Drop patch 0002-imx8m-hab.c-work-around-gcc-12.1-false-positives.patch
which got obsoleted by recent meta-freescale update to 6.1.22-2.0.0.
Follow the pattern used in commit ce9a5ef ("machines: arch arm: follow
change to vendor subdir for dtbs")
Set the variable KERNEL_DTB_PREFIX with the relative path to the device
tree source files and then use it. This variable can then be used
in the creation of the u-boot-distro-boot script.
Related-to: ELB-5263
With moving to kernel 6.5 the kernel commit 724ba67515320 ("ARM: dts:
Move .dts files to vendor sub-directories") introduced a regression
with our 32 bit machines.
We have to add the relative path to the dts/dtb files in our list
of device trees to be built per machine if the distro/kernel flavour
is building a 6.5 and later kernel.
Reassign the full list in the <MACHINE.inc> file to KERNEL_DEVICETREE,
so that we can conditionally add the relative path for a 6.5 kernel.
This allows to override the included file from another layer
with higher priority.
Related-to: ELB-5213
(cherry picked from commit e0206a62beb3e667cab33ce7b19cc464424a06a0)
Otherwise it breaks builds where more than one UBOOT_CONFIG is defined.
(cherry picked from commit 2038ae25edaffb95b5f4e4a65a17d53720e2440d)
Bump SRCREV hashes as used in build of Thu 01 Jun 2023 09:49:35 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 299
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/299
Signed-off-by: ci.toradex <cicd@toradex.com>
(cherry picked from commit 4fdb7d5b8accd5d629f711780e4079813da04ebb)
Bump SRCREV hashes as used in build of Tue 16 May 2023 03:12:53 PM UTC
Matrix Build: image-tezi-kirkstone-6.x.y-nightly-matrix 1
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-kirkstone-6.x.y-nightly-matrix/1
(cherry picked from commit abe1759ed536818c11f11d3f8fab10c57339ad2f)
Add the following additional SKU product IDs which are compatible
with the verdin-imx8mp machines.
0065: Verdin iMX8M Plus QuadLite 1GB IT
0070: Verdin iMX8M Plus Quad 8GB WB IT
Related-to: ELB-5189 ELB-5191
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
(cherry picked from commit 0dc187478a0d363683a6c5ba59b042e56aa87e81)
Bump SRCREV hashes as used in build of Fri 28 Apr 2023 09:13:20 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 273
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/273
(cherry picked from commit 8f9e36d0af54b568a2eada60860605f4899daaa4)
Booting with a FIT image (that includes a ramdisk image) is failing on
several machines with the following error message:
Error: ramdisk overwritten
Ramdisk image is corrupt or invalid
This is because the boot script uses ramdisk_addr_r to load the FIT
image, and this is overlapping with the default fitimage ramdisk load
address.
Fix by adjusting the fitimage ramdisk load address:
UBOOT_RD_LOADADDRESS = ramdisk_addr_r + 32M
Build and boot time tested on all impacted machines.
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
(cherry picked from commit 5a1617c4d363e6b1ac23d6884b47cd113b395d84)
The imx-boot binary can be put together with the imx-mkimage/imx-boot
recipe or now also with U-Boot/binman. meta-freescale changed the default
for all machines from using imx-mkimage to use binman.
Move to use binman, change the downstream U-Boot recipe accordingly.
Related-to: ELB-5155
Bump SRCREV hashes as used in build of Thu 30 Mar 2023 09:05:00 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 250
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/250
(cherry picked from commit 0e6c25e8c7ad105daf6c8737fbdee1c97c4edb41)
Pick proper default overlays when building for downstream due to
changed overlay naming scheme.
Related-to: ELB-4754
(cherry picked from commit b70c8f33240dead59d75d8331a60bcab819b2413)
The device-trees got merged and we can revert this commit again that
disables most of the devicetrees.
This reverts commit 56806394031c06b6d2d45f7c3d913cc8e3138658.
Related-to: ELB-5056
(cherry picked from commit 8c7c6ef95ebc39785931ad0fe2d7a3373eb777e8)
Bump SRCREV hashes as used in build of Tue 28 Feb 2023 05:06:24 AM UTC
Matrix Build: image-torizoncore-kirkstone-6.x.y-nightly-matrix 194
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-nightly-matrix/194
(cherry picked from commit 88427647577e2402e10f3d0983c2fb9f9558cbfd)
It's already added in meta-freescale layer.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit d521345d807d703affb4e23bb2709a087516ce0f)
(cherry picked from commit bb13a03251aa0d3311fe74c853805f1aa880d29d)
Remove the btuart recipe. This is not required anymore because we now
load the driver through a serdev entry in the device tree.
Related-to: ELB-5030
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
(cherry picked from commit 3488268909517eb9729270975dbce5b43b01749f)
Bump SRCREV hashes as used in build of Tue Jan 31 15:52:06 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 186
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/186
(cherry picked from commit a174b6faada51c7e196c39c7a0f914754e8fa41d)
Add wifi and nonwifi devicetrees to both verdin-imx8mm and verdin-imx8mp
machines.
