The structure with common attributes for hid-sensors isn't specific
to the iio-subsystem, so rename it to hid_sensor_common.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
The stuff in hid-sensor-attributes.h is needed by every piece which
uses hid-sensor-hub and merging it into hid-sensor-hub.h makes it accessible
from outside the iio subdirectory.
These are Usage IDs for the attributes year, month, day,
hour, minute and second, needed to read HID time sensors.
Pull watchdog updates from Wim Van Sebroeck:
"This includes some fixes and code improvements (like
clk_prepare_enable and clk_disable_unprepare), conversion from the
omap_wdt and twl4030_wdt drivers to the watchdog framework, addition
of the SB8x0 chipset support and the DA9055 Watchdog driver and some
OF support for the davinci_wdt driver."
* git://www.linux-watchdog.org/linux-watchdog: (22 commits)
watchdog: mei: avoid oops in watchdog unregister code path
watchdog: Orion: Fix possible null-deference in orion_wdt_probe
watchdog: sp5100_tco: Add SB8x0 chipset support
watchdog: davinci_wdt: add OF support
watchdog: da9052: Fix invalid free of devm_ allocated data
watchdog: twl4030_wdt: Change TWL4030_MODULE_PM_RECEIVER to TWL_MODULE_PM_RECEIVER
watchdog: remove depends on CONFIG_EXPERIMENTAL
watchdog: Convert dev_printk(KERN_<LEVEL> to dev_<level>(
watchdog: DA9055 Watchdog driver
watchdog: omap_wdt: eliminate goto
watchdog: omap_wdt: delete redundant platform_set_drvdata() calls
watchdog: omap_wdt: convert to devm_ functions
watchdog: omap_wdt: convert to new watchdog core
watchdog: WatchDog Timer Driver Core: fix comment
watchdog: s3c2410_wdt: use clk_prepare_enable and clk_disable_unprepare
watchdog: imx2_wdt: Select the driver via ARCH_MXC
watchdog: cpu5wdt.c: add missing del_timer call
watchdog: hpwdt.c: Increase version string
watchdog: Convert twl4030_wdt to watchdog core
davinci_wdt: preparation for switch to common clock framework
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm
Pull dm update from Alasdair G Kergon:
"Miscellaneous device-mapper fixes, cleanups and performance
improvements.
Of particular note:
- Disable broken WRITE SAME support in all targets except linear and
striped. Use it when kcopyd is zeroing blocks.
- Remove several mempools from targets by moving the data into the
bio's new front_pad area(which dm calls 'per_bio_data').
- Fix a race in thin provisioning if discards are misused.
- Prevent userspace from interfering with the ioctl parameters and
use kmalloc for the data buffer if it's small instead of vmalloc.
- Throttle some annoying error messages when I/O fails."
* tag 'dm-3.8-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (36 commits)
dm stripe: add WRITE SAME support
dm: remove map_info
dm snapshot: do not use map_context
dm thin: dont use map_context
dm raid1: dont use map_context
dm flakey: dont use map_context
dm raid1: rename read_record to bio_record
dm: move target request nr to dm_target_io
dm snapshot: use per_bio_data
dm verity: use per_bio_data
dm raid1: use per_bio_data
dm: introduce per_bio_data
dm kcopyd: add WRITE SAME support to dm_kcopyd_zero
dm linear: add WRITE SAME support
dm: add WRITE SAME support
dm: prepare to support WRITE SAME
dm ioctl: use kmalloc if possible
dm ioctl: remove PF_MEMALLOC
dm persistent data: improve improve space map block alloc failure message
dm thin: use DMERR_LIMIT for errors
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull more infiniband changes from Roland Dreier:
"Second batch of InfiniBand/RDMA changes for 3.8:
- cxgb4 changes to fix lookup engine hash collisions
- mlx4 changes to make flow steering usable
- fix to IPoIB to avoid pinning dst reference for too long"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
RDMA/cxgb4: Fix bug for active and passive LE hash collision path
RDMA/cxgb4: Fix LE hash collision bug for passive open connection
RDMA/cxgb4: Fix LE hash collision bug for active open connection
mlx4_core: Allow choosing flow steering mode
mlx4_core: Adjustments to Flow Steering activation logic for SR-IOV
mlx4_core: Fix error flow in the flow steering wrapper
mlx4_core: Add QPN enforcement for flow steering rules set by VFs
cxgb4: Add LE hash collision bug fix path in LLD driver
cxgb4: Add T4 filter support
IPoIB: Call skb_dst_drop() once skb is enqueued for sending
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic cleanup from Arnd Bergmann:
"These are a few cleanups for asm-generic:
- a set of patches from Lars-Peter Clausen to generalize asm/mmu.h
and use it in the architectures that don't need any special
handling.
- A patch from Will Deacon to remove the {read,write}s{b,w,l} as
discussed during the arm64 review
- A patch from James Hogan that helps with the meta architecture
series."
* tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
xtensa: Use generic asm/mmu.h for nommu
h8300: Use generic asm/mmu.h
c6x: Use generic asm/mmu.h
asm-generic/mmu.h: Add support for FDPIC
asm-generic/mmu.h: Remove unused vmlist field from mm_context_t
asm-generic: io: remove {read,write} string functions
asm-generic/io.h: remove asm/cacheflush.h include
This patch removes map_info from bio-based device mapper targets.
map_info is still used for request-based targets.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
This patch moves target_request_nr from map_info to dm_target_io and
makes it accessible with dm_bio_get_target_request_nr.
