path: root/drivers
2013-12-22Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Much smaller batch of fixes this week. Biggest one is a revert of an OMAP display change that removed some non-DT pinmux code that was still needed for 3.13 to get DSI displays to work. There's also a fix that resolves some misdescribed GPIO controller resources on shmobile. The rest are mostly smaller fixes, a couple of MAINTAINERS updates, etc" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: Revert "ARM: OMAP2+: Remove legacy mux code for display.c" MAINTAINERS: Add keystone clock drivers MAINTAINERS: Add keystone git tree information ARM: s3c64xx: dt: Fix boot failure due to double clock initialization ARM: shmobile: r8a7790: Fix GPIO resources in DTS irqchip: renesas-intc-irqpin: Fix register bitfield shift calculation ARM: shmobile: lager: phy fixup needs CONFIG_PHYLIB
2013-12-22Merge tag 'firewire-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire fixlet from Stefan Richter: "A one-liner to reenable WRITE SAME over SBP-2 like in v3.8...v3.12. Buggy targets which could malfunction when being subjected to this command are already sufficiently protected by a scsi_level check in sd + SCSI core" * tag 'firewire-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: sbp2: bring back WRITE SAME support
2013-12-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "Mostly minor items this time around, the most notable being a FILEIO backend change to enforce hw_max_sectors based upon the current block_size to address a bug where large sized I/Os (> 1M) where being rejected" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure target: Remove extra percpu_ref_init target/file: Update hw_max_sectors based on current block_size iser-target: Move INIT_WORK setup into isert_create_device_ib_res iscsi-target: Fix incorrect np->np_thread NULL assignment qla2xxx: Fix schedule_delayed_work() for target timeout calculations iser-target: fix error return code in isert_create_device_ib_res() iscsi-target: Fix-up all zero data-length CDBs with R/W_BIT set target: Remove write-only stats fields and lock from struct se_node_acl iscsi-target: return -EINVAL on oversized configfs parameter
2013-12-20pstore: Don't allow high traffic options on fragile devicesLuck, Tony
Some pstore backing devices use on board flash as persistent storage. These have limited numbers of write cycles so it is a poor idea to use them from high frequency operations. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20Merge tag 'dmaengine-fixes-3.13-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine fixes from Dan Williams: - deprecation of net_dma to be removed in 3.14 - crash regression fix in pl330 from the dmaengine_unmap rework - crash regression fix for any channel running raid ops without CONFIG_ASYNC_TX_DMA from dmaengine_unmap - memory leak regression in mv_xor from dmaengine_unmap - build warning regressions in mv_xor, fsldma, ppc4xx, txx9, and at_hdmac from dmaengine_unmap - sleep in atomic regression in dma_async_memcpy_pg_to_pg - new fix in mv_xor for handling channel initialization failures * tag 'dmaengine-fixes-3.13-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: net_dma: mark broken dma: pl330: ensure DMA descriptors are zero-initialised dmaengine: fix sleep in atomic dmaengine: mv_xor: fix oops when channels fail to initialise dma: mv_xor: Use dmaengine_unmap_data for the self-tests dmaengine: fix enable for high order unmap pools dma: fix build warnings in txx9 dmatest: fix build warning on mips dma: fix fsldma build warnings dma: fix build warnings in ppc4xx dmaengine: at_hdmac: remove unused function dma: mv_xor: remove mv_desc_get_dest_addr()
2013-12-20Merge tag 'renesas-fixes-for-v3.13' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes From Simon Horman: Renesas ARM based SoC fixes for v3.13 * r8a7790 (R-Car H1) SoC - Correct GPIO resources in DT. This problem has been present since GPIOs were added to the r8a7790 SoC by f98e10c88aa95bf7 ("ARM: shmobile: r8a7790: Add GPIO controller devices to device tree") in v3.12-rc1. * irqchip renesas-intc-irqpin - Correct register bitfield shift calculation This bug has been present since the renesas-intc-irqpin driver was introduced by 443580486e3b9657 ("irqchip: Renesas INTC External IRQ pin driver") in v3.10-rc1 * Lager board - Do not build the phy fixup unless CONFIG_PHYLIB is enabled This problem was introduced by 48c8b96f21817aad * tag 'renesas-fixes-for-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: r8a7790: Fix GPIO resources in DTS irqchip: renesas-intc-irqpin: Fix register bitfield shift calculation ARM: shmobile: lager: phy fixup needs CONFIG_PHYLIB Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-12-20Merge tag 'stable/for-linus-3.13-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from