commit 38e088546522e1e86d2b8f401a1354ad3a9b3303 upstream.
The NUMA balancing logic uses an arch-specific PROT_NONE page table flag
defined by pte_protnone() or pmd_protnone() to mark PTEs or huge page
PMDs respectively as requiring balancing upon a subsequent page fault.
User-defined PROT_NONE memory regions which also have this flag set will
not normally invoke the NUMA balancing code as do_page_fault() will send
a segfault to the process before handle_mm_fault() is even called.
However if access_remote_vm() is invoked to access a PROT_NONE region of
memory, handle_mm_fault() is called via faultin_page() and
__get_user_pages() without any access checks being performed, meaning
the NUMA balancing logic is incorrectly invoked on a non-NUMA memory
region.
A simple means of triggering this problem is to access PROT_NONE mmap'd
memory using /proc/self/mem which reliably results in the NUMA handling
functions being invoked when CONFIG_NUMA_BALANCING is set.
This issue was reported in bugzilla (issue 99101) which includes some
simple repro code.
There are BUG_ON() checks in do_numa_page() and do_huge_pmd_numa_page()
added at commit c0e7cad to avoid accidentally provoking strange
behaviour by attempting to apply NUMA balancing to pages that are in
fact PROT_NONE. The BUG_ON()'s are consistently triggered by the repro.
This patch moves the PROT_NONE check into mm/memory.c rather than
invoking BUG_ON() as faulting in these pages via faultin_page() is a
valid reason for reaching the NUMA check with the PROT_NONE page table
flag set and is therefore not always a bug.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=99101
Reported-by: Trevor Saunders <tbsaunde@tbsaunde.org>
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Marcelo Henrique Cerri <marcelo.cerri@canonical.com>
[cascardo: context adjustments were necessary]
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@canonical.com>
commit e720e7d0e983bf05de80b231bccc39f1487f0f16 upstream.
There are code paths that rely on zero_pfn to be fully initialized
before core_initcall. For example, wq_sysfs_init() is a core_initcall
function that eventually results in a call to kernel_execve, which
causes a page fault with a subsequent mmput. If zero_pfn is not
initialized by then it may not get cleaned up properly and result in an
error:
BUG: Bad rss-counter state mm:(ptrval) type:MM_ANONPAGES val:1
Here is an analysis of the race as seen on a MIPS device. On this
particular MT7621 device (Ubiquiti ER-X), zero_pfn is PFN 0 until
initialized, at which point it becomes PFN 5120:
1. wq_sysfs_init calls into kobject_uevent_env at core_initcall:
kobject_uevent_env+0x7e4/0x7ec
kset_register+0x68/0x88
bus_register+0xdc/0x34c
subsys_virtual_register+0x34/0x78
wq_sysfs_init+0x1c/0x4c
do_one_initcall+0x50/0x1a8
kernel_init_freeable+0x230/0x2c8
kernel_init+0x10/0x100
ret_from_kernel_thread+0x14/0x1c
2. kobject_uevent_env() calls call_usermodehelper_exec() which executes
kernel_execve asynchronously.
3. Memory allocations in kernel_execve cause a page fault, bumping the
MM reference counter:
add_mm_counter_fast+0xb4/0xc0
handle_mm_fault+0x6e4/0xea0
__get_user_pages.part.78+0x190/0x37c
__get_user_pages_remote+0x128/0x360
get_arg_page+0x34/0xa0
copy_string_kernel+0x194/0x2a4
kernel_execve+0x11c/0x298
call_usermodehelper_exec_async+0x114/0x194
4. In case zero_pfn has not been initialized yet, zap_pte_range does
not decrement the MM_ANONPAGES RSS counter and the BUG message is
triggered shortly afterwards when __mmdrop checks the ref counters:
__mmdrop+0x98/0x1d0
free_bprm+0x44/0x118
kernel_execve+0x160/0x1d8
To avoid races such as described above, initialize init_zero_pfn at
early_initcall level. Depending on the architecture, ZERO_PAGE is
either constant or gets initialized even earlier, at paging_init, so
there is no issue with initializing zero_pfn earlier.
Link: https://lkml.kernel.org/r/CALCv0x2YqOXEAy2Q=hafjhHCtTHVodChv1qpM=niAXOpqEbt7w@mail.gmail.com
Signed-off-by: Ilya Lipnitskiy <ilya.lipnitskiy@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: stable@vger.kernel.org
Tested-by: 周琰杰 (Zhou Yanjie) <zhouyanjie@wanyeetech.com>
[ Upstream commit 90a3e375d324b2255b83e3dd29e99e2b05d82aaf ]
Since commit 42e4089c7890 ("x86/speculation/l1tf: Disallow non privileged
high MMIO PROT_NONE mappings"), when the first pfn modify is not allowed,
we would break the loop with pte unchanged. Then the wrong pte - 1 would
be passed to pte_unmap_unlock.
Andi said:
"While the fix is correct, I'm not sure if it actually is a real bug.
Is there any architecture that would do something else than unlocking
the underlying page? If it's just the underlying page then it should
be always the same page, so no bug"
Link: https://lkml.kernel.org/r/20210109080118.20885-1-linmiaohe@huawei.com
Fixes: 42e4089c789 ("x86/speculation/l1tf: Disallow non privileged high MMIO PROT_NONE mappings")
Signed-off-by: Hongxiang Lou <louhongxiang@huawei.com>
Signed-off-by: Miaohe Lin <linmiaohe@huawei.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
commit 6347e8d5bcce33fc36e651901efefbe2c93a43ef upstream.
This removes the 'write' argument from access_remote_vm() and replaces
it with 'gup_flags' as use of this function previously silently implied
FOLL_FORCE, whereas after this patch callers explicitly pass this flag.
We make this explicit as use of FOLL_FORCE can result in surprising
behaviour (and hence bugs) within the mm subsystem.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 442486ec1096781c50227b73f721a63974b0fdda upstream.
This removes the 'write' argument from __access_remote_vm() and replaces
[bwh: Backported to 4.4: adjust context]
commit 768ae309a96103ed02eb1e111e838c87854d8b51 upstream.
This removes the 'write' and 'force' from get_user_pages() and replaces
them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers
as use of this flag can result in surprising behaviour (and hence bugs)
Acked-by: Christian König <christian.koenig@amd.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
- Drop changes in rapidio, vchiq, goldfish
- Keep the "write" variable in amdgpu_ttm_tt_pin_userptr() as it's still
needed
- Also update calls from various other places that now use
get_user_pages_remote() upstream, which were updated there by commit
9beae1ea8930 "mm: replace get_user_pages_remote() write/force ..."
- Also update calls from hfi1 and ipath
- Adjust context]
commit a6f572084fbee8b30f91465f4a085d7a90901c57 upstream.
Will noted that only checking mm_users is incorrect; we should also
check mm_count in order to cover CPUs that have a lazy reference to
this mm (and could do speculative TLB operations).