This patch is a preparation for the next patch that removes map_info.
Introduce a field per_bio_data_size in struct dm_target.
Targets can set this field in the constructor. If a target sets this
field to a non-zero value, "per_bio_data_size" bytes of auxiliary data
are allocated for each bio submitted to the target. These data can be
used for any purpose by the target and help us improve performance by
removing some per-target mempools.
Per-bio data is accessed with dm_per_bio_data. The
argument data_size must be the same as the value per_bio_data_size in
dm_target.
If the target has a pointer to per_bio_data, it can get a pointer to
the bio with dm_bio_from_per_bio_data() function (data_size must be the
same as the value passed to dm_per_bio_data).
Allow targets to opt in to WRITE SAME support by setting
'num_write_same_requests' in the dm_target structure.
A dm device will only advertise WRITE SAME support if all its
targets and all its underlying devices support it.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
When allocating memory for the userspace ioctl data, set some
appropriate GPF flags directly instead of using PF_MEMALLOC.
Pull filesystem notification updates from Eric Paris:
"This pull mostly is about locking changes in the fsnotify system. By
switching the group lock from a spin_lock() to a mutex() we can now
hold the lock across things like iput(). This fixes a problem
involving unmounting a fs and having inodes be busy, first pointed out
by FAT, but reproducible with tmpfs.
This also restores signal driven I/O for inotify, which has been
broken since about 2.6.32."
Ugh. I *hate* the timing of this. It was rebased after the merge
window opened, and then left to sit with the pull request coming the day
before the merge window closes. That's just crap. But apparently the
patches themselves have been around for over a year, just gathering
dust, so now it's suddenly critical.
Fixed up semantic conflict in fs/notify/fdinfo.c as per Stephen
Rothwell's fixes from -next.
* 'for-next' of git://git.infradead.org/users/eparis/notify:
inotify: automatically restart syscalls
inotify: dont skip removal of watch descriptor if creation of ignored event failed
fanotify: dont merge permission events
fsnotify: make fasync generic for both inotify and fanotify
fsnotify: change locking order
fsnotify: dont put marks on temporary list when clearing marks by group
fsnotify: introduce locked versions of fsnotify_add_mark() and fsnotify_remove_mark()
fsnotify: pass group to fsnotify_destroy_mark()
fsnotify: use a mutex instead of a spinlock to protect a groups mark list
fanotify: add an extra flag to mark_remove_from_mask that indicates wheather a mark should be destroyed
fsnotify: take groups mark_lock before mark lock
fsnotify: use reference counting for groups
fsnotify: introduce fsnotify_get_group()
inotify, fanotify: replace fsnotify_put_group() with fsnotify_destroy_group()
Merge the rest of Andrew's patches for -rc1:
"A bunch of fixes and misc missed-out-on things.
That'll do for -rc1. I still have a batch of IPC patches which still
have a possible bug report which I'm chasing down."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (25 commits)
keys: use keyring_alloc() to create module signing keyring
keys: fix unreachable code
sendfile: allows bypassing of notifier events
SGI-XP: handle non-fatal traps
fat: fix incorrect function comment
Documentation: ABI: remove testing/sysfs-devices-node
proc: fix inconsistent lock state
linux/kernel.h: fix DIV_ROUND_CLOSEST with unsigned divisors
memcg: don't register hotcpu notifier from ->css_alloc()
checkpatch: warn on uapi #includes that #include <uapi/...
revert "rtc: recycle id when unloading a rtc driver"
mm: clean up transparent hugepage sysfs error messages
hfsplus: add error message for the case of failure of sync fs in delayed_sync_fs() method
hfsplus: rework processing of hfs_btree_write() returned error
hfsplus: rework processing errors in hfsplus_free_extents()
hfsplus: avoid crash on failed block map free
kcmp: include linux/ptrace.h
drivers/rtc/rtc-imxdi.c: must include <linux/spinlock.h>
mm: cma: WARN if freed memory is still in use
exec: do not leave bprm->interp on stack
Pull VFS update from Al Viro:
"fscache fixes, ESTALE patchset, vmtruncate removal series, assorted
misc stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (79 commits)
vfs: make lremovexattr retry once on ESTALE error
vfs: make removexattr retry once on ESTALE
vfs: make llistxattr retry once on ESTALE error
vfs: make listxattr retry once on ESTALE error
vfs: make lgetxattr retry once on ESTALE
vfs: make getxattr retry once on an ESTALE error
vfs: allow lsetxattr() to retry once on ESTALE errors
vfs: allow setxattr to retry once on ESTALE errors
vfs: allow utimensat() calls to retry once on an ESTALE error
vfs: fix user_statfs to retry once on ESTALE errors
vfs: make fchownat retry once on ESTALE errors
vfs: make fchmodat retry once on ESTALE errors
vfs: have chroot retry once on ESTALE error
vfs: have chdir retry lookup and call once on ESTALE error
vfs: have faccessat retry once on an ESTALE error
vfs: have do_sys_truncate retry once on an ESTALE error
vfs: fix renameat to retry on ESTALE errors
vfs: make do_unlinkat retry once on ESTALE errors
vfs: make do_rmdir retry once on ESTALE errors
vfs: add a flags argument to user_path_parent
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull signal handling cleanups from Al Viro:
"sigaltstack infrastructure + conversion for x86, alpha and um,
COMPAT_SYSCALL_DEFINE infrastructure.
