path: root/recipes-bsp
2022-03-06layer: Update LICENSE variable to use SPDX license identifiersMax Krummenacher
Since OE-Core commit 9379f80f48 ("license/insane: Show warning for obsolete license usage"), LICENSE field not containing SPDX identifiers are treated with WARNING. An automated conversion using scripts/contrib/convert-spdx-licenses.py to convert to use the standard SPDX license identifiers has been done on the entire layer. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-12-02github: use https protocol and set branch explicitlyMax Krummenacher
Github no longer allows a plain git protocol. https://github.blog/2021-09-01-improving-git-protocol-security-github/#no-more-unauthenticated-git OE is dropping setting the branch to master implicitly if none is specified. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 657a1121250d5e55b435f2f26ef45e29ab832590)
2021-11-16apalis-tk1: use mainline u-bootMax Krummenacher
Mainline (sources.denx.de) has all the functionality needed for Apalis TK1. Build directly from the mainline repo. Add a bbappend which makes the cboot image format. Related-to: ELB-4090 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-11-15Bump SRCREVci.toradex
Bump SRCREV hashes as used in build of Thu Oct 14 22:13:16 UTC 2021 Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 453 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/453 Signed-off-by: ci.toradex <cicd@toradex.com> (cherry picked from commit 54b10a73af4a56999b8b5fbb8707adcee5c5b482)
Bump SRCREV hashes as used in build of Tue Sep 21 22:52:09 UTC 2021 Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 427 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/427 Signed-off-by: ci.toradex <cicd@toradex.com> (cherry picked from commit 8658abd984d327037eeaa601aa1472c4bf7b02df)
Bump SRCREV hashes as used in build of Mon Aug 30 13:56:21 UTC 2021 Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 407 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/407 Signed-off-by: ci.toradex <cicd@toradex.com> (cherry picked from commit d4ef0a4584e04b14a6ba368b8cdf8592af43d3bb)
2021-09-05manual override syntax fixesMax Krummenacher
2021-08-14layer: convert to new override syntaxMax Krummenacher
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-08-08Bump SRCREVci.toradex
Bump SRCREV hashes as used in build of Wed Aug 4 04:59:48 UTC 2021 Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 381 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/381 Signed-off-by: ci.toradex <cicd@toradex.com> (cherry picked from commit f58026172d3c32a9c8026287370ae813d9f14fc5)
2021-07-12Bump SRCREVci.toradex
Bump SRCREV hashes as used in build of Thu Jun 24 23:53:16 UTC 2021 Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 343 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/343 Signed-off-by: ci.toradex <cicd@toradex.com> (cherry picked from commit e37959a52f2cea3a2a2f0c4f165a60715c817565)
2021-07-12apalis-tk1: lvds-tegra124: remove stale lvds-tegra124 recipeMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit a4a813df625b87ac004032fa29bfc730409cc2fc)
2021-06-04u-boot-toradex-tk1: complete update to 2020.07Marcel Ziswiler
While we did rename the branch we forgot to also rename this recipe. Fix this. Fixes commit a21f73d1e08e ("u-boot-toradex: update to 2020.07") Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 1f19651ec747c4842dfd0dba25bc056322f2edac)
2021-06-04Bump SRCREVci.toradex
Bump SRCREV hashes as used in build of Fri Apr 2 22:46:52 UTC 2021 Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 265 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/265 Signed-off-by: ci.toradex <cicd@toradex.com> cherry picked from commit 6b5cc7b and 39a2614 Bump SRCREV Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-03-23Bump SRCREV hashes as used in build of Fri Feb 26 22:28:17 UTC 2021Philippe Schenker
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 231 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/231 Signed-off-by: ci.toradex <cicd@toradex.com> Squashed: (cherry picked from commit a0f00032e59ea7db45e46eea35a221ede499aefd) (cherry picked from commit b214067b27204f471cf405a1e3997d3da233a8f9)
2020-12-10u-boot: update to latestMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 2fa40a70b28efedefa4357519b9a92e92f52415d) (cherry picked from commit b5179b050062a29c2fe0bdfc1717b616c4f1630e)
2020-12-08u-boot: fw_env.config: use stable symlink to the emmcMax Krummenacher
Change to use the stable symlink to the emmc boot area to specify the location of the U-Boot environment. Related-to: ELB-3293 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 4cea50134bc3000094d9d285c9711b72f8164c7f)