If removing this turns out to be a performance issue, we can
re-instate a more complete check, but in tlb_table_flush() eliding the
call_rcu_sched().
Fixes: 267239116987 ("mm, powerpc: move the RCU page-table freeing into generic code")
Reported-by: Will Deacon <will.deacon@arm.com>
Acked-by: Rik van Riel <riel@surriel.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: stable@kernel.org
[ Upstream commit 24eee1e4c47977bdfb71d6f15f6011e7b6188d04 ]
ioremap_prot() can return NULL which could lead to an oops.
Link: http://lkml.kernel.org/r/1533195441-58594-1-git-send-email-chenjie6@huawei.com
Signed-off-by: chen jie <chenjie6@huawei.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Li Zefan <lizefan@huawei.com>
Cc: chenjie <chenjie6@huawei.com>
Cc: Yang Shi <shy828301@gmail.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit 42e4089c7890725fcd329999252dc489b72f2921 upstream
For L1TF PROT_NONE mappings are protected by inverting the PFN in the page
table entry. This sets the high bits in the CPU's address space, thus
making sure to point to not point an unmapped entry to valid cached memory.
Some server system BIOSes put the MMIO mappings high up in the physical
address space. If such an high mapping was mapped to unprivileged users
they could attack low memory by setting such a mapping to PROT_NONE. This
could happen through a special device driver which is not access
protected. Normal /dev/mem is of course access protected.
To avoid this forbid PROT_NONE mappings or mprotect for high MMIO mappings.
Valid page mappings are allowed because the system is then unsafe anyways.
It's not expected that users commonly use PROT_NONE on MMIO. But to
minimize any impact this is only enforced if the mapping actually refers to
a high MMIO address (defined as the MAX_PA-1 bit being set), and also skip
the check for root.
For mmaps this is straight forward and can be handled in vm_insert_pfn and
in remap_pfn_range().
For mprotect it's a bit trickier. At the point where the actual PTEs are
accessed a lot of state has been changed and it would be difficult to undo
on an error. Since this is a uncommon case use a separate early page talk
walk pass for MMIO PROT_NONE mappings that checks for this condition
early. For non MMIO and non PROT_NONE there are no changes.
[dwmw2: Backport to 4.9]
[groeck: Backport to 4.4]
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Dave Hansen <dave.hansen@intel.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit 87744ab3832b83ba71b931f86f9cfdb000d07da5 upstream
vm_insert_mixed() unlike vm_insert_pfn_prot() and vmf_insert_pfn_pmd(),
fails to check the pgprot_t it uses for the mapping against the one
recorded in the memtype tracking tree. Add the missing call to
track_pfn_insert() to preclude cases where incompatible aliased mappings
are established for a given physical address range.
[groeck: Backport to v4.4.y]
Link: http://lkml.kernel.org/r/147328717909.35069.14256589123570653697.stgit@dwillia2-desk3.amr.corp.intel.com
Cc: David Airlie <airlied@linux.ie>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
commit 1745cbc5d0dee0749a6bc0ea8e872c5db0074061 upstream
The x86 vvar vma contains pages with differing cacheability
flags. x86 currently implements this by manually inserting all
the ptes using (io_)remap_pfn_range when the vma is set up.
x86 wants to move to using .fault with VM_FAULT_NOPAGE to set up
the mappings as needed. The correct API to use to insert a pfn
in .fault is vm_insert_pfn(), but vm_insert_pfn() can't override the
vma's cache mode, and the HPET page in particular needs to be
uncached despite the fact that the rest of the VMA is cached.
Add vm_insert_pfn_prot() to support varying cacheability within
the same non-COW VMA in a more sane manner.
x86 could alternatively use multiple VMAs, but that's messy,
would break CRIU, and would create unnecessary VMAs that would
waste memory.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Link: http://lkml.kernel.org/r/d2938d1eb37be7a5e4f86182db646551f11e45aa.1451446564.git.luto@kernel.org
commit c20cd45eb01748f0fba77a504f956b000df4ea73 upstream.
page_cache_read has been historically using page_cache_alloc_cold to
allocate a new page. This means that mapping_gfp_mask is used as the
base for the gfp_mask. Many filesystems are setting this mask to
GFP_NOFS to prevent from fs recursion issues. page_cache_read is called
from the vm_operations_struct::fault() context during the page fault.
This context doesn't need the reclaim protection normally.
ceph and ocfs2 which call filemap_fault from their fault handlers seem
to be OK because they are not taking any fs lock before invoking generic
implementation. xfs which takes XFS_MMAPLOCK_SHARED is safe from the
reclaim recursion POV because this lock serializes truncate and punch
hole with the page faults and it doesn't get involved in the reclaim.
There is simply no reason to deliberately use a weaker allocation
context when a __GFP_FS | __GFP_IO can be used. The GFP_NOFS protection
might be even harmful. There is a push to fail GFP_NOFS allocations
rather than loop within allocator indefinitely with a very limited
reclaim ability. Once we start failing those requests the OOM killer
might be triggered prematurely because the page cache allocation failure
is propagated up the page fault path and end up in
pagefault_out_of_memory.
We cannot play with mapping_gfp_mask directly because that would be racy
wrt. parallel page faults and it might interfere with other users who
really rely on NOFS semantic from the stored gfp_mask. The mask is also
inode proper so it would even be a layering violation. What we can do
instead is to push the gfp_mask into struct vm_fault and allow fs layer
to overwrite it should the callback need to be called with a different
allocation context.
Initialize the default to (mapping_gfp_mask | __GFP_FS | __GFP_IO)
because this should be safe from the page fault path normally. Why do
we care about mapping_gfp_mask at all then? Because this doesn't hold
only reclaim protection flags but it also might contain zone and
movability restrictions (GFP_DMA32, __GFP_MOVABLE and others) so we have
to respect those.
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Mark Fasheh <mfasheh@suse.com>
commit af27d9403f5b80685b79c88425086edccecaf711 upstream.
We get a warning about some slow configurations in randconfig kernels:
mm/memory.c:83:2: error: #warning Unfortunate NUMA and NUMA Balancing config, growing page-frame for last_cpupid. [-Werror=cpp]
The warning is reasonable by itself, but gets in the way of randconfig
build testing, so I'm hiding it whenever CONFIG_COMPILE_TEST is set.
The warning was added in 2013 in commit 75980e97dacc ("mm: fold
page->_last_nid into page->flags where possible").
leaving stale TLB entries
commit 3ea277194daaeaa84ce75180ec7c7a2075027a68 upstream.
Stable note for 4.4: The upstream patch patches madvise(MADV_FREE) but 4.4
does not have support for that feature. The changelog is left
as-is but the hunk related to madvise is omitted from the backport.
Nadav Amit identified a theoritical race between page reclaim and
mprotect due to TLB flushes being batched outside of the PTL being held.