Note that there are several conflicts between "unify
SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline;
resolution is trivial - just remove definitions of SS_ONSTACK and
SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and
include/uapi/linux/signal.h contains the unified variant."
Fixed up conflicts as per Al.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
alpha: switch to generic sigaltstack
new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those
generic compat_sys_sigaltstack()
introduce generic sys_sigaltstack(), switch x86 and um to it
new helper: compat_user_stack_pointer()
new helper: restore_altstack()
unify SS_ONSTACK/SS_DISABLE definitions
new helper: current_user_stack_pointer()
missing user_stack_pointer() instances
Bury the conditionals from kernel_thread/kernel_execve series
COMPAT_SYSCALL_DEFINE: infrastructure
Commit 263a523d18bc ("linux/kernel.h: Fix warning seen with W=1 due to
change in DIV_ROUND_CLOSEST") fixes a warning seen with W=1 due to
change in DIV_ROUND_CLOSEST.
Unfortunately, the C compiler converts divide operations with unsigned
divisors to unsigned, even if the dividend is signed and negative (for
example, -10 / 5U = 858993457). The C standard says "If one operand has
unsigned int type, the other operand is converted to unsigned int", so
the compiler is not to blame. As a result, DIV_ROUND_CLOSEST(0, 2U) and
similar operations now return bad values, since the automatic conversion
of expressions such as "0 - 2U/2" to unsigned was not taken into
account.
Fix by checking for the divisor variable type when deciding which
operation to perform. This fixes DIV_ROUND_CLOSEST(0, 2U), but still
returns bad values for negative dividends divided by unsigned divisors.
Mark the latter case as unsupported.
One observed effect of this problem is that the s2c_hwmon driver reports
a value of 4198403 instead of 0 if the ADC reads 0.
Other impact is unpredictable. Problem is seen if the divisor is an
unsigned variable or constant and the dividend is less than (divisor/2).
Reported-by: Juergen Beisert <jbe@pengutronix.de>
Tested-by: Juergen Beisert <jbe@pengutronix.de>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: <stable@vger.kernel.org> [3.7.x]
If a series of scripts are executed, each triggering module loading via
unprintable bytes in the script header, kernel stack contents can leak
into the command line.
Normally execution of binfmt_script and binfmt_misc happens recursively.
However, when modules are enabled, and unprintable bytes exist in the
bprm->buf, execution will restart after attempting to load matching
binfmt modules. Unfortunately, the logic in binfmt_script and
binfmt_misc does not expect to get restarted. They leave bprm->interp
pointing to their local stack. This means on restart bprm->interp is
left pointing into unused stack memory which can then be copied into the
userspace argv areas.
After additional study, it seems that both recursion and restart remains
the desirable way to handle exec with scripts, misc, and modules. As
such, we need to protect the changes to interp.
This changes the logic to require allocation for any changes to the
bprm->interp. To avoid adding a new kmalloc to every exec, the default
value is left as-is. Only when passing through binfmt_script or
binfmt_misc does an allocation take place.
For a proof of concept, see DoTest.sh from:
http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
Where we can pass in LOOKUP_DIRECTORY or LOOKUP_REVAL. Any other flags
passed in here are currently ignored.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
This function is expected to be called from path-based syscalls to help
them decide whether to try the lookup and call again in the event that
they got an -ESTALE return back on an earier try.
Currently, we only retry the call once on an ESTALE error, but in the
event that we decide that that's not enough in the future, we should be
able to change the logic in this helper without too much effort.
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into for-linus
Commit 8e22cc88d68ca1a46d7d582938f979eb640ed30f removes the (un)lock_super
function definitions but forgets to remove their prototypes.
Signed-off-by: Alessio Igor Bogani <abogani@kernel.org>
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Removed vmtruncate
Mark as cancelled an operation that is in progress rather than pending at the
time it is cancelled, and call fscache_complete_op() to cancel an operation so
that blocked ops can be started.
Convert the fscache_object event IDs from #defines into an enum. Also add an
extra label to the enum to carry the event count and redefine the event mask
in terms of that.
Make a more complete truncate operation available to CacheFiles (including
security checks and suchlike) so that it can use this to clear invalidated
cache files.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Pull nfsd update from Bruce Fields:
"Included this time:
- more nfsd containerization work from Stanislav Kinsbursky: we're
not quite there yet, but should be by 3.9.
- NFSv4.1 progress: implementation of basic backchannel security
negotiation and the mandatory BACKCHANNEL_CTL operation. See
http://wiki.linux-nfs.org/wiki/index.php/Server_4.0_and_4.1_issues
for remaining TODO's
- Fixes for some bugs that could be triggered by unusual compounds.
Our xdr code wasn't designed with v4 compounds in mind, and it
shows. A more thorough rewrite is still a todo.
- If you've ever seen "RPC: multiple fragments per record not
supported" logged while using some sort of odd userland NFS client,
that should now be fixed.
- Further work from Jeff Layton on our mechanism for storing
information about NFSv4 clients across reboots.