Konrad Rzeszutek Wilk: - Fix balloon driver for auto-translate guests (PVHVM, ARM) to not use scratch pages. - Fix block API header for ARM32 and ARM64 to have proper layout - On ARM when mapping guests, stick on PTE_SPECIAL - When using SWIOTLB under ARM, don't call swiotlb functions twice - When unmapping guests memory and if we fail, don't return pages which failed to be unmapped. - Grant driver was using the wrong address on ARM. * tag 'stable/for-linus-3.13-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/balloon: Seperate the auto-translate logic properly (v2) xen/block: Correctly define structures in public headers on ARM32 and ARM64 arm: xen: foreign mapping PTEs are special. xen/arm64: do not call the swiotlb functions twice xen: privcmd: do not return pages which we have failed to unmap XEN: Grant table address, xen_hvm_resume_frames, is a phys_addr not a pfn
2013-12-19qla2xxx: Fix scsi_host leak on qlt_lport_register callback failureNicholas Bellinger
This patch fixes a possible scsi_host reference leak in qlt_lport_register(), when a non zero return from the passed (*callback) does not call drop the local reference via scsi_host_put() before returning. This currently does not effect existing tcm_qla2xxx code as the passed callback will never fail, but fix this up regardless for future code. Cc: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-19target: Remove extra percpu_ref_initAndy Grover
lun->lun_ref is also initialized in core_tpg_post_addlun, so it doesn't need to be done in core_tpg_setup_virtual_lun0. (nab: Drop left-over percpu_ref_cancel_init in failure path) Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-19target/file: Update hw_max_sectors based on current block_sizeNicholas Bellinger
This patch allows FILEIO to update hw_max_sectors based on the current max_bytes_per_io. This is required because vfs_[writev,readv]() can accept a maximum of 2048 iovecs per call, so the enforced hw_max_sectors really needs to be calculated based on block_size. This addresses a >= v3.5 bug where block_size=512 was rejecting > 1M sized I/O requests, because FD_MAX_SECTORS was hardcoded to 2048 for the block_size=4096 case. (v2: Use max_bytes_per_io instead of ->update_hw_max_sectors) Reported-by: Henrik Goldman <hg@x-formation.com> Cc: <stable@vger.kernel.org> #3.5+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-19iser-target: Move INIT_WORK setup into isert_create_device_ib_resNicholas Bellinger
This patch moves INIT_WORK setup for cq_desc->cq_[rx,tx]_work into isert_create_device_ib_res(), instead of being done each callback invocation in isert_cq_[rx,tx]_callback(). This also fixes a 'INFO: trying to register non-static key' warning when cancel_work_sync() is called before INIT_WORK has setup the struct work_struct. Reported-by: Or Gerlitz <ogerlitz@mellanox.com> Cc: <stable@vger.kernel.org> #3.12+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-19iscsi-target: Fix incorrect np->np_thread NULL assignmentNicholas Bellinger
When shutting down a target there is a race condition between iscsit_del_np() and __iscsi_target_login_thread(). The latter sets the thread pointer to NULL, and the former tries to issue kthread_stop() on that pointer without any synchronization. This patch moves the np->np_thread NULL assignment into iscsit_del_np(), after kthread_stop() has completed. It also removes the signal_pending() + np_state check, and only exits when kthread_should_stop() is true. Reported-by: Hannes Reinecke <hare@suse.de> Cc: <stable@vger.kernel.org> #3.12+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-12-18Merge tag 'usb-3.13-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are a few USB fixes for things that have people have reported issues with recently" * tag 'usb-3.13-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: usb: ohci-at91: fix irq and iomem resource retrieval usb: phy: fix driver dependencies phy: kconfig: add depends on "USB_PHY" to OMAP_USB2 and TWL4030_USB drivers: phy: tweaks to phy_create() drivers: phy: Fix memory leak xhci: Limit the spurious wakeup fix only to HP machines usb: chipidea: fix nobody cared IRQ when booting with host role usb: chipidea: host: Only disable the vbus regulator if it is not NULL usb: serial: zte_ev: move support for ZTE AC2726 from zte_ev back to option usb: cdc-wdm: manage_power should always set needs_remote_wakeup usb: phy-tegra-usb.c: wrong pointer check for remap UTMI usb: phy: twl6030-usb: signedness bug in twl6030_readb() usb: dwc3: power off usb phy in error path usb: dwc3: invoke phy_resume after phy_init