He described the race as follows:
CPU0 CPU1
user accesses memory using RW PTE
[PTE now cached in TLB]
try_to_unmap_one()
==> ptep_get_and_clear()
==> set_tlb_ubc_flush_pending()
mprotect(addr, PROT_READ)
==> change_pte_range()
==> [ PTE non-present - no flush ]
user writes using cached RW PTE
try_to_unmap_flush()
The same type of race exists for reads when protecting for PROT_NONE and
also exists for operations that can leave an old TLB entry behind such
as munmap, mremap and madvise.
For some operations like mprotect, it's not necessarily a data integrity
issue but it is a correctness issue as there is a window where an
mprotect that limits access still allows access. For munmap, it's
potentially a data integrity issue although the race is massive as an
munmap, mmap and return to userspace must all complete between the
window when reclaim drops the PTL and flushes the TLB. However, it's
theoritically possible so handle this issue by flushing the mm if
reclaim is potentially currently batching TLB flushes.
Other instances where a flush is required for a present pte should be ok
as either the page lock is held preventing parallel reclaim or a page
reference count is elevated preventing a parallel free leading to
corruption. In the case of page_mkclean there isn't an obvious path
that userspace could take advantage of without using the operations that
are guarded by this patch. Other users such as gup as a race with
reclaim looks just at PTEs. huge page variants should be ok as they
don't race with reclaim. mincore only looks at PTEs. userfault also
should be ok as if a parallel reclaim takes place, it will either fault
the page back in or read some of the data before the flush occurs
triggering a fault.
Note that a variant of this patch was acked by Andy Lutomirski but this
was for the x86 parts on top of his PCID work which didn't make the 4.13
merge window as expected. His ack is dropped from this version and
there will be a follow-on patch on top of PCID that will include his
ack.
[akpm@linux-foundation.org: tweak comments]
[akpm@linux-foundation.org: fix spello]
Link: http://lkml.kernel.org/r/20170717155523.emckq2esjro6hf3z@suse.de
Reported-by: Nadav Amit <nadav.amit@gmail.com>
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
[wt: backport to 4.4: adjust context ; drop ppc hugetlb_radix changes]
Signed-off-by: Willy Tarreau <w@1wt.eu>
[gkh: minor build fixes for 4.4]
commit 28093f9f34cedeaea0f481c58446d9dac6dd620f upstream.
In gather_pte_stats() a THP pmd is cast into a pte, which is wrong
because the layouts may differ depending on the architecture. On s390
this will lead to inaccurate numa_maps accounting in /proc because of
misguided pte_present() and pte_dirty() checks on the fake pte.
On other architectures pte_present() and pte_dirty() may work by chance,
but there may be an issue with direct-access (dax) mappings w/o
underlying struct pages when HAVE_PTE_SPECIAL is set and THP is
available. In vm_normal_page() the fake pte will be checked with
pte_special() and because there is no "special" bit in a pmd, this will
always return false and the VM_PFNMAP | VM_MIXEDMAP checking will be
skipped. On dax mappings w/o struct pages, an invalid struct page
pointer would then be returned that can crash the kernel.
This patch fixes the numa_maps THP handling by introducing new "_pmd"
variants of the can_gather_numa_stats() and vm_normal_page() functions.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com>
commit ad33bb04b2a6cee6c1f99fabb15cddbf93ff0433 upstream.
pmd_trans_unstable()/pmd_none_or_trans_huge_or_clear_bad() were
introduced to locklessy (but atomically) detect when a pmd is a regular
(stable) pmd or when the pmd is unstable and can infinitely transition
from pmd_none() and pmd_trans_huge() from under us, while only holding
the mmap_sem for reading (for writing not).
While holding the mmap_sem only for reading, MADV_DONTNEED can run from
under us and so before we can assume the pmd to be a regular stable pmd
we need to compare it against pmd_none() and pmd_trans_huge() in an
atomic way, with pmd_trans_unstable(). The old pmd_trans_huge() left a
tiny window for a race.
Useful applications are unlikely to notice the difference as doing
MADV_DONTNEED concurrently with a page fault would lead to undefined
behavior.
[akpm@linux-foundation.org: tidy up comment grammar/layout]
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
DAX handling of COW faults has wrong locking sequence:
dax_fault does i_mmap_lock_read
do_cow_fault does i_mmap_unlock_write
Ross's commit[1] missed a fix[2] that Kirill added to Matthew's
commit[3].
Original COW locking logic was introduced by Matthew here[4].
This should be applied to v4.3 as well.
[1] 0f90cc6609c7 mm, dax: fix DAX deadlocks
[2] 52a2b53ffde6 mm, dax: use i_mmap_unlock_write() in do_cow_fault()
[3] 843172978bb9 dax: fix race between simultaneous faults
[4] 2e4cdab0584f mm: allow page fault handlers to perform the COW
Cc: <stable@vger.kernel.org>
Cc: Boaz Harrosh <boaz@plexistor.com>
Cc: Dave Chinner <dchinner@redhat.com>
Cc: Jan Kara <jack@suse.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Acked-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Signed-off-by: Yigal Korman <yigal@plexistor.com>
The following two locking commits in the DAX code:
commit 843172978bb9 ("dax: fix race between simultaneous faults")
commit 46c043ede471 ("mm: take i_mmap_lock in unmap_mapping_range() for DAX")
introduced a number of deadlocks and other issues which need to be fixed
for the v4.3 kernel. The list of issues in DAX after these commits
(some newly introduced by the commits, some preexisting) can be found
here:
https://lkml.org/lkml/2015/9/25/602 (Subject: "Re: [PATCH] dax: fix deadlock in __dax_fault").
This undoes most of the changes introduced by those two commits,
essentially returning us to the DAX locking scheme that was used in
v4.2.
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Tested-by: Dave Chinner <dchinner@redhat.com>
Let's use helper rather than direct check of vma->vm_ops to distinguish
anonymous VMA.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
__dax_fault() takes i_mmap_lock for write. Let's pair it with write
unlock on do_cow_fault() side.
Acked-by: Matthew Wilcox <willy@linux.intel.com>
DAX is not so special: we need i_mmap_lock to protect mapping->i_mmap.
__dax_pmd_fault() uses unmap_mapping_range() shoot out zero page from
all mappings. We need to drop i_mmap_lock there to avoid lock deadlock.
Re-aquiring the lock should be fine since we check i_size after the
point.
Cc: Matthew Wilcox <willy@linux.intel.com>
If two threads write-fault on the same hole at the same time, the winner
of the race will return to userspace and complete their store, only to
have the loser overwrite their store with zeroes. Fix this for now by
taking the i_mmap_sem for write instead of read, and do so outside the
call to get_block(). Now the loser of the race will see the block has
already been zeroed, and will not zero it again.
This severely limits our scalability. I have ideas for improving it, but
those can wait for a later patch.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Allow non-anonymous VMAs to provide huge pages in response to a page fault.
Cc: Hillf Danton <dhillf@gmail.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Jan Kara <jack@suse.cz>
special_mapping_fault() is absolutely broken. It seems it was always
wrong, but this didn't matter until vdso/vvar started to use more than
one page.