- Further work from Bryan Schumaker on his fault-injection mechanism
(which allows us to discard selective NFSv4 state, to excercise
rarely-taken recovery code paths in the client.)
- The usual mix of miscellaneous bugs and cleanup.
Thanks to everyone who tested or contributed this cycle."
* 'for-3.8' of git://linux-nfs.org/~bfields/linux: (111 commits)
nfsd4: don't leave freed stateid hashed
nfsd4: free_stateid can use the current stateid
nfsd4: cleanup: replace rq_resused count by rq_next_page pointer
nfsd: warn on odd reply state in nfsd_vfs_read
nfsd4: fix oops on unusual readlike compound
nfsd4: disable zero-copy on non-final read ops
svcrpc: fix some printks
NFSD: Correct the size calculation in fault_inject_write
NFSD: Pass correct buffer size to rpc_ntop
nfsd: pass proper net to nfsd_destroy() from NFSd kthreads
nfsd: simplify service shutdown
nfsd: replace boolean nfsd_up flag by users counter
nfsd: simplify NFSv4 state init and shutdown
nfsd: introduce helpers for generic resources init and shutdown
nfsd: make NFSd service structure allocated per net
nfsd: make NFSd service boot time per-net
nfsd: per-net NFSd up flag introduced
nfsd: move per-net startup code to separated function
nfsd: pass net to __write_ports() and down
nfsd: pass net to nfsd_set_nrthreads()
Provide a proper invalidation method rather than relying on the netfs retiring
the cookie it has and getting a new one. The problem with this is that isn't
easy for the netfs to make sure that it has completed/cancelled all its
outstanding storage and retrieval operations on the cookie it is retiring.
Instead, have the cache provide an invalidation method that will cancel or wait
for all currently outstanding operations before invalidating the cache, and
will cause new operations to queue up behind that. Whilst invalidation is in
progress, some requests will be rejected until the cache can stack a barrier on
the operation queue to cause new operations to be deferred behind it.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph update from Sage Weil:
"There are a few different groups of commits here. The largest is
Alex's ongoing work to enable the coming RBD features (cloning,
striping). There is some cleanup in libceph that goes along with it.
Cyril and David have fixed some problems with NFS reexport (leaking
dentries and page locks), and there is a batch of patches from Yan
fixing problems with the fs client when running against a clustered
MDS. There are a few bug fixes mixed in for good measure, many of
which will be going to the stable trees once they're upstream.
My apologies for the late pull. There is still a gremlin in the rbd
map/unmap code and I was hoping to include the fix for that as well,
but we haven't been able to confirm the fix is correct yet; I'll send
that in a separate pull once it's nailed down."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (68 commits)
rbd: get rid of rbd_{get,put}_dev()
libceph: register request before unregister linger
libceph: don't use rb_init_node() in ceph_osdc_alloc_request()
libceph: init event->node in ceph_osdc_create_event()
libceph: init osd->o_node in create_osd()
libceph: report connection fault with warning
libceph: socket can close in any connection state
rbd: don't use ENOTSUPP
rbd: remove linger unconditionally
rbd: get rid of RBD_MAX_SEG_NAME_LEN
libceph: avoid using freed osd in __kick_osd_requests()
ceph: don't reference req after put
rbd: do not allow remove of mounted-on image
libceph: Unlock unprocessed pages in start_read() error path
ceph: call handle_cap_grant() for cap import message
ceph: Fix __ceph_do_pending_vmtruncate
ceph: Don't add dirty inode to dirty list if caps is in migration
ceph: Fix infinite loop in __wake_requests
ceph: Don't update i_max_size when handling non-auth cap
bdi_register: add __printf verification, fix arg mismatch
Fix the state management of internal fscache operations and the accounting of
what operations are in what states.
This is done by:
(1) Give struct fscache_operation a enum variable that directly represents the
state it's currently in, rather than spreading this knowledge over a bunch
of flags, who's processing the operation at the moment and whether it is
queued or not.
This makes it easier to write assertions to check the state at various
points and to prevent invalid state transitions.
(2) Add an 'operation complete' state and supply a function to indicate the
completion of an operation (fscache_op_complete()) and make things call
it. The final call to fscache_put_operation() can then check that an op
in the appropriate state (complete or cancelled).
(3) Adjust the use of object->n_ops, ->n_in_progress, ->n_exclusive to better
govern the state of an object:
(a) The ->n_ops is now the number of extant operations on the object
and is now decremented by fscache_put_operation() only.
(b) The ->n_in_progress is simply the number of objects that have been
taken off of the object's pending queue for the purposes of being
run. This is decremented by fscache_op_complete() only.
(c) The ->n_exclusive is the number of exclusive ops that have been
submitted and queued or are in progress. It is decremented by
fscache_op_complete() and by fscache_cancel_op().
fscache_put_operation() and fscache_operation_gc() now no longer try to
clean up ->n_exclusive and ->n_in_progress. That was leading to double
decrements against fscache_cancel_op().
fscache_cancel_op() now no longer decrements ->n_ops. That was leading to
double decrements against fscache_put_operation().
fscache_submit_exclusive_op() now decides whether it has to queue an op
based on ->n_in_progress being > 0 rather than ->n_ops > 0 as the latter
will persist in being true even after all preceding operations have been
cancelled or completed. Furthermore, if an object is active and there are
runnable ops against it, there must be at least one op running.