2013-12-18Merge tag 'tty-3.13-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg KH: "Here are a few fixes for 3.13-rc5 that resolve a number of reported tty and serial driver issues" * tag 'tty-3.13-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: xuartps: Properly guard sysrq specific code n_tty: Fix apparent order of echoed output serial: 8250_dw: add new ACPI IDs serial: 8250_dw: Fix LCR workaround regression tty: Fix hang at ldsem_down_read()
2013-12-18Merge tag 'staging-3.13-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver fixes from Greg KH: "Here are a number of staging, and iio, fixes for 3.13-rc5 that resolve some reported issues" * tag 'staging-3.13-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: imx-drm: imx-drm-core: improve safety of imx_drm_add_crtc() imx-drm: imx-drm-core: make imx_drm_crtc_register() safer imx-drm: imx-drm-core: use defined constant for number of CRTCs. imx-drm: imx-tve: don't call sleeping functions beneath enable_lock spinlock imx-drm: ipu-v3: fix potential CRTC device registration race imx-drm: imx-drm-core: fix DRM cleanup paths imx-drm: imx-drm-core: fix error cleanup path for imx_drm_add_crtc() staging: comedi: drivers: fix return value of comedi_load_firmware() staging: comedi: 8255_pci: fix for newer PCI-DIO48H iio:adc:ad7887 Fix channel reported endianness from cpu to big endian iio:imu:adis16400 fix pressure channel scan type staging:iio:mag:hmc5843 fix incorrect endianness of channel as a result of missuse of the IIO_ST macro. iio: cm36651: Changed return value of read function
2013-12-18net_dma: mark brokenDan Williams
net_dma can cause data to be copied to a stale mapping if a copy-on-write fault occurs during dma. The application sees missing data. The following trace is triggered by modifying the kernel to WARN if it ever triggers copy-on-write on a page that is undergoing dma: WARNING: CPU: 24 PID: 2529 at lib/dma-debug.c:485 debug_dma_assert_idle+0xd2/0x120() ioatdma 0000:00:04.0: DMA-API: cpu touching an active dma mapped page [pfn=0x16bcd9] Modules linked in: iTCO_wdt iTCO_vendor_support ioatdma lpc_ich pcspkr dca CPU: 24 PID: 2529 Comm: linbug Tainted: G W 3.13.0-rc1+ #353 00000000000001e5 ffff88016f45f688 ffffffff81751041 ffff88017ab0ef70 ffff88016f45f6d8 ffff88016f45f6c8 ffffffff8104ed9c ffffffff810f3646 ffff8801768f4840 0000000000000282 ffff88016f6cca10 00007fa2bb699349 Call Trace: [<ffffffff81751041>] dump_stack+0x46/0x58 [<ffffffff8104ed9c>] warn_slowpath_common+0x8c/0xc0 [<ffffffff810f3646>] ? ftrace_pid_func+0x26/0x30 [<ffffffff8104ee86>] warn_slowpath_fmt+0x46/0x50 [<ffffffff8139c062>] debug_dma_assert_idle+0xd2/0x120 [<ffffffff81154a40>] do_wp_page+0xd0/0x790 [<ffffffff811582ac>] handle_mm_fault+0x51c/0xde0 [<ffffffff813830b9>] ? copy_user_enhanced_fast_string+0x9/0x20 [<ffffffff8175fc2c>] __do_page_fault+0x19c/0x530 [<ffffffff8175c196>] ? _raw_spin_lock_bh+0x16/0x40 [<ffffffff810f3539>] ? trace_clock_local+0x9/0x10 [<ffffffff810fa1f4>] ? rb_reserve_next_event+0x64/0x310 [<ffffffffa0014c00>] ? ioat2_dma_prep_memcpy_lock+0x60/0x130 [ioatdma] [<ffffffff8175ffce>] do_page_fault+0xe/0x10 [<ffffffff8175c862>] page_fault+0x22/0x30 [<ffffffff81643991>] ? __kfree_skb+0x51/0xd0 [<ffffffff813830b9>] ? copy_user_enhanced_fast_string+0x9/0x20 [<ffffffff81388ea2>] ? memcpy_toiovec+0x52/0xa0 [<ffffffff8164770f>] skb_copy_datagram_iovec+0x5f/0x2a0 [<ffffffff8169d0f4>] tcp_rcv_established+0x674/0x7f0 [<ffffffff816a68c5>] tcp_v4_do_rcv+0x2e5/0x4a0 [..] ---[ end trace e30e3b01191b7617 ]--- Mapped at: [<ffffffff8139c169>] debug_dma_map_page+0xb9/0x160 [<ffffffff8142bf47>] dma_async_memcpy_pg_to_pg+0x127/0x210 [<ffffffff8142cce9>] dma_memcpy_pg_to_iovec+0x119/0x1f0 [<ffffffff81669d3c>] dma_skb_copy_datagram_iovec+0x11c/0x2b0 [<ffffffff8169d1ca>] tcp_rcv_established+0x74a/0x7f0: ...the problem is that the receive path falls back to cpu-copy in several locations and this trace is just one of the areas. A few options were considered to fix this: 1/ sync all dma whenever a cpu copy branch is taken 2/ modify the page fault handler to hold off while dma is in-flight Option 1 adds yet more cpu overhead to an "offload" that struggles to compete with cpu-copy. Option 2 adds checks for behavior that is already documented as broken when using get_user_pages(). At a minimum a debug mode is warranted to catch and flag these violations of the dma-api vs get_user_pages(). Thanks to David for his reproducer. Cc: <stable@vger.kernel.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Reported-by: David Whipple <whipple@securedatainnovations.ch> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-12-18dma: pl330: ensure DMA descriptors are zero-initialisedWill Deacon