And after this change vma_is_anonymous() becomes really trivial, it
simply checks vm_ops == NULL. However, I do think the helper makes
sense. There are a lot of ->vm_ops != NULL checks, the helper makes the
caller's code more understandable (self-documented) and this is more
grep-friendly.
This patch (of 3):
Preparation. Add the new simple helper, vma_is_anonymous(vma), and change
handle_pte_fault() to use it. It will have more users.
The name is not accurate, say a hpet_mmap()'ed vma is not anonymous.
Perhaps it should be named vma_has_fault() instead. But it matches the
logic in mmap.c/memory.c (see next changes). "True" just means that a
page fault will use do_anonymous_page().
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
This makes the tlb_next_batch() bool due to this particular function only
ever returning either one or zero as its return value.
Signed-off-by: Nicholas Krause <xerofoify@gmail.com>
This is where the page faults must be modified to call
handle_userfault() if userfaultfd_missing() is true (so if the
vma->vm_flags had VM_UFFD_MISSING set).
handle_userfault() then takes care of blocking the page fault and
delivering it to userland.
The fault flags must also be passed as parameter so the "read|write"
kind of fault can be passed to userland.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com>
Cc: zhang.zhanghailiang@huawei.com
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Peter Feiner <pfeiner@google.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com>
Reading page fault handler code I've noticed that under right
circumstances kernel would map anonymous pages into file mappings: if
the VMA doesn't have vm_ops->fault() and the VMA wasn't fully populated
on ->mmap(), kernel would handle page fault to not populated pte with
Let's change page fault handler to use do_anonymous_page() only on
anonymous VMA (->vm_ops == NULL) and make sure that the VMA is not
shared.
For file mappings without vm_ops->fault() or shred VMA without vm_ops,
page fault on pte_none() entry would lead to SIGBUS.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Willy Tarreau <w@1wt.eu>
Pull more vfs updates from Al Viro:
"Assorted VFS fixes and related cleanups (IMO the most interesting in
that part are f_path-related things and Eric's descriptor-related
stuff). UFS regression fixes (it got broken last cycle). 9P fixes.
fs-cache series, DAX patches, Jan's file_remove_suid() work"
[ I'd say this is much more than "fixes and related cleanups". The
file_table locking rule change by Eric Dumazet is a rather big and
fundamental update even if the patch isn't huge. - Linus ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits)
9p: cope with bogus responses from server in p9_client_{read,write}
p9_client_write(): avoid double p9_free_req()
9p: forgetting to cancel request on interrupted zero-copy RPC
dax: bdev_direct_access() may sleep
block: Add support for DAX reads/writes to block devices
dax: Use copy_from_iter_nocache
dax: Add block size note to documentation
fs/file.c: __fget() and dup2() atomicity rules
fs/file.c: don't acquire files->file_lock in fd_install()
fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation
vfs: avoid creation of inode number 0 in get_next_ino
namei: make set_root_rcu() return void
make simple_positive() public
ufs: use dir_pages instead of ufs_dir_pages()
pagemap.h: move dir_pages() over there
remove the pointless include of lglock.h
fs: cleanup slight list_entry abuse
xfs: Correctly lock inode when removing suid and file capabilities
fs: Call security_ops->inode_killpriv on truncate
fs: Provide function telling whether file_remove_privs() will do anything
Historically memcg overhead was high even if memcg was unused. This has
improved a lot but it still showed up in a profile summary as being a
problem.
/usr/src/linux-4.0-vanilla/mm/memcontrol.c 6.6441 395842
mem_cgroup_try_charge 2.950% 175781
__mem_cgroup_count_vm_event 1.431% 85239
mem_cgroup_page_lruvec 0.456% 27156
mem_cgroup_commit_charge 0.392% 23342
uncharge_list 0.323% 19256
mem_cgroup_update_lru_size 0.278% 16538
memcg_check_events 0.216% 12858
mem_cgroup_charge_statistics.isra.22 0.188% 11172
try_charge 0.150% 8928
commit_charge 0.141% 8388
get_mem_cgroup_from_mm 0.121% 7184
That is showing that 6.64% of system CPU cycles were in memcontrol.c and
dominated by mem_cgroup_try_charge. The annotation shows that the bulk
of the cost was checking PageSwapCache which is expected to be cache hot
but is very expensive. The problem appears to be that __SetPageUptodate
is called just before the check which is a write barrier. It is
required to make sure struct page and page data is written before the
PTE is updated and the data visible to userspace. memcg charging does
not require or need the barrier but gets unfairly hit with the cost so
this patch attempts the charging before the barrier. Aside from the
accidental cost to memcg there is the added benefit that the barrier is
avoided if the page cannot be charged. When applied the relevant
profile summary is as follows.
/usr/src/linux-4.0-chargefirst-v2r1/mm/memcontrol.c 3.7907 223277
__mem_cgroup_count_vm_event 1.143% 67312
mem_cgroup_page_lruvec 0.465% 27403
mem_cgroup_commit_charge 0.381% 22452
uncharge_list 0.332% 19543
mem_cgroup_update_lru_size 0.284% 16704
get_mem_cgroup_from_mm 0.271% 15952
mem_cgroup_try_charge 0.237% 13982
memcg_check_events 0.222% 13058
mem_cgroup_charge_statistics.isra.22 0.185% 10920
commit_charge 0.140% 8235
try_charge 0.131% 7716
That brings the overhead down to 3.79% and leaves the memcg fault
accounting to the root cgroup but it's an improvement. The difference
in headline performance of the page fault microbench is marginal as
memcg is such a small component of it.
pft faults
4.0.0 4.0.0
vanilla chargefirst
Hmean faults/cpu-1 1443258.1051 ( 0.00%) 1509075.7561 ( 4.56%)
Hmean faults/cpu-3 1340385.9270 ( 0.00%) 1339160.7113 ( -0.09%)
Hmean faults/cpu-5 875599.0222 ( 0.00%) 874174.1255 ( -0.16%)
Hmean faults/cpu-7 601146.6726 ( 0.00%) 601370.9977 ( 0.04%)
Hmean faults/cpu-8 510728.2754 ( 0.00%) 510598.8214 ( -0.03%)
Hmean faults/sec-1 1432084.7845 ( 0.00%) 1497935.5274 ( 4.60%)
Hmean faults/sec-3 3943818.1437 ( 0.00%) 3941920.1520 ( -0.05%)
Hmean faults/sec-5 3877573.5867 ( 0.00%) 3869385.7553 ( -0.21%)
Hmean faults/sec-7 3991832.0418 ( 0.00%) 3992181.4189 ( 0.01%)
Hmean faults/sec-8 3987189.8167 ( 0.00%) 3986452.2204 ( -0.02%)
It's only visible at single threaded. The overhead is there for higher
threads but other factors dominate.
