab ab ab ........
0x000018: ab ab ab ab ab ab ab ab ........
0x000020: ab ab ab ab ab ab ab ab ........
0x000028: ab ab ab ab ab ab ab ab ........
0x000030: ab ab ab ab ab ab ab ab ........
0x000038: ab ab ab ab ab ab ab ab ........
0x000000: f6 00 00 00 00 00 00 00 ........
0x000008: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 4d 51 30 30 ....MQ00
0x000018: 30 30 20 33 20 20 20 20 00 3
After the patch:
0x000000: 1e 02 f8 00 ff ff ab ab ........
0x000000: d2 e2 d2 df d2 db d2 d7 ........
0x000008: d2 d3 d2 cf d2 cb d2 c7 ........
0x000010: d2 c4 d2 c0 d2 bc d2 b8 ........
0x000018: d2 b4 d2 b0 d2 ac d2 a8 ........
0x000000: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 00 00 00 00 ........
0x000018: 00 00 00 00 00 00 00 00 ........
Reported-by: Moguofang <moguofang@huawei.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Moguofang <moguofang@huawei.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
[ Upstream commit 120f0779c3ed89c25ef1db943feac8ed73a0d7f9 ]
Rearrange the code for fake pgd handling, which is applicable
only for arm64. This will later be removed once we introduce
the stage2 page table walker macros.
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[ Upstream commit a5f56ba3b4ec8d2ad80da4c447d47e37e2b504fb ]
No need to cast the void pointer returned by kmalloc() in
arch/arm/kvm/mmu.c::kvm_alloc_stage2_pgd().
Signed-off-by: Firo Yang <firogm@gmail.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
[ Upstream commit d8581c7c8be172dac156a19d261f988a72ce596f ]
The board file for imx6sx-sdb overrides cpufreq operating points to use
higher voltages. This is done because the board has a shared rail for
VDD_ARM_IN and VDD_SOC_IN and when using LDO bypass the shared voltage
needs to be a value suitable for both ARM and SOC.
This only applies to LDO bypass mode, a feature not present in upstream.
When LDOs are enabled the effect is to use higher voltages than necessary
for no good reason.
Setting these higher voltages can make some boards fail to boot with ugly
semi-random crashes reminiscent of memory corruption. These failures only
happen on board rev. C, rev. B is reported to still work.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Fixes: 54183bd7f766 ("ARM: imx6sx-sdb: add revb board and make it default")
[ Upstream commit 1dd58e12dfd037edfa75825bb719031dec822a73 ]
imx6sx-sdb has custom operating points entries because it has one
power supply that drives both VDDARM_IN and VDDSOC_IN.
As per the MX6UL datasheet we have the following minimum voltages for
198 MHz operation (after adding the 25mV margin value):
VDDARM_IN = 0.975 V
VDDSOC_IN = 1.175 V
So use 1.175V for the 198MHz operation.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
[ Upstream commit 07a63cbe8bcb6ba72fb989dcab1ec55ec6c36c7e ]
git commit c5328901aa1db134 "[S390] entry[64].S improvements" removed
the update of the exit_timer lowcore field from the critical section
cleanup of the .Lsysc_restore/.Lsysc_done and .Lio_restore/.Lio_done
blocks. If the PSW is updated by the critical section cleanup to point to
user space again, the interrupt entry code will do a vtime calculation
after the cleanup completed with an exit_timer value which has *not* been
updated. Due to this incorrect system time deltas are calculated.
If an interrupt occured with an old PSW between .Lsysc_restore/.Lsysc_done
or .Lio_restore/.Lio_done update __LC_EXIT_TIMER with the system entry
time of the interrupt.
Cc: stable@vger.kernel.org # 3.3+
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
Add CSI 5MP OV5640 Camera module support
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Enable ADV7280 decoder on Ixora. This somehow got missed when
ADV7280 support was introduced.
ADV7280 and ADV7180 have same addresses viz. 0x21 respectively,
changing the ADV7280 address to 0x20 would result in a conflict
with MAX9526. As a result enable ADV7280 by default and disable
ADV7180.
Add support for Toradex Ixora V1.1 carrier board.
Split the pinctrl property for usdhc1 into a 4bit SD interface
and an extension to 8bit. This is required to support the 8 bit
MMC interface on the Evaluation Board for usdhc1 and the 4 bit
SD interface on Ixora V1.1 for usdhc1.
The Cortex-M4 boot vector table is located in the OCRAM_S. When
building a firmware with a complete vector table at 0x00000000
Linux overwrites the vector table with suspend information. Use
the higher 16KiB for suspend related information so that we can
use the lower 16KiB for the Cortex-M4 core.
With the backport of 940adb280d23512965409c1fd6b42cc796ce6eb8 the
internal VDDD LDO is no longer unconditionally switched on.
In all Toradex modules which use the sgtl5000 VDDD is supplied
from an external source and thus the internal regulator can be
left in its off state.
Use the newly added "lrclk-strength" property to fix occational
channel swap on audio start.
This reverts commit ba2f75f559bc54406e8938ab5be722298fe7166c.
revert this to get be able to cherry-pick the mainlined patch
