The changes include:
- Drop PREFERRED_PROVIDER_u-boot-fw-utils from machine conf.
- Drop u-boot-toradex-fw-utils-tk1 recipe.
- Drop fw_unlock_mmc.sh, that's not needed for libubootenv.
- Drop reference to u-boot-toradex-initial-env.inc, that's been
removed from BSP common layer.
Related-to: ELB-2553
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit eef28a0a1e16a0d116192f8ac5a97531d2546f9f)
(cherry picked from commit 3e3a33523b73302d09db47a21e069ae97c159efa)
Drop MACHINE_BOOT_FILES and use the boot file directly, following the
rename of the source file to boot.scr-${MACHINE}.
(cherry picked from commit ab0527430fa9081ef594c6f2e49a0b7e81f6fc00)
(cherry picked from commit 9b31aa1cc2aa4464c56b6cd338d7e8e3cee2897b)
PREFERRED_PROVIDER_u-boot should be 'u-boot-toradex-tk1' instead of
'u-boot-toradex', also set PROVIDES += "u-boot" in u-boot-tk1 recipe.
(cherry picked from commit c9180b9e9b1231c8139bbfb47f51acb5692235dc)
They are not needed any more since we upgraded to 2019.07.
(cherry picked from commit 8048bf5cd90a923f6879f1ba714c22e3736fc245)
Rename the apalis-tk1-mainline machine to the now dropped
apalis-tk1 machine name.
Related-to: ELB-2733
(cherry picked from commit 0bf55088d1f34338dd04f83d6b90b7a72f6867de)
The downstream kernel gets to old to be used with the new zeus
userspace components. Drop the machine.
(cherry picked from commit d13caaba2d90f856b944ebde44967b679d3eb3a9)
- TEZI_UBOOT_BINARY_EMMC should be changed to UBOOT_BINARY_TEZI_EMMC.
- Drop TEZI_DISTRO_BOOT_SCRIPTS, it's being referred nowhere.
(cherry picked from commit 545e2e8b2822ab313c1b3c43816e5eb8be651b8f)
Related-to: ELB-2510
(cherry picked from commit 7880c26275385d30ce2d7d6c45065764e0fd2472)
Debugging reveals that it is really also expecting certain firmware at
the original path:
[ 134.878913] firmware tegra12x!vic03_ucode.bin: firmware: requesting tegra12x/vic03_ucode.bin
So make a symbolic link rather then copying them.
Without older systemd's firmware usermode helper fallback in place using
an alternative file name leads to a very long timeout. Fix this by
linking the alternative nameed firmware to the one tried first.
(cherry picked from commit 5d206eb3265bc6bc96442ffcd1cc4ce1f80f0714)
(cherry picked from commit 71f68117693bfd479774aac42412a18fdf77a2e8)
With 'c6427ee apalis-tk1-mainline: use 5.4 kernel' linux-toradex-mainline-4.14
is no longer used.
For a mainlinish kernel linux-toradex-mainline in meta-toradex-bsp is now used.
This currently builds a 5.4.y based kernel.
OE post zeus dropped Python 2. Provide a workaround so that one can still
build the TK1 U-Boot. When we update U-Boot to 2020.01 or later Python 3
will be supported and this patch can be reverted.
Completes '691b446 u-boot.inc: use python3 for build'.
Remove upstreamed patch: Commit acab21ffa8c0951f2180f80184c921fa4799c786
'mmc: core: fix possible use after free of host' fixes the issue with
the same change as 0015-Revert-mmc-core-fix-error-path-in-mmc_host_alloc.
(cherry picked from commit db41fd66b3b56ef1f33ac2ef9eacb33d41cd1738)
recipes-kernel/linux/linux-toradex-mainline_4.14.bb
Move installing of the driver package from machine firmware to the
XSERVER variable where it belongs.
This allows an image without X11 to not pull in unnedded userspace drivers.
(cherry picked from commit 8c8b350b079619edde97e0c11b90f85062532911)
OE dropped python2 support.
Unify u-boot.inc with openembedded-core which now uses python3 for the build.
(cherry picked from commit 8d3d527425b592480900d006c76694877755486a)
recipes-kernel/linux/linux-toradex_3.10.40.bb
Use toradex-kernel-localversion class to implement the new versioning
scheme for U-Boot.
scheme for U-Boot.
Use toradex-u-boot-localversion class to implement the new versioning
scheme for U-Boot.
Otherwise the picked u-boot.inc file depends on the bblayers variable.
0026-apalis_t30-fix-mmc1-cmd-pull-up.patch is now applied upstream
(cherry picked from commit 09dac9171391c90a6cfa0ae8c9ce4029a130b7e6)
(cherry picked from commit 6adc58486ec75545ba6b3918ae72e0a7fe2cbd2c)
Latest Openembedded (Zeus) builds perf with python 3 which requires a
5.x kernel or a kernel patch.
Remove scripting from the perf configuation to allow building against
the 3.10 L4T kernel.
While at it change all overrides to the CPU specific tegra124 override
rather than using apalis-tk1.
Backport the patch to 4.14.
After moving the bb file here, there is now value in keeping the bbappend.
Recent OE adds additional shared object checks which errors out on the way
the binary Tegra drivers are injected.
Rework the recipes, so that
- mesa no longer PROVIDE any OpenGL shared objects and the binaries.
- linux-driver-package now depends on mesa to install development headers
- linux-driver-package PROVIDE and RPROVIDE the OpenGL shared objects.
- linux-driver-package drops the additional arm-linux-gnueabihf/tegra path
to the *.so* files.
- the apalis-tk1 machine PREFERS linux-driver-package as the OpenGL provider.
While at it unify whitespace usage.
This commit does not change any configuration or behaviour, it prepares
for a rework of the recipe.
The issue only manifests on the old 3.10.40 kernels.
OE dropped the obsolete gstreamer version 0.10.
OE-core changed to build mesa with meson. Rework our patches accordingly.
latest glibc dropped support for sys/io.h on arm, which is fixed in
upstream xserver, as a bonus we can drop musl specific patch which was
doing something similar up until now.
Fixes
|In file included from ../../../../xorg-server-1.20.4/hw/xfree86/int10/generic.c:15:
| ../../../../xorg-server-1.20.4/hw/xfree86/common/compiler.h:767:10: fatal error: 'sys/io.h' file not found
| #include <sys/io.h>
| 1 error generated.
(From OE-Core rev: 1c72953b6c890b8411fec997b5c28a17eed82897)
Signed-off-by: Khem Raj <raj.khem@gmail.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
The gstreamer plugins now require addional runtime depends or one gets
qa errors of the following form:
| ERROR: linux-driver-package-21.7.0-r7 do_package_qa: QA Issue: /usr/bin/nvgstplayer-1.0 contained in package linux-driver-package-nvgstapps
| requires libgstvideo-1.0.so.0, but no providers found in RDEPENDS_linux-driver-package-nvgstapps? [file-rdeps]
OE-core dropped eglinfo, thus drop the bbappend on said recipe.
aa36510ebe eglinfo: remove the recipe
meta-openembedded dropped gstreamer 0.10 with commit 010c2f388.
This file is conflicting with another include file with same name in
meta-toradex-bsp-common layer, and no recipe is actually including this
file, so drop it.