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Tejun Heo <tj@kernel.org>
Turn
d_path(&file->f_path, ...);
into
file_path(file, ...);
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
disabled pagefaults
Commit 662bbcb2747c ("mm, sched: Allow uaccess in atomic with
pagefault_disable()") removed might_sleep() checks for all user access
code (that uses might_fault()).
The reason was to disable wrong "sleep in atomic" warnings in the
following scenario:
pagefault_disable()
rc = copy_to_user(...)
pagefault_enable()
Which is valid, as pagefault_disable() increments the preempt counter
and therefore disables the pagefault handler. copy_to_user() will not
sleep and return an error code if a page is not available.
However, as all might_sleep() checks are removed,
CONFIG_DEBUG_ATOMIC_SLEEP would no longer detect the following scenario:
spin_lock(&lock);
spin_unlock(&lock)
If the kernel is compiled with preemption turned on, preempt_disable()
will make in_atomic() detect disabled preemption. The fault handler would
correctly never sleep on user access.
However, with preemption turned off, preempt_disable() is usually a NOP
(with !CONFIG_PREEMPT_COUNT), therefore in_atomic() will not be able to
detect disabled preemption nor disabled pagefaults. The fault handler
could sleep.
We really want to enable CONFIG_DEBUG_ATOMIC_SLEEP checks for user access
functions again, otherwise we can end up with horrible deadlocks.
Root of all evil is that pagefault_disable() acts almost as
preempt_disable(), depending on preemption being turned on/off.
As we now have pagefault_disabled(), we can use it to distinguish
whether user acces functions might sleep.
Convert might_fault() into a makro that calls __might_fault(), to
allow proper file + line messages in case of a might_sleep() warning.
Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David.Laight@ACULAB.COM
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bigeasy@linutronix.de
Cc: borntraeger@de.ibm.com
Cc: daniel.vetter@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: hocko@suse.cz
Cc: hughd@google.com
Cc: mst@redhat.com
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: schwidefsky@de.ibm.com
Cc: yang.shi@windriver.com
Link: http://lkml.kernel.org/r/1431359540-32227-3-git-send-email-dahi@linux.vnet.ibm.com
This will allow FS that uses VM_PFNMAP | VM_MIXEDMAP (no page structs) to
get notified when access is a write to a read-only PFN.
This can happen if we mmap() a file then first mmap-read from it to
page-in a read-only PFN, than we mmap-write to the same page.
We need this functionality to fix a DAX bug, where in the scenario above
we fail to set ctime/mtime though we modified the file. An xfstest is
attached to this patchset that shows the failure and the fix. (A DAX
patch will follow)
This functionality is extra important for us, because upon dirtying of a
pmem page we also want to RDMA the page to a remote cluster node.
We define a new pfn_mkwrite and do not reuse page_mkwrite because
1 - The name ;-)
2 - But mainly because it would take a very long and tedious
audit of all page_mkwrite functions of VM_MIXEDMAP/VM_PFNMAP
users. To make sure they do not now CRASH. For example current
DAX code (which this is for) would crash.
If we would want to reuse page_mkwrite, We will need to first
patch all users, so to not-crash-on-no-page. Then enable this
patch. But even if I did that I would not sleep so well at night.
Adding a new vector is the safest thing to do, and is not that
expensive. an extra pointer at a static function vector per driver.
Also the new vector is better for performance, because else we
Will call all current Kernel vectors, so to:
check-ha-no-page-do-nothing and return.
No need to call it from do_shared_fault because do_wp_page is called to
change pte permissions anyway.
Signed-off-by: Boaz Harrosh <boaz@plexistor.com>
A lot of filesystems use generic_file_mmap() and filemap_fault(),
f_op->mmap and vm_ops->fault aren't enough to identify filesystem.
This prints file name, vm_ops->fault, f_op->mmap and a_ops->readpage
(which is almost always implemented and filesystem-specific).
Example:
[ 23.676410] BUG: Bad page map in process sh pte:1b7e6025 pmd:19bbd067
[ 23.676887] page:ffffea00006df980 count:4 mapcount:1 mapping:ffff8800196426c0 index:0x97
[ 23.677481] flags: 0x10000000000000c(referenced|uptodate)
[ 23.677896] page dumped because: bad pte
[ 23.678205] addr:00007f52fcb17000 vm_flags:00000075 anon_vma: (null) mapping:ffff8800196426c0 index:97
[ 23.678922] file:libc-2.19.so fault:filemap_fault mmap:generic_file_readonly_mmap readpage:v9fs_vfs_readpage
[akpm@linux-foundation.org: use pr_alert, per Kirill]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Sasha Levin <sasha.levin@oracle.com>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
We converted some of the usages of ACCESS_ONCE to READ_ONCE in the mm/
tree since it doesn't work reliably on non-scalar types.
This patch removes the rest of the usages of ACCESS_ONCE, and use the new
READ_ONCE API for the read accesses. This makes things cleaner, instead
of using separate/multiple sets of APIs.
Signed-off-by: Jason Low <jason.low2@hp.com>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
The do_wp_page function is extremely long. Extract the logic for
handling a page belonging to a shared vma into a function of its own.
This helps the readability of the code, without doing any functional
change in it.
Signed-off-by: Shachar Raindel <raindel@mellanox.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Haggai Eran <haggaie@mellanox.com>
Cc: Michel Lespinasse <walken@google.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
In some cases, do_wp_page had to copy the page suffering a write fault
to a new location. If the function logic decided that to do this, it
was done by jumping with a "goto" operation to the relevant code block.
This made the code really hard to understand. It is also against the
kernel coding style guidelines.
This patch extracts the page copy and page table update logic to a
separate function. It also clean up the naming, from "gotten" to
"wp_page_copy", and adds few comments.
When do_wp_page is ending, in several cases it needs to unlock the pages
and ptls it was accessing.
Currently, this logic was "called" by using a goto jump. This makes
following the control flow of the function harder. Readability was
further hampered by the unlock case containing large amount of logic
needed only in one of the 3 cases.
Using goto for cleanup is generally allowed. However, moving the
trivial unlocking flows to the relevant call sites allow deeper
refactoring in the next patch.
Currently do_wp_page contains 265 code lines. It also contains 9 goto
statements, of which 5 are targeting labels which are not cleanup
related. This makes the function extremely difficult to understand.
The following patches are an attempt at breaking the function to its
basic components, and making it easier to understand.
The patches are straight forward function extractions from do_wp_page.
As we extract functions, we remove unneeded parameters and simplify the
code as much as possible. However, the functionality is supposed to
remain completely unchanged. The patches also attempt to document the
functionality of each extracted function. In patch 2, we split the
unlock logic to the contain logic relevant to specific needs of each use
case, instead of having huge number of conditional decisions in a single
unlock flow.
This patch (of 4):
When do_wp_page is ending, in several cases it needs to reuse the existing
page. This is achieved by making the page table writable, and possibly
updating the page-cache state.
following the control flow of the function harder. It is also against the
coding style guidelines for using goto.
As the code can easily be refactored into a specialized function, refactor
it out and simplify the code flow in do_wp_page.
