This requires to adjust the path to include files, e.g.:
-require recipes/images/trdx-image-fstype.inc
+require recipes-images/images/trdx-image-fstype.inc
The script fails when -m is given but rootfs/etc/issue fails to provide
the version info.
While at it correct wrong text output on i.MX 6 based modules.
update.sh guesses the module type from rootfs/etc/issue which works for images
created from our meta-toradex recipes.
If another rootfs is used one has to edit etc/issue.
Overcome that requirement by providing a -m parameter which allows forcing
the targeted module type.
Not giving -m or '-m 0' keeps the old behaviour.
see 'update.sh -h' for valid values.
To be more in-line with all our other modules change update_dtb to
update_fdt also on all our NAND based modules and document it as such.
The binary/symlink mkfs.vfat seems to be considered outdated, it
is only deployed if one configures dosfstools with the flag
--enable-compat-symlinks.
Switch to mkfs.fat which seems to be the official binary to create
FAT filesystems now.
Use static UBI volumes on Colibri T20.
Fix update over ethernet on Colibri Vybrid
Add exit trap to report unexpected exits (due to set -e). Note that
this traps every exit, also explicit calls to exit. Therefor register
the trap only during the sequencial image generating/coping part,
after the sanity checks...
If executing the command fails, the exit code will be <> 1 which
leads to an imeadiate exit (due to set -e). Avoid exiting by
adding "|| true" to the sanity check commands.
Use "command" instead of "which" for sanity checks. This is preferable
to several reasons, see:
http://stackoverflow.com/questions/592620/check-if-a-program-exists-from-a-bash-script
Also always use or (||) syntax to avoid bash script exits. Tested to
be working on Ubuntu, Fedora and Arch Linux.
By omitting an explicit exit code after the recovery command we
will get the exit code of the last command. This makes sense,
since we would be able to tell whether recovery actually succeeded
or not.
Since we introduced set -e commands which fail will exit silently.
This leads to no error message when the grep which tests for
specified parameters failed.
We could solve it with || true, but it seems more lightweight to
just test for the strings inside the if statement. It also checks
for the full length (e.g. disallows "25" as RAM size).
The later fixed only 256 MB RAM size copy paste issue.
Unix commands usually exit successfully when help was explicitly
asked for. However, in case arguments are incomplete or otherwise
wrong, exit with error.
printf allows to print escape sequences (e.g. for colored output)
and is part of the POSIX standard.
Further clean-up and unify our update scripts:
- Universally mention Ethernet aka TFTP, SD card and USB flash drive as
possible update media.
- Universally mention detailed recovery/update procedures being
available on our developer website.
- Universally split usage and flashing instructions (-f).
- Make sure we don't exceed the 80 characters line length limit.
- Fix various spelling issues.
Now that both Apalis/Colibri iMX6 as well as Apalis/Colibri T30 will
use the same eMMC layout also concerning boot loader, environment and
configblock locations in the primary eMMC boot area partition update
resp. description.
The following commit:
f463f754048ebc3325025f0e1506b03cf14203a5
update.sh: use moduletype specific folder for output files
moved the output folder check above the module type selection which now
fails in case of debug aka recovery mode only operation with the
following error:
does not exist, exiting
This patch fixes this by not erring out in the debug aka recovery mode
only operation if no output folder is set.
With update.sh one creates files on e.g. a SD-card or a tftp server
which enables updating the SW on a module from U-Boot running on
said module.
This commit adds a module type specific directory on that output media
so that update data for multiple module types can be stored on one media.
Generic U-Boot scripts in the media's root directory do select the
matching update data depending on module type.
To flash a large rootfs over tftp the rootfs must be split into chunks
of 64MB on the tftp server.
Add the option '-c' to the update.sh script which does this automatically.
Use 64MB chunks on all module types.
Switch to using the temperature Chamber validated 800 MHz BCT
Apalis_T30_2GB_800Mhz.bct.
Please note that for now this is a fixed 800 MHz BCT which does not
allow for memory DVFS (e.g. 400/800 MHz switching like currently only
possible on Colibri T30).
While we were checking whether the mkfs.ubifs tool has the magic
--space-fixup option available we never actually enabled that option
to be used when generating our UBIFS root file system images.
Thanks Bhuvan for spotting this having actually been in our update
scripts for almost two years now!
Now that we exit on failure the test for a user accessible parted must not
return an error code.
On recent Ubuntu distributions gawk no longer supports awk -V which makes
the test fail.
Simulate our awk use case and test the result instead.
Additionally set 'set -e' to exit immediately on errors. Fix places where
a command returns not zero in 'normal' situations.
E.g. A full disk leads otherwise to funny effects.
Allow relative OUT_DIR.
The eMMC layout comments are confusing and in some regards outdated.
Clean it up.
While at it move the calculation of the rootfs file system size to
the rootfs creation to not confuse the rootfs file system size with
the size of the rootfs partition.
Was Boot and arm
