path: root/drivers
2013-07-21iio: ti_am335x_adc: Fix wrong samples received on 1st readiio-fixes-for-3.11bPatil, Rachna
Previously we tried to read data form ADC even before ADC sequencer finished sampling. This led to wrong samples. We now wait on ADC status register idle bit to be set. Signed-off-by: Patil, Rachna <rachna@ti.com> Signed-off-by: Zubair Lutfullah <zubair.lutfullah@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-07-20iio:trigger: Fix use_count race conditionLars-Peter Clausen
When using more than one trigger consumer it can happen that multiple threads perform a read-modify-update cycle on 'use_count' concurrently. This can cause updates to be lost and use_count can get stuck at non-zero value, in which case the IIO core assumes that at least one thread is still running and will wait for it to finish before running any trigger handlers again. This effectively renders the trigger disabled and a reboot is necessary before it can be used again. To fix this make use_count an atomic variable. Also set it to the number of consumers before starting the first consumer, otherwise it might happen that use_count drops to 0 even though not all consumers have been run yet. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-07-16Merge tag 'iio-fixes-for-3.11a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: The first round of IIO fixes for the 3.11 cycle. This set is larger than I would like, partly due to my lack of review time in the weeks before the merge window and partly because a couple of large drivers and the subsystem as a whole seem to be getting a lot more exposure and testing recently. 1) A long term bug in trigger handling gave a double free of the device. 2) Wrong return value handling means offsets are ignored in iio_convert_raw_to_processed_unlocked. 3) The iio_channel_has_info utility function was incorrectly updated during the recent info_mask split, this is now fixed. 4) mxs-lradc has a couple of little fixes. 5) A couple of missing .driver_module entries meant that drivers could be removed from underneath their users. 6) Error path fixes for ad7303 and lis3l02dq. 7) The scale value for presure in the lps331ap driver was out by a factor of 100.
2013-07-16staging: csr: remove driverGreg Kroah-Hartman
This driver is not being updated as the specifications are not able to be gotten from CSR or anyone else. Without those, getting this driver into proper mergable shape is going to be impossible. So remove the driver from the tree. If the specifications ever become available, this patch can be reverted and the driver fixed up properly. Reported-by: Lidza Louina <lidza.louina@gmail.com> Cc: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Cc: Mikko Virkkilä <mikko.virkkila@bluegiga.com> Cc: Lauri Hintsala <Lauri.Hintsala@bluegiga.com> Cc: Riku Mettälä <riku.mettala@bluegiga.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-16iio: lps331ap: Fix wrong in_pressure_scale output valueiio-fixes-for-3.11aJacek Anaszewski
This patch fixes improper in_pressure_scale output that is returned by the lps331ap barometer sensor driver. According to the documentation the pressure after applying the scale has to be expressed in kilopascal units. With erroneous implementation the scale value larger by two orders of magnitude is returned - 2441410 instead of 24414. Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-07-14Linux 3.11-rc1v3.11-rc1Linus Torvalds
2013-07-13Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver updates from Matthew Garrett: "Nothing overly exciting here - a couple of new drivers that don't do a great deal, along with some miscellaneous fixes and a couple of small feature enablement patches" * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: x86 platform drivers: fix gpio leak toshiba_acpi: Add dependency on SERIO_I8042 asus-nb-wmi: set wapf=4 for ASUSTeK COMPUTER INC. 1015E/U Add trivial driver to disable Intel Smart Connect Add support driver for Intel Rapid Start Technology hp-wmi: add supports for POST code error asus-wmi: control wlan-led only if wapf == 4 drivers/platform/x86/intel_ips: Convert to module_pci_driver asus-nb-wmi: ignore ALS notification key code asus-wmi: append newline to messages x86: asus-laptop: fix invalid point access x86: msi-laptop: fix memleak amilo-rfkill: Add dependency on SERIO_I8042 dell-laptop: fix error return code in dell_init() hp-wmi: Enable hotkeys on some systems
2013-07-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull second round of input updates from Dmitry Torokhov: "An update to Elantech driver to support hardware v7, fix to the new cyttsp4 driver to use proper addressing, ads7846 device tree support and nspire-keypad got a small cleanup." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: nspire-keypad - replace magic offset with define Input: elantech - fix for newer hardware versions (v7) Input: cyttsp4 - use 16bit address for I2C/SPI communication Input: ads7846 - add device tree bindings Input: ads7846 - make sure we do not change platform data
2013-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Just a bunch of small fixes and tidy ups: 1) Finish the "busy_poll" renames, from Eliezer Tamir. 2) Fix RCU stalls in IFB driver, from Ding Tianhong. 3) Linearize buffers properly in tun/macvtap zerocopy code. 4) Don't crash on rmmod in vxlan, from Pravin B Shelar. 5) Spinlock used before init in alx driver, from Maarten Lankhorst. 6) A sparse warning fix in bnx2x broke TSO checksums, fix from Dmitry Kravkov. 7) Dummy and ifb driver load failure paths can oops, fixes from Tan Xiaojun and Ding Tianhong. 8) Correct MTU calculations in IP tunnels, from Alexander Duyck. 9) Account all TCP retransmits in SNMP stats properly, from Yuchung Cheng. 10) atl1e and via-rhine do not handle DMA mapping failures properly, from Neil Horman. 11) Various equal-cost multipath route fixes in ipv6 from Hannes Frederic Sowa" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (36 commits) ipv6: only static routes qualify for equal cost multipathing via-rhine: fix dma mapping errors atl1e: fix dma mapping warnings tcp: account all retransmit failures usb/net/r815x: fix cast to restricted __le32 usb/net/r8152: fix integer overflow in expression net: access page->private by using page_private net: strict_strtoul is obsolete, use kstrtoul instead drivers/net/ieee802154: don't use devm_pinctrl_get_select_default() in probe drivers/net/ethernet/cadence: don't use devm_pinctrl_get_select_default() in probe drivers/net/can/c_can: don't use devm_pinctrl_get_select_default() in probe net/usb: add relative mii functions for r815x net/tipc: use %*phC to dump small buffers in hex form qlcnic: Adding Maintainers. gre: Fix MTU sizing check for gretap tunnels pkt_sched: sch_qfq: remove forward declaration of qfq_update_agg_ts pkt_sched: sch_qfq: improve efficiency of make_eligible gso: Update tunnel segmentation to support Tx checksum offload inet: fix spacing in assignment ifb: fix oops when loading the ifb failed ...