2020-11-23Bump SRCREVci.toradex
Bump SRCREV hashes as used in build of Fri Oct 30 22:10:03 UTC 2020 Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 115 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/115 Signed-off-by: ci.toradex <cicd@toradex.com> (cherry picked from commit 1e47313b76cddf103e79a872b652dab7d1c7e062)
2020-09-30Bump SRCREVci.toradex
Bump SRCREV hashes as used in build of Wed Sep 30 15:34:14 UTC 2020 Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 84 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/84 Signed-off-by: ci.toradex <cicd@toradex.com>
2020-09-29Bump SRCREVci.toradex
Bump SRCREV hashes as used in build of Tue Sep 29 12:08:03 UTC 2020 Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 81 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/81 Signed-off-by: ci.toradex <cicd@toradex.com>
2020-09-03u-boot: update to latestMax Krummenacher
2020-09-03u-boot-toradex: complete update to 2020.07Max Krummenacher
2020.07 is reworked to use python3 so the patch which made 2019.07 build in a python3 only enviromenent can be dropped. Use the 2020.07 branch also with use-head-next. Fixes commit a21f73d1 ("u-boot-toradex: update to 2020.07") Related-to: ELB-2758 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-08-20u-boot-toradex: update to 2020.07Max Krummenacher
2020-08-06meta: change to use libubootenv to provide u-boot-fw-utilsMing Liu
The changes include: - Drop PREFERRED_PROVIDER_u-boot-fw-utils from machine conf. - Drop u-boot-toradex-fw-utils-tk1 recipe. - Drop fw_unlock_mmc.sh, that's not needed for libubootenv. - Drop reference to u-boot-toradex-initial-env.inc, that's been removed from BSP common layer. Related-to: ELB-2553 Signed-off-by: Ming Liu <ming.liu@toradex.com>
2020-08-06u-boot recipes: update to latestMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit eef28a0a1e16a0d116192f8ac5a97531d2546f9f)
2020-06-30u-boot recipes: update to latestMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 3e3a33523b73302d09db47a21e069ae97c159efa)
2020-06-17tdx-k20-fw: update to v1.5Max Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit ab0527430fa9081ef594c6f2e49a0b7e81f6fc00)
2020-06-02apalis-tk1: fix wrong PREFERRED_PROVIDER_u-bootMing Liu
PREFERRED_PROVIDER_u-boot should be 'u-boot-toradex-tk1' instead of 'u-boot-toradex', also set PROVIDES += "u-boot" in u-boot-tk1 recipe. Signed-off-by: Ming Liu <ming.liu@toradex.com> (cherry picked from commit c9180b9e9b1231c8139bbfb47f51acb5692235dc)
2020-06-02u-boot: drop some useless patchesMing Liu
They are not needed any more since we upgraded to 2019.07. Signed-off-by: Ming Liu <ming.liu@toradex.com> (cherry picked from commit 8048bf5cd90a923f6879f1ba714c22e3736fc245)
2020-06-01apalis-tk1-mainline: rename machine to apalis-tk1Max Krummenacher
Rename the apalis-tk1-mainline machine to the now dropped apalis-tk1 machine name. Related-to: ELB-2733 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 0bf55088d1f34338dd04f83d6b90b7a72f6867de)
2020-06-01apalis-tk1: drop machineMax Krummenacher
The downstream kernel gets to old to be used with the new zeus userspace components. Drop the machine. Related-to: ELB-2733 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit d13caaba2d90f856b944ebde44967b679d3eb3a9)
2020-06-01linux kernel & u-boot recipes: update to latestMarcel Ziswiler
Related-to: ELB-2510 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 7880c26275385d30ce2d7d6c45065764e0fd2472)
2020-06-01linux-driver-package: fix direct-loading firmwareMarcel Ziswiler
Debugging reveals that it is really also expecting certain firmware at the original path: [ 134.878913] firmware tegra12x!vic03_ucode.bin: firmware: requesting tegra12x/vic03_ucode.bin So make a symbolic link rather then copying them. Without older systemd's firmware usermode helper fallback in place using an alternative file name leads to a very long timeout. Fix this by linking the alternative nameed firmware to the one tried first. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 5d206eb3265bc6bc96442ffcd1cc4ce1f80f0714) (cherry picked from commit 71f68117693bfd479774aac42412a18fdf77a2e8)
2020-02-03u-boot-toradex-tk1: use python3 for buildMax Krummenacher
OE post zeus dropped Python 2. Provide a workaround so that one can still build the TK1 U-Boot. When we update U-Boot to 2020.01 or later Python 3 will be supported and this patch can be reverted. Completes '691b446 u-boot.inc: use python3 for build'. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-01-25u-boot.inc: use python3 for buildMax Krummenacher
