path: root/recipes-qt/qt4/qt4-x11-free-systemd.bb
2019-05-08images and helpers: drop qt4Max Krummenacher
Qt 4 was first released in 2005 and has been unsupported since 2015. Drop it from what we regularly install. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-12-22recipes: fix invalid license file locationMax Krummenacher
Use '${COMMON_LICENSE_DIR} for license files fix the warning: | WARNING: packagegroup-xfce-base-1.0-r5 do_populate_lic: | ${COREBASE}/LICENSE is not a valid license file, please use |'${COMMON_LICENSE_DIR}/MIT' for a MIT License file in LIC_FILES_CHKSUM. |This will become an error in the future Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07recipes: remove unneeded RDEPENDSMax Krummenacher
Empty RDEPENDS are not needed, the others are automatically added by the buildsystem. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-10-28qt4-x11-free-systemd: change filenames for systemd serviceMax Krummenacher
qtdemo-init exists in another recipe for qte. When both recipes are built we get an error during sysroot deployment.
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2014-12-08qt4-x11-free-systemd.bb: move init script to /usr/binStefan Agner
Due to the move to systemd, all init scripts located under /etc/init.d get deleted by the inherited systemd recipes (systemd.inc). Since we don't use the script as a system V init script, we can move the script to /usr/bin.
2014-08-04qt4-x11-free-systemd.bb: Update after toplevel LICENSE file checksum changeMax Krummenacher
2013-09-22systemd: adapt to new systemd handlingMax Krummenacher
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed
2013-03-27images: added a QT4 X11 imageMax Krummenacher
- bbappends to the base qt4-x11-free recipe to use OpenGL ES2 - script which starts X plus qtdemo, including a systemd service to activate script
