This the basic functional Invensense MPU6050 Device driver.
Signed-off-by: Ge Gao <ggao@invensense.com>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Also include a couple of forward defs of struct iio_trigger and struct
iio_trigger_ops to avoid doing this in each driver.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Acked-by: Denis Ciocca <denis.ciocca@st.com>
Quite often the pattern used for setting up and transferring a synchronous SPI
transaction looks very much like the following:
struct spi_message msg;
struct spi_transfer xfers[] = {
spi_message_init(&msg);
spi_message_add_tail(&xfers[0], &msg);
spi_message_add_tail(&xfers[ARRAY_SIZE(xfers) - 1], &msg);
ret = spi_sync(&msg);
This patch adds two new helper functions for handling this case. The first
helper function spi_message_init_with_transfers() takes a spi_message and an
array of spi_transfers. It will initialize the message and then call
spi_message_add_tail() for each transfer in the array. E.g. the following
can be rewritten as
spi_message_init_with_transfers(&msg, xfers, ARRAY_SIZE(xfers));
The second function spi_sync_transfer() takes a SPI device and an array of
spi_transfers. It will allocate a new spi_message (on the stack) and add all
transfers in the array to the message. Finally it will call spi_sync() on the
message.
E.g. the follwing
ret = spi_sync(spi, &msg);
can be rewritten as
ret = spi_sync_transfer(spi, xfers, ARRAY_SIZE(xfers));
A coccinelle script to find such instances will follow.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
disabled.
This patch resolve a bugfix when driver is compiled without trigger.
Signed-off-by: Denis Ciocca <denis.ciocca@st.com>
For iio_channel_get to work with OF based configurations, it needs the
consumer device pointer instead of the consumer device name as argument.
Acked-by: Anton Vorontsov <anton@enomsg.org>
Acked-by: Chanwoo Choi <cw00.choi@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
"Third set of IIO new drivers, cleanups and fixes for the 3.9 cycle
New drivers
1) A driver for ST microelectronics sensors. This driver already covers
a large set of new parts (20 gyros, accelerometer and magnetometers)
not currently covered by the existing drivers. The intent moving forward
is to merge this with the other drivers for similar parts already in tree.
The lis3l02dq driver currently in staging/iio will be trivial, the lis3
driver in misc more complex as it has a number of additional interfaces.
Any merging in of the lis3 driver will rely on the not currently
merged iio_input bridge driver and handling of freefall notifications
etc.
2) A driver for the itg3200 gyroscope.
Graduations from staging
1) Cleanup and move out of staging of the adxrs450 gyroscope driver. The
cleanup required was all minor but there were a couple of fixes hidden in
there.
Core and driver additions
1) Initial work from Guenter Roeck on device tree support for IIO's provider/
consumer code. Focuses on the iio_hwmon driver and the max1363 adc driver.
The full device tree syntax is currently under discussion but should
follow shortly.
Cleanups and fixes
1) Remove a noop function __iio_update_buffer
2) Couple of small fixes and cleanups for the max1363
There are a number of pci vendor ids that are used in multiple
drivers in the comedi subsystem. Move these ids to pci_ids.h.
This also fixes some build warnings reported by the kbuild test
robot about PCI_VENDOR_ID_AMPLICON being undeclared.
Instead of requiring the map to unregister, simply unregister all map entries
associated with the given iio device. This simplifies map removal and also works
for maps generated through devicetree.
Pass device pointer instead of device name as parameter to iio_channel_get_all
and iio_channel_get_all_cb. This will enable us to use OF information to
retrieve consumer channel information.
This patch remove st_sensors_get_sampling_frequency_avl and
st_sensors_get_scale_avl functions used only in
st_sensors_sysfs_sampling_frequency_avail and st_sensors_sysfs_scale_avail
sysfs functions.
This patch adds support for the InvenSense itg3200.
The itg3200 is a three-axis gyro with 16-bit ADC and
I2C interface.
Signed-off-by: Manuel Stahl <manuel.stahl@iis.fraunhofer.de>
__iio_update_buffer updates the buffer's bytes_per_datum and length fields.
But the only user of this function just passes in these exact fields, so the
call basically looks like this:
buffer->bytes_per_datum = buffer->bytes_per_datum;
buffer->length = buffer->length;
Which means it is a noop and can be removed. Also remove the function itself,
since it is now unused.
