drivers/iio/common/hid-sensors/hid-sensor-trigger.c
include/linux/hid-sensor-hub.h
Add additional flag to read in async mode. In this mode the caller will get
reply via registered callback for capture_sample. Callbacks can be registered
using sensor_hub_register_callback function. The usage id parameter of the
capture_sample can be matched with the usage id of the requested attribute.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Use common hid sensor iio pm functions. Also the poll time read and
wait is part of power up function of hid sensor iio pm function, so
remove from the client drivers.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
This patch removes the .owner field for drivers which use the
platform_driver_register api because this is overriden in
_platform_driver_register.
Signed-off-by: Sanjeev Sharma <Sanjeev_Sharma@mentor.com>
IIO_CHAN_INFO_SAMP_FREQ and IIO_CHAN_INFO_HYSTERESIS cases ignored
the actual return values (which could be -EINVAL) and instead
returned IIO_VAL_INT_PLUS_MICRO always. Return the actual value
obtained from the functions. Both functions return IIO_VAL_INT_PLUS_MICRO
upon success.
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
Cc: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Added support for raw reading of channel. If the sensor is powered
off, it will turn on for reading value.
Added an API to allow client drivers to turn ON and OFF sensors for
quick read. Added data_read as counting varaible instead of boolean,
so that sensor is powered off only when last user released it.
Using units and unit exponent to calculate scale which is compliant
to IIO ABI.
we want these fixes in here.
A number of Properties that can be applied to Data Fields are per data
field basis or for all data fields. Adding sensitivity field for all
accelerometer fields, which is most commonly used in currently
available sensor hubs.
We can't store the trigger instance created by iio_trigger_alloc, in
trig field of iio_device structure. This needs to be stored in the
driver private data. Othewise it can result in crash during module
unload. Hence created a trig_ptr in the common data structure
for each HID sensor IIO driver and storing here.
Now that iio_push_to_buffers() takes a void pointer for the data parameter we
can remove those casts to u8*.
IIO_VAL_INT_PLUS_MICRO is the default, no need to return it explicitly
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Acked-by: srinivas pandruvada <srinivas.pandruvada@intel.com>
Using devm_iio_device_alloc makes code simpler.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Srinivas Pandruvada <srinivas.pandruvada@intel.com>
Add a MODULE_DEVICE_TABLE in order to let hotplug mechanisms automatically
load the driver.
This makes it also possible to use the usual driver name instead of
HID-SENSOR-2000xx which isn't very descriptive in kernel messages.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
Acked-by:Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
The original info_mask is going away in favour of the broken out versions.
This resolves a merge issue with a iio driver, and the zram code.
The structure with common attributes for hid-sensors isn't specific
to the iio-subsystem, so rename it to hid_sensor_common.
Acked-by: Jiri Kosina <jkosina@suse.cz>
The stuff in hid-sensor-attributes.h is needed by every piece which
uses hid-sensor-hub and merging it into hid-sensor-hub.h makes it accessible
from outside the iio subdirectory.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, and __devexit
from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Return -ENOMEM instead of 0 if kmemdup fails.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Route all buffer writes through the demux.
Addition or removal of a buffer results in tear down and
setup of all the buffers for a given device.
Tested-by: srinivas pandruvada <srinivas.pandruvada@intel.com>
Drop timestamp parameter from buffer store_to callback and subsequently from
iio_push_to_buffer. The timestamp parameter is unused and it seems likely that
it will stay unused in the future, so it should be safe to remove it.
Consistently use iio_push_to_buffer instead of manually calling the buffers
store_to callback.
These crossed with Lars-Peter's patch set doing every other case.
Added usage id processing for Accelerometer 3D.This uses IIO
interfaces for triggered buffer to present data to user
mode.This uses HID sensor framework for registering callback
events from the sensor hub.
Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com>
