path: root/drivers/ddr/marvell
2025-07-29ddr: marvell: a38x: Fix unsigned issuesAndrew Goodbody
Cannot test an unsigned variable to be less than 0, it will always fail. Signed-off-by: Andrew Goodbody <andrew.goodbody@linaro.org> Reviewed-by: Stefan Roese <stefan.roese@mailbox.org>
2024-10-11drivers: Use CONFIG_XPL_BUILD instead of CONFIG_SPL_BUILDSimon Glass
Use the new symbol to refer to any 'SPL' build, including TPL and VPL Signed-off-by: Simon Glass <sjg@chromium.org>
2024-07-22drivers: ddr: Remove duplicate newlinesMarek Vasut
Drop all duplicate newlines. No functional change. Signed-off-by: Marek Vasut <marek.vasut+renesas@mailbox.org>
2024-07-08arm: mvebu: a38x: Add optional support for using old DDR3 training codeMarek Behún
Add optional support for using old DDR3 training code from 2017. The code lives in drivers/ddr/marvell/a38x/old/. To prevent symbol clashing with new DDR3 training code, a special header which renames all clashing symbols via macros is included and the symbols are prefixed with 'old_'. If old DDR3 training support is selected for a board, then the SPL initialization code calls a new function board_use_old_ddr3_training() to check whether it should use old DDR3 training code. The default weak implementation returns false, defaulting to new DDR3 training code. Boards that wish to support this need to select the ARMADA_38X_SUPPORT_OLD_DDR3_TRAINING config option and implement the old version of DDR topology provider, ddr3_get_topology_map(). Signed-off-by: Marek Behún <kabel@kernel.org>
2024-07-08ddr: marvell: a38x: old: Backport immutable debug settingsMarek Behún
Backport the option to compile with immutable debug settings also to the old implementation of the DDR3 training code. The original PR for mv-ddr-marvell can be seen at https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell/pull/45/ Signed-off-by: Marek Behún <kabel@kernel.org>
2024-07-08ddr: marvell: a38x: old: Fix some compiler warning of the old codeMarek Behún
Fix some compilation warning in the old DDR training code. Signed-off-by: Marek Behún <kabel@kernel.org>
2024-07-08ddr: marvell: a38x: Import old DDR training code from 2017 version of U-BootMarek Behún
Import DDR training code from commit 1b69ce2fc0ec ("arm: mvebu: ddr3_debug: remove self assignments") into drivers/ddr/marvell/a38x/old/. The code is not used yet. Explanation: Since 2019, on some Turris Omnia boards we have been having problems with newer versions of Marvell's DDR3 training code for Armada 38x, which is ported from mv-ddr-marvell [1] to U-Boot into the drivers/ddr/marvell/a38x/ directory: - sometimes the DDR3 training fails on some older boards, sometime it fails on some newer boards - other times it succeeds, but some boards experience crashes of the operating system after running for some time. Using the stock version of Turris Omnia's U-Boot from solved these issues, but this solution was not satisfactory, since we wanted features from new U-Boot. Back in 2020-2022 we have spent several months trying to debug the issues, working with Marvell, on our own, and also with U-Boot community, but these issues persist still. One solution we used back in 2019 was a "hybrid U-Boot": the SPL part (containing the DDR3 training code) was taken from the stock version, while the proper part was current U-Boot at the time. This solution also has its drawbacks, of which the main one is the need to glue binaries from two separate builds. Since then there have been some more changes to the DDR3 training code in upstream mv-ddr-marvell that have been ported to U-Boot. We have provided our users experimental builds of U-Boot in the TurrisOS so that they could try upgrading the firmware and let us know if those problems still exist. And they do. We do not have the time nor manpower to debug this problem and fix it properly. Marvell was also no able to provide a solution to this, probably because they do not have the manpower as well. I have therefore come up with this "not that pretty" solution: take the DDR3 training code from an older version of U-Boot that is known to work, put it into current U-Boot under old/ subdirectory within drivers/ddr/marvell/a38x/, build into the SPL binary both the old and new versions and make it possible to select the old version via an env variable. [1] https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell Signed-off-by: Marek Behún <kabel@kernel.org>