This patch add a generic library for STMicroelectronics 3-axis sensors.
This driver is simple, uses the latest interfaces and contains few if
any controversial elements. All of its interfaces have been in place
for a long time now. Hence let's move it out of staging.
Acked-by: Peter Meerwald <pmeerw@pmeerw.net>
This resolves a merge issue with a iio driver, and the zram code.
Pull ARM SoC fixes from Olof Johansson:
"Here's a long-pending fixes pull request for arm-soc (I didn't send
one in the -rc4 cycle).
The larger deltas are from:
- A fixup of error paths in the mvsdio driver
- Header file move for a driver that hadn't been properly converted
to multiplatform on i.MX, which was causing build failures when
included
- Device tree updates for at91 dealing mostly with their new pinctrl
setup merged in 3.8 and mistakes in those initial configs
The rest are the normal mix of small fixes all over the place; sunxi,
omap, imx, mvebu, etc, etc."
* tag 'fixes-for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
mfd: vexpress-sysreg: Don't skip initialization on probe
ARM: vexpress: Enable A7 cores in V2P-CA15_A7's Device Tree
ARM: vexpress: extend the MPIDR range used for pen release check
ARM: at91/dts: correct comment in at91sam9x5.dtsi for mii
ARM: at91/at91_dt_defconfig: add at91sam9n12 SoC to DT defconfig
ARM: at91/at91_dt_defconfig: remove memory specification to cmdline
ARM: at91/dts: add macb mii pinctrl config for kizbox
ARM: at91: rm9200: remake the BGA as default version
ARM: at91: fix gpios on i2c-gpio for RM9200 DT
ARM: at91/at91sam9x5 DTS: add SCK USART pins
ARM: at91/at91sam9x5 DTS: correct wrong PIO BANK values on u(s)arts
ARM: at91/at91-pinctrl documentation: fix typo and add some details
ARM: kirkwood: fix missing #interrupt-cells property
mmc: mvsdio: use devm_ API to simplify/correct error paths.
clk: mvebu/clk-cpu.c: fix memory leakage
ARM: OMAP2+: omap4-panda: add UART2 muxing for WiLink shared transport
ARM: OMAP2+: DT node Timer iteration fix
ARM: OMAP2+: Fix section warning for omap_init_ocp2scp()
ARM: OMAP2+: fix build break for omapdrm
ARM: OMAP2: Fix missing omap2xxx_clkt_vps_late_init function calls
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k fixes from Geert Uytterhoeven:
"The asm-generic changeset has been ack'ed by Arnd."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: Wire up finit_module
asm-generic/dma-mapping-broken.h: Provide dma_alloc_attrs()/dma_free_attrs()
m68k: Provide dma_alloc_attrs()/dma_free_attrs()
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
From Tony Lindgren:
Minimal omap fixes for the -rc series:
- A build fix for recently merged omap DRM changes
- Regression fixes from the common clock framework conversion
for omap4 audio and omap2 reboot
- Regression fix for pandaboard WLAN control UART muxing caused by
u-boot only muxing essential pins nowadays
- Timer iteration fix for CONFIG_OF_DYNAMIC
- A section mismatch fix for ocp2scp init
* tag 'omap-for-v3.8-rc4/fixes-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (306 commits)
ARM: OMAP4: hwmod_data: Correct IDLEMODE for McPDM
ARM: OMAP4: clock data: Lock ABE DPLL on all revisions
+ Linux 3.8-rc4
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
Pull libata fixes from Jeff Garzik:
1) ahci: Fix typo that caused erronenous error handling.
Thought: I wonder if sparse could have caught this, somehow.
2) ahci: support a slightly odd Enmotus variant
3) core: fix a drive detection problem by correcting the logic by which
the DevSlp timing variables are obtained and used.
* tag 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
[libata] replace sata_settings with devslp_timing
[libata] ahci: Add support for Enmotus Bobcat device.
[libata] ahci: Fix lack of command retry after a success error handler.
Cleanup and preparation for the next change.
signal_wake_up(resume => true) is overused. None of ptrace/jctl callers
actually want to wakeup a TASK_WAKEKILL task, but they can't specify the
necessary mask.
Turn signal_wake_up() into signal_wake_up_state(state), reintroduce
signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up()
which adds __TASK_TRACED.