Related-to: ELB-4681
(cherry picked from commit 2547f335dc277ba173340f366f1e5bff096cc9df)
Currently the nxp89xx firmware is being included at the image level
(i.e. when Toradex BSP users build a Toradex reference image).
Because of this, custom images that are not based on the Toradex
reference image don't get the nxp89xx firmware, and WiFi doesn't work.
Fix that by including the firmware as a RRECOMMENDS package for the
machine.
Obs.: This change affects only images that are based on
packagegroup-base, which does not include for example the
core-image-minimal.
(cherry picked from commit c18aa339e5cbb915f40411fca744e8717feab1a4)
If no camera is configured in the device tree systemd imx8-isp.service
goes to the failed state. Prevent that.
Related-to: ELB-5002
(cherry picked from commit 9baec9cc6777638b44249877d453d03fcb298632)
Bump SRCREV hashes as used in build of Thu Jan 5 09:11:01 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 163
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/163
(cherry picked from commit 364341c23ea49fb875e84f980b208699311aaf9c)
Bump SRCREV hashes as used in build of Tue Jan 3 21:55:34 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 158
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/158
(cherry picked from commit 23b07abfabb169780b6f93334f34c01586f1f870)
Add the spidev overlays to overlays.txt so that they get applied
out of the box.
Related-to: ELB-4894
(cherry picked from commit 5d9713e72fb530540198970b1e69d87225a4b4c6)
Do not apply spidev overlay by default as already CAN is enabled on that
spi interface. They will interfere with each other resulting in an
error.
Related-to: ELB-4724
(cherry picked from commit 3ea30ab50cd6c59698f33ee2342fc1db45bba035)
After change, the KERNEL_DEVICETREE contains the following DTBs:
imx7d-colibri-eval-v3.dtb
imx7s-colibri-eval-v3.dtb
imx7d-colibri-aster.dtb
imx7s-colibri-aster.dtb
imx7d-colibri-iris.dtb
imx7d-colibri-iris-v2.dtb
imx7s-colibri-iris.dtb
imx7s-colibri-iris-v2.dtb
Related-to: ELB-4906
(cherry picked from commit 45d4fd4ed2b8b31de5e548dcc4acc81178a424ca)
imx7d-colibri-emmc-eval-v3.dtb
imx7d-colibri-emmc-aster.dtb
imx7d-colibri-emmc-iris.dtb
imx7d-colibri-emmc-iris-v2.dtb
(cherry picked from commit 6554e8be154018bf63d11cd61eb3dde08e00653f)
imx6ull-colibri-eval-v3.dtb
imx6ull-colibri-wifi-eval-v3.dtb
imx6ull-colibri-aster.dtb
imx6ull-colibri-iris.dtb
imx6ull-colibri-iris-v2.dtb
imx6ull-colibri-wifi-aster.dtb
imx6ull-colibri-wifi-iris.dtb
imx6ull-colibri-wifi-iris-v2.dtb
(cherry picked from commit 503e86805db8a4ba0d278ee4fa2429981665783d)
imx6ull-colibri-emmc-eval-v3.dtb
imx6ull-colibri-emmc-aster.dtb
imx6ull-colibri-emmc-iris.dtb
imx6ull-colibri-emmc-iris-v2.dtb
(cherry picked from commit 6c8aa610970cccc1721078147d3a7d2efb3eef27)
imx6dl-colibri-eval-v3.dtb
imx6dl-colibri-aster.dtb
imx6dl-colibri-iris.dtb
imx6dl-colibri-iris-v2.dtb
(cherry picked from commit 9a43d970a9db64cf39be180cfe85aa9dea0c8eb5)
imx6q-apalis-eval.dtb
imx6q-apalis-ixora.dtb
imx6q-apalis-ixora-v1.1.dtb
imx6q-apalis-ixora-v1.2.dtb
Also remove "+=" usage, change to ":append" instead, since "+=" might
not work if overrides being used somewhere.
(cherry picked from commit b4835afb40cf5e2c8464163bd81964e043018e5f)
This reverts commit 1542cf213aa446e6883ca2f4e6698e0eb0f40232.
Reenable building the dtb now available in the 5.15-2.1.x kernel.
(cherry picked from commit 08711132d7c2c0e28091f0275f42bff6f85e15db)
Configure alsa audio to use dmix/dsnoop at 48 kHz.
imx8m PLL is not able to output a exactly multiple of 44.1 kHz MCLK
input to audio codecs, starting from 24.576 MHz module clock.
If mclk-fs is 256, optimal clock is 11289600,
obtained clock is 11234743. Frequency erro is -0,49 %.
Instead, it is able to generate a exact multiple of 48 kHz MCLK.
