This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
- Drop deprecated NATIVE_SYSTEMD_SUPPORT.
- Drop do_compile, base_do_compile would be good enough.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit d7d020fffa5b8101917b5f34d603e21663eaba8c)
In case the resizefs.sh script ends quite fast, the system might still
be in boot sequence. Removing a systemd service can be problematic
in that case: It seems that systemd looses the state of .device units,
and some services depend on such units (namely serial consoles such as
serial-getty@ttymxc0.service). The following sequence shows this problem:
Jan 12 00:16:45 apalis-imx6 sh[399]: Removed /etc/systemd/system/multi-user.target.wants/resizefs.service.
Jan 12 00:16:45 apalis-imx6 systemd[1]: Reloading.
Jan 12 00:16:45 apalis-imx6 root[704]: resizing mmcblk0p2 finished, new size is 3755M
Jan 19 00:04:08 apalis-imx6 systemd[1]: dev-ttymxc0.device: Job dev-ttymxc0.device/start timed out.
Jan 19 00:04:08 apalis-imx6 systemd[1]: Timed out waiting for device dev-ttymxc0.device.
Jan 19 00:04:08 apalis-imx6 systemd[1]: Dependency failed for Serial Getty on ttymxc0.
(the time has been updated between this to events, but that does not
influence the issue)
Using --no-reload avoids the "Reloading." message above and seems to not
cause such issues anymore.
The script used for all machines (e.g. T30) and the mx6 specific
script are the very same scripts. Drop the mx6 specific script,
with that the recipe will use the general scripts for all machines.
Non graphical images will never execute graphical.target services.
With fido e2fsprogs did split out the package e2fsprogs-resize2fs.
RRECOMMEND it so that it gets picked up during rootfs creation.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size.
On first boot this filesystem is resized to fill its full partion.
This slows down IO responsivness during the first 5 minutes.