(4) Add a remaining-pages counter (n_pages) to struct fscache_retrieval and
provide a function to record completion of the pages as they complete.
When n_pages reaches 0, the operation is deemed to be complete and
fscache_op_complete() is called.
Add calls to fscache_retrieval_complete() anywhere we've finished with a
page we've been given to read or allocate for. This includes places where
we just return pages to the netfs for reading from the server and where
accessing the cache fails and we discard the proposed netfs page.
The bugs in the unfixed state management manifest themselves as oopses like the
following where the operation completion gets out of sync with return of the
cookie by the netfs. This is possible because the cache unlocks and returns
all the netfs pages before recording its completion - which means that there's
nothing to stop the netfs discarding them and returning the cookie.
FS-Cache: Cookie 'NFS.fh' still has outstanding reads
kernel BUG at fs/fscache/cookie.c:519!
invalid opcode: 0000 [#1] SMP
CPU 1
Modules linked in: cachefiles nfs fscache auth_rpcgss nfs_acl lockd sunrpc
Pid: 400, comm: kswapd0 Not tainted 3.1.0-rc7-fsdevel+ #1090 /DG965RY
RIP: 0010:[<ffffffffa007050a>] [<ffffffffa007050a>] __fscache_relinquish_cookie+0x170/0x343 [fscache]
RSP: 0018:ffff8800368cfb00 EFLAGS: 00010282
RAX: 000000000000003c RBX: ffff880023cc8790 RCX: 0000000000000000
RDX: 0000000000002f2e RSI: 0000000000000001 RDI: ffffffff813ab86c
RBP: ffff8800368cfb50 R08: 0000000000000002 R09: 0000000000000000
R10: ffff88003a1b7890 R11: ffff88001df6e488 R12: ffff880023d8ed98
R13: ffff880023cc8798 R14: 0000000000000004 R15: ffff88003b8bf370
FS: 0000000000000000(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000008ba008 CR3: 0000000023d93000 CR4: 00000000000006e0
Process kswapd0 (pid: 400, threadinfo ffff8800368ce000, task ffff88003b8bf040)
Stack:
ffff88003b8bf040 ffff88001df6e528 ffff88001df6e528 ffffffffa00b46b0
ffff88003b8bf040 ffff88001df6e488 ffff88001df6e620 ffffffffa00b46b0
ffff88001ebd04c8 0000000000000004 ffff8800368cfb70 ffffffffa00b2c91
Call Trace:
[<ffffffffa00b2c91>] nfs_fscache_release_inode_cookie+0x3b/0x47 [nfs]
[<ffffffffa008f25f>] nfs_clear_inode+0x3c/0x41 [nfs]
[<ffffffffa0090df1>] nfs4_evict_inode+0x2f/0x33 [nfs]
[<ffffffff810d8d47>] evict+0xa1/0x15c
[<ffffffff810d8e2e>] dispose_list+0x2c/0x38
[<ffffffff810d9ebd>] prune_icache_sb+0x28c/0x29b
[<ffffffff810c56b7>] prune_super+0xd5/0x140
[<ffffffff8109b615>] shrink_slab+0x102/0x1ab
[<ffffffff8109d690>] balance_pgdat+0x2f2/0x595
[<ffffffff8103e009>] ? process_timeout+0xb/0xb
[<ffffffff8109dba3>] kswapd+0x270/0x289
[<ffffffff8104c5ea>] ? __init_waitqueue_head+0x46/0x46
[<ffffffff8109d933>] ? balance_pgdat+0x595/0x595
[<ffffffff8104bf7a>] kthread+0x7f/0x87
[<ffffffff813ad6b4>] kernel_thread_helper+0x4/0x10
[<ffffffff81026b98>] ? finish_task_switch+0x45/0xc0
[<ffffffff813abcdd>] ? retint_restore_args+0xe/0xe
[<ffffffff8104befb>] ? __init_kthread_worker+0x53/0x53
[<ffffffff813ad6b0>] ? gs_change+0xb/0xb
Make fscache_relinquish_cookie() log a warning and wait if there are any
outstanding reads left on the cookie it was given.
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull new F2FS filesystem from Jaegeuk Kim:
"Introduce a new file system, Flash-Friendly File System (F2FS), to
Linux 3.8.
Highlights:
- Add initial f2fs source codes
- Fix an endian conversion bug
- Fix build failures on random configs
- Fix the power-off-recovery routine
- Minor cleanup, coding style, and typos patches"
From the Kconfig help text:
F2FS is based on Log-structured File System (LFS), which supports
versatile "flash-friendly" features. The design has been focused on
addressing the fundamental issues in LFS, which are snowball effect
of wandering tree and high cleaning overhead.