Dave Chinner reported the following on https://lkml.org/lkml/2015/3/1/226
Across the board the 4.0-rc1 numbers are much slower, and the degradation
is far worse when using the large memory footprint configs. Perf points
straight at the cause - this is from 4.0-rc1 on the "-o bhash=101073" config:
- 56.07% 56.07% [kernel] [k] default_send_IPI_mask_sequence_phys
- default_send_IPI_mask_sequence_phys
- 99.99% physflat_send_IPI_mask
- 99.37% native_send_call_func_ipi
smp_call_function_many
- native_flush_tlb_others
- 99.85% flush_tlb_page
ptep_clear_flush
try_to_unmap_one
rmap_walk
try_to_unmap
migrate_pages
migrate_misplaced_page
- handle_mm_fault
- 99.73% __do_page_fault
trace_do_page_fault
do_async_page_fault
+ async_page_fault
0.63% native_send_call_func_single_ipi
generic_exec_single
smp_call_function_single
This is showing excessive migration activity even though excessive
migrations are meant to get throttled. Normally, the scan rate is tuned
on a per-task basis depending on the locality of faults. However, if
migrations fail for any reason then the PTE scanner may scan faster if
the faults continue to be remote. This means there is higher system CPU
overhead and fault trapping at exactly the time we know that migrations
cannot happen. This patch tracks when migration failures occur and
slows the PTE scanner.
Reported-by: Dave Chinner <david@fromorbit.com>
Tested-by: Dave Chinner <david@fromorbit.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Protecting a PTE to trap a NUMA hinting fault clears the writable bit
and further faults are needed after trapping a NUMA hinting fault to set
the writable bit again. This patch preserves the writable bit when
trapping NUMA hinting faults. The impact is obvious from the number of
minor faults trapped during the basis balancing benchmark and the system
CPU usage;
autonumabench
4.0.0-rc4 4.0.0-rc4
baseline preserve
Time System-NUMA01 107.13 ( 0.00%) 103.13 ( 3.73%)
Time System-NUMA01_THEADLOCAL 131.87 ( 0.00%) 83.30 ( 36.83%)
Time System-NUMA02 8.95 ( 0.00%) 10.72 (-19.78%)
Time System-NUMA02_SMT 4.57 ( 0.00%) 3.99 ( 12.69%)
Time Elapsed-NUMA01 515.78 ( 0.00%) 517.26 ( -0.29%)
Time Elapsed-NUMA01_THEADLOCAL 384.10 ( 0.00%) 384.31 ( -0.05%)
Time Elapsed-NUMA02 48.86 ( 0.00%) 48.78 ( 0.16%)
Time Elapsed-NUMA02_SMT 47.98 ( 0.00%) 48.12 ( -0.29%)
4.0.0-rc4 4.0.0-rc4
baseline preserve
User 44383.95 43971.89
System 252.61 201.24
Elapsed 998.68 1000.94
Minor Faults 2597249 1981230
Major Faults 365 364
There is a similar drop in system CPU usage using Dave Chinner's xfsrepair
workload
4.0.0-rc4 4.0.0-rc4
baseline preserve
Amean real-xfsrepair 454.14 ( 0.00%) 442.36 ( 2.60%)
Amean syst-xfsrepair 277.20 ( 0.00%) 204.68 ( 26.16%)
The patch looks hacky but the alternatives looked worse. The tidest was
to rewalk the page tables after a hinting fault but it was more complex
than this approach and the performance was worse. It's not generally
safe to just mark the page writable during the fault if it's a write
fault as it may have been read-only for COW so that approach was
discarded.
These are three follow-on patches based on the xfsrepair workload Dave
Chinner reported was problematic in 4.0-rc1 due to changes in page table
management -- https://lkml.org/lkml/2015/3/1/226.
Much of the problem was reduced by commit 53da3bc2ba9e ("mm: fix up numa
read-only thread grouping logic") and commit ba68bc0115eb ("mm: thp:
Return the correct value for change_huge_pmd"). It was known that the
performance in 3.19 was still better even if is far less safe. This
series aims to restore the performance without compromising on safety.
For the test of this mail, I'm comparing 3.19 against 4.0-rc4 and the
three patches applied on top
autonumabench
3.19.0 4.0.0-rc4 4.0.0-rc4 4.0.0-rc4 4.0.0-rc4
vanilla vanilla vmwrite-v5r8 preserve-v5r8 slowscan-v5r8
Time System-NUMA01 124.00 ( 0.00%) 161.86 (-30.53%) 107.13 ( 13.60%) 103.13 ( 16.83%) 145.01 (-16.94%)
Time System-NUMA01_THEADLOCAL 115.54 ( 0.00%) 107.64 ( 6.84%) 131.87 (-14.13%) 83.30 ( 27.90%) 92.35 ( 20.07%)
Time System-NUMA02 9.35 ( 0.00%) 10.44 (-11.66%) 8.95 ( 4.28%) 10.72 (-14.65%) 8.16 ( 12.73%)
Time System-NUMA02_SMT 3.87 ( 0.00%) 4.63 (-19.64%) 4.57 (-18.09%) 3.99 ( -3.10%) 3.36 ( 13.18%)
Time Elapsed-NUMA01 570.06 ( 0.00%) 567.82 ( 0.39%) 515.78 ( 9.52%) 517.26 ( 9.26%) 543.80 ( 4.61%)
Time Elapsed-NUMA01_THEADLOCAL 393.69 ( 0.00%) 384.83 ( 2.25%) 384.10 ( 2.44%) 384.31 ( 2.38%) 380.73 ( 3.29%)
Time Elapsed-NUMA02 49.09 ( 0.00%) 49.33 ( -0.49%) 48.86 ( 0.47%) 48.78 ( 0.63%) 50.94 ( -3.77%)
Time Elapsed-NUMA02_SMT 47.51 ( 0.00%) 47.15 ( 0.76%) 47.98 ( -0.99%) 48.12 ( -1.28%) 49.56 ( -4.31%)
vanilla vanillavmwrite-v5r8preserve-v5r8slowscan-v5r8
User 46334.60 46391.94 44383.95 43971.89 44372.12
System 252.84 284.66 252.61 201.24 249.00
Elapsed 1062.14 1050.96 998.68 1000.94 1026.78
Overall the system CPU usage is comparable and the test is naturally a
bit variable. The slowing of the scanner hurts numa01 but on this
machine it is an adverse workload and patches that dramatically help it
often hurt absolutely everything else.
Due to patch 2, the fault activity is interesting
Minor Faults 2097811 2656646 2597249 1981230 1636841
Major Faults 362 450 365 364 365
Note the impact preserving the write bit across protection updates and
fault reduces faults.