I see the following splat with 3.13-rc1 when attempting to perform DMA: [ 253.004516] Alignment trap: not handling instruction e1902f9f at [<c0204b40>] [ 253.004583] Unhandled fault: alignment exception (0x221) at 0xdfdfdfd7 [ 253.004646] Internal error: : 221 [#1] PREEMPT SMP ARM [ 253.004691] Modules linked in: dmatest(+) [last unloaded: dmatest] [ 253.004798] CPU: 0 PID: 671 Comm: kthreadd Not tainted 3.13.0-rc1+ #2 [ 253.004864] task: df9b0900 ti: df03e000 task.ti: df03e000 [ 253.004937] PC is at dmaengine_unmap_put+0x14/0x34 [ 253.005010] LR is at pl330_tasklet+0x3c8/0x550 [ 253.005087] pc : [<c0204b44>] lr : [<c0207478>] psr: a00e0193 [ 253.005087] sp : df03fe48 ip : 00000000 fp : df03bf18 [ 253.005178] r10: bf00e108 r9 : 00000001 r8 : 00000000 [ 253.005245] r7 : df837040 r6 : dfb41800 r5 : df837048 r4 : df837000 [ 253.005316] r3 : dfdfdfcf r2 : dfb41f80 r1 : df837048 r0 : dfdfdfd7 [ 253.005384] Flags: NzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel [ 253.005459] Control: 30c5387d Table: 9fb9ba80 DAC: fffffffd [ 253.005520] Process kthreadd (pid: 671, stack limit = 0xdf03e248) This is due to desc->txd.unmap containing garbage (uninitialised memory). Rather than add another dummy initialisation to _init_desc, instead ensure that the descriptors are zero-initialised during allocation and remove the dummy, per-field initialisation. Cc: Andriy Shevchenko <andriy.shevchenko@intel.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-12-17imx-drm: imx-drm-core: improve safety of imx_drm_add_crtc()Russell King
We must not add more CRTCs than we have declared to the vblank helpers, otherwise we overflow their arrays. Force failure if we exceed the number of CRTCs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17imx-drm: imx-drm-core: make imx_drm_crtc_register() saferRussell King
imx_drm_crtc_register() doesn't clean up the CRTC upon failure, which leaves the CRTC attached to the DRM device. Also, it does setup after attaching the CRTC to the DRM device. Fix this by reordering the function such that we do the setup before drm_crtc_init(): this fixes both issues. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17imx-drm: imx-drm-core: use defined constant for number of CRTCs.Russell King
We have this definition, there's no reason not to use it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17imx-drm: imx-tve: don't call sleeping functions beneath enable_lock spinlockRussell King
Enable lock claims that it is serializing tve_enable/disable calls. However, DRM already serialises mode sets with a mutex, which prevents encoder/connector functions being called concurrently. Secondly, holding a spinlock while calling clk_prepare_enable() is wrong; it will cause a might_sleep() warning should that debugging be enabled. So, let's just get rid of the enable_lock. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17imx-drm: ipu-v3: fix potential CRTC device registration raceRussell King
Clean up the IPUv3 CRTC device registration; we don't need a separate function just to call platform_device_register_data(), and we don't need the return value converted at all. Update the IPU client id under a mutex, so that parallel probing doesn't race. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17imx-drm: imx-drm-core: fix DRM cleanup pathsRussell King
We must call drm_vblank_cleanup() on the error cleanup and unload paths after we've had a successful call to drm_vblank_init(). Ensure that the calls are in the reverse order to the initialisation order. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17imx-drm: imx-drm-core: fix error cleanup path for imx_drm_add_crtc()Russell King
imx_drm_add_crtc() was kfree'ing the imx_drm_crtc structure while leaving it on the list of CRTCs. Delete it from the list first. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Definitely seems quieter this week, Radeon, intel, intel broadwell, vmwgfx, ttm, armada, and a couple of core fixes, one revert in radeon Most of these are either going to stable or fixes for things introduced in the merge window" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (30 commits) drm/edid: add quirk for BPC in Samsung NP700G7A-S01PL notebook drm/ttm: Fix accesses through vmas with only partial coverage drm/nouveau: only runtime suspend by default in optimus configuration drm: don't double-free on driver load error Revert "drm/radeon: Implement radeon_pci_shutdown" drm/radeon: add missing display tiling setup for oland drm/radeon: fix typo in cik_copy_dma drm/radeon/cik: plug in missing blit callback drm/radeon/dpm: Fix hwmon crash drm/radeon: Fix sideport problems on certain RS690 boards drm/i915: don't update the dri1 breadcrumb with modesetting DRM: Armada: prime refcounting bug fix DRM: Armada: fix printing of phys_addr_t/dma_addr_t DRM: Armada: destroy framebuffer after helper DRM: Armada: implement lastclose() for fbhelper drm/i915: Repeat eviction search after idling the GPU drm/vmwgfx: Add max surface memory param drm/i915: Fix use-after-free in do_switch drm/i915: fix pm init ordering drm/i915: Hold mutex across i915_gem_release ...
