Signed-off-by: Denis Ciocca <denis.ciocca@st.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Introduce iio_tigger_{set,get}_drvdata which allows to attach driver specific
data to a trigger. The functions wrap access to the triggers private_data field
and all current users are updated to use iio_tigger_{set,get}_drvdata instead of
directly accessing the private_data field. This is the first step towards
removing the private_data field from the iio_trigger struct.
The following coccinelle script has been used to update the drivers:
<smpl>
struct iio_trigger *trigger;
expression priv;
-trigger->private_data = priv
+iio_trigger_set_drv_data(trigger, priv)
+iio_trigger_get_drv_data(trigger)
</smpl>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
First set of IIO new drivers and cleanup for the 3.10 cycle.
New stuff
1) Add OF support for specifying mappings between iio devices and their
in kernel consumers.
2) Driver for AD7923 (extra functionality and support for ad7904, ad7914 and
ad7924 added later in series)
3) Driver for Exynos adc (dt suppor for phy added later in series).
4) Make iio_push_event save IRQ context - necessary if it is to be used
within an interrupt handler. Users of this functionality to follow.
5) For iio use the device tree node name to provide the hwmon name attribute
if available.
Removal and moves out of staging
1) Drop the adt7410 driver from IIO now that there is a hmwon driver with
equivalent support. This device is very much targeted at hardware
monitoring so hwmon is a more appropriate host for the driver.
2) Move iio_hwmon driver to drivers/hwmon.
Cleanups
1) Minor cleanup in ST common library.
2) Large set of patches to break the info_mask element which previously used
odd and even bits to specify if a channel attribute was either shared across
similar channels or specific to only one. Now we have two bitmaps, one for
those parameters that are specific to this channel and one for those shared
by all channels with the same type as this one. This has no effect on the
userspace abi. It simplifies the core code and provides more space for new
channel parameters. It has been on the todo list for a long time!
drivers/iio/dac/ad5064.c
Use the new spi_sync_transfer() helper function instead of open-coding it.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
This patch remove st_sensors_get_sampling_frequency_avl and
st_sensors_get_scale_avl functions used only in
st_sensors_sysfs_sampling_frequency_avail and st_sensors_sysfs_scale_avail
sysfs functions.
This patch add a generic library for STMicroelectronics 3-axis sensors.
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
This is to get the comedi fixes, and resolve the issue in comdi_test.c
and comedi_fops.c that were caused by changes in both branches.
It also allows the fwserial driver changes to be applied, as they
required the fixes that are in staging-linus.
The structure with common attributes for hid-sensors isn't specific
to the iio-subsystem, so rename it to hid_sensor_common.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
Acked-by: Jiri Kosina <jkosina@suse.cz>
The stuff in hid-sensor-attributes.h is needed by every piece which
uses hid-sensor-hub and merging it into hid-sensor-hub.h makes it accessible
from outside the iio subdirectory.
Not much to say, without that change, hid-sensor-trigger will be
always compiled if HID_SENSOR_IIO_COMMON is selected which fails if
CONFIG_IIO_TRIGGER is not set because CONFIG_IIO_CONSUMERS_PER_TRIGGER
will not be defined.
It's non-sense to use tristate for the option, it's bool.
When hid sensor hub is unplugged, there is a crash in
iio_device_unregister_trigger_consumer.
In a typical IIO driver when remove is called, it will unregister and free
trigger and then it will call iio_device_free.
The function iio_trigger_free() will free the allocated memory for trigger.
If this trigger was assigned to iio_dev->trig, then it should be set to NULL.
Othewise when iio_device_free() is called later, it finally calls
iio_device_unregsister_trigger(), which checks for
if (indio_dev->trig)
iio_trigger_put(indio_dev->trig);
If indio_dev->trig is not set to NULL, it calls iio_trigger_put on a bad
pointer causing crash.
This scenerio can happen in any driver, which is storing trigger pointer in
iio_dev structure and following current procedure during remove.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
This patch contains the common code, which is used by all HID sensors.
There are some common set of attributes, which every hid sensor
needs it. This patch contains all such attributes processing.
Also the trigger interface is common among all HID sensors. This
patch contains common trigger functions utilized by all HID sensors.
Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com>