2024-07-08ddr: marvell: a38x: debug: Allow compiling with immutable debug settings to ↵Marek Behún
reduce binary size Allow compiling with immutable debug settings: - DEBUG_LEVEL is always set to DEBUG_LEVEL_ERROR - register dumps are disabled This can save around 10 KiB of space in the resulting binary, which is a lot in U-Boot SPL. Signed-off-by: Marek Behún <kabel@kernel.org>
2024-07-08ddr: marvell: a38x: debug: Define DDR_VIEWER_TOOL variables only if needed, ↵Marek Behún
and make them static The variables is_validate_window_per_if, is_validate_window_per_pup, sweep_cnt and is_run_leveling_sweep_tests are only used if DDR_VIEWER_TOOL macro is defined, so define them only in that case. Make them static since they are only used in ddr3_debug.c. Signed-off-by: Marek Behún <kabel@kernel.org>
2024-07-08ddr: marvell: a38x: debug: Remove unused variablesMarek Behún
The variables is_default_centralization, is_tune_result and is_bist_reset_bit are never used. Signed-off-by: Marek Behún <kabel@kernel.org>
2024-07-08ddr: marvell: a38x: debug: return from ddr3_tip_print_log() early if we ↵Marek Behún
won't print anything Return from ddr3_tip_print_log() early if we won't print anything anyway. This way the compiler can optimize away the VALIDATE_IF_ACTIVE() calls in the for-loop, so if the SILENT_LIB macro is defined, no code is generated for the rest of the function, which saves some space. Signed-off-by: Marek Behún <kabel@kernel.org>
2024-05-20Restore patch series "arm: dts: am62-beagleplay: Fix Beagleplay Ethernet"Tom Rini
As part of bringing the master branch back in to next, we need to allow for all of these changes to exist here. Reported-by: Jonas Karlman <jonas@kwiboo.se> Signed-off-by: Tom Rini <trini@konsulko.com>
2024-05-19Revert "Merge patch series "arm: dts: am62-beagleplay: Fix Beagleplay Ethernet""Tom Rini
When bringing in the series 'arm: dts: am62-beagleplay: Fix Beagleplay Ethernet"' I failed to notice that b4 noticed it was based on next and so took that as the base commit and merged that part of next to master. This reverts commit c8ffd1356d42223cbb8c86280a083cc3c93e6426, reversing changes made to 2ee6f3a5f7550de3599faef9704e166e5dcace35. Reported-by: Jonas Karlman <jonas@kwiboo.se> Signed-off-by: Tom Rini <trini@konsulko.com>
2024-05-07ddr: Remove <common.h> and add needed includesTom Rini
Remove <common.h> from this driver directory and when needed add missing include files directly. Signed-off-by: Tom Rini <trini@konsulko.com>
2023-12-21global: Drop common.h inclusionTom Rini
In order to make it easier to move on to dropping common.h from code directly, remove common.h inclusion from the rest of the header file which had been including it. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2023-12-21arm: Partial cleanup and audit usage of <config.h>Tom Rini
We need to include <config.h> directly when a file needs to have something such as CFG_SYS_SDRAM_SIZE referenced as this file is not automatically globally included and is most commonly indirectly included via common.h. Remove most cases of arm including config.h directly, but add it where needed. This includes a few board-specific fixes. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2023-04-13ddr: marvell: a38x: Perform DDR training sequence again for 2nd bootTony Dinh
- DDR Training sequence happens very fast. The speedup in boot time is negligible by skipping the training sequence during 2nd boot or after. So remove the check and skip. - This change improves the robustness of DDR training. If u-boot crashed during DDR training, the training could be left in a limbo state, where the BootROM has recorded that it is already in a 2nd boot. The training must be repeated in this scenario to get out of this limbo state, but due to the check it cannot be performed. Signed-off-by: Tony Dinh <mibodhi@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2023-03-24ddr: marvell: a38x: Remove unused file seq_exec.hPali Rohár