2013-12-17tty: xuartps: Properly guard sysrq specific codeSoren Brinkmann
Commit 'tty: xuartps: Implement BREAK detection, add SYSRQ support' (0c0c47bc40a2e358d593b2d7fb93b50027fbfc0c) introduced sysrq support without properly guarding sysrq specific code which results in build errors when sysrq is disabled: DNAME=KBUILD_STR(xilinx_uartps)" -c -o drivers/tty/serial/.tmp_xilinx_uartps.o drivers/tty/serial/xilinx_uartps.c drivers/tty/serial/xilinx_uartps.c: In function 'xuartps_isr': drivers/tty/serial/xilinx_uartps.c:247:5: error: 'struct uart_port' has no member named 'sysrq' drivers/tty/serial/xilinx_uartps.c:247:5: error: 'struct uart_port' has no member named 'sysrq' drivers/tty/serial/xilinx_uartps.c:247:5: error: 'struct uart_port' has no member named 'sysrq' make[3]: *** [drivers/tty/serial/xilinx_uartps.o] Error 1 Reported-by: Masanari Iida <standby24x7@gmail.com> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A quick batch of fixes, including the annoying bad lock stack problem introduced by udp_sk_rx_dst_set() locking change: 1) Use xchg() instead of sk_dst_lock() in udp_sk_rx_dst_set(), from Eric Dumazet. 2) qlcnic bug fixes from Himanshu Madhani and Manish Chopra. 3) Update IPSEC MAINTAINERS entry, from Steffen Klassert. 4) Administrative neigh entry changes should generate netlink notifications the same as event generated ones. From Bob Gilligan. 5) Netfilter SYNPROXY fixes from Patrick McHardy. 6) Netfilter nft_reject endianness fixes from Eric Leblond" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: qlcnic: Dump mailbox registers when mailbox command times out. qlcnic: Fix mailbox processing during diagnostic test qlcnic: Allow firmware dump collection when auto firmware recovery is disabled qlcnic: Fix memory allocation qlcnic: Fix TSS/RSS validation for 83xx/84xx series adapter. qlcnic: Fix TSS/RSS ring validation logic. qlcnic: Fix diagnostic test for all adapters. qlcnic: Fix usage of netif_tx_{wake, stop} api during link change. xen-netback: fix fragments error handling in checksum_setup_ip() neigh: Netlink notification for administrative NUD state change ipv4: improve documentation of ip_no_pmtu_disc net: unix: allow bind to fail on mutex lock MAINTAINERS: Update the IPsec maintainer entry udp: ipv4: do not use sk_dst_lock from softirq context netvsc: don't flush peers notifying work during setting mtu can: peak_usb: fix mem leak in pcan_usb_pro_init() can: ems_usb: fix urb leaks on failure paths sctp: loading sctp when load sctp_probe netfilter: nft_reject: fix endianness in dump function netfilter: SYNPROXY target: restrict to INPUT/FORWARD
2013-12-17Merge branch 'fixes-for-3.13' of git://gitorious.org/linux-can/linux-canDavid S. Miller
Marc Kleine-Budde says: ==================== this is a pull request with two fixes for net/master, the current release cycle. It consists of a patch by Alexey Khoroshilov from the Linux Driver Verification project, which fixes a memory leak in ems_usb's failure patch. And a patch by me which fixes a memory leak in the peak usb driver. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17qlcnic: Dump mailbox registers when mailbox command times out.Manish chopra
Signed-off-by: Manish Chopra <manish.chopra@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17qlcnic: Fix mailbox processing during diagnostic testManish chopra
o Do not enable mailbox polling in case of legacy interrupt. Process mailbox AEN/response from the interrupt. Signed-off-by: Manish Chopra <manish.chopra@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17qlcnic: Allow firmware dump collection when auto firmware recovery is disabledManish Chopra
o Allow driver to collect firmware dump, during a forced firmware dump operation, when auto firmware recovery is disabled. Also, during this operation, driver should not allow reset recovery to be performed. Signed-off-by: Manish Chopra <manish.chopra@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17qlcnic: Fix memory allocationManish Chopra
o Use vzalloc() instead of kzalloc() for allocation of bootloader size memory. kzalloc() may fail to allocate the size of bootloader Signed-off-by: Manish Chopra <manish.chopra@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17qlcnic: Fix TSS/RSS validation for 83xx/84xx series adapter.Himanshu Madhani
o Current code was not allowing the user to configure more than one Tx ring using ethtool for 83xx/84xx adapter. This regression was introduced by commit id 18afc102fdcb95d6c7d57f2967a06f2f8fe3ba4c ("qlcnic: Enable multiple Tx queue support for 83xx/84xx Series adapter.") Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17qlcnic: Fix TSS/RSS ring validation logic.Himanshu Madhani