This way ptrace_signal_wake_up() can work "inside" ptrace_request()
even if the tracee doesn't have the TASK_WAKEKILL bit set.
fixes
From Sascha Hauer:
ARM i.MX fixes for -rc.
This contains a single compilation fix for the CODA driver.
* tag 'imx-fixes-rc' of git://git.pengutronix.de/git/imx/linux-2.6:
[media] coda: Fix build due to iram.h rename
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module fixes and a virtio block fix from Rusty Russell:
"Various minor fixes, but a slightly more complex one to fix the
per-cpu overload problem introduced recently by kvm id changes."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
module: put modules in list much earlier.
module: add new state MODULE_STATE_UNFORMED.
module: prevent warning when finit_module a 0 sized file
virtio-blk: Don't free ida when disk is in use
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull misc syscall fixes from Al Viro:
- compat syscall fixes (discussed back in December)
- a couple of "make life easier for sigaltstack stuff by reducing
inter-tree dependencies"
- fix up compiler/asmlinkage calling convention disagreement of
sys_clone()
- misc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
sys_clone() needs asmlinkage_protect
make sure that /linuxrc has std{in,out,err}
x32: fix sigtimedwait
x32: fix waitid()
switch compat_sys_wait4() and compat_sys_waitid() to COMPAT_SYSCALL_DEFINE
switch compat_sys_sigaltstack() to COMPAT_SYSCALL_DEFINE
CONFIG_GENERIC_SIGALTSTACK build breakage with asm-generic/syscalls.h
Ensure that kernel_init_freeable() is not inlined into non __init code
The ia64 function "thread_matches()" has no users since commit
e868a55c2a8c ("[IA64] remove find_thread_for_addr()"). Remove it.
This allows us to make ptrace_check_attach() static to kernel/ptrace.c,
which is good since we'll need to change the semantics of it and fix up
all the callers.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg Kroah-Hartman:
"Here are a few tty/serial driver fixes for 3.8-rc4 that resolve a
number of problems that people have been having, including the ptys
ioctl issue that is a regression fix"
* tag 'tty-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
8250/16?50: Add support for Broadcom TruManage redirected serial port
pty: return EINVAL for TIOCGPTN for BSD ptys
serial:ifx6x60:Keep word size accordance with SPI controller
tty: 8250_dw: Fix inverted arguments to serial_out in IRQ handler
serial: samsung: remove redundant setting of line config during port reset
serial:ifx6x60:Delete SPI timer when shut down port
tty/8250: The correct device id for this card is 0x0022
tty/8250: pbn_b0_8_1152000_200 is supposed to be an 8 port definition
tty: serial: vt8500: fix return value check in vt8500_serial_probe()
serial: mxs-auart: Index is unsigned
mxs: uart: fix setting RTS from software
Commit 816422ad7647 ("asm-generic, mm: pgtable: consolidate zero page
helpers") broke the compile on MIPS if SPARSEMEM is enabled. We get
this:
In file included from arch/mips/include/asm/pgtable.h:552,
from include/linux/mm.h:44,
from arch/mips/kernel/asm-offsets.c:14:
include/asm-generic/pgtable.h: In function 'my_zero_pfn':
include/asm-generic/pgtable.h:466: error: implicit declaration of function 'page_to_section'
In file included from arch/mips/kernel/asm-offsets.c:14:
include/linux/mm.h: At top level:
include/linux/mm.h:738: error: conflicting types for 'page_to_section'
include/asm-generic/pgtable.h:466: note: previous implicit declaration of 'page_to_section' was here
Due header files inter-dependencies, the only way I see to fix it is
convert my_zero_pfn() for __HAVE_COLOR_ZERO_PAGE to macros.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: David Daney <david.daney@cavium.com>
Add support for the UART device present in Broadcom TruManage capable
NetXtreme chips (ie: 5761m 5762, and 5725).
This implementation has a hidden transmit FIFO, so running in single-byte
interrupt mode results in too many interrupts. The UART_CAP_HFIFO
capability was added to track this. It continues to reload the THR as long
as the THRE and TSRE bits are set in the LSR up to a specified limit (1024
is used here).
Signed-off-by: Stephen Hurd <shurd@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Cc: stable <stable@vger.kernel.org>
Pull ACPI and power management fixes from Rafael Wysocki:
- cpuidle regression fix related to the initialization of state
kobjects from Krzysztof Mazur.