2013-07-13Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull final round of SCSI updates from James Bottomley: "This is the remaining set of SCSI patches for the merge window. It's mostly driver updates (scsi_debug, qla2xxx, storvsc, mp3sas). There are also several bug fixes in fcoe, libfc, and megaraid_sas. We also have a couple of core changes to try to make device destruction more deterministic" * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (46 commits) [SCSI] scsi constants: command, sense key + additional sense strings fcoe: Reduce number of sparse warnings fcoe: Stop fc_rport_priv structure leak libfcoe: Fix meaningless log statement libfc: Differentiate echange timer cancellation debug statements libfc: Remove extra space in fc_exch_timer_cancel definition fcoe: fix the link error status block sparse warnings fcoe: Fix smatch warning in fcoe_fdmi_info function libfc: Reject PLOGI from nodes with incompatible role [SCSI] enable destruction of blocked devices which fail LUN scanning [SCSI] Fix race between starved list and device removal [SCSI] megaraid_sas: fix a bug for 64 bit arches [SCSI] scsi_debug: reduce duplication between prot_verify_read and prot_verify_write [SCSI] scsi_debug: simplify offset calculation for dif_storep [SCSI] scsi_debug: invalidate protection info for unmapped region [SCSI] scsi_debug: fix NULL pointer dereference with parameters dif=0 dix=1 [SCSI] scsi_debug: fix incorrectly nested kmap_atomic() [SCSI] scsi_debug: fix invalid address passed to kunmap_atomic() [SCSI] mpt3sas: Bump driver version to v02.100.00.00 [SCSI] mpt3sas: when async scanning is enabled then while scanning, devices are removed but their transport layer entries are not removed ...
2013-07-13Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: - core fix for missing round up in the generic irq chip implementation - new irq chip for MOXA SoCs - a few fixes and cleanups in the irqchip drivers * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: Add support for MOXA ART SoCs genirq: generic chip: Use DIV_ROUND_UP to calculate numchips irqchip: nvic: Fix wrong num_ct argument for irq_alloc_domain_generic_chips() irqchip: sun4i: Staticize sun4i_irq_ack() irqchip: vt8500: Staticize local symbols
2013-07-13Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: - watchdog fixes for full dynticks - improved debug output for full dynticks - remove an obsolete full dynticks check - two ARM SoC clocksource drivers for sharing across SoCs - tick broadcast fix for CPU hotplug * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick: broadcast: Check broadcast mode on CPU hotplug clocksource: arm_global_timer: Add ARM global timer support clocksource: Add Marvell Orion SoC timer nohz: Remove obsolete check for full dynticks CPUs to be RCU nocbs watchdog: Boot-disable by default on full dynticks watchdog: Rename confusing state variable watchdog: Register / unregister watchdog kthreads on sysctl control nohz: Warn if the machine can not perform nohz_full
2013-07-13Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "MIPS updates: - All the things that didn't make 3.10. - Removes the Windriver PPMC platform. Nobody will miss it. - Remove a workaround from kernel/irq/irqdomain.c which was there exclusivly for MIPS. Patch by Grant Likely. - More small improvments for the SEAD 3 platform - Improvments on the BMIPS / SMP support for the BCM63xx series. - Various cleanups of dead leftovers. - Platform support for the Cavium Octeon-based EdgeRouter Lite. Two large KVM patchsets didn't make it for this pull request because their respective authors are vacationing" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (124 commits) MIPS: Kconfig: Add missing MODULES dependency to VPE_LOADER MIPS: BCM63xx: CLK: Add dummy clk_{set,round}_rate() functions MIPS: SEAD3: Disable L2 cache on SEAD-3. MIPS: BCM63xx: Enable second core SMP on BCM6328 if available MIPS: BCM63xx: Add SMP support to prom.c MIPS: define write{b,w,l,q}_relaxed MIPS: Expose missing pci_io{map,unmap} declarations MIPS: Malta: Update GCMP detection. Revert "MIPS: make CAC_ADDR and UNCAC_ADDR account for PHYS_OFFSET" MIPS: APSP: Remove <asm/kspd.h> SSB: Kconfig: Amend SSB_EMBEDDED dependencies MIPS: microMIPS: Fix improper definition of ISA exception bit. MIPS: Don't try to decode microMIPS branch instructions where they cannot exist. MIPS: Declare emulate_load_store_microMIPS as a static function. MIPS: Fix typos and cleanup comment MIPS: Cleanup indentation and whitespace MIPS: BMIPS: support booting from physical CPU other than 0 MIPS: Only set cpu_has_mmips if SYS_SUPPORTS_MICROMIPS MIPS: GIC: Fix gic_set_affinity infinite loop MIPS: Don't save/restore OCTEON wide multiplier state on syscalls. ...