o TSS/RSS ring validation does not take into account that either of these ring values can be 0. This patch fixes this validation and would fail set_channel operation if any of these ring value is 0. This regression was added as part of commit id 34e8c406fda5b5a9d2e126a92bab84cd28e3b5fa ("qlcnic: refactor Tx/SDS ring calculation and validation in driver.") Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17qlcnic: Fix diagnostic test for all adapters.Himanshu Madhani
o Driver should re-allocate all Tx queues after completing diagnostic tests. This regression was added by commit id c2c5e3a0681bb1945c0cb211a5f4baa22cb2cbb3 ("qlcnic: Enable diagnostic test for multiple Tx queues.") Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17qlcnic: Fix usage of netif_tx_{wake, stop} api during link change.Himanshu Madhani
o Driver was using netif_tx_{stop,wake}_all_queues() api during link change event. Remove these api calls to manage queue start/stop event, as core networking stack will manage this based on netif_carrier_{on,off} call. These API's were modified as part of commit id 012ec81223aa45d2b80aeafb77392fd1a19c7b10 ("qlcnic: Multi Tx queue support for 82xx Series adapter.") Signed-off-by: Shahed Shaikh <shahed.shaikh@qlogic.com> Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17usb: ohci-at91: fix irq and iomem resource retrievalBoris BREZILLON
When using dt resources retrieval (interrupts and reg properties) there is no predefined order for these resources in the platform dev resources table. Retrieve resources using platform_get_resource and platform_get_irq functions instead of direct resource table entries to avoid resource type mismatch. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reviewed-by: Tomasz Figa <tomasz.figa@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17xen-netback: fix fragments error handling in checksum_setup_ip()Wei Yongjun
Fix to return -EPROTO error if fragments detected in checksum_setup_ip(). Fixes: 1431fb31ecba ('xen-netback: fix fragment detection in checksum setup') Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Paul Durrant <paul.durrant@citrix.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17staging: comedi: drivers: fix return value of comedi_load_firmware()H Hartley Sweeten
Some of the callback functions that upload the firmware in the comedi drivers return a positive value indicating the number of bytes sent to the device. Detect this condition and just return '0' to indicate a successful upload. Reported-by: Bernd Porr <mail@berndporr.me.uk> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ian Abbott <abbotti@mev.co.uk> Acked-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17staging: comedi: 8255_pci: fix for newer PCI-DIO48HIan Abbott
At some point, Measurement Computing / ComputerBoards redesigned the PCI-DIO48H to use a PLX PCI interface chip instead of an AMCC chip. This meant they had to put their hardware registers in the PCI BAR 2 region instead of PCI BAR 1. Unfortunately, they kept the same PCI device ID for the new design. This means the driver recognizes the newer cards, but doesn't work (and is likely to screw up the local configuration registers of the PLX chip) because it's using the wrong region. Since the PCI subvendor and subdevice IDs were both zero on the old design, but are the same as the vendor and device on the new design, we can tell the old design and new design apart easily enough. Split the existing entry for the PCI-DIO48H in `pci_8255_boards[]` into two new entries, referenced by different entries in the PCI device ID table `pci_8255_pci_table[]`. Use the same board name for both entries. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Cc: stablle <stable@vger.kernel.org> # 3.10.y # 3.11.y # 3.12.y # 3.13.y Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17Merge tag 'iio-fixes-for-3.13c' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: Third set of fixes for IIO in the 3.13 cycle. * Fix for a bug in the new cm36651 driver where it told the IIO driver it was providing a decimal part, but then didn't. Now it correctly tells the IIO core that it is only providing an integer value. This prevents random incorrect values being output on a sysfs read. * 3 fixes where drivers were miss specifying the endianness of their channels as output through the buffer interface. These were discovered whilst removing the terrible IIO_ST macro once and for all. The result is that userspace may be informed that the buffer elements are being output as little endian (on little endian platforms) when infact they are big endian. Thus userspace will handle them incorrectly. This incorrect buffer element specification is provided as sysfs attributes under iio:deviceN/scan_elements.