DDR code does not use seq_exec.h, so remove it. Signed-off-by: Pali Rohár <pali@kernel.org>
2023-01-26ddr: marvell: a38x: Add support for DDR4 from Marvell mv-ddr-marvell repositoryTony Dinh
This syncs drivers/ddr/marvell/a38x/ with the master branch of repository https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git up to the commit "mv_ddr: a3700: Use the right size for memset to not overflow" d5acc10c287e40cc2feeb28710b92e45c93c702c This patch was created by following steps: 1. Replace all a38x files in U-Boot tree by files from upstream github Marvell mv-ddr-marvell repository. 2. Run following command to omit portions not relevant for a38x, ddr3, and ddr4: files=drivers/ddr/marvell/a38x/* unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_APN806 \ -UCONFIG_MC_STATIC -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_PHY_STATIC_PRINT -UCONFIG_CUSTOMER_BOARD_SUPPORT \ -UCONFIG_A3700 -UA3900 -UA80X0 -UA70X0 -DCONFIG_ARMADA_38X -UCONFIG_ARMADA_39X \ -UCONFIG_64BIT $files 3. Manually change license to SPDX-License-Identifier (upstream license in upstream github repository contains long license texts and U-Boot is using just SPDX-License-Identifier. After applying this patch, a38x, ddr3, and ddr4 code in upstream Marvell github repository and in U-Boot would be fully identical. So in future applying above steps could be used to sync code again. The only change in this patch are: 1. Some fixes with include files. 2. Some function return and basic type defines changes in mv_ddr_plat.c (to correct Marvell bug). 3. Remove of dead code in newly copied files (as a result of the filter script stripping out everything other than a38x, dd3, and ddr4). Reference: "ddr: marvell: a38x: Sync code with Marvell mv-ddr-marvell repository" https://source.denx.de/u-boot/u-boot/-/commit/107c3391b95bcc2ba09a876da4fa0c31b6c1e460 Signed-off-by: Tony Dinh <mibodhi@gmail.com> Reviewed-by: Pali Rohár <pali@kernel.org> Reviewed-by: Stefan Roese <sr@denx.de>
2022-12-23global: Remove undef CONFIG_... for unused valuesTom Rini
We have a number of places that undef CONFIG_... while we never reference CONFIG_... in the first place. Remove these lines. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-12-05global: Move remaining CONFIG_SYS_SDRAM_* to CFG_SYS_SDRAM_*Tom Rini
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_SDRAM namespace do not easily transition to Kconfig. In many cases they likely should come from the device tree instead. Move these out of CONFIG namespace and in to CFG namespace. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-04-01db-mv784mp-gp: Rename CONFIG_DB_784MP_GP to CONFIG_TARGET_DB_MV784MP_GPTom Rini
The value CONFIG_DB_784MP_GP is only used in the DDR code to refer to CONFIG_TARGET_DB_MV784MP_GP so just use that second value directly. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefan Roese <sr@denx.de>
2022-02-17ddr: marvell: a38x: fix BYTE_HOMOGENEOUS_SPLIT_OUT decisionMarek Behún
In commit 3fc92a215b69 ("ddr: marvell: a38x: fix SPLIT_OUT_MIX state decision") I ported a cleaned up and changed version of patch mv_ddr: a380: fix SPLIT_OUT_MIX state decision In the port we removed checking for BYTE_HOMOGENEOUS_SPLIT_OUT bit, because: - the fix seemed to work without it - the bit was checked for only at one place out of two, while the second bit, BYTE_SPLIT_OUT_MIX, was checked for in both cases - without the removal it didn't work on Allied Telesis' x530 board We recently had a chance to test on more boards, and it seems that the change needs to be opposite: instead of removing the check for BYTE_HOMOGENEOUS_SPLIT_OUT from the first if() statement, the check needs to be added also to the second one - it needs to be at both places. With this change all the Turris Omnia boards I have had available to test seem to work, I didn't encounter not even one failed DDR training. As last time, I am noting that I do not understand what this code is actually doing, I haven't studied the DDR training algorithm and I suspect that no one will be able to explain it to U-Boot contributors, so we are left with this blind poking in the code with testing whether it works on several boards and hoping it doesn't break anything for anyone :-(. Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2022-01-14ddr: marvell: a38x: fix SPLIT_OUT_MIX state decisionMarek Behún
