These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
Tezi now shows the image description more prominently. Update the standard
image descriptions using DESCRIPTION.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
uClibc has been removed in morty.
Images for tk1 and tk1-mainline are currently indistinguishable
especially when path to the image is long. For now simply append the
description with " (Mainline)" should work. Let’s integrate this into
our builds.
Trying to store PNG files off our CSI Camera Module 5MP OV5640 on Apalis
TK1 revealed the first few frames to be black resp. greenish. One way to
overcome this is to save several images and just throw the first few
away. In order to do so the multifilesink plug-in would be needed:
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,format={UYVY},width=640,height=480' ! videorate max-rate=10 ! videoconvert ! avenc_png ! multifilesink location=test%d.png
The package libopencl-mx6 has been renamed to libopencl-imx.
This does currently not build.
With the removal of meta-systemd one no longer needs to add
connman-systemd to the image to get the systemd service files
installed and enabled.
Depending on the module we use gstreamer in version 0.10 and 1.0. Building
the plugins just to have the ipk packages without installing them now
makes the recipe unreasonably complicated without adding real value.
It is no longer built by default since oe-core commit 958926dd51d5e18ef983280a6e3b50fc8f33eb12:
Even old hardware these days doesn't really need fixed-integer Vorbis decoding
by default, so disable Tremor out of the box.
Use PV variable to define the image version. With that the Tezi
image class can use OpenEmbedded variables to get the image version.
Deploy gstreamer-0.10 with nvidia TK1 support plugins.
While at it also reflect changed name of tdx-nv-binaries.
LXDE: LinuxImage -> LXDE-Image
Qt4: LinuxImage-qt -> Qt4-X11-Image
Qt4 embedded: LinuxImage-qte -> Qt4e-Image
Qt5: LinuxImage-qt5 -> Qt5-X11-Image
Console: LinuxConsoleImage -> Console-Image
Additionaly the underscore in the machine name is replaced by a dash
so that the image name is now comprised of 3 elements which themselfes
do not contain an underscore but are separated by underscores.
<machine>_<image type>_version
e.g.:
Apalis_iMX6_LinuxImageV2.7_20170327.tar.bz2
becomes
Apalis-iMX6_LXDE-Image_2.7b2-20170327.tar.bz2
The package initscripts deploys some SysV initscripts which were still
required for earlier systemd version. All services are now available
through systemd, so this is not necessary anymore. It even leads to
interference with systemd printing messages like:
[ 3.030281] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with alignment.service/start
[ SKIP ] Ordering cycle found, skipping alignment.service
Stop deploying initscripts in our images.
When systemd was introduced to OE sysv initscripts did sometimes interfere
with systemd services. We deleted them at image creation time.
This is no longer done, however a task which creates a no longer called
script is still in the recipe. Remove that.
We use the image summary as image name for the Toradex Easy Installer.
Since we might end up in a list of images of other operating systems
and maybe even other companies, make sure to mention Toradex and Linux.
While at it use a common summary pattern across all image recipes.
The old solution with using packagegroup-fsl-tools-gpu with a
bbappend to remove the big tools and examples needs more maintanance
and makes it hard for someone who really wants the examples or tools
in a image.
So change to a new packagegroup to deploy the libraries.
Also deploy OpenCL releated libraries seperately.
mesa-glut was dropped in favour of freeglut in oe.
This requires to adjust the path to include files, e.g.:
-require recipes/images/trdx-image-fstype.inc
+require recipes-images/images/trdx-image-fstype.inc