2013-12-17Merge tag 's2mps11-build' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator/clk fix from Mark Brown: "Fix s2mps11 build This patch fixes a build failure that appeared in v3.13-rc4 due to an RTC/MFD update merged via -mm" * tag 's2mps11-build' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: mfd: s2mps11: Fix build after regmap field rename in sec-core.c
2013-12-17iio:adc:ad7887 Fix channel reported endianness from cpu to big endianiio-fixes-for-3.13cJonathan Cameron
Note this also sets the endianness to big endian whereas it would previously have defaulted to the cpu endian. Hence technically this is a bug fix on LE platforms. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Cc: stable@vger.kernel.org
2013-12-17Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Ingo Molnar: "Five self-contained fixlets: - fix clocksource driver build bug - fix two sched_clock() bugs triggering on specific hardware - fix devicetree enumeration bug affecting specific hardware - fix irq handler registration race resulting in boot crash - fix device node refcount bug" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: dw_apb_timer_of: Fix support for dts binding "snps,dw-apb-timer" clocksource: dw_apb_timer_of: Fix read_sched_clock clocksource: sunxi: Stop timer from ticking before enabling interrupts clocksource: clksrc-of: Do not drop unheld reference on device node clocksource: armada-370-xp: Register sched_clock after the counter reset clocksource: time-efm32: Select CLKSRC_MMIO
2013-12-17iio:imu:adis16400 fix pressure channel scan typeJonathan Cameron
A single channel in this driver was using the IIO_ST macro. This does not provide a parameter for setting the endianness of the channel. Thus this channel will have been reported as whatever is the native endianness of the cpu rather than big endian. This means it would be incorrect on little endian platforms. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Cc: stable@vger.kernel.org
2013-12-17staging:iio:mag:hmc5843 fix incorrect endianness of channel as a result of ↵Jonathan Cameron
missuse of the IIO_ST macro. This driver sets the shift value equal to IIO_BE (or 1) rather than setting that to 0 and specificying the endianness. This means the channel type is missreported as [be|le]:u16/16>>1 where the be|le is dependent on the cpu native endianness, rather than be:u16/16>>0 resulting in any userspace code using this information, miss converting the channel and generating thoroughly trashed data. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Cc: stable@vger.kernel.org
2013-12-17Merge tag 'gpio-v3.13-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO fixes from Linus Walleij: "All but one are long-standing bug fixes that are also tagged for stable - Driver bug fixes for SH PFC, TWL4030, MSM and RCAR. - Update the MAINTAINERS" * tag 'gpio-v3.13-4' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio: rcar: Fix level interrupt handling gpio: msm: Fix irq mask/unmask by writing bits instead of numbers gpio: twl4030: Fix regression for twl gpio LED output sh-pfc: Fix PINMUX_GPIO macro MAINTAINERS: update GPIO maintainers entry
2013-12-17netvsc: don't flush peers notifying work during setting mtuJason Wang
