2022-02-18 | wpa-supplicant: disable background scan | Ming Liu | |
Disable background scan in config to avoid a significant increase in bandwidth. Related-to: ELB-4148 Signed-off-by: Ming Liu <ming.liu@toradex.com> | |||
2015-05-12 | wpa-supplicant: remove bbappend, fixed in bb | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2013-09-22 | wpa-supplicant: workaround missing service file | Max Krummenacher | |
2013-09-22 | remove obsolete files | Max Krummenacher | |
2013-09-22 | wpa-supplicant: don't install systemd service file | Max Krummenacher | |
- is already installed |