- cpuidle fix removing some not very useful code and making some
user-visible problems go away at the same time. From Daniel Lezcano.
- ACPI build fix from Yinghai Lu.
* tag 'pm+acpi-for-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpuidle: remove the power_specified field in the driver
ACPI / glue: Fix build with ACPI_GLUE_DEBUG set
cpuidle: fix number of initialized/destroyed states
Commit 1b963c81b145 ("lockdep, rwsem: provide down_write_nest_lock()")
contains a bug in a codepath when CONFIG_DEBUG_LOCK_ALLOC is disabled,
which causes down_read() to be called instead of down_write() by mistake
on such configurations. Fix that.
Reported-and-tested-by: Andrew Clayton <andrew@digital-domain.net>
Reported-and-tested-by: Zlatko Calusic <zlatko.calusic@iskon.hr>
Pull scsi target fixes from Nicholas Bellinger:
"This includes an important >= v3.6 regression bugfix for active I/O
shutdown (Roland), some TMR related failure / corner cases fixes for
long outstanding I/O (Roland), two FCoE target mode fabric fabric role
fixes (MDR), a fix for an incorrect sense code during LUN
communication failure (Dr. Hannes), plus a handful of other minor
fixes.
There are still some outstanding zero-length control CDB regression
fixes that need to be addressed for v3.8, that will be coming in a
follow-up PULL request."
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iscsi-target: Fix CmdSN comparison (use cmd->cmd_sn instead of cmd->stat_sn)
target: Release se_cmd when LUN lookup fails for TMR
target: Fix use-after-free in LUN RESET handling
target: Fix missing CMD_T_ACTIVE bit regression for pending WRITEs
tcm_fc: Do not report target role when target is not defined
tcm_fc: Do not indicate retry capability to initiators
target: Use TCM_NO_SENSE for initialisation
target: Introduce TCM_NO_SENSE
target: use correct sense code for LUN communication failure
If the default iosched is built as module, the kernel may deadlock
while trying to load the iosched module on device probe if the probing
was running off async. This is because async_synchronize_full() at
the end of module init ends up waiting for the async job which
initiated the module loading.
async A modprobe
1. finds a device
2. registers the block device
3. request_module(default iosched)
4. modprobe in userland
5. load and init module
6. async_synchronize_full()
Async A waits for modprobe to finish in request_module() and modprobe
waits for async A to finish in async_synchronize_full().
Because there's no easy to track dependency once control goes out to
userland, implementing properly nested flushing is difficult. For
now, make module init perform async_synchronize_full() iff module init
has queued async jobs as suggested by Linus.
This avoids the described deadlock because iosched module doesn't use
async and thus wouldn't invoke async_synchronize_full(). This is
hacky and incomplete. It will deadlock if async module loading nests;
however, this works around the known problem case and seems to be the
best of bad options.
For more details, please refer to the following thread.
http://thread.gmane.org/gmane.linux.kernel/1420814
Reported-by: Alex Riesen <raa.lkml@gmail.com>
Tested-by: Ming Lei <ming.lei@canonical.com>
Tested-by: Alex Riesen <raa.lkml@gmail.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
We realized that the power usage field is never filled and when it
is filled for tegra, the power_specified flag is not set causing all
of these values to be reset when the driver is initialized with
set_power_state().
However, the power_specified flag can be simply removed under the
assumption that the states are always backward sorted, which is the
case with the current code.
This change allows the menu governor select function and the
cpuidle_play_dead() to be simplified. Moreover, the
set_power_states() function can removed as it does not make sense
any more.
Drop the power_specified flag from struct cpuidle_driver and make
the related changes as described above.
As a consequence, this also fixes the bug where on the dynamic
C-states system, the power fields are not initialized.
[rjw: Changelog]
References: https://bugzilla.kernel.org/show_bug.cgi?id=42870
References: https://bugzilla.kernel.org/show_bug.cgi?id=43349
References: https://lkml.org/lkml/2012/10/16/518
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Most of commits found here are for ASoC device specific fixes,
arizona, cs4271, wm5102, wm2200, etc, in addition to a couple of
memory leak fixes in ASoC core.
Other than that, regression fixes in HD-audio and USB-audio, and a fix
for new Realtek codecs."
* tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (30 commits)
ALSA: usb-audio: Fix NULL dereference by access to non-existing substream
ALSA: hda - Add support of new codec ALC284
ALSA: usb-audio: Make ebox44_table static
ALSA: hdspm - Fix wordclock status on AES32
Revert "ALSA: hda - Shut up pins at power-saving mode with Conexnat codecs"
ALSA: hda - Disable runtime D3 for Intel CPT & co
ALSA: pxa27x: fix ac97 warm reset
ALSA: pxa27x: fix ac97 cold reset
ASoC: wm_adsp: Ensure that block writes are from DMA aligned addresses
ASoC: wm2000: Fix sense of speech clarity enable
ASoC: wm5100: Remove DSP B and left justified formats
ASoC: arizona: Remove DSP B and left justified AIF modes
ASoC: wm2200: Remove DSP B and left justified AIF modes
ASoC: wm5102: Improve speaker enable performance
ASoC: core: fix the memory leak in case of remove_aux_dev()
ASoC: core: fix the memory leak in case of device_add() failure
ASoC: cs42l52: Catch no-match case in cs42l52_get_clk
ASoC: lm49453: Update lm49453_reg_defs values as per LM49453 HW revision-B
ASoC: lm49453: Fix adc, mic and sidetone volume ranges
ASoC: arizona: Correct FLL source definitions
NCQ capability was used to check availability of SATA Settings page
from Identify Device Data Log, which contains DevSlp timing variables.
It does not work on some HDDs and leads to error messages.
IDENTIFY word 78 bit 5(Hardware Feature Control) can't work either
because it is only the sufficient condition of Identify Device data
log, not the necessary condition.
This patch replaced ata_device->sata_settings with ->devslp_timing
to only save DevSlp timing variables(8 bytes), instead of the whole
SATA Settings page(512 bytes).
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=51881
Reported-by: Borislav Petkov <bp@alien8.de>
Signed-off-by: Shane Huang <shane.huang@amd.com>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fixes from Greg Kroah-Hartman:
"Here are two patches for 3.8-rc3.
One removes the __dev* defines from init.h now that all usages of it
are gone from your tree. The other fix is for debugfs's paramater
that was using the wrong base for the option.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'driver-core-3.8-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
debugfs: convert gid= argument from decimal, not octal
Remove __dev* markings from init.h
Pull networking fixes from David Miller:
1) Fix regression allowing IP_TTL setting of zero, fix from Cong Wang.
2) Fix leak regressions in tunap, from Jason Wang.
3) be2net driver always returns IRQ_HANDLED in INTx handler, fix from
Sathya Perla.
4) qlge doesn't really support NETIF_F_TSO6, don't set that flag. Fix
from Amerigo Wang.
5) Add 802.11ad Atheros wil6210 driver, from Vladimir Kondratiev.
6) Fix MTU calculations in mac80211 layer, from T Krishna Chaitanya.
7) Station info layer of mac80211 needs to use del_timer_sync(), from
Johannes Berg.
8) tcp_read_sock() can loop forever, because we don't immediately stop
when recv_actor() returns zero. Fix from Eric Dumazet.
9) Fix WARN_ON() in tcp_cleanup_rbuf(). We have to use sk_eat_skb() in
tcp_recv_skb() to handle the case where a large GRO packet is split
up while it is use by a splice() operation. Fix also from Eric
Dumazet.
10) addrconf_get_prefix_route() in ipv6 tests flags incorrectly, it
does:
if (X && (p->flags & Y) != 0)
when it really meant to go:
if (X && (p->flags & X) != 0)
fix from Romain Kuntz.
11) Fix lost Kconfig dependency for bfin_mac driver hardware
timestamping. From Lars-Peter Clausen.
12) Fix regression in handling of RST without ACK in TCP, from Eric
Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (37 commits)
be2net: fix unconditionally returning IRQ_HANDLED in INTx
tuntap: fix leaking reference count
tuntap: forbid calling TUNSETIFF when detached
tuntap: switch to use rtnl_dereference()
net, wireless: overwrite default_ethtool_ops
qlge: remove NETIF_F_TSO6 flag
tcp: accept RST without ACK flag
net: ethernet: xilinx: Do not use NO_IRQ in axienet
net: ethernet: xilinx: Do not use axienet on PPC
bnx2x: Allow management traffic after boot from SAN
bnx2x: Fix fastpath structures when memory allocation fails
bfin_mac: Restore hardware time-stamping dependency on BF518
tun: avoid owner checks on IFF_ATTACH_QUEUE
bnx2x: move debugging code before the return
tuntap: refuse to re-attach to different tun_struct
ipv6: use addrconf_get_prefix_route for prefix route lookup [v2]
ipv6: fix the noflags test in addrconf_get_prefix_route
tcp: fix splice() and tcp collapsing interaction
tcp: splice: fix an infinite loop in tcp_read_sock()
net: prevent setting ttl=0 via IP_TTL
You should never look at such a module, so it's excised from all paths
which traverse the modules list.