There's a possible deadlock if we flush the peers notifying work during setting mtu: [ 22.991149] ====================================================== [ 22.991173] [ INFO: possible circular locking dependency detected ] [ 22.991198] 3.10.0-54.0.1.el7.x86_64.debug #1 Not tainted [ 22.991219] ------------------------------------------------------- [ 22.991243] ip/974 is trying to acquire lock: [ 22.991261] ((&(&net_device_ctx->dwork)->work)){+.+.+.}, at: [<ffffffff8108af95>] flush_work+0x5/0x2e0 [ 22.991307] but task is already holding lock: [ 22.991330] (rtnl_mutex){+.+.+.}, at: [<ffffffff81539deb>] rtnetlink_rcv+0x1b/0x40 [ 22.991367] which lock already depends on the new lock. [ 22.991398] the existing dependency chain (in reverse order) is: [ 22.991426] -> #1 (rtnl_mutex){+.+.+.}: [ 22.991449] [<ffffffff810dfdd9>] __lock_acquire+0xb19/0x1260 [ 22.991477] [<ffffffff810e0d12>] lock_acquire+0xa2/0x1f0 [ 22.991501] [<ffffffff81673659>] mutex_lock_nested+0x89/0x4f0 [ 22.991529] [<ffffffff815392b7>] rtnl_lock+0x17/0x20 [ 22.991552] [<ffffffff815230b2>] netdev_notify_peers+0x12/0x30 [ 22.991579] [<ffffffffa0340212>] netvsc_send_garp+0x22/0x30 [hv_netvsc] [ 22.991610] [<ffffffff8108d251>] process_one_work+0x211/0x6e0 [ 22.991637] [<ffffffff8108d83b>] worker_thread+0x11b/0x3a0 [ 22.991663] [<ffffffff81095e5d>] kthread+0xed/0x100 [ 22.991686] [<ffffffff81681c6c>] ret_from_fork+0x7c/0xb0 [ 22.991715] -> #0 ((&(&net_device_ctx->dwork)->work)){+.+.+.}: [ 22.991715] [<ffffffff810de817>] check_prevs_add+0x967/0x970 [ 22.991715] [<ffffffff810dfdd9>] __lock_acquire+0xb19/0x1260 [ 22.991715] [<ffffffff810e0d12>] lock_acquire+0xa2/0x1f0 [ 22.991715] [<ffffffff8108afde>] flush_work+0x4e/0x2e0 [ 22.991715] [<ffffffff8108e1b5>] __cancel_work_timer+0x95/0x130 [ 22.991715] [<ffffffff8108e303>] cancel_delayed_work_sync+0x13/0x20 [ 22.991715] [<ffffffffa03404e4>] netvsc_change_mtu+0x84/0x200 [hv_netvsc] [ 22.991715] [<ffffffff815233d4>] dev_set_mtu+0x34/0x80 [ 22.991715] [<ffffffff8153bc2a>] do_setlink+0x23a/0xa00 [ 22.991715] [<ffffffff8153d054>] rtnl_newlink+0x394/0x5e0 [ 22.991715] [<ffffffff81539eac>] rtnetlink_rcv_msg+0x9c/0x260 [ 22.991715] [<ffffffff8155cdd9>] netlink_rcv_skb+0xa9/0xc0 [ 22.991715] [<ffffffff81539dfa>] rtnetlink_rcv+0x2a/0x40 [ 22.991715] [<ffffffff8155c41d>] netlink_unicast+0xdd/0x190 [ 22.991715] [<ffffffff8155c807>] netlink_sendmsg+0x337/0x750 [ 22.991715] [<ffffffff8150d219>] sock_sendmsg+0x99/0xd0 [ 22.991715] [<ffffffff8150d63e>] ___sys_sendmsg+0x39e/0x3b0 [ 22.991715] [<ffffffff8150eba2>] __sys_sendmsg+0x42/0x80 [ 22.991715] [<ffffffff8150ebf2>] SyS_sendmsg+0x12/0x20 [ 22.991715] [<ffffffff81681d19>] system_call_fastpath+0x16/0x1b This is because we hold the rtnl_lock() before ndo_change_mtu() and try to flush the work in netvsc_change_mtu(), in the mean time, netdev_notify_peers() may be called from worker and also trying to hold the rtnl_lock. This will lead the flush won't succeed forever. Solve this by not canceling and flushing the work, this is safe because the transmission done by NETDEV_NOTIFY_PEERS was synchronized with the netif_tx_disable() called by netvsc_change_mtu(). Reported-by: Yaju Cao <yacao@redhat.com> Tested-by: Yaju Cao <yacao@redhat.com> Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17n_tty: Fix apparent order of echoed outputPeter Hurley
With block processing of echoed output, observed output order is still required. Push completed echoes and echo commands prior to output. Introduce echo_mark echo buffer index, which tracks completed echo commands; ie., those submitted via commit_echoes but which may not have been committed. Ensure that completed echoes are output prior to subsequent terminal writes in process_echoes(). Fixes newline/prompt output order in cooked mode shell. Cc: <stable@vger.kernel.org> # 3.12.x : 39434ab n_tty: Fix missing newline echo Reported-by: Karl Dahlke <eklhad@comcast.net> Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Tested-by: Karl Dahlke <eklhad@comcast.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-17serial: 8250_dw: add new ACPI IDsMika Westerberg
Newer Intel PCHs with LPSS have the same Designware controllers than Haswell but ACPI IDs are different. Add these IDs to the driver list. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