OE dropped python2 support. Unify u-boot.inc with openembedded-core which now uses python3 for the build. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-12-31linux kernel & u-boot recipes: update to latestMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 8d3d527425b592480900d006c76694877755486a) Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: recipes-kernel/linux/linux-toradex-mainline_4.14.bb recipes-kernel/linux/linux-toradex_3.10.40.bb
2019-12-18u-boot-toradex: use new versioningStefan Agner
Use toradex-u-boot-localversion class to implement the new versioning scheme for U-Boot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2019-12-16u-boot-tk1.inc: put python2 from python-native in the pathMax Krummenacher
2019-12-15u-boot: make u-boot*.inc file uniqueMax Krummenacher
Otherwise the picked u-boot.inc file depends on the bblayers variable. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-10-17linux-driver-package: fix libglx deploymentMax Krummenacher
2019-09-29linux-driver-package, mesa: rework the recipeMax Krummenacher
Recent OE adds additional shared object checks which errors out on the way the binary Tegra drivers are injected. Rework the recipes, so that - mesa no longer PROVIDE any OpenGL shared objects and the binaries. - linux-driver-package now depends on mesa to install development headers - linux-driver-package PROVIDE and RPROVIDE the OpenGL shared objects. - linux-driver-package drops the additional arm-linux-gnueabihf/tegra path to the *.so* files. - the apalis-tk1 machine PREFERS linux-driver-package as the OpenGL provider. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-09-29linux-driver-package: merge our bbappendMax Krummenacher
While at it unify whitespace usage. This commit does not change any configuration or behaviour, it prepares for a rework of the recipe. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-09-14linux-driver-package: add additional rdepsMax Krummenacher
The gstreamer plugins now require addional runtime depends or one gets qa errors of the following form: | ERROR: linux-driver-package-21.7.0-r7 do_package_qa: QA Issue: /usr/bin/nvgstplayer-1.0 contained in package linux-driver-package-nvgstapps | requires libgstvideo-1.0.so.0, but no providers found in RDEPENDS_linux-driver-package-nvgstapps? [file-rdeps] Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-09-13linux-driver-package: no longer deploy gstreamer 0.10 based filesMax Krummenacher
meta-openembedded dropped gstreamer 0.10 with commit 010c2f388. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-08-26linux kernel & u-boot recipes: update to latestMax Krummenacher
2019-08-20tdx-k20-fw: drop a invalid license settingMing Liu
There is not a generic license called "FREESCALE_SEMICONDUCTOR_SOFTWARE_LICENSE_AGREEMENT", drop it, use "CLOSED" instead, this fixes a following QA warning: | tdx-k20-fw: No generic license file exists for: FREESCALE_SEMICONDUCTOR_SOFTWARE_LICENSE_AGREEMENT in any provider Also remove a relative path reference in LIC_FILES_CHKSUM. Signed-off-by: Ming Liu <ming.liu@toradex.com>
2019-08-16linux-driver-package: move firmware where gk20a expects it to bePhilippe Schenker
2019-08-16linux-driver-package: Fix nv and nvfb services to be enabledPhilippe Schenker
2019-07-22linux-driver-package: fix commit rework to allow building for SysVMax Krummenacher
commit 8691ba636cb2 allowed to also use SysV init. However, if only systemd is configured in DISTRO_FEATURES the content of /etc/init.d is deleted after the install step. This results in the scripts nv and nvfb not being present. Fix this by installing them additionally in /usr/bin so that the systemd service can call them. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-07-10u-boot-toradex: update to 2019.07 basedMax Krummenacher
Update to a 2019.07 based U-Boot. Use the openembedded master recipes for u-boot_2019.07 as a base. While at it append -tk1 to PN to have a name different from the u-boot recipe name for our NXP based SoM and set the prefered provider accordingly. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-04linux-driver-package: fix do rootfsMax Krummenacher
Assign the systemd service in the package providing them. Prevents the following do_rootfs error if linux-driver-package is installed but linux-driver-package-*boot is not: | WARNING: linux-driver-package.postinst returned 1, marking as unpacked only, configuration required on target. | ERROR: Postinstall scriptlets of ['linux-driver-package'] have failed. If the intention is to defer them to first boot, | then please place them into pkg_postinst_ontarget_${PN} (). This is caused by sytemctl trying to enable the not existing services nv.service and nvfb.service. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