2013-07-13Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: - lots of devm_ conversions and cleanup - platform_set_drvdata cleanups - s3c2410: dev_err/dev_info + dev_pm_ops - watchdog_core: don't try to stop device if not running fix - wdrtas: use print_hex_dump - xilinx cleanups - orion_wdt fixes - softdog cleanup - hpwdt: check on UEFI bits - deletion of mpcore_wdt driver - addition of broadcom BCM2835 watchdog timer driver - addition of MEN A21 watcdog devices * git://www.linux-watchdog.org/linux-watchdog: (38 commits) watchdog: hpwdt: Add check for UEFI bits watchdog: softdog: remove replaceable ping operation watchdog: New watchdog driver for MEN A21 watchdogs Watchdog: fix clearing of the watchdog interrupt Watchdog: allow orion_wdt to be built for Dove watchdog: Add Broadcom BCM2835 watchdog timer driver watchdog: delete mpcore_wdt driver watchdog: xilinx: Setup the origin compatible string watchdog: xilinx: Fix driver header watchdog: wdrtas: don't use custom version of print_hex_dump watchdog: core: don't try to stop device if not running watchdog: jz4740: Pass device to clk_get watchdog: twl4030: Remove redundant platform_set_drvdata() watchdog: mpcore: Remove redundant platform_set_drvdata() watchdog: da9055: use platform_{get,set}_drvdata() watchdog: da9052: use platform_{get,set}_drvdata() watchdog: cpwd: use platform_{get,set}_drvdata() watchdog: s3c2410_wdt: convert s3c2410wdt to dev_pm_ops watchdog: s3c2410_wdt: use dev_err()/dev_info() instead of pr_err()/pr_info() watchdog: wm831x: use platform_{get,set}_drvdata() ...
2013-07-13Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull InfiniBand/RDMA changes from Roland Dreier: - AF_IB (native IB addressing) for CMA from Sean Hefty - new mlx5 driver for Mellanox Connect-IB adapters (including post merge request fixes) - SRP fixes from Bart Van Assche (including fix to first merge request) - qib HW driver updates - resurrection of ocrdma HW driver development - uverbs conversion to create fds with O_CLOEXEC set - other small changes and fixes * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (66 commits) mlx5: Return -EFAULT instead of -EPERM IB/qib: Log all SDMA errors unconditionally IB/qib: Fix module-level leak mlx5_core: Adjust hca_cap.uar_page_sz to conform to Connect-IB spec IB/srp: Let srp_abort() return FAST_IO_FAIL if TL offline IB/uverbs: Use get_unused_fd_flags(O_CLOEXEC) instead of get_unused_fd() mlx5_core: Fixes for sparse warnings IB/mlx5: Make profile[] static in main.c mlx5: Fix parameter type of health_handler_t mlx5: Add driver for Mellanox Connect-IB adapters IB/core: Add reserved values to enums for low-level driver use IB/srp: Bump driver version and release date IB/srp: Make HCA completion vector configurable IB/srp: Maintain a single connection per I_T nexus IB/srp: Fail I/O fast if target offline IB/srp: Skip host settle delay IB/srp: Avoid skipping srp_reset_host() after a transport error IB/srp: Fix remove_one crash due to resource exhaustion IB/qib: New transmitter tunning settings for Dell 1.1 backplane IB/core: Fix error return code in add_port() ...