Related-to: ELB-4481
Fixes: 9e5c0e3043a7 ("alsa-state: set up asound configs dynamically for verdin-imx8 boards")
(cherry picked from commit 2495461248ea431c1c41a8092033bd46a8552517)
Bump SRCREV hashes as used in build of Wed Nov 30 23:28:13 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 128
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/128
(cherry picked from commit a23c4b6d01831d45634d4156b513746dda051161)
Remove usage of the `use-head-next` override for anything, apart the
SRCREV variable.
Currently this variable is only used on local builds, while uprev on
Jenkins CI/CD is implemented using `scripts/uprev-srcrev` that update
only the SRCREV variable. This way we ensure a consistent experience
despite how the image is build and we avoid potential confusion.
Related-to: ELB-4885
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
(cherry picked from commit 51e8c29019744428b86be0fd1f1f5c07d8b8c942)
Follow the update of the kernel branch.
Related-to: ELB-4873
(cherry picked from commit 49979f25564f51265f4c009b2ebde34edb24f8d9)
Add SOC_ATF_BOOT_UART_BASE in relevant machine conf instead of having
IMX_BOOT_UART_BASE added to EXTRA_OEMAKE in imx_atf_%bbappend, this
change remove the dependency on our .bbappend to have a working ATF binary.
SOC_ATF_BOOT_UART_BASE variable support was introduce in commit
453def7956c8 ("imx-atf: allow setting the UART used during boot")
in meta-freescale.
Related-to: ELB-4889
(cherry picked from commit b2db48cac3b2384857e9b6c2b418533122c5e03a)
Until 1.14.0 the license was not synched to the public repo. This meant
that the hash never needed updating. This change now includes three
years of differences on the SCFW license.
Related-to: ELB-4593
(cherry picked from commit 7f7d8b15549a9f2bf0a07b4b8729acc72e59a06d)
This commit bumps version to latest 1.14.0. It does also update the
SRCREV as with the new recipe name it doesn't make sense to build any
other hash at the moment.
(cherry picked from commit a5716ad0945c0b3b0f5613695dc53f37390b4ca2)
Update the downstream kernel (NXP fork) to lf-5.15-2.1.0 plus fslc
stable patches merges.
I.e. rebase our 5.15-2.0.0 on top of
https://github.com/Freescale/linux-fslc/commit/0dbb0e28ad332aa0955b873beb91190ae05ac655
For the RT kernel, set the matching RT patch plus refresh/add
patches which allow to apply the RT patch and cleanup afterwards.
(cherry picked from commit 934f013425879aa5acc7507ddb553448b7a47b66)
The PREEMPT_RT config depends indirectly on !KVM, so make sure
that KVM is not set.
Related-to: ELB-4887
(cherry picked from commit 9116bd263386310f6ede2531d1190a4deba9498f)
The mainline kernel now has two recipes, one for non RT and one for the
RT flavour.
Set the correct one depending on the set overrides.
Related-to: ELB-4868
(cherry picked from commit 310715ee5f84da7267a039b8adee63614015c61e)
Pick proper overlays when building for mainline.
(cherry picked from commit 4cec03039eb82142329aecd3e1efb0f2c1d2c9e8)
Bump SRCREV hashes as used in build of Sun Oct 23 09:58:29 UTC 2022
Matrix Build: image-torizoncore-kirkstone-6.x.y-nightly-matrix 74
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-nightly-matrix/74
(cherry picked from commit c0e40951656f06b6691448eb3b9041a5ac827d47)
The changes in this bbappend file are deprecated since the following
commit merged in meta-freescale:
commit c59f817b0d1ee70ef224405ff8acd31e0743ed91
Author: Andrey Zhizhikin <andrey.z@gmail.com>
Date: Thu Oct 21 10:01:01 2021 +0000
imx-mkimage: use mkimage tool from sysroot
mkimage tool is provided as a part of sysroot and should not be used as
a local copy, since it contains runtime dependencies which local copy
does not account for.
Drop the local copy on mkimage, introduce the patch that fixes mkimage
invocations in build system.
Signed-off-by: Andrey Zhizhikin <andrey.z@gmail.com>
let's delete the bbappend recipe.
(cherry picked from commit 9e006dccef9e22a430ab56b765420b13f532c56a)
Set mixer audio level to default, this prevents audio distortions and
fixes our automated test execution.
Related-to: ELB-4829
Fixes: 5f920cd5b4b2 ("alsa-state:apalis-imx6: fix sound device name in asound.conf/asound.state")
(cherry picked from commit 9f9bd44f739697448a03c19534fa079e6445377f)
The sound device name in asound.conf of apalis-imx6 machine does not
match the sound driver of kernel 5.15 and upper, fix that. Also
regenerate asound.state according to the new asound.conf.
(cherry picked from commit 5f920cd5b4b202b277eeae945fbda6c206672005)
Related-to: ELB-4838
(cherry picked from commit 91f253942aef769901bc5e5058851fdc4d49a64c)