This is a cleaned up and fixed version of a patch mv_ddr: a380: fix SPLIT_OUT_MIX state decision in each pattern cycle the bus state can be changed in order to avoide it, need to back to the same bus state on each pattern cycle by Moti Boskula <motib@marvell.com> The original patch is not in Marvell's mv-ddr-marvell repository. It was gives to us by Marvell to fix an issues with DDR training on some boards, but it cannot be applied as is to mv-ddr-marvell, because it is a very dirty draft patch that would certainly break other things, mainly DDR4 training code in mv-ddr-marvell, since it changes common functions. I have cleaned up the patch and removed stuff that seemed unnecessary (when removed, it still fixed things). Note that I don't understand completely what the code does exactly, since I haven't studied the DDR training code extensively (and I suspect that no one besides some few people in Marvell understand the code completely). Anyway after the cleanup the patch still fixes isssues with DDR training on the failing boards. There was also a problem with the original patch on some of the Allied Telesis' x530 boards, reported by Chris Packham. I have asked Chris to send me some logs, and managed to fix it: - if you look at the change, you'll notice that it introduces subtraction of cur_start_win[] and cur_end_win[] members, depending on a bit set in the current_byte_status variable - the original patch subtracted cur_start_win[] if either BYTE_SPLIT_OUT_MIX or BYTE_HOMOGENEOUS_SPLIT_OUT bits were set, but subtracted cur_end_win[] only if the first one (BYTE_SPLIT_OUT_MIX) was set - from Chris Packham logs I discovered that the x530 board where the original patch introduced DDR training failure, only the BYTE_HOMOGENEOUS_SPLIT_OUT bit was set, and on our boards where the patch is needed only the BYTE_SPLIT_OUT_MIX is set in the current_byte_status variable - this led me to the hypothesis that both cur_start_win[] and cur_end_win[] should be subtracted only if BYTE_SPLIT_OUT_MIX bit is set, the BYTE_HOMOGENEOUS_SPLIT_OUT bit shouldn't be considered at all - this hypothesis also gains credibility when considering the commit title ("fix SPLIT_OUT_MIX state decision") Hopefully this will fix things without breaking anything else. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Chris Packham <judge.packham@gmail.com>
2022-01-14ddr: marvell: a38x: Fix Synchronous vs Asynchronous mode determinationMarek Behún
Before commit 4c289425752f ("mv_ddr: a38x: add support for ddr async mode"), Asynchornous Mode was only used when the CPU Subsystem Clock Options[4:0] field in the SAR1 register was set to value 0x13: CPU at 2 GHz and DDR at 933 MHz. Then commit 4c289425752f ("mv_ddr: a38x: add support for ddr async mode") added support for Asynchornous Modes with frequencies other than 933 MHz (but at least 467 MHz), but the code it added to check for whether Asynchornous Mode should be used is wrong: it checks whether the frequency setting in board DDR topology map is set to value other than MV_DDR_FREQ_SAR. Thus boards which define a specific value, greater than 400 MHz, for DDR frequency in their board topology (e.g. Turris Omnia defines MV_DDR_FREQ_800), are incorrectly put into Asynchornous Mode after that commit. The A38x Functional Specification, section 10.12 DRAM Clocking, says: In Synchornous mode, the DRAM and CPU clocks are edge aligned and run in 1:2 or 1:3 CPU to DRAM frequency ratios. Change the check for whether Asynchornous Mode should be used according to this explanation in Functional Specification. Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2021-12-19arm: mvebu: axp: ddr: Switch to using DM I2C APIStefan Roese
No functional change intended. This patch switches from the legacy I2C API to the DM I2C API, so that this code can be used with DM I2C enabled. Signed-off-by: Stefan Roese <sr@denx.de>