2013-07-13Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This series contain: - new i2c video drivers: ml86v7667 (video decoder), ths8200 (video encoder) - a new video driver for EasyCap cards based on Fushicai USBTV007 - Improved support for OF and embedded systems, with V4L2 async initialization and a better support for clocks - API cleanups on the ioctls used by the v4l2 debug tool - Lots of cleanups - As usual, several driver improvements and new cards additions - Revert two changesets that change the minimal symbol rate for stv0399, as request by Manu - Update MAINTAINERS and other files to point to my new e-mail" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (378 commits) MAINTAINERS & ABI: Update to point to my new email [media] stb0899: restore minimal rate to 5Mbauds [media] exynos4-is: Correct colorspace handling at FIMC-LITE [media] exynos4-is: Set valid initial format on FIMC.n subdevs [media] exynos4-is: Set valid initial format on FIMC-IS-ISP subdev pads [media] exynos4-is: Fix format propagation on FIMC-IS-ISP subdev [media] exynos4-is: Set valid initial format at FIMC-LITE [media] exynos4-is: Fix format propagation on FIMC-LITE.n subdevs [media] MAINTAINERS: Update S5P/Exynos FIMC driver entry [media] Documentation: Update driver's directory in video4linux/fimc.txt [media] exynos4-is: Change fimc-is firmware file names [media] exynos4-is: Add support for Exynos5250 MIPI-CSIS [media] exynos4-is: Add Exynos5250 SoC support to fimc-lite driver [media] exynos4-is: Drop drvdata handling in fimc-lite for non-dt platforms [media] media: i2c: tvp514x: remove manual setting of subdev name [media] media: i2c: tvp7002: remove manual setting of subdev name [media] mem2mem: set missing v4l2_dev pointer [media] wl128x: add missing struct v4l2_device [media] tvp514x: Fix init seqeunce [media] saa7134: Fix sparse warnings by adding __user annotation ...
2013-07-12Merge branch 'next' into for-linusDmitry Torokhov
Bring in second round of updates for 3.11.
2013-07-13Merge tag 'fcoe' into for-linusJames Bottomley
A short series of fixes to libfc, libfcoe and fcoe. Most patches fix formatting problems, one changes the behavior of which discovered ports can/will be logged into and another fixes a memory leak.
2013-07-12via-rhine: fix dma mapping errorsNeil Horman
this bug: https://bugzilla.redhat.com/show_bug.cgi?id=951695 Reported a dma debug backtrace: WARNING: at lib/dma-debug.c:937 check_unmap+0x47d/0x930() Hardware name: To Be Filled By O.E.M. via-rhine 0000:00:12.0: DMA-API: device driver failed to check map error[device address=0x0000000075a837b2] [size=90 bytes] [mapped as single] Modules linked in: ip6_tables gspca_spca561 gspca_main videodev media snd_hda_codec_realtek snd_hda_intel i2c_viapro snd_hda_codec snd_hwdep snd_seq ppdev mperf via_rhine coretemp snd_pcm mii microcode snd_page_alloc snd_timer snd_mpu401 snd_mpu401_uart snd_rawmidi snd_seq_device snd soundcore parport_pc parport shpchp ata_generic pata_acpi radeon i2c_algo_bit drm_kms_helper ttm drm pata_via sata_via i2c_core uinput Pid: 295, comm: systemd-journal Not tainted 3.9.0-0.rc6.git2.1.fc20.x86_64 #1 Call Trace: <IRQ> [<ffffffff81068dd0>] warn_slowpath_common+0x70/0xa0 [<ffffffff81068e4c>] warn_slowpath_fmt+0x4c/0x50 [<ffffffff8137ec6d>] check_unmap+0x47d/0x930 [<ffffffff810ace9f>] ? local_clock+0x5f/0x70 [<ffffffff8137f17f>] debug_dma_unmap_page+0x5f/0x70 [<ffffffffa0225edc>] ? rhine_ack_events.isra.14+0x3c/0x50 [via_rhine] [<ffffffffa02275f8>] rhine_napipoll+0x1d8/0xd80 [via_rhine] [<ffffffff815d3d51>] ? net_rx_action+0xa1/0x380 [<ffffffff815d3e22>] net_rx_action+0x172/0x380 [<ffffffff8107345f>] __do_softirq+0xff/0x400 [<ffffffff81073925>] irq_exit+0xb5/0xc0 [<ffffffff81724cd6>] do_IRQ+0x56/0xc0 [<ffffffff81719ff2>] common_interrupt+0x72/0x72 <EOI> [<ffffffff8170ff57>] ? __slab_alloc+0x4c2/0x526 [<ffffffff811992e0>] ? mmap_region+0x2b0/0x5a0 [<ffffffff810d5807>] ? __lock_is_held+0x57/0x80 [<ffffffff811992e0>] ? mmap_region+0x2b0/0x5a0 [<ffffffff811bf1bf>] kmem_cache_alloc+0x2df/0x360 [<ffffffff811992e0>] mmap_region+0x2b0/0x5a0 [<ffffffff811998e6>] do_mmap_pgoff+0x316/0x3d0 [<ffffffff81183ca0>] vm_mmap_pgoff+0x90/0xc0 [<ffffffff81197d6c>] sys_mmap_pgoff+0x4c/0x190 [<ffffffff81367d7e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff8101eb42>] sys_mmap+0x22/0x30 [<ffffffff81722fd9>] system_call_fastpath+0x16/0x1b Usual problem with the usual fix, add the appropriate calls to dma_mapping_error where appropriate Untested, as I don't have hardware, but its pretty straightforward Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: David S. Miller <davem@davemloft.net> CC: Roger Luethi <rl@hellgate.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-12atl1e: fix dma mapping warningsNeil Horman