We add the state at the end, to avoid gratuitous ABI break (ksplice).
Since:
commit 2c60db037034d27f8c636403355d52872da92f81
Author: Eric Dumazet <edumazet@google.com>
Date: Sun Sep 16 09:17:26 2012 +0000
net: provide a default dev->ethtool_ops
wireless core does not correctly assign ethtool_ops.
After alloc_netdev*() call, some cfg80211 drivers provide they own
ethtool_ops, but some do not. For them, wireless core provide generic
cfg80211_ethtool_ops, which is assigned in NETDEV_REGISTER notify call:
if (!dev->ethtool_ops)
dev->ethtool_ops = &cfg80211_ethtool_ops;
But after Eric's commit, dev->ethtool_ops is no longer NULL (on cfg80211
drivers without custom ethtool_ops), but points to &default_ethtool_ops.
In order to fix the problem, provide function which will overwrite
default_ethtool_ops and use it by wireless core.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
Merge misc fixes from Andrew Morton:
"The audit fixes have been floating around for a while - Al and Eric
aren't responding to either myself or Kees so I asked Kees to
re-review them and here they are."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (22 commits)
lib/rbtree.c: avoid the use of non-static __always_inline
MAINTAINERS: Omar had moved
mm: compaction: partially revert capture of suitable high-order page
linux/audit.h: move ptrace.h include to kernel header
kernel/audit.c: avoid negative sleep durations
audit: catch possible NULL audit buffers
audit: create explicit AUDIT_SECCOMP event type
MAINTAINERS: fix a status pattern
MAINTAINERS: fix arch/arm/plat-omap/include/plat/omap_hwmod.h
mm: thp: acquire the anon_vma rwsem for write during split
mm: mmap: annotate vm_lock_anon_vma locking properly for lockdep
arch/mn10300/Kconfig: select CONFIG_GENERIC_ATOMIC64
mm: bootmem: fix free_all_bootmem_core() with odd bitmap alignment
mm: use aligned zone start for pfn_to_bitidx calculation
fs/exec.c: work around icc miscompilation
mm: compaction: fix echo 1 > compact_memory return error issue
mm: memblock: fix wrong memmove size in memblock_merge_regions()
drivers/video/ssd1307fb.c: fix bit order bug in the byte translation function
mm: migrate: check page_count of THP before migrating
lib/rbtree.c declared __rb_erase_color() as __always_inline void, and
then exported it with EXPORT_SYMBOL.
This was because __rb_erase_color() must be exported for augmented
rbtree users, but it must also be inlined into rb_erase() so that the
dummy callback can get optimized out of that call site.
(Actually with a modern compiler, none of the dummy callback functions
should even be generated as separate text functions).
The above usage is legal C, but it was unusual enough for some compilers
to warn about it. This change makes things more explicit, with a static
__always_inline ____rb_erase_color function for use in rb_erase(), and a
separate non-inline __rb_erase_color function for use in
rb_erase_augmented call sites.
Signed-off-by: Michel Lespinasse <walken@google.com>
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Eric Wong reported on 3.7 and 3.8-rc2 that ppoll() got stuck when
waiting for POLLIN on a local TCP socket. It was easier to trigger if
there was disk IO and dirty pages at the same time and he bisected it to
commit 1fb3f8ca0e92 ("mm: compaction: capture a suitable high-order page
immediately when it is made available").
The intention of that patch was to improve high-order allocations under
memory pressure after changes made to reclaim in 3.6 drastically hurt
THP allocations but the approach was flawed. For Eric, the problem was
that page->pfmemalloc was not being cleared for captured pages leading
to a poor interaction with swap-over-NFS support causing the packets to
be dropped. However, I identified a few more problems with the patch
including the fact that it can increase contention on zone->lock in some
cases which could result in async direct compaction being aborted early.