Since flash-based storages show different characteristics according to
the internal geometry or flash memory management schemes aka FTL, F2FS
and tools support various parameters not only for configuring on-disk
layout, but also for selecting allocation and cleaning algorithms.
and there's an article by Neil Brown about it on lwn.net:
http://lwn.net/Articles/518988/
* tag 'for-3.8-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (36 commits)
f2fs: fix tracking parent inode number
f2fs: cleanup the f2fs_bio_alloc routine
f2fs: introduce accessor to retrieve number of dentry slots
f2fs: remove redundant call to f2fs_put_page in delete entry
f2fs: make use of GFP_F2FS_ZERO for setting gfp_mask
f2fs: rewrite f2fs_bio_alloc to make it simpler
f2fs: fix a typo in f2fs documentation
f2fs: remove unused variable
f2fs: move error condition for mkdir at proper place
f2fs: remove unneeded initialization
f2fs: check read only condition before beginning write out
f2fs: remove unneeded memset from init_once
f2fs: show error in case of invalid mount arguments
f2fs: fix the compiler warning for uninitialized use of variable
f2fs: resolve build failures
f2fs: adjust kernel coding style
f2fs: fix endian conversion bugs reported by sparse
f2fs: remove unneeded version.h header file from f2fs.h
f2fs: update the f2fs document
f2fs: update Kconfig and Makefile
Under some circumstances CacheFiles defers the marking of pages with PG_fscache
so that it can take advantage of pagevecs to reduce the number of calls to
fscache_mark_pages_cached() and the netfs's hook to keep track of this.
There are, however, two problems with this:
(1) It can lead to the PG_fscache mark being applied _after_ the page is set
PG_uptodate and unlocked (by the call to fscache_end_io()).
(2) CacheFiles's ref on the page is dropped immediately following
fscache_end_io() - and so may not still be held when the mark is applied.
This can lead to the page being passed back to the allocator before the
mark is applied.
Fix this by, where appropriate, marking the page before calling
fscache_end_io() and releasing the page. This means that we can't take
advantage of pagevecs and have to make a separate call for each page to the
marking routines.
The symptoms of this are Bad Page state errors cropping up under memory
pressure, for example:
BUG: Bad page state in process tar pfn:002da
page:ffffea0000009fb0 count:0 mapcount:0 mapping: (null) index:0x1447
page flags: 0x1000(private_2)
Pid: 4574, comm: tar Tainted: G W 3.1.0-rc4-fsdevel+ #1064
Call Trace:
[<ffffffff8109583c>] ? dump_page+0xb9/0xbe
[<ffffffff81095916>] bad_page+0xd5/0xea
[<ffffffff81095d82>] get_page_from_freelist+0x35b/0x46a
[<ffffffff810961f3>] __alloc_pages_nodemask+0x362/0x662
[<ffffffff810989da>] __do_page_cache_readahead+0x13a/0x267
[<ffffffff81098942>] ? __do_page_cache_readahead+0xa2/0x267
[<ffffffff81098d7b>] ra_submit+0x1c/0x20
[<ffffffff8109900a>] ondemand_readahead+0x28b/0x29a
[<ffffffff81098ee2>] ? ondemand_readahead+0x163/0x29a
[<ffffffff810990ce>] page_cache_sync_readahead+0x38/0x3a
[<ffffffff81091d8a>] generic_file_aio_read+0x2ab/0x67e
[<ffffffffa008cfbe>] nfs_file_read+0xa4/0xc9 [nfs]
[<ffffffff810c22c4>] do_sync_read+0xba/0xfa
[<ffffffff81177a47>] ? security_file_permission+0x7b/0x84
[<ffffffff810c25dd>] ? rw_verify_area+0xab/0xc8
[<ffffffff810c29a4>] vfs_read+0xaa/0x13a
[<ffffffff810c2a79>] sys_read+0x45/0x6c
[<ffffffff813ac37b>] system_call_fastpath+0x16/0x1b
As can be seen, PG_private_2 (== PG_fscache) is set in the page flags.
Instrumenting fscache_mark_pages_cached() to verify whether page->mapping was
set appropriately showed that sometimes it wasn't. This led to the discovery
that sometimes the page has apparently been reclaimed by the time the marker
got to see it.
Reported-by: M. Stevens <m@tippett.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
The code that relied on that flag was ripped out of btrfs quite some
time ago, and never added back. Josef indicated that he was going to
take a different approach to the problem in btrfs, and that we
could just eliminate this flag.
Cc: Josef Bacik <jbacik@fusionio.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"A few new features this merge-window. The most important one is
probably, that dma-debug now warns if a dma-handle is not checked with
dma_mapping_error by the device driver. This requires minor changes
to some architectures which make use of dma-debug. Most of these
changes have the respective Acks by the Arch-Maintainers.
Besides that there are updates to the AMD IOMMU driver for refactor
the IOMMU-Groups support and to make sure it does not trigger a
hardware erratum.
The OMAP changes (for which I pulled in a branch from Tony Lindgren's
tree) have a conflict in linux-next with the arm-soc tree. The
conflict is in the file arch/arm/mach-omap2/clock44xx_data.c which is
deleted in the arm-soc tree. It is safe to delete the file too so
solve the conflict. Similar changes are done in the arm-soc tree in
the common clock framework migration. A missing hunk from the patch
in the IOMMU tree will be submitted as a seperate patch when the
merge-window is closed."