2021-12-19arm: mvebu: axp: Remove unreferenced ddr3_get_eprom_fabric() functionStefan Roese
This function is not referenced in mainline U-Boot. Let's remove now. Signed-off-by: Stefan Roese <sr@denx.de>
2021-09-30WS cleanup: remove SPACE(s) followed by TABWolfgang Denk
2021-09-30WS cleanup: remove trailing empty linesWolfgang Denk
2021-08-31mvebe: Migrate CONFIG_DDR_LOG_LEVEL to KconfigTom Rini
Move this specific option to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-31mvebu: ddr: Rename CONFIG_DDR_FIXED_SIZE to CONFIG_SYS_SDRAM_SIZETom Rini
We have a number of CONFIG symbols to express the fixed size of system memory. For now, rename CONFIG_DDR_FIXED_SIZE to CONFIG_SYS_SDRAM_SIZE and adjust usage to match that CONFIG_SYS_SDRAM_SIZE expects the entire size rather than MiB. Cc: Marek Behún <marek.behun@nic.cz> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Marek Behún <marek.behun@nic.cz>
2021-07-07ARM: mvebu: a38x: Correct mismatched bound warningsTom Rini
With gcc-11 we see: drivers/ddr/marvell/a38x/ddr3_debug.c:672:47: error: argument 2 of type 'u32[5]' {aka 'unsigned int[5]'} with mismatched bound [-Werror=array-parameter=] 672 | int ddr3_tip_read_adll_value(u32 dev_num, u32 pup_values[MAX_INTERFACE_NUM * MAX_BUS_NUM], | ~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ In file included from drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h:10, from drivers/ddr/marvell/a38x/ddr3_init.h:17, from drivers/ddr/marvell/a38x/ddr3_debug.c:6: drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h:116:47: note: previously declared as 'u32[]' {aka 'unsigned int[]'} And similar warnings. Correct these by updating the prototype. Remove the prototype for ddr3_tip_read_pup_value as it is unused. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-03-12arm: mvebu: a38x: Remove dead code ARMADA_39XPali Rohár
Config option ARMADA_39X is never set so remove all dead code hidden under ifdef CONFIG_ARMADA_39X blocks. Also remove useless checks for CONFIG_ARMADA_38X define as this macro is always defined for a38x code path. Signed-off-by: Pali Rohár <pali@kernel.org> Reviewed-by: Stefan Roese <sr@denx.de>
2021-03-12ddr: marvell: axp: fix array types have different bounds warningMarek Behún
The arrays `pbs_dq_mapping`, `div_ratio1to1` and `div_ratio2to1` have different bounds declared in header files where these variables are also defined from the ones declared in source files. This causes the compiler to complain (when building with LTO): ddr3_sdram.c:24:12: warning: type of ‘pbs_dq_mapping’ does not match original declaration [-Wlto-type-mismatch] ddr3_patterns_64bit.h:911:5: note: array types have different bounds ddr3_patterns_64bit.h:911:5: note: ‘pbs_dq_mapping’ was previously declared here ddr3_dfs.c:45:11: warning: type of ‘div_ratio1to1’ does not match original declaration [-Wlto-type-mismatch] ddr3_axp_vars.h:167:4: note: array types have different bounds ddr3_axp_vars.h:167:4: note: ‘div_ratio1to1’ was previously declared here ddr3_dfs.c:46:11: warning: type of ‘div_ratio2to1’ does not match original declaration [-Wlto-type-mismatch] ddr3_axp_vars.h:196:4: note: array types have different bounds ddr3_axp_vars.h:196:4: note: ‘div_ratio2to1’ was previously declared here CI managed to trigger this as an error when compiling with LTO for AXP. Fix this by using values from the header files, which seem to be the correct ones. Signed-off-by: Marek Behún <marek.behun@nic.cz>
2021-03-12ddr: marvell: axp: align signature of mv_xor_mem_init() with a38xMarek Behún
In arch/arm/mach-mvebu/dram.c we always include axp's xor.h for common XOR definitions, regardless whether we compile for axp or a38x. But the declaration of this function has a different signature in axp's xor.h from the one used in a38x' implementation - one parameter is u64 instead of u32. This can result in wrong argument's being passed to that function on a38x with no one the wiser. I discovered this when building U-Boot for Turris Omnia with LTO. The compiler complains about the different signatures being thrown into the same linking process: axp/xor.h:67:5: warning: type of ‘mv_xor_mem_init’ does not match original declaration [-Wlto-type-mismatch] 67 | int mv_xor_mem_init(u32 chan, u32 start_ptr, u32 block_size, | ^ a38x/xor.c:165:5: note: type mismatch in parameter 3 165 | int mv_xor_mem_init(u32 chan, u32 start_ptr, unsigned long long | ^ a38x/xor.c:165:5: note: type ‘long long unsigned int’ should match type ‘u32’ Fix this by changing the type of the block_size argument in the axp's implementation and header file to the one used in a38x (and upstream mv-ddr-marvell). Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de>