In retrospect the capture patch took the wrong approach. What it should
have done is mark the pageblock being migrated as MIGRATE_ISOLATE if it
was allocating for THP and avoided races that way. While the patch was
showing to improve allocation success rates at the time, the benefit is
marginal given the relative complexity and it should be revisited from
scratch in the context of the other reclaim-related changes that have
taken place since the patch was first written and tested. This patch
partially reverts commit 1fb3f8ca0e92 ("mm: compaction: capture a
suitable high-order page immediately when it is made available").
Reported-and-tested-by: Eric Wong <normalperson@yhbt.net>
Tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Cc: <stable@vger.kernel.org>
While the kernel internals want pt_regs (and so it includes
linux/ptrace.h), the user version of audit.h does not need it. So move
the include out of the uapi version.
This avoids issues where people want the audit defines and userland
ptrace api. Including both the kernel ptrace and the userland ptrace
headers can easily lead to failure.
Cc: Eric Paris <eparis@redhat.com>
The seccomp path was using AUDIT_ANOM_ABEND from when seccomp mode 1
could only kill a process. While we still want to make sure an audit
record is forced on a kill, this should use a separate record type since
seccomp mode 2 introduces other behaviors.
In the case of "handled" behaviors (process wasn't killed), only emit a
record if the process is under inspection. This change also fixes
userspace examination of seccomp audit events, since it was considered
malformed due to missing fields of the AUDIT_ANOM_ABEND event type.
Cc: Jeff Layton <jlayton@redhat.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Julien Tinnes <jln@google.com>
Acked-by: Will Drewry <wad@chromium.org>
Acked-by: Steve Grubb <sgrubb@redhat.com>
down_write_nest_lock() provides a means to annotate locking scenario
where an outer lock is guaranteed to serialize the order nested locks
are being acquired.
This is analogoue to already existing mutex_lock_nest_lock() and
spin_lock_nest_lock().
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
In some cases, free_irq_cpu_rmap() is called while holding a lock (eg
rtnl). This can lead to deadlocks, because it invokes
flush_scheduled_work() which ends up waiting for whole system workqueue
to flush, but some pending works might try to acquire the lock we are
already holding.
This commit uses reference-counting to replace
irq_run_affinity_notifiers(). It also removes
irq_run_affinity_notifiers() altogether.
[akpm@linux-foundation.org: eliminate free_cpu_rmap, rename cpu_rmap_reclaim() to cpu_rmap_release(), propagate kref_put() retval from cpu_rmap_put()]
Signed-off-by: David Decotigny <decot@googlers.com>
Reviewed-by: Ben Hutchings <bhutchings@solarflare.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Acked-by: Amir Vadai <amirv@mellanox.com>
Pull intel DRM fixes from Dave Airlie:
"Just intel fixes, including getting the Ironlake systems back to the
state they were in for 3.6."
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/i915: Revert shrinker changes from "Track unbound pages"
drm/i915: Use pixel size for computing linear offsets into a sprite
drm/i915: Add DEBUG messages to all intel_create_user_framebuffer error paths
drm/i915: The sprite scaler on Ironlake also support YUV planes
drm: Only evict the blocks required to create the requested hole
drm/i915: Treat crtc->mode.clock == 0 as disabled
Revert "drm/i915: no lvds quirk for Zotac ZDBOX SD ID12/ID13"
drm/i915; Only increment the user-pin-count after successfully pinning the bo
partially reverts commit 1fb3f8ca "mm: compaction: capture a suitable
high-order page immediately when it is made available".
Introduce TCM_NO_SENSE, mapping to sense code
'Not ready, no additional sense information'.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Cc: Nicholas Bellinger <nab@risingtidesystems.com>
Daniel writes:
"Pretty much all just major fixes:
- 2 pieces of duct-tape for the ilk bug.
- Sprite regression fixes from Chris.
- OOPS fix for a div-by-zero from Chris, regression due to the modeset
rework in 3.7, now brought to light by a benign change in 3.8.
- Fix interrupted bo pinning, used to work around CS coherency issues on
i830/i845 (kernel also has a w/a newly in 3.8, but pinning is more efficient if
possible)."
Now that all in-kernel users of __dev* are gone, let's remove them from
init.h to keep them from popping up again and again.
Thanks to Bill Pemberton for doing all of the hard work to make removal
of this possible.
Cc: Bill Pemberton <wfp5p@virginia.edu>