Recently had this backtrace reported: WARNING: at lib/dma-debug.c:937 check_unmap+0x47d/0x930() Hardware name: System Product Name ATL1E 0000:02:00.0: DMA-API: device driver failed to check map error[device address=0x00000000cbfd1000] [size=90 bytes] [mapped as single] Modules linked in: xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables snd_hda_codec_hdmi snd_hda_codec_realtek iTCO_wdt iTCO_vendor_support snd_hda_intel acpi_cpufreq mperf coretemp btrfs zlib_deflate snd_hda_codec snd_hwdep microcode raid6_pq libcrc32c snd_seq usblp serio_raw xor snd_seq_device joydev snd_pcm snd_page_alloc snd_timer snd lpc_ich i2c_i801 soundcore mfd_core atl1e asus_atk0110 ata_generic pata_acpi radeon i2c_algo_bit drm_kms_helper ttm drm i2c_core pata_marvell uinput Pid: 314, comm: systemd-journal Not tainted 3.9.0-0.rc6.git2.3.fc19.x86_64 #1 Call Trace: <IRQ> [<ffffffff81069106>] warn_slowpath_common+0x66/0x80 [<ffffffff8106916c>] warn_slowpath_fmt+0x4c/0x50 [<ffffffff8138151d>] check_unmap+0x47d/0x930 [<ffffffff810ad048>] ? sched_clock_cpu+0xa8/0x100 [<ffffffff81381a2f>] debug_dma_unmap_page+0x5f/0x70 [<ffffffff8137ce30>] ? unmap_single+0x20/0x30 [<ffffffffa01569a1>] atl1e_intr+0x3a1/0x5b0 [atl1e] [<ffffffff810d53fd>] ? trace_hardirqs_off+0xd/0x10 [<ffffffff81119636>] handle_irq_event_percpu+0x56/0x390 [<ffffffff811199ad>] handle_irq_event+0x3d/0x60 [<ffffffff8111cb6a>] handle_fasteoi_irq+0x5a/0x100 [<ffffffff8101c36f>] handle_irq+0xbf/0x150 [<ffffffff811dcb2f>] ? file_sb_list_del+0x3f/0x50 [<ffffffff81073b10>] ? irq_enter+0x50/0xa0 [<ffffffff8172738d>] do_IRQ+0x4d/0xc0 [<ffffffff811dcb2f>] ? file_sb_list_del+0x3f/0x50 [<ffffffff8171c6b2>] common_interrupt+0x72/0x72 <EOI> [<ffffffff810db5b2>] ? lock_release+0xc2/0x310 [<ffffffff8109ea04>] lg_local_unlock_cpu+0x24/0x50 [<ffffffff811dcb2f>] file_sb_list_del+0x3f/0x50 [<ffffffff811dcb6d>] fput+0x2d/0xc0 [<ffffffff811d8ea1>] filp_close+0x61/0x90 [<ffffffff811fae4d>] __close_fd+0x8d/0x150 [<ffffffff811d8ef0>] sys_close+0x20/0x50 [<ffffffff81725699>] system_call_fastpath+0x16/0x1b The usual straighforward failure to check for dma_mapping_error after a map operation is completed. This patch should fix it, the reporter wandered off after filing this bz: https://bugzilla.redhat.com/show_bug.cgi?id=954170 and I don't have hardware to test, but the fix is pretty straightforward, so I figured I'd post it for review. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Jay Cliburn <jcliburn@gmail.com> CC: Chris Snook <chris.snook@gmail.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-12usb/net/r815x: fix cast to restricted __le32hayeswang
>> drivers/net/usb/r815x.c:38:16: sparse: cast to restricted __le32 >> drivers/net/usb/r815x.c:67:15: sparse: cast to restricted __le32 >> drivers/net/usb/r815x.c:69:13: sparse: incorrect type in assignment (different base types) drivers/net/usb/r815x.c:69:13: expected unsigned int [unsigned] [addressable] [assigned] [usertype] tmp drivers/net/usb/r815x.c:69:13: got restricted __le32 [usertype] <noident> Signed-off-by: Hayes Wang <hayeswang@realtek.com> Spotted-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-12usb/net/r8152: fix integer overflow in expressionhayeswang
config: make ARCH=avr32 allyesconfig drivers/net/usb/r8152.c: In function 'rtl8152_start_xmit': drivers/net/usb/r8152.c:956: warning: integer overflow in expression 955 memset(tx_desc, 0, sizeof(*tx_desc)); > 956 tx_desc->opts1 = cpu_to_le32((len & TX_LEN_MASK) | TX_FS | TX_LS); 957 tp->tx_skb = skb; Signed-off-by: Hayes Wang <hayeswang@realtek.com> Spotted-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-12Merge branch '3.10-fixes' into mips-for-linux-nextRalf Baechle
This that should have been fixed but weren't, way to much, intrusive and late.