* tag 'iommu-updates-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (29 commits)
ARM: dma-mapping: support debug_dma_mapping_error
ARM: OMAP4: hwmod data: ipu and dsp to use parent clocks instead of leaf clocks
iommu/omap: Adapt to runtime pm
iommu/omap: Migrate to hwmod framework
iommu/omap: Keep mmu enabled when requested
iommu/omap: Remove redundant clock handling on ISR
iommu/amd: Remove obsolete comment
iommu/amd: Don't use 512GB pages
iommu/tegra: smmu: Move bus_set_iommu after probe for multi arch
iommu/tegra: gart: Move bus_set_iommu after probe for multi arch
iommu/tegra: smmu: Remove unnecessary PTC/TLB flush all
tile: dma_debug: add debug_dma_mapping_error support
sh: dma_debug: add debug_dma_mapping_error support
powerpc: dma_debug: add debug_dma_mapping_error support
mips: dma_debug: add debug_dma_mapping_error support
microblaze: dma-mapping: support debug_dma_mapping_error
ia64: dma_debug: add debug_dma_mapping_error support
c6x: dma_debug: add debug_dma_mapping_error support
ARM64: dma_debug: add debug_dma_mapping_error support
intel-iommu: Prevent devices with RMRRs from being placed into SI Domain
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio update from Rusty Russell:
"Some nice cleanups, and even a patch my wife did as a "live" demo for
Latinoware 2012.
There's a slightly non-trivial merge in virtio-net, as we cleaned up
the virtio add_buf interface while DaveM accepted the mq virtio-net
patches."
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (27 commits)
virtio_console: Add support for remoteproc serial
virtio_console: Merge struct buffer_token into struct port_buffer
virtio: add drv_to_virtio to make code clearly
virtio: use dev_to_virtio wrapper in virtio
virtio-mmio: Fix irq parsing in command line parameter
virtio_console: Free buffers from out-queue upon close
virtio: Convert dev_printk(KERN_<LEVEL> to dev_<level>(
virtio_console: Use kmalloc instead of kzalloc
virtio_console: Free buffer if splice fails
virtio: tools: make it clear that virtqueue_add_buf() no longer returns > 0
virtio: scsi: make it clear that virtqueue_add_buf() no longer returns > 0
virtio: rpmsg: make it clear that virtqueue_add_buf() no longer returns > 0
virtio: net: make it clear that virtqueue_add_buf() no longer returns > 0
virtio: console: make it clear that virtqueue_add_buf() no longer returns > 0
virtio: make virtqueue_add_buf() returning 0 on success, not capacity.
virtio: console: don't rely on virtqueue_add_buf() returning capacity.
virtio_net: don't rely on virtqueue_add_buf() returning capacity.
virtio-net: remove unused skb_vnet_hdr->num_sg field
virtio-net: correct capacity math on ring full
virtio: move queue_index and num_free fields into core struct virtqueue.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"This update contains overall only driver-specific fixes. Slightly
large LOC are seen in usb-audio driver for a couple of new device
quirks and cs42l71 ASoC driver for enhanced features. The others are
a few small (regression) fixes HD-audio, and yet other small / trival
ASoC fixes."
* tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: usb-audio: Support for Digidesign Mbox 2 USB sound card:
ALSA: HDA: Fix sound resume hang
ALSA: hda - bug fix for invalid connection list of Haswell HDMI codec pins
ALSA: hda - Fix the wrong pincaps set in ALC861VD dallas/hp fixup
ALSA: hda - Set codec->single_adc_amp flag for Realtek codecs
ASoC: atmel-ssc: change disable to disable in dts node
ASoC: Prevent pop_wait overwrite
ALSA: usb-audio: ignore-quirk for HP Wireless Audio
ALSA: hda - Always turn on pins for HDMI/DP
ALSA: hda - Fix pin configuration of HP Pavilion dv7
ASoC: core: Fix splitting of log messages
ASoC: cs42l73: Change VSPIN/VSPOUT to VSPINOUT
ASoC: cs42l73: Add DAPM events for power down.
ASoC: cs42l73: Add DMIC's as DAPM inputs.
ASoC: sigmadsp: Fix endianness conversion issue
ASoC: tpa6130a2: Use devm_* APIs
Pull ARM SoC fixes from Olof Johansson:
"This is a batch of fixes for arm-soc platforms, most of it is for OMAP
but there are others too (i.MX, Tegra, ep93xx). Fixes warnings, some
broken platforms and drivers, etc. A bit all over the map really."
There was some concern about commit 68136b10 ("RM: sunxi: Change device
tree naming scheme for sunxi"), but Tony says:
"Looks like that's trivial to fix as needed, no need to rebuild the
branch to fix that AFAIK.
The fix can be done once Olof is available online again.
Linus, I suggest that you go ahead and pull this if there are no other
issues with this branch."
* tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits)
ARM: sunxi: Change device tree naming scheme for sunxi
ARM: ux500: fix missing include
ARM: u300: delete custom pin hog code
ARM: davinci: fix build break due to missing include
ARM: exynos: Fix warning due to missing 'inline' in stub
ARM: imx: Move platform-mx2-emma to arch/arm/mach-imx/devices
ARM i.MX51 clock: Fix regression since enabling MIPI/HSP clocks
ARM: dts: mx27: Fix the AIPI bus for FEC
ARM: OMAP2+: common: remove use of vram
ARM: OMAP3/4: cpuidle: fix sparse and checkpatch warnings
ARM: OMAP4: clock data: DPLLs are missing bypass clocks in their parent lists
ARM: OMAP4: clock data: div_iva_hs_clk is a power-of-two divider
ARM: OMAP4: Fix EMU clock domain always on
ARM: OMAP4460: Workaround ABE DPLL failing to turn-on
ARM: OMAP4: Enhance support for DPLLs with 4X multiplier
ARM: OMAP4: Add function table for non-M4X dplls
ARM: OMAP4: Update timer clock aliases
ARM: OMAP: Move plat/omap-serial.h to include/linux/platform_data/serial-omap.h
ARM: dts: Add build target for omap4-panda-a4
ARM: dts: OMAP2420: Correct H4 board memory size
Documentation says that code requiring dma-buf should add it to
select, so inline fallbacks are not going to be used. A link error
will make it obvious what went wrong, instead of silently doing
nothing at runtime.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Rob Clark <rob.clark@linaro.org>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
Pull networking fixes from David Miller:
1) Really fix tuntap SKB use after free bug, from Eric Dumazet.