2021-03-12ddr: marvell: a38x: Sync code with Marvell mv-ddr-marvell repositoryPali Rohár
This syncs drivers/ddr/marvell/a38x/ with the master branch of repository https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git up to the commit 7c351731d196 ("Merge pull request #29 from pali/sync-a38x-uboot"). This patch was created by following steps: 1. Replace all a38x files in U-Boot tree by files from upstream github Marvell mv-ddr-marvell repository. 2. Run following command to omit portions not relevant for a38x and ddr3: files=drivers/ddr/marvell/a38x/* sed 's/#if defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_39X)/#ifdef TRUE/' -i $files unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 -UCONFIG_APN806 \ -UCONFIG_MC_STATIC -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_PHY_STATIC_PRINT -UCONFIG_CUSTOMER_BOARD_SUPPORT \ -UCONFIG_A3700 -UA3900 -UA80X0 -UA70X0 -DTRUE $files 3. Manually omit SPDX-License-Identifier changes from this patch as upstream license in upstream github repository contains long license texts and U-Boot is using just SPDX-License-Identifier. After applying this patch, a38x ddr3 code in upstream Marvell github repository and in U-Boot would be fully identical. So in future applying above steps could be used to sync code again. The only change in this patch is removal of dead code and some fixes with include files. Signed-off-by: Pali Rohár <pali@kernel.org> Tested-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2021-03-12ddr: marvell: a38x: Add more space for additional info from SPDSujeet Baranwal
commit 258be123226f8f5cd516b7813fe201fb7d7416e9 upstream. At this moment, only page 0 of SPD is being read but to support smbios, we need to read page 1 also which has more info. In order to do that, we need to allocate more space. Signed-off-by: Sujeet Baranwal <sujeet.baranwal@cavium.com> Tested-by: sa_ip-sw-jenkins <sa_ip-sw-jenkins@marvell.com> Reviewed-by: Sujeet Kumar Baranwal <Sujeet.Baranwal@cavium.com> Reviewed-by: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <judge.packham@gmail.com>
2021-02-26ddr: marvell: a38x: fix comment in conditional macroMarek Behún
The code was processed with unifdef utility to omit portions not relevant to A38x and DDR3. This removes usage of many macros, including A70X0, A80X0 and A3900. It seems that the unifdef utility did not remove the macros from #else comment. Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: bump version to 14.0.0Marek Behún
Bump version of a38x DDR3 trianing to version 14.0.0 to reflect the version in the mv-ddr-devel branch of upstream repository https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. There is a new version numbering system, where after 18.12.0 came 1.0.0, 2.0.0, and so on until 14.0.0. So 14.0.0 is newer than 18.12.0. Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: enum mv_ddr_twin_die: change orderheaterC
commit 56db5d1464b44df10a02b99e615ebd6f6a35c428 upstream. @pali suggested this change In commit 6285efb ("mv_ddr: add support for twin-die combined memory device") was added support for twin-die combined memory device and default value for explicitly uninitialized structure members is zero, s also twin_die_combined is initialized to zero. Which means COMBINED value. As prior this commit there was no support for twin-die combined memory device, default value for twin_die_combined should be NOT_COMBINED. This change change order of enum mv_ddr_twin_die to ensure that NOT_COMBINED has value zero. Signed-off-by: heaterC <airyguy@gmx.de> Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: import code change from upstreamMarek Behún