NUMA alloc hit 1229008 1217015 1191660 1178322 1199681
NUMA alloc miss 0 0 0 0 0
NUMA interleave hit 0 0 0 0 0
NUMA alloc local 1228514 1216317 1190871 1177448 1199021
NUMA base PTE updates 245706197 240041607 238195516 244704842 115012800
NUMA huge PMD updates 479530 468448 464868 477573 224487
NUMA page range updates 491225557 479886983 476207932 489222218 229950144
NUMA hint faults 659753 656503 641678 656926 294842
NUMA hint local faults 381604 373963 360478 337585 186249
NUMA hint local percent 57 56 56 51 63
NUMA pages migrated 5412140 6374899 6266530 5277468 5755096
AutoNUMA cost 5121% 5083% 4994% 5097% 2388%
Here the impact of slowing the PTE scanner on migratrion failures is
obvious as "NUMA base PTE updates" and "NUMA huge PMD updates" are
massively reduced even though the headline performance is very similar.
As xfsrepair was the reported workload here is the impact of the series
on it.
xfsrepair
Min real-fsmark 1183.29 ( 0.00%) 1165.73 ( 1.48%) 1152.78 ( 2.58%) 1153.64 ( 2.51%) 1177.62 ( 0.48%)
Min syst-fsmark 4107.85 ( 0.00%) 4027.75 ( 1.95%) 3986.74 ( 2.95%) 3979.16 ( 3.13%) 4048.76 ( 1.44%)
Min real-xfsrepair 441.51 ( 0.00%) 463.96 ( -5.08%) 449.50 ( -1.81%) 440.08 ( 0.32%) 439.87 ( 0.37%)
Min syst-xfsrepair 195.76 ( 0.00%) 278.47 (-42.25%) 262.34 (-34.01%) 203.70 ( -4.06%) 143.64 ( 26.62%)
Amean real-fsmark 1188.30 ( 0.00%) 1177.34 ( 0.92%) 1157.97 ( 2.55%) 1158.21 ( 2.53%) 1182.22 ( 0.51%)
Amean syst-fsmark 4111.37 ( 0.00%) 4055.70 ( 1.35%) 3987.19 ( 3.02%) 3998.72 ( 2.74%) 4061.69 ( 1.21%)
Amean real-xfsrepair 450.88 ( 0.00%) 468.32 ( -3.87%) 454.14 ( -0.72%) 442.36 ( 1.89%) 440.59 ( 2.28%)
Amean syst-xfsrepair 199.66 ( 0.00%) 290.60 (-45.55%) 277.20 (-38.84%) 204.68 ( -2.51%) 150.55 ( 24.60%)
Stddev real-fsmark 4.12 ( 0.00%) 10.82 (-162.29%) 4.14 ( -0.28%) 5.98 (-45.05%) 4.60 (-11.53%)
Stddev syst-fsmark 2.63 ( 0.00%) 20.32 (-671.82%) 0.37 ( 85.89%) 16.47 (-525.59%) 15.05 (-471.79%)
Stddev real-xfsrepair 6.87 ( 0.00%) 4.55 ( 33.75%) 3.46 ( 49.58%) 1.78 ( 74.12%) 0.52 ( 92.50%)
Stddev syst-xfsrepair 3.02 ( 0.00%) 10.30 (-241.37%) 13.17 (-336.37%) 0.71 ( 76.63%) 5.00 (-65.61%)
CoeffVar real-fsmark 0.35 ( 0.00%) 0.92 (-164.73%) 0.36 ( -2.91%) 0.52 (-48.82%) 0.39 (-12.10%)
CoeffVar syst-fsmark 0.06 ( 0.00%) 0.50 (-682.41%) 0.01 ( 85.45%) 0.41 (-543.22%) 0.37 (-478.78%)
CoeffVar real-xfsrepair 1.52 ( 0.00%) 0.97 ( 36.21%) 0.76 ( 49.94%) 0.40 ( 73.62%) 0.12 ( 92.33%)
CoeffVar syst-xfsrepair 1.51 ( 0.00%) 3.54 (-134.54%) 4.75 (-214.31%) 0.34 ( 77.20%) 3.32 (-119.63%)
Max real-fsmark 1193.39 ( 0.00%) 1191.77 ( 0.14%) 1162.90 ( 2.55%) 1166.66 ( 2.24%) 1188.50 ( 0.41%)
Max syst-fsmark 4114.18 ( 0.00%) 4075.45 ( 0.94%) 3987.65 ( 3.08%) 4019.45 ( 2.30%) 4082.80 ( 0.76%)
Max real-xfsrepair 457.80 ( 0.00%) 474.60 ( -3.67%) 457.82 ( -0.00%) 444.42 ( 2.92%) 441.03 ( 3.66%)
Max syst-xfsrepair 203.11 ( 0.00%) 303.65 (-49.50%) 294.35 (-44.92%) 205.33 ( -1.09%) 155.28 ( 23.55%)
The really relevant lines as syst-xfsrepair which is the system CPU
usage when running xfsrepair. Note that on my machine the overhead was
45% higher on 4.0-rc4 which may be part of what Dave is seeing. Once we
preserve the write bit across faults, it's only 2.51% higher on average.
With the full series applied, system CPU usage is 24.6% lower on
average.
Again, the impact of preserving the write bit on minor faults is obvious
and the impact of slowing scanning after migration failures is obvious
on the PTE updates. Note also that the number of pages migrated is much
reduced even though the headline performance is comparable.
Minor Faults 153466827 254507978 249163829 153501373 105737890
Major Faults 610 702 690 649 724
NUMA base PTE updates 217735049 210756527 217729596 216937111 144344993
NUMA huge PMD updates 129294 85044 106921 127246 79887
NUMA pages migrated 21938995 29705270 28594162 22687324 16258075
Mean sdb-avgqusz 13.47 2.54 2.55 2.47 2.49
Mean sdb-avgrqsz 202.32 140.22 139.50 139.02 138.12
Mean sdb-await 25.92 5.09 5.33 5.02 5.22
Mean sdb-r_await 4.71 0.19 0.83 0.51 0.11
Mean sdb-w_await 104.13 5.21 5.38 5.05 5.32
Mean sdb-svctm 0.59 0.13 0.14 0.13 0.14
Mean sdb-rrqm 0.16 0.00 0.00 0.00 0.00
Mean sdb-wrqm 3.59 1799.43 1826.84 1812.21 1785.67
Max sdb-avgqusz 111.06 12.13 14.05 11.66 15.60
Max sdb-avgrqsz 255.60 190.34 190.01 187.33 191.78
Max sdb-await 168.24 39.28 49.22 44.64 65.62
Max sdb-r_await 660.00 52.00 280.00 76.00 12.00
Max sdb-w_await 7804.00 39.28 49.22 44.64 65.62
Max sdb-svctm 4.00 2.82 2.86 1.98 2.84
Max sdb-rrqm 8.30 0.00 0.00 0.00 0.00
Max sdb-wrqm 34.20 5372.80 5278.60 5386.60 5546.15
FWIW, I also checked SPECjbb in different configurations but it's
similar observations -- minor faults lower, PTE update activity lower
and performance is roughly comparable against 3.19.