2) Adjust SKB data pointer to point past the transport header before
calling icmpv6_notify() so that the headers are in the state which
that function expects. From Duan Jiong.
3) Fix ambiguities in the new tuntap multi-queue APIs. From Jason
Wang.
4) mISDN needs to use del_timer_sync(), from Konstantin Khlebnikov.
5) Don't destroy mutex after freeing up device private in mac802154,
fix also from Konstantin Khlebnikov.
6) Fix INET request socket leak in TCP and DCCP, from Christoph Paasch.
7) SCTP HMAC kconfig rework, from Neil Horman.
8) Fix SCTP jprobes function signature, otherwise things explode, from
Daniel Borkmann.
9) Fix typo in ipv6-offload Makefile variable reference, from Simon
Arlott.
10) Don't fail USBNET open just because remote wakeup isn't supported,
from Oliver Neukum.
11) be2net driver bug fixes from Sathya Perla.
12) SOLOS PCI ATM driver bug fixes from Nathan Williams and David
Woodhouse.
13) Fix MTU changing regression in 8139cp driver, from John Greene.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (45 commits)
solos-pci: ensure all TX packets are aligned to 4 bytes
solos-pci: add firmware upgrade support for new models
solos-pci: remove superfluous debug output
solos-pci: add GPIO support for newer versions on Geos board
8139cp: Prevent dev_close/cp_interrupt race on MTU change
net: qmi_wwan: add ZTE MF880
drivers/net: Use of_match_ptr() macro in smsc911x.c
drivers/net: Use of_match_ptr() macro in smc91x.c
ipv6: addrconf.c: remove unnecessary "if"
bridge: Correctly encode addresses when dumping mdb entries
bridge: Do not unregister all PF_BRIDGE rtnl operations
use generic usbnet_manage_power()
usbnet: generic manage_power()
usbnet: handle PM failure gracefully
ksz884x: fix receive polling race condition
qlcnic: update driver version
qlcnic: fix unused variable warnings
net: fec: forbid FEC_PTP on SoCs that do not support
be2net: fix wrong frag_idx reported by RX CQ
be2net: fix be_close() to ensure all events are ack'ed
git://git.secretlab.ca/git/linux-2.6
Pull devicetree, gpio and spi bugfixes from Grant Likely:
"Device tree v3.8 bug fix:
- Fixes an undefined struct device build error and a missing symbol
export.
GPIO device driver bug fixes:
- gpio/mvebu-gpio: Make mvebu-gpio depend on OF_CONFIG
- gpio/ich: Add missing spinlock init
SPI device driver bug fixes:
- Most of this is bug fixes to the core code and the sh-hspi and
s3c64xx device drivers.
- There is also a patch here to add DT support to the Atmel driver.
This one should have been in the first round, but I missed it.
It's a low risk change contained within a single driver and the
Atmel maintainer has requested it."
* tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6:
of: define struct device in of_platform.h if !OF_DEVICE and !OF_ADDRESS
of: Fix export of of_find_matching_node_and_match()
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6:
* tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6:
spi/sh-hspi: fix return value check in hspi_probe().
spi: fix tegra SPI binding examples
spi/atmel: add DT support
of/spi: Fix SPI module loading by using proper "spi:" modalias prefixes.
spi: Change FIFO flush operation and spi channel off
spi: Keep chipselect assertion during one message
note that they are relying on access_ok() already checked by caller.
Again, conditional on CONFIG_GENERIC_SIGALTSTACK
Conditional on CONFIG_GENERIC_SIGALTSTACK; architectures that do not
select it are completely unaffected
Compat counterpart of current_user_stack_pointer(); for most of the biarch
architectures those two are identical, but e.g. arm64 and arm use different
registers for stack pointer...
Note that amd64 variants of current_user_stack_pointer/compat_user_stack_pointer
do *not* rely on pt_regs having been through FIXUP_TOP_OF_STACK.
to be used by rt_sigreturn instances
Cross-architecture equivalent of rdusp(); default is
user_stack_pointer(current_pt_regs()) - that works for almost all
platforms that have usp saved in pt_regs. The only exception from
that is ia64 - we want memory stack, not the backing store for
register one.
All architectures have
CONFIG_GENERIC_KERNEL_THREAD
CONFIG_GENERIC_KERNEL_EXECVE
__ARCH_WANT_SYS_EXECVE
None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers
of kernel_execve() (which is a trivial wrapper for do_execve() now) left.
Kill the conditionals and make both callers use do_execve().