2013-07-12Merge branch 'timers/clockevents' of ↵Thomas Gleixner
git://git.linaro.org/people/dlezcano/clockevents into timers/urgent * New clocksource drivers for ARM SoCs to share
2013-07-11drivers/net/ieee802154: don't use devm_pinctrl_get_select_default() in probeWolfram Sang
Since commit ab78029 (drivers/pinctrl: grab default handles from device core), we can rely on device core for setting the default pins. Compile tested only. Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-11drivers/net/ethernet/cadence: don't use devm_pinctrl_get_select_default() in ↵Wolfram Sang
probe Since commit ab78029 (drivers/pinctrl: grab default handles from device core), we can rely on device core for setting the default pins. Compile tested only. Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-11drivers/net/can/c_can: don't use devm_pinctrl_get_select_default() in probeWolfram Sang
Since commit ab78029 (drivers/pinctrl: grab default handles from device core), we can rely on device core for setting the default pins. Compile tested only. Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-11net/usb: add relative mii functions for r815xhayeswang
Base on cdc_ether, add the mii functions for RTL8152 and RTL8153. The RTL8152 and RTL8153 support ECM mode which use the driver of cdc_ether. Add the mii functions. Then, the basic PHY access is possible. Signed-off-by: Hayes Wang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-11Merge branches 'mlx5', 'qib' and 'srp' into for-nextRoland Dreier
2013-07-11mlx5: Return -EFAULT instead of -EPERMDan Carpenter
For copy_to/from_user() failure, the correct error code is -EFAULT not -EPERM. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-07-11IB/qib: Log all SDMA errors unconditionallyDean Luick
This patch adds code to log SDMA errors for supportability purposes. Signed-off-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-07-11IB/qib: Fix module-level leakMike Marciniszyn
The vzalloc()'ed field physshadow is leaked on module unload. This patch adds vfree after the sibling page shadow is freed. Reported-by: Dean Luick <dean.luick@intel.com> Reviewed-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-07-11mlx5_core: Adjust hca_cap.uar_page_sz to conform to Connect-IB specMoshe Lazer
Sparse reported an endianness bug in the assignment to hca_cap.uar_page_sz. Fix the declaration of this field to be __be16 (which is what is in the firmware spec), renaming the field to log_uar_pg_size to conform to the spec, which fixes the endianness bug reported by sparse. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Moshe Lazer <moshel@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-07-11IB/srp: Let srp_abort() return FAST_IO_FAIL if TL offlineBart Van Assche
If the transport layer is offline it is more appropriate to let srp_abort() return FAST_IO_FAIL instead of SUCCESS. Reported-by: Sebastian Riemer <sebastian.riemer@profitbricks.com> Acked-by: David Dillow <dillowda@ornl.gov> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-07-11watchdog: hpwdt: Add check for UEFI bitsMingarelli, Thomas
This patch is being created to use the UEFI bits in the type 219 SMBIOS record in order to decide whether or not to execute BIOS code. This is a better solution than to depend on the iCRU bit since not all future servers will use iCRU. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> ---- drivers/watchdog/hpwdt.c | 9 ++++++--- 1 files changed, 6 insertions(+), 3 deletions(-)
2013-07-11watchdog: softdog: remove replaceable ping operationKim, Milo
In watchdog_ping(), 'start' is called automatically when 'ping' function call is not configured. Softdog driver has same handling in both cases - start and ping, so 'ping' OPS can be removed. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-11watchdog: New watchdog driver for MEN A21 watchdogsJohannes Thumshirn
This patch adds the driver for the watchdog devices found on MEN Mikro Elektronik A21 VMEbus CPU Carrier Boards. It has DT-support and uses the watchdog framework. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-11Watchdog: fix clearing of the watchdog interruptRussell King
The bits in BRIDGE_CAUSE are documented as RW0C - read, write 0 to clear. If we read the register, mask off the watchdog bit, and write it back, we're actually clearing every interrupt which wasn't pending at the time we read the register - and that is racy. Fix this to only write ~WATCHDOG_BIT to the register, which means we write as zero only the watchdog bit. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Jason Cooper <jason@lakedaemon.net> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-11Watchdog: allow orion_wdt to be built for DoveRussell King