This patch (of 3):
Threads that share writable data within pages are grouped together as
related tasks. This decision is based on whether the PTE is marked
dirty which is subject to timing races between the PTE scanner update
and when the application writes the page. If the page is file-backed,
then background flushes and sync also affect placement. This is
unpredictable behaviour which is impossible to reason about so this
patch makes grouping decisions based on the VMA flags.
Dave Chinner reported that commit 4d9424669946 ("mm: convert
p[te|md]_mknonnuma and remaining page table manipulations") slowed down
his xfsrepair test enormously. In particular, it was using more system
time due to extra TLB flushing.
The ultimate reason turns out to be how the change to use the regular
page table accessor functions broke the NUMA grouping logic. The old
special mknuma/mknonnuma code accessed the page table present bit and
the magic NUMA bit directly, while the new code just changes the page
protections using PROT_NONE and the regular vma protections.
That sounds equivalent, and from a fault standpoint it really is, but a
subtle side effect is that the *other* protection bits of the page table
entries also change. And the code to decide how to group the NUMA
entries together used the writable bit to decide whether a particular
page was likely to be shared read-only or not.
And with the change to make the NUMA handling use the regular permission
setting functions, that writable bit was basically always cleared for
private mappings due to COW. So even if the page actually ends up being
written to in the end, the NUMA balancing would act as if it was always
shared RO.
This code is a heuristic anyway, so the fix - at least for now - is to
instead check whether the page is dirty rather than writable. The bit
doesn't change with protection changes.
NOTE! This also adds a FIXME comment to revisit this issue,
Not only should we probably re-visit the whole "is this a shared
read-only page" heuristic (we might want to take the vma permissions
into account and base this more on those than the per-page ones, and
also look at whether the particular access that triggers it is a write
or not), but the whole COW issue shows that we should think about the
NUMA fault handling some more.
For example, maybe we should do the early-COW thing that a regular fault
does. Or maybe we should accept that while using the same bits as
PROTNONE was a good thing (and got rid of the specual NUMA bit), we
might still want to just preseve the other protection bits across NUMA
faulting.
Those are bigger questions, left for later. This just fixes up the
heuristic so that it at least approximates working again. More analysis
and work needed.
Tested-by: Mel Gorman <mgorman@suse.de>
Cc: Ingo Molnar <mingo@kernel.org>,
Currently COW of an XIP file is done by first bringing in a read-only
mapping, then retrying the fault and copying the page. It is much more
efficient to tell the fault handler that a COW is being attempted (by
passing in the pre-allocated page in the vm_fault structure), and allow
the handler to perform the COW operation itself.
The handler cannot insert the page itself if there is already a read-only
mapping at that address, so allow the handler to return VM_FAULT_LOCKED
and set the fault_page to be NULL. This indicates to the MM code that the
i_mmap_lock is held instead of the page lock.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Andreas Dilger <andreas.dilger@intel.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
DAX is a replacement for the variation of XIP currently supported by the
ext2 filesystem. We have three different things in the tree called 'XIP',
and the new focus is on access to data rather than executables, so a name
change was in order. DAX stands for Direct Access. The X is for
eXciting.
The new focus on data access has resulted in more careful attention to
races that exist in the current XIP code, but are not hit by the use-case
that it was designed for. XIP's architecture worked fine for ext2, but
DAX is architected to work with modern filsystems such as ext4 and XFS.
DAX is not intended for use with btrfs; the value that btrfs adds relies
on manipulating data and writing data to different locations, while DAX's
value is for write-in-place and keeping the kernel from touching the data.
DAX was developed in order to support NV-DIMMs, but it's become clear that
its usefuless extends beyond NV-DIMMs and there are several potential
customers including the tracing machinery. Other people want to place the
kernel log in an area of memory, as long as they have a BIOS that does not
clear DRAM on reboot.
Patch 1 is a bug fix, probably worth including in 3.18.
Patches 2 & 3 are infrastructure for DAX.
Patches 4-8 replace the XIP code with its DAX equivalents, transforming
ext2 to use the DAX code as we go. Note that patch 10 is the
Documentation patch.
Patches 9-15 clean up after the XIP code, removing the infrastructure
that is no longer needed and renaming various XIP things to DAX.
Most of these patches were added after Jan found things he didn't
like in an earlier version of the ext4 patch ... that had been copied
from ext2. So ext2 i being transformed to do things the same way that
ext4 will later. The ability to mount ext2 filesystems with the 'xip'
option is retained, although the 'dax' option is now preferred.
Patch 16 adds some DAX infrastructure to support ext4.
Patch 17 adds DAX support to ext4. It is broadly similar to ext2's DAX
support, but it is more efficient than ext4's due to its support for
unwritten extents.
Patch 18 is another cleanup patch renaming XIP to DAX.
My thanks to Mathieu Desnoyers for his reviews of the v11 patchset. Most
of the changes below were based on his feedback.
This patch (of 18):
Pagecache faults recheck i_size after taking the page lock to ensure that
the fault didn't race against a truncate. We don't have a page to lock in
the XIP case, so use i_mmap_lock_read() instead. It is locked in the
truncate path in unmap_mapping_range() after updating i_size. So while we
hold it in the fault path, we are guaranteed that either i_size has
already been updated in the truncate path, or that the truncate will
subsequently call zap_page_range_single() and so remove the mapping we
have just inserted.
There is a window of time in which i_size has been reduced and the thread
has a mapping to a page which will be removed from the file, but this is
harmless as the page will not be allocated to a different purpose before
the thread's access to it is revoked.
[akpm@linux-foundation.org: switch to i_mmap_lock_read(), add comment in unmap_single_vma()]
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
For whatever reason, generic_access_phys() only remaps one page, but
actually allows to access arbitrary size. It's quite easy to trigger
large reads, like printing out large structure with gdb, which leads to a
crash. Fix it by remapping correct size.
Fixes: 28b2ee20c7cb ("access_process_vm device memory infrastructure")
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
pte_protnone_numa is only safe to use after VMA checks for PROT_NONE are
complete. Treating a real PROT_NONE PTE as a NUMA hinting fault is going
to result in strangeness so add a check for it. BUG_ON looks like
overkill but if this is hit then it's a serious bug that could result in
corruption so do not even try recovering. It would have been more
comprehensive to check VMA flags in pte_protnone_numa but it would have
made the API ugly just for a debugging check.
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com>
Faults on the huge zero page are pointless and there is a BUG_ON to catch
them during fault time. This patch reintroduces a check that avoids
marking the zero page PAGE_NONE.
With PROT_NONE, the traditional page table manipulation functions are
sufficient.
[andre.przywara@arm.com: fix compiler warning in pmdp_invalidate()]
[akpm@linux-foundation.org: fix build with STRICT_MM_TYPECHECKS]
Acked-by: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Convert existing users of pte_numa and friends to the new helper. Note
that the kernel is broken after this patch is applied until the other page
table modifiers are also altered. This patch layout is to make review
easier.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