commit 2bdd12dd68b1f8e27a03a3443ae49a09a14c18e4 upstream. The commit mentioned above changes non-DDR3 stuff in upstream, but it also changes code in ddr3_training.c. Import this change to remain consistent with upstream. Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: fix memory cs size functionMoti Buskila
commit c8b301463d508c807a33f7b7eaea98bbda4aa35e upstream. The funtion returnd cs size in byte instead of MB, that cause calculation error since the caller was expected to get u32 and when he got above 4G it refers it as 0. The fix was to get the cs memory size from function as in MB and then multiply it by 1MB. Signed-off-by: Moti Buskila <motib@marvell.com> Reviewed-by: Kostya Porotchkin <kostap@marvell.com> Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: import header change from upstreamMarek Behún
commit d653b305d0b3da9727c49124683f1a6d95d5c9a5 upstream. The commit mentioned above changes non-DDR3 stuff in upstream, but it also changes header ddr_topology_def.h. Import this header change to remain consistent with upstream. Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: disable WL phase correction stage in case of bus_width=16bitMoti Buskila
commit 20c89a28548cdab11f88d2ec8936344af0686a1e upstream. WL phase correcion stage is failing while using bus_width of 16bit, not to be fix this stage is un-necessary when working with bus_width of 16 bit. Signed-off-by: Moti Buskila <motib@marvell.com> Reviewed-by: Kostya Porotchkin <kostap@marvell.com> Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: add support for twin-die combined memory deviceMoti Buskila
commit 6285efb8a118940877522c4c07bd7c64569b4f5f upstream. the twin-die combined memory device should be treatened as X8 device and not as X16 one Signed-off-by: Moti Buskila <motib@marvell.com> Reviewed-by: Kostya Porotchkin <kostap@marvell.com> [ - the default value for twin_die_combined is set to NOT_COMBINED for all boards, as this was default behaviour prior this change ] Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: add 16Gbit memory devices supportMoti Buskila
commit 994509eb4fe6771d92cd06314c37895098ac48fa upstream. Signed-off-by: Moti Buskila <motib@marvell.com> Reviewed-by: Kostya Porotchkin <kostap@marvell.com> Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: allow board specific ODT configurationBaruch Siach
commit 2d3b9437cf38c06c4330e0de07f29476197f5e04 upstream. The ODT enable heuristic based on active chip-selects is not always correct. Some board might use two chip-selects, but have only one ODT line connected. Allow board specific mv_ddr_topology_map to directly set the ODT configuration register value. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Moti Buskila <motib@marvell.com> Reviewed-by: Nadav Haklai <Nadav.Haklai@cavium.com> Reviewed-by: Kostya Porotchkin <Kostya.Porotchkin@cavium.com> Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
commit 3908e20c6c520339e9bddb566823ae5e065d5218 upstream. The commit mentioned above changes non-DDR3 stuff in upstream, but it also changes header ddr_topology_def.h. Import this header change to remain consistent with upstream. Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: fix memory size calculation using 32bit bus widthMoti Buskila
commit ab9240402a70cc02496683971779e75eff410ab4 upstream. - function mv_ddr_spd_die_capacity_user_get() has a bug, since it insert a user memory enum to it, instead of SPD memory enum (which are different) - fix: remove mv_ddr_spd_die_capacity_user_get() function. - memory size with 64 and 32 bit already calculated correctly at mv_ddr_mem_sz_per_cs_get() function Signed-off-by: Moti Buskila <motib@marvell.com> Reviewed-by: Stefan Chulski <Stefan.Chulski@cavium.com> Reviewed-by: Alex Leibovich <alexl@marvell.com> Reviewed-by: Kostya Porotchkin <Kostya.Porotchkin@cavium.com> Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-26ddr: marvell: a38x: fix 32bitMoti Buskila
commit 0b5adedd4ced9b8f528faad1957d4d69e95759ef upstream. Signed-off-by: Moti Buskila <motib@marvell.com> Reviewed-by: Alex Leibovich <alexl@marvell.com> Reviewed-by: Kostya Porotchkin <Kostya.Porotchkin@cavium.com> Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