The watchdog infrastructure in Dove is no different from that in Orion5x or Kirkwood, so let's enable it for Dove. The only things missing are a few register settings in Dove's bridge-regs.h. Rather than duplicating the same register bit masks for the RSTOUTn_MASK and BRIDGE_CAUSE registers, move the definitions into the watchdog driver itself. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Jason Cooper <jason@lakedaemon.net> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-11watchdog: Add Broadcom BCM2835 watchdog timer driverLubomir Rintel
This adds a driver for watchdog timer hardware present on Broadcom BCM2835 SoC, used in Raspberry Pi and Roku 2 devices. Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: linux-rpi-kernel@lists.infradead.org Cc: linux-watchdog@vger.kernel.org Cc: devicetree-discuss@lists.ozlabs.org
2013-07-11Merge tag 'dm-3.11-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper changes from Alasdair G Kergon: "Add a device-mapper target called dm-switch to provide a multipath framework for storage arrays that dynamically reconfigure their preferred paths for different device regions. Fix a bug in the verity target that prevented its use with some specific sizes of devices. Improve some locking mechanisms in the device-mapper core and bufio. Add Mike Snitzer as a device-mapper maintainer. A few more clean-ups and fixes" * tag 'dm-3.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: dm: add switch target dm: update maintainers dm: optimize reorder structure dm: optimize use SRCU and RCU dm bufio: submit writes outside lock dm cache: fix arm link errors with inline dm verity: use __ffs and __fls dm flakey: correct ctr alloc failure mesg dm verity: remove pointless comparison dm: use __GFP_HIGHMEM in __vmalloc dm verity: fix inability to use a few specific devices sizes dm ioctl: set noio flag to avoid __vmalloc deadlock dm mpath: fix ioctl deadlock when no paths
2013-07-11Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "Lots of activity this round on performance improvements in target-core while benchmarking the prototype scsi-mq initiator code with vhost-scsi fabric ports, along with a number of iscsi/iser-target improvements and hardening fixes for exception path cases post v3.10 merge. The highlights include: - Make persistent reservations APTPL buffer allocated on-demand, and drop per t10_reservation buffer. (grover) - Make virtual LUN=0 a NULLIO device, and skip allocation of NULLIO device pages (grover) - Add transport_cmd_check_stop write_pending bit to avoid extra access of ->t_state_lock is WRITE I/O submission fast-path. (nab) - Drop unnecessary CMD_T_DEV_ACTIVE check from transport_lun_remove_cmd to avoid extra access of ->t_state_lock in release fast-path. (nab) - Avoid extra t_state_lock access in __target_execute_cmd fast-path (nab) - Drop unnecessary vhost-scsi wait_for_tasks=true usage + ->t_state_lock access in release fast-path. (nab) - Convert vhost-scsi to use modern se_cmd->cmd_kref TARGET_SCF_ACK_KREF usage (nab) - Add tracepoints for SCSI commands being processed (roland) - Refactoring of iscsi-target handling of ISCSI_OP_NOOP + ISCSI_OP_TEXT to be transport independent (nab) - Add iscsi-target SendTargets=$IQN support for in-band discovery (nab) - Add iser-target support for in-band discovery (nab + Or) - Add iscsi-target demo-mode TPG authentication context support (nab) - Fix isert_put_reject payload buffer post (nab) - Fix iscsit_add_reject* usage for iser (nab) - Fix iscsit_sequence_cmd reject handling for iser (nab) - Fix ISCSI_OP_SCSI_TMFUNC handling for iser (nab) - Fix session reset bug with RDMA_CM_EVENT_DISCONNECTED (nab) The last five iscsi/iser-target items are CC'ed to stable, as they do address issues present in v3.10 code. They are certainly larger than I'd like for stable patch set, but are important to ensure proper REJECT exception handling in iser-target for 3.10.y" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits) iser-target: Ignore non TEXT + LOGOUT opcodes for discovery target: make queue_tm_rsp() return void target: remove unused codes from enum tcm_tmrsp_table iscsi-target: kstrtou* configfs attribute parameter cleanups iscsi-target: Fix tfc_tpg_auth_cit configfs length overflow iscsi-target: Fix tfc_tpg_nacl_auth_cit configfs length overflow iser-target: Add support for ISCSI_OP_TEXT opcode + payload handling iser-target: Rename sense_buf_[dma,len] to pdu_[dma,len] iser-target: Add vendor_err debug output target: Add (obsolete) checking for PMI/LBA fields in READ CAPACITY(10) target: Return correct sense data for IO past the end of a device target: Add tracepoints for SCSI commands being processed iser-target: Fix session reset bug with RDMA_CM_EVENT_DISCONNECTED iscsi-target: Fix ISCSI_OP_SCSI_TMFUNC handling for iser iscsi-target: Fix iscsit_sequence_cmd reject handling for iser iscsi-target: Fix iscsit_add_reject* usage for iser iser-target: Fix isert_put_reject payload buffer post iscsi-target: missing kfree() on error path iscsi-target: Drop left-over iscsi_conn->bad_hdr target: Make core_scsi3_update_and_write_aptpl return sense_reason_t ...
2013-07-11watchdog: delete mpcore_wdt driverViresh Kumar
Interrupt request doesn't use the right API: The TWD watchdog uses a per-cpu interrupt (usually interrupt #30), and the GIC configuration should flag it as such. With this setup, request_irq() should fail, and the right API is request_percpu_irq(), together with enable_percpu_irq()/disable_percpu_irq(). Nothing ensures the userspace ioctl() will end-up kicking the watchdog on the right CPU. There are no users of this driver since a long time and it makes more sense to get rid of it as nobody is looking to fix it. In case somebody wakes up after this has been removed and needs it, please revert this driver and pick these updates (These were never pushed to mainline): http://comments.gmane.org/gmane.linux.ports.arm.kernel/245998 Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-11watchdog: xilinx: Setup the origin compatible stringMichal Simek
Watchdog 1.01.a is also compatible with 1.00.a. Add the origin version to compatible list. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-11Merge tag 'remoteproc-3.11-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc Pull remoteproc fixes from Ohad Ben-Cohen: "Trivial remoteproc fixes by Suman Anna, Wei Yongjun and Thomas Meyer" * tag 'remoteproc-3.11-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: remoteproc: Cocci spatch "memdup.spatch" remoteproc: free carveout memories only after unmapping them remoteproc/omap: fix a sparse warning remoteproc: fix checkpatch errors in remoteproc code remoteproc: fix error return code in rproc_fw_boot()
2013-07-11Merge tag 'pm+acpi-3.11-rc1-more' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management and ACPI updates from Rafael Wysocki: - Fix for a recent cpufreq regression that caused WARN() to trigger overzealously in a couple of places and spam the kernel log with useless garbage as a result. From Viresh Kumar. - ACPI dock fix removing a discrepancy between the definition of acpi_dock_init(), which says that the function returns int, and its header in the header file, which says that it is a void function. The function is now defined as void too. - ACPI PM fix for failures to update device power states as needed, for example, during resume from system suspend, because the old state was deeper than the new one, but the new one is not D0. - Fix for two debug messages in the ACPI power resources code that don't have a newline at the end and make the kernel log difficult to read. From Mika Westerberg. - Two ACPI cleanups from Naresh Bhat and Haicheng Li. - cpupower updates from Thomas Renninger, including Intel Haswell support improvements and a new idle-set subcommand among other things. * tag 'pm+acpi-3.11-rc1-more' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / power: add missing newline to debug messages cpupower: Add Haswell family 0x45 specific idle monitor to show PC8,9,10 states cpupower: Haswell also supports the C-states introduced with SandyBridge cpupower: Introduce idle-set subcommand and C-state enabling/disabling cpupower: Implement disabling of cstate interface cpupower: Make idlestate usage unsigned ACPI / fan: Initialize acpi_state variable ACPI / scan: remove unused LIST_HEAD(acpi_device_list) ACPI / dock: Actually define acpi_dock_init() as void ACPI / PM: Fix corner case in acpi_bus_update_power() cpufreq: Fix serialization of frequency transitions
2013-07-11watchdog: xilinx: Fix driver headerMichal Simek
- Remove reference for IP version - Fix header coding style - Remove notes which are visible from the code - Fix driver license according to header Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-11watchdog: wdrtas: don't use custom version of print_hex_dumpAndy Shevchenko
Kernel has nice helpers to dump buffers. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "There are not too many changes this time, except two new platform thermal drivers, ti-soc-thermal driver and x86_pkg_temp_thermal driver, and a couple of small fixes. Highlights: - move the ti-soc-thermal driver out of the staging tree to the thermal tree. - introduce the x86_pkg_temp_thermal driver. This driver registers CPU digital temperature package level sensor as a thermal zone. - small fixes/cleanups including removing redundant use of platform_set_drvdata() and of_match_ptr for all platform thermal drivers" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (34 commits) thermal: cpu_cooling: fix stub function thermal: ti-soc-thermal: use standard GPIO DT bindings thermal: MAINTAINERS: Add git tree path for SoC specific updates thermal: fix x86_pkg_temp_thermal.c build and Kconfig Thermal: Documentation for x86 package temperature thermal driver Thermal: CPU Package temperature thermal thermal: consider emul_temperature while computing trend thermal: ti-soc-thermal: add DT example for DRA752 chip thermal: ti-soc-thermal: add dra752 chip to device table thermal: ti-soc-thermal: add thermal data for DRA752 chips thermal: ti-soc-thermal: remove usage of IS_ERR_OR_NULL thermal: ti-soc-thermal: freeze FSM while computing trend thermal: ti-soc-thermal: remove external heat while extrapolating hotspot thermal: ti-soc-thermal: update DT reference for OMAP5430 x86, mcheck, therm_throt: Process package thresholds thermal: cpu_cooling: fix 'descend' check in get_property() Thermal: spear: Remove redundant use of of_match_ptr Thermal: kirkwood: Remove redundant use of of_match_ptr Thermal: dove: Remove redundant use of of_match_ptr Thermal: armada: Remove redundant use of of_match_ptr ...
2013-07-11watchdog: core: don't try to stop device if not runningHector Palacios
A watchdog device may be stopped from userspace using WDIOC_SETOPTIONS ioctl and flag WDIOS_DISABLECARD. If the device is closed after this operation, watchdog_release() is called and status bits checked for stopping it. Besides, if the device has not been unregistered a critical message "watchdog did not stop!" is printed, although the ioctl may have successfully stopped it already. Without the patch a user application sample code like this will successfully stop the watchdog, but the kernel will output the message "watchdog did not stop!": wd_fd = open("/dev/watchdog", O_RDWR); flags = WDIOS_DISABLECARD; ioctl(wd_fd, WDIOC_SETOPTIONS, &flags); close(wd_fd); Signed-off-by: Hector Palacios <hector.palacios@digi.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
